[PATCH 7/7] score: Hide SMP lock profiling impl if disabled
Thu Jun 25 13:17:17 UTC 2015
The problem is that empty structures have a different size in C and C++.
 cpukit/score/include/rtems/score/percpu.h  |  17 ++-
 cpukit/score/include/rtems/score/smplock.h | 167 +++++++++++++++++------------
 cpukit/score/src/profilingsmplock.c        |  18 ++--
 cpukit/score/src/smp.c                     |   5 +-
 4 files changed, 127 insertions(+), 80 deletions(-)
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index a6f7a25..088c31f 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -319,10 +319,17 @@ typedef struct Per_CPU_Control {
     SMP_ticket_lock_Control Lock;
-     * @brief Lock statistics context for the per-CPU lock.
-    SMP_lock_Stats_context Lock_stats_context;
+    #if defined( RTEMS_PROFILING )
+       * @brief Lock statistics for the per-CPU lock.
+      SMP_lock_Stats Lock_stats;
+       * @brief Lock statistics context for the per-CPU lock.
+      SMP_lock_Stats_context Lock_stats_context;
+    #endif
      * @brief Context for the Giant lock acquire and release pair of this
@@ -385,6 +392,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_Acquire( cpu ) \
   _SMP_ticket_lock_Acquire( \
     &( cpu )->Lock, \
+    &( cpu )->Lock_stats, \
     &( cpu )->Lock_stats_context \
 #else
@@ -398,6 +406,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_Release( cpu ) \
   _SMP_ticket_lock_Release( \
     &( cpu )->Lock, \
 #else
diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
index 50a0662..b56a64b 100644
--- a/cpukit/score/include/rtems/score/smplock.h
+++ b/cpukit/score/include/rtems/score/smplock.h
@@ -58,6 +58,8 @@ extern "C" {
+#if defined( RTEMS_PROFILING )
  * @brief Count of lock contention counters for lock statistics.
@@ -82,7 +84,6 @@ extern "C" {
  * instant and the lock acquire instant.
 typedef struct {
-#if defined( RTEMS_PROFILING )
    * @brief Node for SMP lock statistics chain.
@@ -142,33 +143,25 @@ typedef struct {
    * @brief The lock name.
   const char *name;
-#endif /* defined( RTEMS_PROFILING ) */
 } SMP_lock_Stats;
  * @brief Local context for SMP lock statistics.
 typedef struct {
    * @brief The last lock acquire instant in CPU counter ticks.
    * This value is used to measure the lock section time.
   CPU_Counter_ticks acquire_instant;
-#endif
 } SMP_lock_Stats_context;
  * @brief SMP lock statistics initializer for static initialization.
 #define SMP_LOCK_STATS_INITIALIZER( name ) \
   { { NULL, NULL }, 0, 0, 0, 0, { 0, 0, 0, 0 }, 0, name }
-#else
-#define SMP_LOCK_STATS_INITIALIZER( name ) \
-#endif
  * @brief Initializes an SMP lock statistics block.
@@ -190,14 +183,14 @@ static inline void _SMP_lock_Stats_initialize(
  * @brief Destroys an SMP lock statistics block.
- * @param[in,out] stats The SMP lock statistics block.
+ * @param[in] stats The SMP lock statistics block.
 static inline void _SMP_lock_Stats_destroy( SMP_lock_Stats *stats );
  * @param[in] stats_context The SMP lock statistics context.
 static inline void _SMP_lock_Stats_release_update(
@@ -205,23 +198,23 @@ static inline void _SMP_lock_Stats_release_update(
   const SMP_lock_Stats_context *stats_context
+#endif /* RTEMS_PROFILING */
  * @brief SMP ticket lock control.
 typedef struct {
   Atomic_Uint next_ticket;
   Atomic_Uint now_serving;
-  SMP_lock_Stats Stats;
 } SMP_ticket_lock_Control;
  * @brief SMP ticket lock control initializer for static initialization.
-#define SMP_TICKET_LOCK_INITIALIZER( name ) \
+#define SMP_TICKET_LOCK_INITIALIZER \
     ATOMIC_INITIALIZER_UINT( 0U ), \
-    ATOMIC_INITIALIZER_UINT( 0U ), \
-    SMP_LOCK_STATS_INITIALIZER( name ) \
+    ATOMIC_INITIALIZER_UINT( 0U ) \
@@ -229,18 +222,16 @@ typedef struct {
  * Concurrent initialization leads to unpredictable results.
- * @param[in,out] lock The SMP ticket lock control.
+ * @param[in] lock The SMP ticket lock control.
  * @param[in] name The name for the SMP ticket lock.  This name must be
  * persistent throughout the life time of this lock.
 static inline void _SMP_ticket_lock_Initialize(
-  SMP_ticket_lock_Control *lock,
-  const char *name
+  SMP_ticket_lock_Control *lock
   _Atomic_Init_uint( &lock->next_ticket, 0U );
   _Atomic_Init_uint( &lock->now_serving, 0U );
-  _SMP_lock_Stats_initialize( &lock->Stats, name );
@@ -248,33 +239,26 @@ static inline void _SMP_ticket_lock_Initialize(
  * Concurrent destruction leads to unpredictable results.
 static inline void _SMP_ticket_lock_Destroy( SMP_ticket_lock_Control *lock )
-  _SMP_lock_Stats_destroy( &lock->Stats );
+  (void) lock;
- * @brief Acquires an SMP ticket lock.
- * This function will not disable interrupts.  The caller must ensure that the
- * current thread of execution is not interrupted indefinite once it obtained
- * the SMP ticket lock.
- * @param[out] stats_context The SMP lock statistics context.
-static inline void _SMP_ticket_lock_Acquire(
+static inline void _SMP_ticket_lock_Do_acquire(
+  SMP_lock_Stats *stats,
+#endif
   unsigned int my_ticket;
   unsigned int now_serving;
-  SMP_lock_Stats *stats = &lock->Stats;
   CPU_Counter_ticks first;
   CPU_Counter_ticks second;
   CPU_Counter_ticks delta;
@@ -324,30 +308,67 @@ static inline void _SMP_ticket_lock_Acquire(
- * @brief Releases an SMP ticket lock.
+ * @brief Acquires an SMP ticket lock.
- * @param[in] stats_context The SMP lock statistics context.
+ * This function will not disable interrupts.  The caller must ensure that the
+ * current thread of execution is not interrupted indefinite once it obtained
+ * the SMP ticket lock.
+ * @param[in] stats The SMP lock statistics.
+ * @param[out] stats_context The SMP lock statistics context.
-static inline void _SMP_ticket_lock_Release(
+  #define _SMP_ticket_lock_Acquire( lock, stats, stats_context ) \
+    _SMP_ticket_lock_Do_acquire( lock, stats, stats_context )
+#else
+    _SMP_ticket_lock_Do_acquire( lock )
+#endif
+static inline void _SMP_ticket_lock_Do_release(
+#endif
   unsigned int current_ticket =
     _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_RELAXED );
   unsigned int next_ticket = current_ticket + 1U;
-  _SMP_lock_Stats_release_update( &lock->Stats, stats_context );
+  _SMP_lock_Stats_release_update( stats, stats_context );
+#endif
   _Atomic_Store_uint( &lock->now_serving, next_ticket, ATOMIC_ORDER_RELEASE );
+ * @brief Releases an SMP ticket lock.
+ * @param[in] stats_context The SMP lock statistics context.
+  #define _SMP_ticket_lock_Release( lock, stats, stats_context ) \
+    _SMP_ticket_lock_Do_release( lock, stats, stats_context )
+#else
+    _SMP_ticket_lock_Do_release( lock )
+#endif
  * @brief SMP lock control.
 typedef struct {
-  SMP_ticket_lock_Control ticket_lock;
+  SMP_ticket_lock_Control Ticket_lock;
+  SMP_lock_Stats Stats;
+#endif
 } SMP_lock_Control;
@@ -355,20 +376,27 @@ typedef struct {
 typedef struct {
   ISR_Level isr_level;
   SMP_lock_Stats_context Stats_context;
+#endif
 } SMP_lock_Context;
  * @brief SMP lock control initializer for static initialization.
-#define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER( name ) }
+  #define SMP_LOCK_INITIALIZER( name ) \
+    { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_STATS_INITIALIZER( name ) }
+#else
+  #define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER }
+#endif
  * @brief Initializes an SMP lock.
- * @param[in,out] lock The SMP lock control.
+ * @param[in] lock The SMP lock control.
  * @param[in] name The name for the SMP lock statistics.  This name must be
  * persistent throughout the life time of this statistics block.
@@ -386,7 +414,12 @@ static inline void _SMP_lock_Initialize(
   const char *name
-  _SMP_ticket_lock_Initialize( &lock->ticket_lock, name );
+  _SMP_ticket_lock_Initialize( &lock->Ticket_lock );
+  _SMP_lock_Stats_initialize( &lock->Stats, name );
+#else
+  (void) name;
+#endif
@@ -394,7 +427,7 @@ static inline void _SMP_lock_Initialize(
 #if defined( RTEMS_SMP_LOCK_DO_NOT_INLINE )
 void _SMP_lock_Destroy( SMP_lock_Control *lock );
@@ -404,7 +437,8 @@ static inline void _SMP_lock_Destroy_body( SMP_lock_Control *lock )
 static inline void _SMP_lock_Destroy( SMP_lock_Control *lock )
 #endif
-  _SMP_ticket_lock_Destroy( &lock->ticket_lock );
+  _SMP_ticket_lock_Destroy( &lock->Ticket_lock );
+  _SMP_lock_Stats_destroy( &lock->Stats );
@@ -414,8 +448,8 @@ static inline void _SMP_lock_Destroy( SMP_lock_Control *lock )
  * the SMP lock.
- * @param[in,out] context The local SMP lock context for an acquire and release
+ * @param[in] context The local SMP lock context for an acquire and release
  * pair.
@@ -433,14 +467,18 @@ static inline void _SMP_lock_Acquire(
   (void) context;
-  _SMP_ticket_lock_Acquire( &lock->ticket_lock, &context->Stats_context );
+  _SMP_ticket_lock_Acquire(
+    &lock->Ticket_lock,
+    &lock->Stats,
+    &context->Stats_context
  * @brief Releases an SMP lock.
  * pair.
@@ -458,14 +496,18 @@ static inline void _SMP_lock_Release(
   (void) context;
-  _SMP_ticket_lock_Release( &lock->ticket_lock, &context->Stats_context );
+  _SMP_ticket_lock_Release(
+    &lock->Stats,
  * @brief Disables interrupts and acquires the SMP lock.
  * pair.
@@ -489,8 +531,8 @@ static inline void _SMP_lock_ISR_disable_and_acquire(
  * @brief Releases the SMP lock and enables interrupts.
  * pair.
@@ -512,6 +554,7 @@ static inline void _SMP_lock_Release_and_ISR_enable(
 typedef struct {
   SMP_lock_Control Lock;
   Chain_Control Stats_chain;
@@ -596,11 +639,9 @@ static inline void _SMP_lock_Stats_iteration_stop(
   _Chain_Extract_unprotected( &iteration_context->Node );
   _SMP_lock_Release_and_ISR_enable( &control->Lock, &lock_context );
-#endif
   if ( !_Chain_Is_node_off_chain( &stats->Node ) ) {
     SMP_lock_Stats_control *control = &_SMP_lock_Stats_control;
     SMP_lock_Context lock_context;
@@ -629,9 +670,6 @@ static inline void _SMP_lock_Stats_destroy( SMP_lock_Stats *stats )
-#else
-  (void) stats;
-#endif
@@ -639,7 +677,6 @@ static inline void _SMP_lock_Stats_release_update(
   CPU_Counter_ticks first = stats_context->acquire_instant;
   CPU_Counter_ticks second = _CPU_Counter_read();
   CPU_Counter_ticks delta = _CPU_Counter_difference( second, first );
@@ -658,12 +695,10 @@ static inline void _SMP_lock_Stats_release_update(
-#else
-  (void) stats;
-  (void) stats_context;
-#endif
 #ifdef __cplusplus
diff --git a/cpukit/score/src/profilingsmplock.c b/cpukit/score/src/profilingsmplock.c
index be60ba9..a77e1a1 100644
--- a/cpukit/score/src/profilingsmplock.c
+++ b/cpukit/score/src/profilingsmplock.c
@@ -21,19 +21,19 @@
 SMP_lock_Stats_control _SMP_lock_Stats_control = {
   .Lock = {
-    .ticket_lock = {
+    .Ticket_lock = {
       .next_ticket = ATOMIC_INITIALIZER_UINT( 0U ),
-      .now_serving = ATOMIC_INITIALIZER_UINT( 0U ),
-      .Stats = {
-        .Node = CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(
-          &_SMP_lock_Stats_control.Stats_chain
-        .name = "SMP lock stats"
+      .now_serving = ATOMIC_INITIALIZER_UINT( 0U )
+    .Stats = {
+      .Node = CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(
+        &_SMP_lock_Stats_control.Stats_chain
+      .name = "SMP Lock Stats"
   .Stats_chain = CHAIN_INITIALIZER_ONE_NODE(
-    &_SMP_lock_Stats_control.Lock.ticket_lock.Stats.Node
+    &_SMP_lock_Stats_control.Lock.Stats.Node
   .Iterator_chain = CHAIN_INITIALIZER_EMPTY(
     _SMP_lock_Stats_control.Iterator_chain
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 8ffeb1d..8e01034 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -80,7 +80,10 @@ void _SMP_Handler_initialize( void )
   for ( cpu_index = 0 ; cpu_index < cpu_max; ++cpu_index ) {
     Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
-    _SMP_ticket_lock_Initialize( &cpu->Lock, "per-CPU" );
+    _SMP_ticket_lock_Initialize( &cpu->Lock );
+#if defined(RTEMS_PROFILING)
+    _SMP_lock_Stats_initialize( &cpu->Lock_stats, "Per-CPU" );
+#endif
1.8.4.5
