GSoC 2015 RPi USB Support
Yurii Shevtsov ungetch at gmail.com
Thu Jun 25 12:50:53 UTC 2015
This is ping message, with small update: the problem is not on the
linking stage, driver is linked to testsuite (checked with objdump)
2015-06-21 17:57 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> Hello)
> Now I have apps from libbsd testsuite running. But DWC OTG driver doesn't loads.
> I added this lines to init01/test_main.c:
> +SYSINIT_NEED_USB_CORE;
> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
> (I know it's bad hardcode)
> If I run it. I get only this:
>   nexus0: <RTEMS Nexus device>
>   devctl: +nexus0 at   on root0
>   devctl: !system=IFNET subsystem=lo0 type=ATTACH
> Of course, I modified rtemsbsd/include/machine/rtems-bsd-sysinit.h and
> rtemsbsd/include/bsp/nexus-devices.h (took vlues from working DTS) and
> did other nexus-related changes to drivers. You can find changes in my
> repo https://github.com/gtament/rtems-libbsd/
> So I need some kind of code review, please.
> P.S. All testsuites (netshell01, usb01) with shell hangs without any output.
> Thanks in advance!
