[PATCH] Ethernet driver For BBB ported from FreeBSD
ragu nath ragunath3252 at gmail.com
Thu Jun 25 17:20:15 UTC 2015
Hi Gedare,
I will send them separately.
Thanks,
Ragunath
On Thu, Jun 25, 2015 at 10:29 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> Can you split the commits so that the import from BSD is separate from
> your modifications to it?
> On Thu, Jun 25, 2015 at 12:18 PM, ragunath <ragunath3252 at gmail.com> wrote:
>> This patch includes changes for porting cpsw ethernet driver for Beaglebone black from Freebsd.
>> It also includes smsc phy ported from FreeBSD. Corresponding nexus devices are added.
>> For networking to work properly, two additional changes are needed on the RTEMS side.
>>  Makefile                                           |    3 +
>>  freebsd/sys/arm/ti/cpsw/if_cpsw.c                  | 2239 ++++++++++++++++++++
>>  freebsd/sys/arm/ti/cpsw/if_cpswreg.h               |  137 ++
>>  freebsd/sys/arm/ti/cpsw/if_cpswvar.h               |  126 ++
>>  freebsd/sys/dev/mii/smscphy.c                      |  227 ++
>>  rtemsbsd/include/bsp/nexus-devices.h               |   34 +
>>  rtemsbsd/include/machine/rtems-bsd-cache.h         |    2 +-
>>  .../include/rtems/bsd/test/network-config.h.in     |    2 +
>>  8 files changed, 2769 insertions(+), 1 deletion(-)
>>  create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpsw.c
>>  create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswreg.h
>>  create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswvar.h
>>  create mode 100644 freebsd/sys/dev/mii/smscphy.c
>> diff --git a/Makefile b/Makefile
>> index f747106..e215a07 100644
>> --- a/Makefile
>> +++ b/Makefile
>> @@ -26,6 +26,7 @@ COMMON_FLAGS += -Ifreebsd/contrib/tcpdump
>>  COMMON_FLAGS += -Ifreebsd/lib/libmemstat
>>  COMMON_FLAGS += -Ifreebsd/lib/libipsec
>>  COMMON_FLAGS += -Irtemsbsd/sys
>> +COMMON_FLAGS += -Irtemsbsd/include/rtems/bsd/local
>>  COMMON_FLAGS += -ImDNSResponder/mDNSCore
>>  COMMON_FLAGS += -ImDNSResponder/mDNSShared
>>  COMMON_FLAGS += -ImDNSResponder/mDNSPosix
>> @@ -185,10 +186,12 @@ LIB_C_FILES += freebsd/sys/dev/mii/brgphy.c
>>  LIB_C_FILES += freebsd/sys/dev/mii/micphy.c
>>  LIB_C_FILES += freebsd/sys/dev/mii/ukphy.c
>>  LIB_C_FILES += freebsd/sys/dev/mii/ukphy_subr.c
>> +LIB_C_FILES += freebsd/sys/dev/mii/smscphy.c
>>  LIB_C_FILES += freebsd/sys/dev/tsec/if_tsec.c
>>  LIB_C_FILES += freebsd/sys/dev/cadence/if_cgem.c
>>  LIB_C_FILES += freebsd/sys/dev/dwc/if_dwc.c
>>  LIB_C_FILES += freebsd/sys/arm/xilinx/zy7_slcr.c
>> +LIB_C_FILES += freebsd/sys/arm/ti/cpsw/if_cpsw.c
>>  LIB_C_FILES += freebsd/sys/dev/random/harvest.c
>>  LIB_C_FILES += freebsd/sys/netinet/tcp_hostcache.c
>>  LIB_C_FILES += freebsd/sys/dev/led/led.c
>> diff --git a/freebsd/sys/arm/ti/cpsw/if_cpsw.c b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
>> new file mode 100644
>> index 0000000..0eb73ee
>> --- /dev/null
>> +++ b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
>> @@ -0,0 +1,2239 @@
>> +#include <machine/rtems-bsd-kernel-space.h>
>> + * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
>> + * All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * TI Common Platform Ethernet Switch (CPSW) Driver
>> + * Found in TI8148 "DaVinci" and AM335x "Sitara" SoCs.
>> + * This controller is documented in the AM335x Technical Reference
>> + * Manual, in the TMS320DM814x DaVinci Digital Video Processors TRM
>> + * and in the TMS320C6452 3 Port Switch Ethernet Subsystem TRM.
>> + * It is basically a single Ethernet port (port 0) wired internally to
>> + * a 3-port store-and-forward switch connected to two independent
>> + * "sliver" controllers (port 1 and port 2).  You can operate the
>> + * controller in a variety of different ways by suitably configuring
>> + * the slivers and the Address Lookup Engine (ALE) that routes packets
>> + * between the ports.
>> + * This code was developed and tested on a BeagleBone with
>> + * an AM335x SoC.
>> +#include <sys/cdefs.h>
>> +__FBSDID("$FreeBSD$");
>> +#include <sys/param.h>
>> +#include <sys/systm.h>
>> +#include <sys/endian.h>
>> +#include <sys/mbuf.h>
>> +#ifndef __rtems__
>> +#include <sys/lock.h>
>> +#else
>> +#include <rtems/bsd/sys/lock.h>
>> +#endif
>> +#include <sys/mutex.h>
>> +#include <sys/kernel.h>
>> +#include <sys/module.h>
>> +#include <sys/socket.h>
>> +#include <sys/sysctl.h>
>> +#include <net/ethernet.h>
>> +#include <net/bpf.h>
>> +#include <net/if.h>
>> +#include <net/if_arp.h>
>> +#include <net/if_dl.h>
>> +#include <net/if_media.h>
>> +#include <net/if_types.h>
>> +#include <net/if_var.h>
>> +#include <net/if_vlan_var.h>
>> +#include <netinet/in_systm.h>
>> +#include <netinet/in.h>
>> +#include <netinet/ip.h>
>> +#include <sys/sockio.h>
>> +#include <sys/bus.h>
>> +#include <machine/bus.h>
>> +#include <sys/rman.h>
>> +#include <machine/resource.h>
>> +#include <dev/mii/mii.h>
>> +#include <dev/mii/miivar.h>
>> +#ifndef __rtems__
>> +#include <dev/fdt/fdt_common.h>
>> +#include <dev/ofw/ofw_bus.h>
>> +#include <dev/ofw/ofw_bus_subr.h>
>> +#endif
>> +#include "if_cpswreg.h"
>> +#include "if_cpswvar.h"
>> +#ifndef __rtems__
>> +#include <arm/ti/ti_scm.h>
>> +#endif
>> +#include "miibus_if.h"
>> +/* Device probe/attach/detach. */
>> +static int cpsw_probe(device_t);
>> +static void cpsw_init_slots(struct cpsw_softc *);
>> +static int cpsw_attach(device_t);
>> +static void cpsw_free_slot(struct cpsw_softc *, struct cpsw_slot *);
>> +static int cpsw_detach(device_t);
>> +/* Device Init/shutdown. */
>> +static void cpsw_init(void *);
>> +static void cpsw_init_locked(void *);
>> +static int cpsw_shutdown(device_t);
>> +static void cpsw_shutdown_locked(struct cpsw_softc *);
>> +/* Device Suspend/Resume. */
>> +static int cpsw_suspend(device_t);
>> +static int cpsw_resume(device_t);
>> +/* Ioctl. */
>> +static int cpsw_ioctl(struct ifnet *, u_long command, caddr_t data);
>> +static int cpsw_miibus_readreg(device_t, int phy, int reg);
>> +static int cpsw_miibus_writereg(device_t, int phy, int reg, int value);
>> +/* Send/Receive packets. */
>> +static void cpsw_intr_rx(void *arg);
>> +static struct mbuf *cpsw_rx_dequeue(struct cpsw_softc *);
>> +static void cpsw_rx_enqueue(struct cpsw_softc *);
>> +static void cpsw_start(struct ifnet *);
>> +static void cpsw_tx_enqueue(struct cpsw_softc *);
>> +static int cpsw_tx_dequeue(struct cpsw_softc *);
>> +/* Misc interrupts and watchdog. */
>> +static void cpsw_intr_rx_thresh(void *);
>> +static void cpsw_intr_misc(void *);
>> +static void cpsw_tick(void *);
>> +static void cpsw_ifmedia_sts(struct ifnet *, struct ifmediareq *);
>> +static int cpsw_ifmedia_upd(struct ifnet *);
>> +static void cpsw_tx_watchdog(struct cpsw_softc *);
>> +/* ALE support */
>> +static void cpsw_ale_read_entry(struct cpsw_softc *, uint16_t idx, uint32_t *ale_entry);
>> +static void cpsw_ale_write_entry(struct cpsw_softc *, uint16_t idx, uint32_t *ale_entry);
>> +static int cpsw_ale_mc_entry_set(struct cpsw_softc *, uint8_t portmap, uint8_t *mac);
>> +static int cpsw_ale_update_addresses(struct cpsw_softc *, int purge);
>> +static void cpsw_ale_dump_table(struct cpsw_softc *);
>> +/* Statistics and sysctls. */
>> +#ifndef __rtems__
>> +static void cpsw_add_sysctls(struct cpsw_softc *);
>> +static void cpsw_stats_collect(struct cpsw_softc *);
>> +static int cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS);
>> +#endif
>> + * Arbitrary limit on number of segments in an mbuf to be transmitted.
>> + * Packets with more segments than this will be defragmented before
>> + * they are queued.
>> +#define CPSW_TXFRAGS 8
>> + * TODO: The CPSW subsystem (CPSW_SS) can drive two independent PHYs
>> + * as separate Ethernet ports.  To properly support this, we should
>> + * break this into two separate devices: a CPSW_SS device that owns
>> + * the interrupts and actually talks to the CPSW hardware, and a
>> + * separate CPSW Ethernet child device for each Ethernet port.  The RX
>> + * interrupt, for example, would be part of CPSW_SS; it would receive
>> + * a packet, note the input port, and then dispatch it to the child
>> + * device's interface queue.  Similarly for transmit.
>> + * It's not clear to me whether the device tree should be restructured
>> + * with a cpsw_ss node and two child nodes.  That would allow specifying
>> + * MAC addresses for each port, for example, but might be overkill.
>> + * Unfortunately, I don't have hardware right now that supports two
>> + * Ethernet ports via CPSW.
>> +static device_method_t cpsw_methods[] = {
>> +       /* Device interface */
>> +       DEVMETHOD(device_probe,         cpsw_probe),
>> +       DEVMETHOD(device_attach,        cpsw_attach),
>> +       DEVMETHOD(device_detach,        cpsw_detach),
>> +       DEVMETHOD(device_shutdown,      cpsw_shutdown),
>> +       DEVMETHOD(device_suspend,       cpsw_suspend),
>> +       DEVMETHOD(device_resume,        cpsw_resume),
>> +       /* MII interface */
>> +       DEVMETHOD(miibus_readreg,       cpsw_miibus_readreg),
>> +       DEVMETHOD(miibus_writereg,      cpsw_miibus_writereg),
>> +       { 0, 0 }
>> +static driver_t cpsw_driver = {
>> +       "cpsw",
>> +       cpsw_methods,
>> +       sizeof(struct cpsw_softc),
>> +static devclass_t cpsw_devclass;
>> +#ifndef __rtems__
>> +DRIVER_MODULE(cpsw, simplebus, cpsw_driver, cpsw_devclass, 0, 0);
>> +#else
>> +DRIVER_MODULE(cpsw, nexus, cpsw_driver, cpsw_devclass, 0, 0);
>> +#endif
>> +DRIVER_MODULE(miibus, cpsw, miibus_driver, miibus_devclass, 0, 0);
>> +MODULE_DEPEND(cpsw, ether, 1, 1, 1);
>> +MODULE_DEPEND(cpsw, miibus, 1, 1, 1);
>> +static struct resource_spec res_spec[] = {
>> +       { SYS_RES_MEMORY, 0, RF_ACTIVE },
>> +       { SYS_RES_IRQ, 0, RF_ACTIVE | RF_SHAREABLE },
>> +       { SYS_RES_IRQ, 1, RF_ACTIVE | RF_SHAREABLE },
>> +       { SYS_RES_IRQ, 2, RF_ACTIVE | RF_SHAREABLE },
>> +       { SYS_RES_IRQ, 3, RF_ACTIVE | RF_SHAREABLE },
>> +       { -1, 0 }
>> +#ifndef __rtems__
>> +/* Number of entries here must match size of stats
>> + * array in struct cpsw_softc. */
>> +static struct cpsw_stat {
>> +       int     reg;
>> +       char *oid;
>> +} cpsw_stat_sysctls[CPSW_SYSCTL_COUNT] = {
>> +       {0x00, "GoodRxFrames"},
>> +       {0x04, "BroadcastRxFrames"},
>> +       {0x08, "MulticastRxFrames"},
>> +       {0x0C, "PauseRxFrames"},
>> +       {0x10, "RxCrcErrors"},
>> +       {0x14, "RxAlignErrors"},
>> +       {0x18, "OversizeRxFrames"},
>> +       {0x1c, "RxJabbers"},
>> +       {0x20, "ShortRxFrames"},
>> +       {0x24, "RxFragments"},
>> +       {0x30, "RxOctets"},
>> +       {0x34, "GoodTxFrames"},
>> +       {0x38, "BroadcastTxFrames"},
>> +       {0x3c, "MulticastTxFrames"},
>> +       {0x40, "PauseTxFrames"},
>> +       {0x44, "DeferredTxFrames"},
>> +       {0x48, "CollisionsTxFrames"},
>> +       {0x4c, "SingleCollisionTxFrames"},
>> +       {0x50, "MultipleCollisionTxFrames"},
>> +       {0x54, "ExcessiveCollisions"},
>> +       {0x58, "LateCollisions"},
>> +       {0x5c, "TxUnderrun"},
>> +       {0x60, "CarrierSenseErrors"},
>> +       {0x64, "TxOctets"},
>> +       {0x68, "RxTx64OctetFrames"},
>> +       {0x6c, "RxTx65to127OctetFrames"},
>> +       {0x70, "RxTx128to255OctetFrames"},
>> +       {0x74, "RxTx256to511OctetFrames"},
>> +       {0x78, "RxTx512to1024OctetFrames"},
>> +       {0x7c, "RxTx1024upOctetFrames"},
>> +       {0x80, "NetOctets"},
>> +       {0x84, "RxStartOfFrameOverruns"},
>> +       {0x88, "RxMiddleOfFrameOverruns"},
>> +       {0x8c, "RxDmaOverruns"}
>> +#endif
>> + * Basic debug support.
>> +#define IF_DEBUG(sc)  if (sc->cpsw_if_flags & IFF_DEBUG)
>> +static void
>> +cpsw_debugf_head(const char *funcname)
>> +       int t = (int)(time_second % (24 * 60 * 60));
>> +       printf("%02d:%02d:%02d %s ", t / (60 * 60), (t / 60) % 60, t % 60, funcname);
>> +#include <machine/stdarg.h>
>> +static void
>> +cpsw_debugf(const char *fmt, ...)
>> +       va_list ap;
>> +       va_start(ap, fmt);
>> +       vprintf(fmt, ap);
>> +       va_end(ap);
>> +       printf("\n");
>> +#define CPSW_DEBUGF(a) do {                                    \
>> +       IF_DEBUG(sc) {                                          \
>> +               cpsw_debugf_head(__func__);                     \
>> +               cpsw_debugf a;                                  \
>> +} while (0)
>> + * Locking macros
>> +#define CPSW_TX_LOCK(sc) do {                                  \
>> +               mtx_assert(&(sc)->rx.lock, MA_NOTOWNED);                \
>> +               mtx_lock(&(sc)->tx.lock);                               \
>> +} while (0)
>> +#define CPSW_TX_UNLOCK(sc)     mtx_unlock(&(sc)->tx.lock)
>> +#define CPSW_TX_LOCK_ASSERT(sc)        mtx_assert(&(sc)->tx.lock, MA_OWNED)
>> +#define CPSW_RX_LOCK(sc) do {                                  \
>> +               mtx_assert(&(sc)->tx.lock, MA_NOTOWNED);                \
>> +               mtx_lock(&(sc)->rx.lock);                               \
>> +} while (0)
>> +#define CPSW_RX_UNLOCK(sc)             mtx_unlock(&(sc)->rx.lock)
>> +#define CPSW_RX_LOCK_ASSERT(sc)        mtx_assert(&(sc)->rx.lock, MA_OWNED)
>> +#define CPSW_GLOBAL_LOCK(sc) do {                                      \
>> +               if ((mtx_owned(&(sc)->tx.lock) ? 1 : 0) !=      \
>> +                   (mtx_owned(&(sc)->rx.lock) ? 1 : 0)) {              \
>> +                       panic("cpsw deadlock possibility detection!");  \
>> +} while (0)
>> +#define CPSW_GLOBAL_UNLOCK(sc) do {                                    \
>> +               CPSW_RX_UNLOCK(sc);                             \
>> +               CPSW_TX_UNLOCK(sc);                             \
>> +} while (0)
>> +#define CPSW_GLOBAL_LOCK_ASSERT(sc) do {                               \
>> +               CPSW_TX_LOCK_ASSERT(sc);                                \
>> +               CPSW_RX_LOCK_ASSERT(sc);                                \
>> +} while (0)
>> + * Read/Write macros
>> +#define        cpsw_read_4(sc, reg)            bus_read_4(sc->res[0], reg)
>> +#define        cpsw_write_4(sc, reg, val)      bus_write_4(sc->res[0], reg, val)
>> +#define BUS_SPACE_PHYSADDR(res, offs) \
>> +        ((u_int)(rman_get_start(res)+(offs)))
>> +#define CONTROL_MOD_BASE 0x44E10000
>> +#define cm_read(a)    (*(volatile uint32_t *)(a))
>> +#define cm_write(a,v) (*(volatile uint32_t *)(a) = (v))
>> +#define        cpsw_cpdma_bd_offset(i) (CPSW_CPPI_RAM_OFFSET + ((i)*16))
>> +#define        cpsw_cpdma_bd_paddr(sc, slot)                           \
>> +       BUS_SPACE_PHYSADDR(sc->res[0], slot->bd_offset)
>> +#define        cpsw_cpdma_read_bd(sc, slot, val)                               \
>> +       bus_read_region_4(sc->res[0], slot->bd_offset, (uint32_t *) val, 4)
>> +#define        cpsw_cpdma_write_bd(sc, slot, val)                              \
>> +       bus_write_region_4(sc->res[0], slot->bd_offset, (uint32_t *) val, 4)
>> +#define        cpsw_cpdma_write_bd_next(sc, slot, next_slot)                   \
>> +       cpsw_write_4(sc, slot->bd_offset, cpsw_cpdma_bd_paddr(sc, next_slot))
>> +#define        cpsw_cpdma_read_bd_flags(sc, slot)              \
>> +       bus_read_2(sc->res[0], slot->bd_offset + 14)
>> +#define        cpsw_write_hdp_slot(sc, queue, slot)                            \
>> +       cpsw_write_4(sc, (queue)->hdp_offset, cpsw_cpdma_bd_paddr(sc, slot))
>> +#define        CP_OFFSET (CPSW_CPDMA_TX_CP(0) - CPSW_CPDMA_TX_HDP(0))
>> +#define        cpsw_read_cp(sc, queue)                         \
>> +       cpsw_read_4(sc, (queue)->hdp_offset + CP_OFFSET)
>> +#define        cpsw_write_cp(sc, queue, val)                           \
>> +       cpsw_write_4(sc, (queue)->hdp_offset + CP_OFFSET, (val))
>> +#define        cpsw_write_cp_slot(sc, queue, slot)             \
>> +       cpsw_write_cp(sc, queue, cpsw_cpdma_bd_paddr(sc, slot))
>> +#if 0
>> +/* XXX temporary function versions for debugging. */
>> +static void
>> +cpsw_write_hdp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
>> +       uint32_t reg = queue->hdp_offset;
>> +       uint32_t v = cpsw_cpdma_bd_paddr(sc, slot);
>> +       CPSW_DEBUGF(("HDP <=== 0x%08x (was 0x%08x)", v, cpsw_read_4(sc, reg)));
>> +       cpsw_write_4(sc, reg, v);
>> +static void
>> +cpsw_write_cp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
>> +       CPSW_DEBUGF(("CP <=== 0x%08x (expecting 0x%08x)", v, cpsw_read_cp(sc, queue)));
>> +       cpsw_write_cp(sc, queue, v);
>> +#endif
>> + * Expanded dump routines for verbose debugging.
>> +static void
>> +cpsw_dump_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
>> +       static const char *flags[] = {"SOP", "EOP", "Owner", "EOQ",
>> +           "TDownCmplt", "PassCRC", "Long", "Short", "MacCtl", "Overrun",
>> +           "PktErr1", "PortEn/PktErr0", "RxVlanEncap", "Port2", "Port1",
>> +           "Port0"};
>> +       struct cpsw_cpdma_bd bd;
>> +       const char *sep;
>> +       int i;
>> +       cpsw_cpdma_read_bd(sc, slot, &bd);
>> +       printf("BD Addr: 0x%08x   Next: 0x%08x\n", cpsw_cpdma_bd_paddr(sc, slot), bd.next);
>> +       printf("  BufPtr: 0x%08x   BufLen: 0x%08x\n", bd.bufptr, bd.buflen);
>> +       printf("  BufOff: 0x%08x   PktLen: 0x%08x\n", bd.bufoff, bd.pktlen);
>> +       printf("  Flags: ");
>> +       sep = "";
>> +       for (i = 0; i < 16; ++i) {
>> +               if (bd.flags & (1 << (15 - i))) {
>> +                       printf("%s%s", sep, flags[i]);
>> +                       sep = ",";
>> +       printf("\n");
>> +       if (slot->mbuf) {
>> +               printf("  Ether:  %14D\n",
>> +                   (char *)(slot->mbuf->m_data), " ");
>> +               printf("  Packet: %16D\n",
>> +                   (char *)(slot->mbuf->m_data) + 14, " ");
>> +#define CPSW_DUMP_SLOT(cs, slot) do {                          \
>> +       IF_DEBUG(sc) {                                          \
>> +               cpsw_dump_slot(sc, slot);                       \
>> +} while (0)
>> +static void
>> +cpsw_dump_queue(struct cpsw_softc *sc, struct cpsw_slots *q)
>> +       struct cpsw_slot *slot;
>> +       int i = 0;
>> +       int others = 0;
>> +       STAILQ_FOREACH(slot, q, next) {
>> +               if (i > 4)
>> +                       ++others;
>> +               else
>> +               ++i;
>> +       if (others)
>> +               printf(" ... and %d more.\n", others);
>> +       printf("\n");
>> +#define CPSW_DUMP_QUEUE(sc, q) do {                            \
>> +       IF_DEBUG(sc) {                                          \
>> +               cpsw_dump_queue(sc, q);                         \
>> +} while (0)
>> + * Device Probe, Attach, Detach.
>> +static int
>> +cpsw_probe(device_t dev)
>> +#ifndef __rtems__
>> +       if (!ofw_bus_status_okay(dev))
>> +               return (ENXIO);
>> +       if (!ofw_bus_is_compatible(dev, "ti,cpsw"))
>> +               return (ENXIO);
>> +#endif
>> +       device_set_desc(dev, "3-port Switch Ethernet Subsystem");
>> +       return (BUS_PROBE_DEFAULT);
>> +static void
>> +cpsw_init_slots(struct cpsw_softc *sc)
>> +       int i;
>> +       STAILQ_INIT(&sc->avail);
>> +       /* Put the slot descriptors onto the global avail list. */
>> +       for (i = 0; i < sizeof(sc->_slots) / sizeof(sc->_slots[0]); i++) {
>> +               slot = &sc->_slots[i];
>> +               slot->bd_offset = cpsw_cpdma_bd_offset(i);
>> +               STAILQ_INSERT_TAIL(&sc->avail, slot, next);
>> + * bind an interrupt, add the relevant info to sc->interrupts
>> +static int
>> +cpsw_attach_interrupt(struct cpsw_softc *sc, struct resource *res, driver_intr_t *handler, const char *description)
>> +       void **pcookie;
>> +       int error;
>> +       sc->interrupts[sc->interrupt_count].res = res;
>> +       sc->interrupts[sc->interrupt_count].description = description;
>> +       pcookie = &sc->interrupts[sc->interrupt_count].ih_cookie;
>> +       error = bus_setup_intr(sc->dev, res, INTR_TYPE_NET | INTR_MPSAFE,
>> +           NULL, *handler, sc, pcookie);
>> +       if (error)
>> +               device_printf(sc->dev,
>> +                   "could not setup %s\n", description);
>> +       else
>> +               ++sc->interrupt_count;
>> +       return (error);
>> + * teardown everything in sc->interrupts.
>> +static void
>> +cpsw_detach_interrupts(struct cpsw_softc *sc)
>> +       int error;
>> +       int i;
>> +       for (i = 0; i < sizeof(sc->interrupts) / sizeof(sc->interrupts[0]); ++i) {
>> +               if (!sc->interrupts[i].ih_cookie)
>> +                       continue;
>> +               error = bus_teardown_intr(sc->dev,
>> +                   sc->interrupts[i].res, sc->interrupts[i].ih_cookie);
>> +               if (error)
>> +                       device_printf(sc->dev, "could not release %s\n",
>> +                           sc->interrupts[i].description);
>> +               sc->interrupts[i].ih_cookie = NULL;
>> +static int
>> +cpsw_add_slots(struct cpsw_softc *sc, struct cpsw_queue *queue, int requested)
>> +       const int max_slots = sizeof(sc->_slots) / sizeof(sc->_slots[0]);
>> +       int i;
>> +       if (requested < 0)
>> +               requested = max_slots;
>> +       for (i = 0; i < requested; ++i) {
>> +               slot = STAILQ_FIRST(&sc->avail);
>> +               if (slot == NULL)
>> +                       return (0);
>> +               if (bus_dmamap_create(sc->mbuf_dtag, 0, &slot->dmamap)) {
>> +                       if_printf(sc->ifp, "failed to create dmamap\n");
>> +                       return (ENOMEM);
>> +               STAILQ_REMOVE_HEAD(&sc->avail, next);
>> +               STAILQ_INSERT_TAIL(&queue->avail, slot, next);
>> +               ++queue->avail_queue_len;
>> +               ++queue->queue_slots;
>> +       return (0);
>> +static int
>> +cpsw_attach(device_t dev)
>> +       bus_dma_segment_t segs[1];
>> +       struct cpsw_softc *sc = device_get_softc(dev);
>> +       struct mii_softc *miisc;
>> +       struct ifnet *ifp;
>> +#ifndef __rtems__
>> +       void *phy_sc;
>> +       int phy;
>> +#endif
>> +       int error, nsegs;
>> +       uint32_t reg;
>> +       CPSW_DEBUGF((""));
>> +       getbinuptime(&sc->attach_uptime);
>> +       sc->dev = dev;
>> +#ifndef __rtems__
>> +       sc->node = ofw_bus_get_node(dev);
>> +       /* Get phy address from fdt */
>> +       if (fdt_get_phyaddr(sc->node, sc->dev, &phy, &phy_sc) != 0) {
>> +               device_printf(dev, "failed to get PHY address from FDT\n");
>> +               return (ENXIO);
>> +#endif
>> +       /* Initialize mutexes */
>> +       mtx_init(&sc->tx.lock, device_get_nameunit(dev),
>> +           "cpsw TX lock", MTX_DEF);
>> +       mtx_init(&sc->rx.lock, device_get_nameunit(dev),
>> +           "cpsw RX lock", MTX_DEF);
>> +       /* Allocate IO and IRQ resources */
>> +       error = bus_alloc_resources(dev, res_spec, sc->res);
>> +       if (error) {
>> +               device_printf(dev, "could not allocate resources\n");
>> +               cpsw_detach(dev);
>> +               return (ENXIO);
>> +       reg = cpsw_read_4(sc, CPSW_SS_IDVER);
>> +       device_printf(dev, "CPSW SS Version %d.%d (%d)\n", (reg >> 8 & 0x7),
>> +               reg & 0xFF, (reg >> 11) & 0x1F);
>> +#ifndef __rtems__
>> +       cpsw_add_sysctls(sc);
>> +#endif
>> +       /* Allocate a busdma tag and DMA safe memory for mbufs. */
>> +       error = bus_dma_tag_create(
>> +               bus_get_dma_tag(sc->dev),       /* parent */
>> +               1, 0,                           /* alignment, boundary */
>> +               BUS_SPACE_MAXADDR_32BIT,        /* lowaddr */
>> +               BUS_SPACE_MAXADDR,              /* highaddr */
>> +               NULL, NULL,                     /* filtfunc, filtfuncarg */
>> +               MCLBYTES, CPSW_TXFRAGS,         /* maxsize, nsegments */
>> +               MCLBYTES, 0,                    /* maxsegsz, flags */
>> +               NULL, NULL,                     /* lockfunc, lockfuncarg */
>> +               &sc->mbuf_dtag);                /* dmatag */
>> +       if (error) {
>> +               device_printf(dev, "bus_dma_tag_create failed\n");
>> +               cpsw_detach(dev);
>> +               return (error);
>> +       /* Allocate network interface */
>> +       ifp = sc->ifp = if_alloc(IFT_ETHER);
>> +       if (ifp == NULL) {
>> +               device_printf(dev, "if_alloc() failed\n");
>> +               cpsw_detach(dev);
>> +               return (ENOMEM);
>> +       /* Allocate the null mbuf and pre-sync it. */
>> +       sc->null_mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
>> +       memset(sc->null_mbuf->m_data, 0, sc->null_mbuf->m_ext.ext_size);
>> +       bus_dmamap_create(sc->mbuf_dtag, 0, &sc->null_mbuf_dmamap);
>> +       bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, sc->null_mbuf_dmamap,
>> +           sc->null_mbuf, segs, &nsegs, BUS_DMA_NOWAIT);
>> +       bus_dmamap_sync(sc->mbuf_dtag, sc->null_mbuf_dmamap,
>> +           BUS_DMASYNC_PREWRITE);
>> +       sc->null_mbuf_paddr = segs[0].ds_addr;
>> +       if_initname(ifp, device_get_name(dev), device_get_unit(dev));
>> +       ifp->if_softc = sc;
>> +       ifp->if_flags = IFF_SIMPLEX | IFF_MULTICAST | IFF_BROADCAST;
>> +       ifp->if_capabilities = IFCAP_VLAN_MTU | IFCAP_HWCSUM; //FIXME VLAN?
>> +       ifp->if_capenable = ifp->if_capabilities;
>> +       ifp->if_init = cpsw_init;
>> +       ifp->if_start = cpsw_start;
>> +       ifp->if_ioctl = cpsw_ioctl;
>> +       cpsw_init_slots(sc);
>> +       /* Allocate slots to TX and RX queues. */
>> +       STAILQ_INIT(&sc->rx.avail);
>> +       STAILQ_INIT(&sc->rx.active);
>> +       STAILQ_INIT(&sc->tx.avail);
>> +       STAILQ_INIT(&sc->tx.active);
>> +       // For now:  128 slots to TX, rest to RX.
>> +       // XXX TODO: start with 32/64 and grow dynamically based on demand.
>> +       if (cpsw_add_slots(sc, &sc->tx, 128) || cpsw_add_slots(sc, &sc->rx, -1)) {
>> +               device_printf(dev, "failed to allocate dmamaps\n");
>> +               cpsw_detach(dev);
>> +               return (ENOMEM);
>> +       device_printf(dev, "Initial queue size TX=%d RX=%d\n",
>> +           sc->tx.queue_slots, sc->rx.queue_slots);
>> +       ifp->if_snd.ifq_drv_maxlen = sc->tx.queue_slots;
>> +       IFQ_SET_MAXLEN(&ifp->if_snd, ifp->if_snd.ifq_drv_maxlen);
>> +       IFQ_SET_READY(&ifp->if_snd);
>> +       sc->tx.hdp_offset = CPSW_CPDMA_TX_HDP(0);
>> +       sc->rx.hdp_offset = CPSW_CPDMA_RX_HDP(0);
>> +       /* Get high part of MAC address from control module (mac_id0_hi) */
>> +       /* TODO: Get MAC ID1 as well as MAC ID0. */
>> +#ifndef __rtems__
>> +       ti_scm_reg_read_4(0x634, &reg);
>> +#else
>> +        reg = cm_read(CONTROL_MOD_BASE+0x634);
>> +#endif
>> +       sc->mac_addr[0] = reg & 0xFF;
>> +       sc->mac_addr[1] = (reg >>  8) & 0xFF;
>> +       sc->mac_addr[2] = (reg >> 16) & 0xFF;
>> +       sc->mac_addr[3] = (reg >> 24) & 0xFF;
>> +       /* Get low part of MAC address from control module (mac_id0_lo) */
>> +#ifndef __rtems__
>> +       ti_scm_reg_read_4(0x630, &reg);
>> +#else
>> +        reg = cm_read(CONTROL_MOD_BASE+0x630);
>> +#endif
>> +       sc->mac_addr[4] = reg & 0xFF;
>> +       sc->mac_addr[5] = (reg >>  8) & 0xFF;
>> +       /* Initialze MDIO - ENABLE, PREAMBLE=0, FAULTENB, CLKDIV=0xFF */
>> +       /* TODO Calculate MDCLK=CLK/(CLKDIV+1) */
>> +       cpsw_write_4(sc, MDIOCONTROL, 1 << 30 | 1 << 18 | 0xFF);
>> +       /* Clear ALE */
>> +       cpsw_write_4(sc, CPSW_ALE_CONTROL, 1 << 30);
>> +       /* Attach PHY(s) */
>> +       error = mii_attach(dev, &sc->miibus, ifp, cpsw_ifmedia_upd,
>> +           cpsw_ifmedia_sts, BMSR_DEFCAPMASK,MII_PHY_ANY, MII_OFFSET_ANY, 0);
>> +       if (error) {
>> +               device_printf(dev, "attaching PHYs failed\n");
>> +               cpsw_detach(dev);
>> +               return (error);
>> +       sc->mii = device_get_softc(sc->miibus);
>> +       /* Tell the MAC where to find the PHY so autoneg works */
>> +       miisc = LIST_FIRST(&sc->mii->mii_phys);
>> +       /* Select PHY and enable interrupts */
>> +       cpsw_write_4(sc, MDIOUSERPHYSEL0, 1 << 6 | (miisc->mii_phy & 0x1F));
>> +       /* Note: We don't use sc->res[3] (TX interrupt) */
>> +       if (cpsw_attach_interrupt(sc, sc->res[1],
>> +               cpsw_intr_rx_thresh, "CPSW RX threshold interrupt") ||
>> +           cpsw_attach_interrupt(sc, sc->res[2],
>> +               cpsw_intr_rx, "CPSW RX interrupt") ||
>> +           cpsw_attach_interrupt(sc, sc->res[4],
>> +               cpsw_intr_misc, "CPSW misc interrupt")) {
>> +               cpsw_detach(dev);
>> +               return (ENXIO);
>> +       ether_ifattach(ifp, sc->mac_addr);
>> +       callout_init(&sc->watchdog.callout, 0);
>> +       return (0);
>> +static void
>> +cpsw_free_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
>> +       int error;
>> +       if (slot->dmamap) {
>> +               error = bus_dmamap_destroy(sc->mbuf_dtag, slot->dmamap);
>> +               KASSERT(error == 0, ("Mapping still active"));
>> +               slot->dmamap = NULL;
>> +       if (slot->mbuf) {
>> +               m_freem(slot->mbuf);
>> +               slot->mbuf = NULL;
>> +static int
>> +cpsw_detach(device_t dev)
>> +       int error, i;
>> +       /* Stop controller and free TX queue */
>> +       if (device_is_attached(dev)) {
>> +               ether_ifdetach(sc->ifp);
>> +               CPSW_GLOBAL_LOCK(sc);
>> +               cpsw_shutdown_locked(sc);
>> +               CPSW_GLOBAL_UNLOCK(sc);
>> +               callout_drain(&sc->watchdog.callout);
>> +       bus_generic_detach(dev);
>> +       if (sc->miibus)
>> +               device_delete_child(dev, sc->miibus);
>> +       /* Stop and release all interrupts */
>> +       cpsw_detach_interrupts(sc);
>> +       /* Free dmamaps and mbufs */
>> +       for (i = 0; i < sizeof(sc->_slots) / sizeof(sc->_slots[0]); ++i)
>> +               cpsw_free_slot(sc, &sc->_slots[i]);
>> +       if (sc->null_mbuf_dmamap) {
>> +               error = bus_dmamap_destroy(sc->mbuf_dtag, sc->null_mbuf_dmamap);
>> +       if (sc->null_mbuf)
>> +               m_freem(sc->null_mbuf);
>> +       /* Free DMA tag */
>> +       error = bus_dma_tag_destroy(sc->mbuf_dtag);
>> +       KASSERT(error == 0, ("Unable to destroy DMA tag"));
>> +       /* Free IO memory handler */
>> +       bus_release_resources(dev, res_spec, sc->res);
>> +       if (sc->ifp != NULL)
>> +               if_free(sc->ifp);
>> +       /* Destroy mutexes */
>> +       mtx_destroy(&sc->rx.lock);
>> +       mtx_destroy(&sc->tx.lock);
>> +       return (0);
>> + * Init/Shutdown.
>> +static void
>> +cpsw_reset(struct cpsw_softc *sc)
>> +       int i;
>> +       /* Reset RMII/RGMII wrapper. */
>> +       cpsw_write_4(sc, CPSW_WR_SOFT_RESET, 1);
>> +       while (cpsw_read_4(sc, CPSW_WR_SOFT_RESET) & 1)
>> +       /* Disable TX and RX interrupts for all cores. */
>> +       for (i = 0; i < 3; ++i) {
>> +               cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(i), 0x00);
>> +               cpsw_write_4(sc, CPSW_WR_C_TX_EN(i), 0x00);
>> +               cpsw_write_4(sc, CPSW_WR_C_RX_EN(i), 0x00);
>> +               cpsw_write_4(sc, CPSW_WR_C_MISC_EN(i), 0x00);
>> +       /* Reset CPSW subsystem. */
>> +       cpsw_write_4(sc, CPSW_SS_SOFT_RESET, 1);
>> +       while (cpsw_read_4(sc, CPSW_SS_SOFT_RESET) & 1)
>> +       /* Reset Sliver port 1 and 2 */
>> +       for (i = 0; i < 2; i++) {
>> +               /* Reset */
>> +               cpsw_write_4(sc, CPSW_SL_SOFT_RESET(i), 1);
>> +               while (cpsw_read_4(sc, CPSW_SL_SOFT_RESET(i)) & 1)
>> +       /* Reset DMA controller. */
>> +       cpsw_write_4(sc, CPSW_CPDMA_SOFT_RESET, 1);
>> +       while (cpsw_read_4(sc, CPSW_CPDMA_SOFT_RESET) & 1)
>> +       /* Disable TX & RX DMA */
>> +       cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 0);
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 0);
>> +       /* Clear all queues. */
>> +       for (i = 0; i < 8; i++) {
>> +               cpsw_write_4(sc, CPSW_CPDMA_TX_HDP(i), 0);
>> +               cpsw_write_4(sc, CPSW_CPDMA_RX_HDP(i), 0);
>> +               cpsw_write_4(sc, CPSW_CPDMA_TX_CP(i), 0);
>> +               cpsw_write_4(sc, CPSW_CPDMA_RX_CP(i), 0);
>> +       /* Clear all interrupt Masks */
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_CLEAR, 0xFFFFFFFF);
>> +       cpsw_write_4(sc, CPSW_CPDMA_TX_INTMASK_CLEAR, 0xFFFFFFFF);
>> +static void
>> +cpsw_init(void *arg)
>> +       struct cpsw_softc *sc = arg;
>> +       cpsw_init_locked(arg);
>> +static void
>> +cpsw_init_locked(void *arg)
>> +       uint32_t i;
>> +       ifp = sc->ifp;
>> +       if ((ifp->if_drv_flags & IFF_DRV_RUNNING) != 0)
>> +               return;
>> +       getbinuptime(&sc->init_uptime);
>> +       /* Reset the controller. */
>> +       cpsw_reset(sc);
>> +       /* Enable ALE */
>> +       cpsw_write_4(sc, CPSW_ALE_CONTROL, 1 << 31 | 1 << 4);
>> +       /* Init Sliver port 1 and 2 */
>> +               /* Set Slave Mapping */
>> +               cpsw_write_4(sc, CPSW_SL_RX_PRI_MAP(i), 0x76543210);
>> +               cpsw_write_4(sc, CPSW_PORT_P_TX_PRI_MAP(i + 1), 0x33221100);
>> +               cpsw_write_4(sc, CPSW_SL_RX_MAXLEN(i), 0x5f2);
>> +               /* Set MACCONTROL for ports 0,1: IFCTL_B(16), IFCTL_A(15),
>> +                  GMII_EN(5), FULLDUPLEX(1) */
>> +               /* TODO: Docs claim that IFCTL_B and IFCTL_A do the same thing? */
>> +               /* Huh?  Docs call bit 0 "Loopback" some places, "FullDuplex" others. */
>> +               cpsw_write_4(sc, CPSW_SL_MACCONTROL(i), 1 << 15 | 1 << 5 | 1);
>> +       /* Set Host Port Mapping */
>> +       cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_TX_PRI_MAP, 0x76543210);
>> +       cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_RX_CH_MAP, 0);
>> +       /* Initialize ALE: all ports set to forwarding(3), initialize addrs */
>> +       for (i = 0; i < 3; i++)
>> +               cpsw_write_4(sc, CPSW_ALE_PORTCTL(i), 3);
>> +       cpsw_ale_update_addresses(sc, 1);
>> +       cpsw_write_4(sc, CPSW_SS_PTYPE, 0);
>> +       /* Enable statistics for ports 0, 1 and 2 */
>> +       cpsw_write_4(sc, CPSW_SS_STAT_PORT_EN, 7);
>> +       /* Experiment:  Turn off flow control */
>> +       /* This seems to fix the watchdog resets that have plagued
>> +          earlier versions of this driver; I'm not yet sure if there
>> +          are negative effects yet. */
>> +       cpsw_write_4(sc, CPSW_SS_FLOW_CONTROL, 0);
>> +       /* Make IP hdr aligned with 4 */
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_BUFFER_OFFSET, 2);
>> +       /* Initialize RX Buffer Descriptors */
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_FREEBUFFER(0), 0);
>> +       /* Enable TX & RX DMA */
>> +       cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 1);
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 1);
>> +       /* Enable Interrupts for core 0 */
>> +       cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(0), 0xFF);
>> +       cpsw_write_4(sc, CPSW_WR_C_RX_EN(0), 0xFF);
>> +       cpsw_write_4(sc, CPSW_WR_C_MISC_EN(0), 0x3F);
>> +       /* Enable host Error Interrupt */
>> +       cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_SET, 3);
>> +       /* Enable interrupts for RX Channel 0 */
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_SET, 1);
>> +       /* Select MII in GMII_SEL, Internal Delay mode */
>> +       //ti_scm_reg_write_4(0x650, 0);
>> +       /* Initialize active queues. */
>> +       slot = STAILQ_FIRST(&sc->tx.active);
>> +       if (slot != NULL)
>> +               cpsw_write_hdp_slot(sc, &sc->tx, slot);
>> +       slot = STAILQ_FIRST(&sc->rx.active);
>> +       if (slot != NULL)
>> +               cpsw_write_hdp_slot(sc, &sc->rx, slot);
>> +       cpsw_rx_enqueue(sc);
>> +       /* Activate network interface */
>> +       sc->rx.running = 1;
>> +       sc->tx.running = 1;
>> +       sc->watchdog.timer = 0;
>> +       callout_reset(&sc->watchdog.callout, hz, cpsw_tick, sc);
>> +       sc->ifp->if_drv_flags |= IFF_DRV_RUNNING;
>> +       sc->ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
>> +static int
>> +cpsw_shutdown(device_t dev)
>> +       return (0);
>> +static void
>> +cpsw_rx_teardown_locked(struct cpsw_softc *sc)
>> +       struct mbuf *received, *next;
>> +       int i = 0;
>> +       CPSW_DEBUGF(("starting RX teardown"));
>> +       cpsw_write_4(sc, CPSW_CPDMA_RX_TEARDOWN, 0);
>> +       for (;;) {
>> +               received = cpsw_rx_dequeue(sc);
>> +               while (received != NULL) {
>> +                       next = received->m_nextpkt;
>> +                       received->m_nextpkt = NULL;
>> +                       (*sc->ifp->if_input)(sc->ifp, received);
>> +                       received = next;
>> +               if (!sc->rx.running) {
>> +                       CPSW_DEBUGF(("finished RX teardown (%d retries)", i));
>> +                       return;
>> +               if (++i > 10) {
>> +                       if_printf(sc->ifp, "Unable to cleanly shutdown receiver\n");
>> +                       return;
>> +               DELAY(10);
>> +static void
>> +cpsw_tx_teardown_locked(struct cpsw_softc *sc)
>> +       int i = 0;
>> +       CPSW_DEBUGF(("starting TX teardown"));
>> +       cpsw_write_4(sc, CPSW_CPDMA_TX_TEARDOWN, 0);
>> +       cpsw_tx_dequeue(sc);
>> +       while (sc->tx.running && ++i < 10) {
>> +               DELAY(10);
>> +       if (sc->tx.running)
>> +               if_printf(sc->ifp, "Unable to cleanly shutdown transmitter\n");
>> +       CPSW_DEBUGF(("finished TX teardown (%d retries, %d idle buffers)",
>> +           i, sc->tx.active_queue_len));
>> +static void
>> +cpsw_shutdown_locked(struct cpsw_softc *sc)
>> +       CPSW_GLOBAL_LOCK_ASSERT(sc);
>> +       ifp = sc->ifp;
>> +       if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0)
>> +               return;
>> +       /* Disable interface */
>> +       ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
>> +       ifp->if_drv_flags |= IFF_DRV_OACTIVE;
>> +       /* Stop ticker */
>> +       callout_stop(&sc->watchdog.callout);
>> +       /* Tear down the RX/TX queues. */
>> +       cpsw_rx_teardown_locked(sc);
>> +       cpsw_tx_teardown_locked(sc);
>> +#ifndef __rtems__
>> +       /* Capture stats before we reset controller. */
>> +       cpsw_stats_collect(sc);
>> +#endif
>> +       cpsw_reset(sc);
>> + *  Suspend/Resume.
>> +static int
>> +cpsw_suspend(device_t dev)
>> +       return (0);
>> +static int
>> +cpsw_resume(device_t dev)
>> +       CPSW_DEBUGF(("UNIMPLEMENTED"));
>> +       return (0);
>> + *  IOCTL
>> +static void
>> +cpsw_set_promisc(struct cpsw_softc *sc, int set)
>> +        * Enabling promiscuous mode requires two bits of work: First,
>> +        * ALE_BYPASS needs to be enabled.  That disables the ALE
>> +        * forwarding logic and causes every packet to be sent to the
>> +        * host port.  That makes us promiscuous wrt received packets.
>> +        * With ALE forwarding disabled, the transmitter needs to set
>> +        * an explicit output port on every packet to route it to the
>> +        * correct egress.  This should be doable for systems such as
>> +        * BeagleBone where only one egress port is actually wired to
>> +        * a PHY.  If you have both egress ports wired up, life gets a
>> +        * lot more interesting.
>> +        * Hmmm.... NetBSD driver uses ALE_BYPASS always and doesn't
>> +        * seem to set explicit egress ports.  Does that mean they
>> +        * are always promiscuous?
>> +       if (set) {
>> +               printf("Promiscuous mode unimplemented\n");
>> +static void
>> +cpsw_set_allmulti(struct cpsw_softc *sc, int set)
>> +       if (set) {
>> +               printf("All-multicast mode unimplemented\n");
>> +static int
>> +cpsw_ioctl(struct ifnet *ifp, u_long command, caddr_t data)
>> +       struct cpsw_softc *sc = ifp->if_softc;
>> +       struct ifreq *ifr = (struct ifreq *)data;
>> +       int error;
>> +       uint32_t changed;
>> +       error = 0;
>> +       switch (command) {
>> +       case SIOCSIFFLAGS:
>> +               if (ifp->if_flags & IFF_UP) {
>> +                       if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
>> +                               changed = ifp->if_flags ^ sc->cpsw_if_flags;
>> +                               CPSW_DEBUGF(("SIOCSIFFLAGS: UP & RUNNING (changed=0x%x)", changed));
>> +                               if (changed & IFF_PROMISC)
>> +                                       cpsw_set_promisc(sc,
>> +                                           ifp->if_flags & IFF_PROMISC);
>> +                               if (changed & IFF_ALLMULTI)
>> +                                       cpsw_set_allmulti(sc,
>> +                                           ifp->if_flags & IFF_ALLMULTI);
>> +                       } else {
>> +                               CPSW_DEBUGF(("SIOCSIFFLAGS: UP but not RUNNING; starting up"));
>> +                               cpsw_init_locked(sc);
>> +               } else if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
>> +                       CPSW_DEBUGF(("SIOCSIFFLAGS: not UP but RUNNING; shutting down"));
>> +               sc->cpsw_if_flags = ifp->if_flags;
>> +               break;
>> +       case SIOCADDMULTI:
>> +               cpsw_ale_update_addresses(sc, 0);
>> +               break;
>> +       case SIOCDELMULTI:
>> +               /* Ugh.  DELMULTI doesn't provide the specific address
>> +                  being removed, so the best we can do is remove
>> +                  everything and rebuild it all. */
>> +               break;
>> +       case SIOCGIFMEDIA:
>> +       case SIOCSIFMEDIA:
>> +               error = ifmedia_ioctl(ifp, ifr, &sc->mii->mii_media, command);
>> +               break;
>> +       default:
>> +               error = ether_ioctl(ifp, command, data);
>> +       return (error);
>> + * MIIBUS
>> +static int
>> +cpsw_miibus_ready(struct cpsw_softc *sc)
>> +       uint32_t r, retries = CPSW_MIIBUS_RETRIES;
>> +       while (--retries) {
>> +               r = cpsw_read_4(sc, MDIOUSERACCESS0);
>> +               if ((r & 1 << 31) == 0)
>> +                       return 1;
>> +               DELAY(CPSW_MIIBUS_DELAY);
>> +       return 0;
>> +static int
>> +cpsw_miibus_readreg(device_t dev, int phy, int reg)
>> +       uint32_t cmd, r;
>> +       if (!cpsw_miibus_ready(sc)) {
>> +               device_printf(dev, "MDIO not ready to read\n");
>> +               return 0;
>> +       /* Set GO, reg, phy */
>> +       cmd = 1 << 31 | (reg & 0x1F) << 21 | (phy & 0x1F) << 16;
>> +       cpsw_write_4(sc, MDIOUSERACCESS0, cmd);
>> +               device_printf(dev, "MDIO timed out during read\n");
>> +               return 0;
>> +       if((r & 1 << 29) == 0) {
>> +               CPSW_DEBUGF(("Failed to read from PHY.\n"));
>> +               r = 0;
>> +       return (r & 0xFFFF);
>> +static int
>> +cpsw_miibus_writereg(device_t dev, int phy, int reg, int value)
>> +       uint32_t cmd;
>> +               device_printf(dev, "MDIO not ready to write\n");
>> +               return 0;
>> +       /* Set GO, WRITE, reg, phy, and value */
>> +       cmd = 3 << 30 | (reg & 0x1F) << 21 | (phy & 0x1F) << 16
>> +           | (value & 0xFFFF);
>> +               device_printf(dev, "MDIO timed out during write\n");
>> +               return 0;
>> +       if((cpsw_read_4(sc, MDIOUSERACCESS0) & (1 << 29)) == 0)
>> +               CPSW_DEBUGF(("Failed to write to PHY.\n"));
>> +       return 0;
>> + * Transmit/Receive Packets.
>> +static void
>> +cpsw_intr_rx(void *arg)
>> +       CPSW_RX_LOCK(sc);
>> +       cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 1);
>> +               received = next;
>> +cpsw_rx_dequeue(struct cpsw_softc *sc)
>> +       struct mbuf *mb_head, *mb_tail;
>> +       int removed = 0;
>> +       ifp = sc->ifp;
>> +       mb_head = mb_tail = NULL;
>> +       /* Pull completed packets off hardware RX queue. */
>> +       while ((slot = STAILQ_FIRST(&sc->rx.active)) != NULL) {
>> +               if (bd.flags & CPDMA_BD_OWNER)
>> +                       break; /* Still in use by hardware */
>> +               CPSW_DEBUGF(("Removing received packet from RX queue"));
>> +               ++removed;
>> +               STAILQ_REMOVE_HEAD(&sc->rx.active, next);
>> +               STAILQ_INSERT_TAIL(&sc->rx.avail, slot, next);
>> +               bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTREAD);
>> +               bus_dmamap_unload(sc->mbuf_dtag, slot->dmamap);
>> +               if (bd.flags & CPDMA_BD_TDOWNCMPLT) {
>> +                       CPSW_DEBUGF(("RX teardown in progress"));
>> +                       cpsw_write_cp(sc, &sc->rx, 0xfffffffc);
>> +                       sc->rx.running = 0;
>> +                       break;
>> +               cpsw_write_cp_slot(sc, &sc->rx, slot);
>> +               /* Set up mbuf */
>> +               /* TODO: track SOP/EOP bits to assemble a full mbuf
>> +                  out of received fragments. */
>> +               slot->mbuf->m_data += bd.bufoff;
>> +               slot->mbuf->m_len = bd.pktlen - 4;
>> +               slot->mbuf->m_pkthdr.len = bd.pktlen - 4;
>> +               slot->mbuf->m_flags |= M_PKTHDR;
>> +               slot->mbuf->m_pkthdr.rcvif = ifp;
>> +               slot->mbuf->m_nextpkt = NULL;
>> +               if ((ifp->if_capenable & IFCAP_RXCSUM) != 0) {
>> +                       /* check for valid CRC by looking into pkt_err[5:4] */
>> +                       if ((bd.flags & CPDMA_BD_PKT_ERR_MASK) == 0) {
>> +                               slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_CHECKED;
>> +                               slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_VALID;
>> +                               slot->mbuf->m_pkthdr.csum_data = 0xffff;
>> +               /* Add mbuf to packet list to be returned. */
>> +               if (mb_tail) {
>> +                       mb_tail->m_nextpkt = slot->mbuf;
>> +               } else {
>> +                       mb_head = slot->mbuf;
>> +               mb_tail = slot->mbuf;
>> +       if (removed != 0) {
>> +               sc->rx.queue_removes += removed;
>> +               sc->rx.active_queue_len -= removed;
>> +               sc->rx.avail_queue_len += removed;
>> +               if (sc->rx.avail_queue_len > sc->rx.max_avail_queue_len)
>> +                       sc->rx.max_avail_queue_len = sc->rx.avail_queue_len;
>> +       return (mb_head);
>> +static void
>> +cpsw_rx_enqueue(struct cpsw_softc *sc)
>> +       bus_dma_segment_t seg[1];
>> +       struct ifnet *ifp = sc->ifp;
>> +       struct cpsw_slots tmpqueue = STAILQ_HEAD_INITIALIZER(tmpqueue);
>> +       struct cpsw_slot *slot, *prev_slot = NULL;
>> +       struct cpsw_slot *last_old_slot, *first_new_slot;
>> +       int error, nsegs, added = 0;
>> +       /* Register new mbufs with hardware. */
>> +       while ((slot = STAILQ_FIRST(&sc->rx.avail)) != NULL) {
>> +               if (slot->mbuf == NULL) {
>> +                       slot->mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
>> +                               if_printf(sc->ifp, "Unable to fill RX queue\n");
>> +                               break;
>> +                           slot->mbuf->m_ext.ext_size;
>> +               error = bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, slot->dmamap,
>> +                   slot->mbuf, seg, &nsegs, BUS_DMA_NOWAIT);
>> +               KASSERT(nsegs == 1, ("More than one segment (nsegs=%d)", nsegs));
>> +               KASSERT(error == 0, ("DMA error (error=%d)", error));
>> +               if (error != 0 || nsegs != 1) {
>> +                       if_printf(ifp,
>> +                           "%s: Can't prep RX buf for DMA (nsegs=%d, error=%d)\n",
>> +                           __func__, nsegs, error);
>> +                       break;
>> +               bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_PREREAD);
>> +               /* Create and submit new rx descriptor*/
>> +               bd.next = 0;
>> +               bd.bufptr = seg->ds_addr;
>> +               bd.bufoff = 0;
>> +               bd.buflen = MCLBYTES - 1;
>> +               bd.pktlen = bd.buflen;
>> +               bd.flags = CPDMA_BD_OWNER;
>> +               cpsw_cpdma_write_bd(sc, slot, &bd);
>> +               ++added;
>> +               if (prev_slot != NULL)
>> +                       cpsw_cpdma_write_bd_next(sc, prev_slot, slot);
>> +               prev_slot = slot;
>> +               STAILQ_REMOVE_HEAD(&sc->rx.avail, next);
>> +               sc->rx.avail_queue_len--;
>> +               STAILQ_INSERT_TAIL(&tmpqueue, slot, next);
>> +       if (added == 0)
>> +               return;
>> +       CPSW_DEBUGF(("Adding %d buffers to RX queue", added));
>> +       /* Link new entries to hardware RX queue. */
>> +       last_old_slot = STAILQ_LAST(&sc->rx.active, cpsw_slot, next);
>> +       first_new_slot = STAILQ_FIRST(&tmpqueue);
>> +       STAILQ_CONCAT(&sc->rx.active, &tmpqueue);
>> +       if (first_new_slot == NULL) {
>> +               return;
>> +       } else if (last_old_slot == NULL) {
>> +               /* Start a fresh queue. */
>> +               cpsw_write_hdp_slot(sc, &sc->rx, first_new_slot);
>> +       } else {
>> +               /* Add buffers to end of current queue. */
>> +               cpsw_cpdma_write_bd_next(sc, last_old_slot, first_new_slot);
>> +               /* If underrun, restart queue. */
>> +               if (cpsw_cpdma_read_bd_flags(sc, last_old_slot) & CPDMA_BD_EOQ) {
>> +       sc->rx.queue_adds += added;
>> +       sc->rx.active_queue_len += added;
>> +       if (sc->rx.active_queue_len > sc->rx.max_active_queue_len) {
>> +               sc->rx.max_active_queue_len = sc->rx.active_queue_len;
>> +static void
>> +cpsw_start(struct ifnet *ifp)
>> +       CPSW_TX_LOCK(sc);
>> +       if ((ifp->if_drv_flags & IFF_DRV_RUNNING) && sc->tx.running) {
>> +               cpsw_tx_enqueue(sc);
>> +static void
>> +cpsw_tx_enqueue(struct cpsw_softc *sc)
>> +       bus_dma_segment_t segs[CPSW_TXFRAGS];
>> +       struct mbuf *m0;
>> +       int error, nsegs, seg, added = 0, padlen;
>> +       /* Pull pending packets from IF queue and prep them for DMA. */
>> +       while ((slot = STAILQ_FIRST(&sc->tx.avail)) != NULL) {
>> +               IF_DEQUEUE(&sc->ifp->if_snd, m0);
>> +               if (m0 == NULL)
>> +                       break;
>> +               slot->mbuf = m0;
>> +               padlen = ETHER_MIN_LEN - slot->mbuf->m_pkthdr.len;
>> +               if (padlen < 0)
>> +                       padlen = 0;
>> +               /* Create mapping in DMA memory */
>> +                   slot->mbuf, segs, &nsegs, BUS_DMA_NOWAIT);
>> +               /* If the packet is too fragmented, try to simplify. */
>> +               if (error == EFBIG ||
>> +                   (error == 0 &&
>> +                       nsegs + (padlen > 0 ? 1 : 0) > sc->tx.avail_queue_len)) {
>> +                       if (padlen > 0) /* May as well add padding. */
>> +                               m_append(slot->mbuf, padlen,
>> +                                   sc->null_mbuf->m_data);
>> +                       m0 = m_defrag(slot->mbuf, M_NOWAIT);
>> +                       if (m0 == NULL) {
>> +                                   "Can't defragment packet; dropping\n");
>> +                       } else {
>> +                               CPSW_DEBUGF(("Requeueing defragmented packet"));
>> +                               IF_PREPEND(&sc->ifp->if_snd, m0);
>> +                       continue;
>> +               if (error != 0) {
>> +                           "%s: Can't setup DMA (error=%d), dropping packet\n",
>> +                           __func__, error);
>> +                       break;
>> +               CPSW_DEBUGF(("Queueing TX packet: %d segments + %d pad bytes",
>> +                       nsegs, padlen));
>> +               /* If there is only one segment, the for() loop
>> +                * gets skipped and the single buffer gets set up
>> +                * as both SOP and EOP. */
>> +               /* Start by setting up the first buffer */
>> +               bd.next = 0;
>> +               bd.bufptr = segs[0].ds_addr;
>> +               bd.bufoff = 0;
>> +               bd.buflen = segs[0].ds_len;
>> +               bd.pktlen = m_length(slot->mbuf, NULL) + padlen;
>> +               bd.flags =  CPDMA_BD_SOP | CPDMA_BD_OWNER;
>> +               for (seg = 1; seg < nsegs; ++seg) {
>> +                       /* Save the previous buffer (which isn't EOP) */
>> +                       prev_slot = slot;
>> +                       STAILQ_REMOVE_HEAD(&sc->tx.avail, next);
>> +                       sc->tx.avail_queue_len--;
>> +                       ++added;
>> +                       slot = STAILQ_FIRST(&sc->tx.avail);
>> +                       /* Setup next buffer (which isn't SOP) */
>> +                       bd.next = 0;
>> +                       bd.bufptr = segs[seg].ds_addr;
>> +                       bd.bufoff = 0;
>> +                       bd.buflen = segs[seg].ds_len;
>> +                       bd.pktlen = 0;
>> +               /* Save the final buffer. */
>> +               if (padlen <= 0)
>> +                       bd.flags |= CPDMA_BD_EOP;
>> +               prev_slot = slot;
>> +               ++added;
>> +               if (padlen > 0) {
>> +                       ++added;
>> +                       /* Setup buffer of null pad bytes (definitely EOP) */
>> +                       prev_slot = slot;
>> +                       bd.next = 0;
>> +                       bd.bufptr = sc->null_mbuf_paddr;
>> +                       bd.bufoff = 0;
>> +                       bd.buflen = padlen;
>> +                       bd.pktlen = 0;
>> +                       bd.flags = CPDMA_BD_EOP | CPDMA_BD_OWNER;
>> +                       ++nsegs;
>> +               if (nsegs > sc->tx.longest_chain)
>> +                       sc->tx.longest_chain = nsegs;
>> +               // TODO: Should we defer the BPF tap until
>> +               // after all packets are queued?
>> +               BPF_MTAP(sc->ifp, m0);
>> +       /* Attach the list of new buffers to the hardware TX queue. */
>> +       last_old_slot = STAILQ_LAST(&sc->tx.active, cpsw_slot, next);
>> +       STAILQ_CONCAT(&sc->tx.active, &tmpqueue);
>> +               return;
>> +               cpsw_write_hdp_slot(sc, &sc->tx, first_new_slot);
>> +       } else {
>> +       sc->tx.queue_adds += added;
>> +       sc->tx.active_queue_len += added;
>> +       if (sc->tx.active_queue_len > sc->tx.max_active_queue_len) {
>> +               sc->tx.max_active_queue_len = sc->tx.active_queue_len;
>> +static int
>> +cpsw_tx_dequeue(struct cpsw_softc *sc)
>> +       struct cpsw_slot *slot, *last_removed_slot = NULL;
>> +       uint32_t flags, removed = 0;
>> +       if (slot == NULL && cpsw_read_cp(sc, &sc->tx) == 0xfffffffc) {
>> +               CPSW_DEBUGF(("TX teardown of an empty queue"));
>> +               cpsw_write_cp(sc, &sc->tx, 0xfffffffc);
>> +               sc->tx.running = 0;
>> +               return (0);
>> +       /* Pull completed buffers off the hardware TX queue. */
>> +       while (slot != NULL) {
>> +               flags = cpsw_cpdma_read_bd_flags(sc, slot);
>> +               if (flags & CPDMA_BD_OWNER)
>> +                       break; /* Hardware is still using this packet. */
>> +               CPSW_DEBUGF(("TX removing completed packet"));
>> +               bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTWRITE);
>> +               /* Dequeue any additional buffers used by this packet. */
>> +               while (slot != NULL && slot->mbuf == NULL) {
>> +                       STAILQ_REMOVE_HEAD(&sc->tx.active, next);
>> +                       STAILQ_INSERT_TAIL(&sc->tx.avail, slot, next);
>> +                       ++removed;
>> +                       last_removed_slot = slot;
>> +               /* TearDown complete is only marked on the SOP for the packet. */
>> +               if (flags & CPDMA_BD_TDOWNCMPLT) {
>> +                       CPSW_DEBUGF(("TX teardown in progress"));
>> +                       // TODO: Increment a count of dropped TX packets
>> +                       break;
>> +               cpsw_write_cp_slot(sc, &sc->tx, last_removed_slot);
>> +               sc->tx.queue_removes += removed;
>> +               sc->tx.active_queue_len -= removed;
>> +               sc->tx.avail_queue_len += removed;
>> +               if (sc->tx.avail_queue_len > sc->tx.max_avail_queue_len)
>> +                       sc->tx.max_avail_queue_len = sc->tx.avail_queue_len;
>> +       return (removed);
>> + * Miscellaneous interrupts.
>> +static void
>> +cpsw_intr_rx_thresh(void *arg)
>> +       uint32_t stat = cpsw_read_4(sc, CPSW_WR_C_RX_THRESH_STAT(0));
>> +       CPSW_DEBUGF(("stat=%x", stat));
>> +       cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 0);
>> +static void
>> +cpsw_intr_misc_host_error(struct cpsw_softc *sc)
>> +       uint32_t intstat;
>> +       uint32_t dmastat;
>> +       int txerr, rxerr, txchan, rxchan;
>> +       printf("\n\n");
>> +           "HOST ERROR:  PROGRAMMING ERROR DETECTED BY HARDWARE\n");
>> +       printf("\n\n");
>> +       intstat = cpsw_read_4(sc, CPSW_CPDMA_DMA_INTSTAT_MASKED);
>> +       device_printf(sc->dev, "CPSW_CPDMA_DMA_INTSTAT_MASKED=0x%x\n", intstat);
>> +       dmastat = cpsw_read_4(sc, CPSW_CPDMA_DMASTATUS);
>> +       device_printf(sc->dev, "CPSW_CPDMA_DMASTATUS=0x%x\n", dmastat);
>> +       txerr = (dmastat >> 20) & 15;
>> +       txchan = (dmastat >> 16) & 7;
>> +       rxerr = (dmastat >> 12) & 15;
>> +       rxchan = (dmastat >> 8) & 7;
>> +       switch (txerr) {
>> +       case 0: break;
>> +       case 1: printf("SOP error on TX channel %d\n", txchan);
>> +               break;
>> +       case 2: printf("Ownership bit not set on SOP buffer on TX channel %d\n", txchan);
>> +               break;
>> +       case 3: printf("Zero Next Buffer but not EOP on TX channel %d\n", txchan);
>> +               break;
>> +       case 4: printf("Zero Buffer Pointer on TX channel %d\n", txchan);
>> +               break;
>> +       case 5: printf("Zero Buffer Length on TX channel %d\n", txchan);
>> +               break;
>> +       case 6: printf("Packet length error on TX channel %d\n", txchan);
>> +               break;
>> +       default: printf("Unknown error on TX channel %d\n", txchan);
>> +               break;
>> +       if (txerr != 0) {
>> +               printf("CPSW_CPDMA_TX%d_HDP=0x%x\n",
>> +                   txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_HDP(txchan)));
>> +               printf("CPSW_CPDMA_TX%d_CP=0x%x\n",
>> +                   txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_CP(txchan)));
>> +               cpsw_dump_queue(sc, &sc->tx.active);
>> +       switch (rxerr) {
>> +       case 0: break;
>> +       case 2: printf("Ownership bit not set on RX channel %d\n", rxchan);
>> +               break;
>> +       case 4: printf("Zero Buffer Pointer on RX channel %d\n", rxchan);
>> +               break;
>> +       case 5: printf("Zero Buffer Length on RX channel %d\n", rxchan);
>> +               break;
>> +       case 6: printf("Buffer offset too big on RX channel %d\n", rxchan);
>> +               break;
>> +       default: printf("Unknown RX error on RX channel %d\n", rxchan);
>> +               break;
>> +       if (rxerr != 0) {
>> +               printf("CPSW_CPDMA_RX%d_HDP=0x%x\n",
>> +                   rxchan, cpsw_read_4(sc,CPSW_CPDMA_RX_HDP(rxchan)));
>> +               printf("CPSW_CPDMA_RX%d_CP=0x%x\n",
>> +                   rxchan, cpsw_read_4(sc, CPSW_CPDMA_RX_CP(rxchan)));
>> +               cpsw_dump_queue(sc, &sc->rx.active);
>> +       printf("\nALE Table\n");
>> +       cpsw_ale_dump_table(sc);
>> +       // XXX do something useful here??
>> +       panic("CPSW HOST ERROR INTERRUPT");
>> +       // Suppress this interrupt in the future.
>> +       cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_CLEAR, intstat);
>> +       printf("XXX HOST ERROR INTERRUPT SUPPRESSED\n");
>> +       // The watchdog will probably reset the controller
>> +       // in a little while.  It will probably fail again.
>> +static void
>> +cpsw_intr_misc(void *arg)
>> +       uint32_t stat = cpsw_read_4(sc, CPSW_WR_C_MISC_STAT(0));
>> +       if (stat & 16)
>> +               CPSW_DEBUGF(("Time sync event interrupt unimplemented"));
>> +#ifndef __rtems__
>> +       if (stat & 8)
>> +#endif
>> +       if (stat & 4)
>> +               cpsw_intr_misc_host_error(sc);
>> +       if (stat & 2)
>> +               CPSW_DEBUGF(("MDIO link change interrupt unimplemented"));
>> +       if (stat & 1)
>> +               CPSW_DEBUGF(("MDIO operation completed interrupt unimplemented"));
>> +       cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 3);
>> + * Periodic Checks and Watchdog.
>> +static void
>> +cpsw_tick(void *msc)
>> +       struct cpsw_softc *sc = msc;
>> +       /* Check for TX timeout */
>> +       cpsw_tx_watchdog(sc);
>> +       /* Check for media type change */
>> +       mii_tick(sc->mii);
>> +       if(sc->cpsw_media_status != sc->mii->mii_media.ifm_media) {
>> +               printf("%s: media type changed (ifm_media=%x)\n", __func__,
>> +                       sc->mii->mii_media.ifm_media);
>> +               cpsw_ifmedia_upd(sc->ifp);
>> +       /* Schedule another timeout one second from now */
>> +static void
>> +cpsw_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
>> +       struct mii_data *mii;
>> +       CPSW_TX_LOCK(sc);
>> +       mii = sc->mii;
>> +       mii_pollstat(mii);
>> +       ifmr->ifm_active = mii->mii_media_active;
>> +       ifmr->ifm_status = mii->mii_media_status;
>> +static int
>> +cpsw_ifmedia_upd(struct ifnet *ifp)
>> +               sc->cpsw_media_status = sc->mii->mii_media.ifm_media;
>> +               mii_mediachg(sc->mii);
>> +       return (0);
>> +static void
>> +cpsw_tx_watchdog_full_reset(struct cpsw_softc *sc)
>> +       cpsw_debugf_head("CPSW watchdog");
>> +       if_printf(sc->ifp, "watchdog timeout\n");
>> +static void
>> +cpsw_tx_watchdog(struct cpsw_softc *sc)
>> +       if (sc->tx.active_queue_len == 0 || (ifp->if_flags & IFF_UP) == 0 ||
>> +           (ifp->if_drv_flags & IFF_DRV_RUNNING) == 0 || !sc->tx.running) {
>> +               sc->watchdog.timer = 0; /* Nothing to do. */
>> +       } else if (sc->tx.queue_removes > sc->tx.queue_removes_at_last_tick) {
>> +               sc->watchdog.timer = 0;  /* Stuff done while we weren't looking. */
>> +       } else if (cpsw_tx_dequeue(sc) > 0) {
>> +               sc->watchdog.timer = 0;  /* We just did something. */
>> +       } else {
>> +               /* There was something to do but it didn't get done. */
>> +               ++sc->watchdog.timer;
>> +               if (sc->watchdog.timer > 2) {
>> +#ifndef __rtems__
>> +                       if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
>> +#else
>> +                        sc->ifp->if_oerrors++;
>> +#endif
>> +                       ++sc->watchdog.resets;
>> +                       cpsw_tx_watchdog_full_reset(sc);
>> +       sc->tx.queue_removes_at_last_tick = sc->tx.queue_removes;
>> + * ALE support routines.
>> +static void
>> +cpsw_ale_read_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
>> +       cpsw_write_4(sc, CPSW_ALE_TBLCTL, idx & 1023);
>> +       ale_entry[0] = cpsw_read_4(sc, CPSW_ALE_TBLW0);
>> +       ale_entry[1] = cpsw_read_4(sc, CPSW_ALE_TBLW1);
>> +       ale_entry[2] = cpsw_read_4(sc, CPSW_ALE_TBLW2);
>> +static void
>> +cpsw_ale_write_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
>> +       cpsw_write_4(sc, CPSW_ALE_TBLW0, ale_entry[0]);
>> +       cpsw_write_4(sc, CPSW_ALE_TBLW1, ale_entry[1]);
>> +       cpsw_write_4(sc, CPSW_ALE_TBLW2, ale_entry[2]);
>> +       cpsw_write_4(sc, CPSW_ALE_TBLCTL, 1 << 31 | (idx & 1023));
>> +static int
>> +cpsw_ale_remove_all_mc_entries(struct cpsw_softc *sc)
>> +       int i;
>> +       uint32_t ale_entry[3];
>> +       /* First two entries are link address and broadcast. */
>> +       for (i = 2; i < CPSW_MAX_ALE_ENTRIES; i++) {
>> +               cpsw_ale_read_entry(sc, i, ale_entry);
>> +               if (((ale_entry[1] >> 28) & 3) == 1 && /* Address entry */
>> +                   ((ale_entry[1] >> 8) & 1) == 1) { /* MCast link addr */
>> +                       ale_entry[0] = ale_entry[1] = ale_entry[2] = 0;
>> +                       cpsw_ale_write_entry(sc, i, ale_entry);
>> +       return CPSW_MAX_ALE_ENTRIES;
>> +static int
>> +cpsw_ale_mc_entry_set(struct cpsw_softc *sc, uint8_t portmap, uint8_t *mac)
>> +       int free_index = -1, matching_index = -1, i;
>> +       /* Find a matching entry or a free entry. */
>> +       for (i = 0; i < CPSW_MAX_ALE_ENTRIES; i++) {
>> +               /* Entry Type[61:60] is 0 for free entry */
>> +               if (free_index < 0 && ((ale_entry[1] >> 28) & 3) == 0) {
>> +                       free_index = i;
>> +               if ((((ale_entry[1] >> 8) & 0xFF) == mac[0]) &&
>> +                   (((ale_entry[1] >> 0) & 0xFF) == mac[1]) &&
>> +                   (((ale_entry[0] >>24) & 0xFF) == mac[2]) &&
>> +                   (((ale_entry[0] >>16) & 0xFF) == mac[3]) &&
>> +                   (((ale_entry[0] >> 8) & 0xFF) == mac[4]) &&
>> +                   (((ale_entry[0] >> 0) & 0xFF) == mac[5])) {
>> +                       matching_index = i;
>> +                       break;
>> +       if (matching_index < 0) {
>> +               if (free_index < 0)
>> +                       return (ENOMEM);
>> +               i = free_index;
>> +       /* Set MAC address */
>> +       ale_entry[0] = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5];
>> +       ale_entry[1] = mac[0] << 8 | mac[1];
>> +       /* Entry type[61:60] is addr entry(1), Mcast fwd state[63:62] is fw(3)*/
>> +       ale_entry[1] |= 0xd0 << 24;
>> +       /* Set portmask [68:66] */
>> +       ale_entry[2] = (portmap & 7) << 2;
>> +       return 0;
>> +static void
>> +cpsw_ale_dump_table(struct cpsw_softc *sc) {
>> +       int i;
>> +               if (ale_entry[0] || ale_entry[1] || ale_entry[2]) {
>> +                       printf("ALE[%4u] %08x %08x %08x ", i, ale_entry[0],
>> +                               ale_entry[1], ale_entry[2]);
>> +                       printf("mac: %02x:%02x:%02x:%02x:%02x:%02x ",
>> +                               (ale_entry[1] >> 8) & 0xFF,
>> +                               (ale_entry[1] >> 0) & 0xFF,
>> +                               (ale_entry[0] >>24) & 0xFF,
>> +                               (ale_entry[0] >>16) & 0xFF,
>> +                               (ale_entry[0] >> 8) & 0xFF,
>> +                               (ale_entry[0] >> 0) & 0xFF);
>> +                       printf(((ale_entry[1] >> 8) & 1) ? "mcast " : "ucast ");
>> +                       printf("type: %u ", (ale_entry[1] >> 28) & 3);
>> +                       printf("port: %u ", (ale_entry[2] >> 2) & 7);
>> +                       printf("\n");
>> +       printf("\n");
>> +static int
>> +cpsw_ale_update_addresses(struct cpsw_softc *sc, int purge)
>> +       uint8_t *mac;
>> +       struct ifmultiaddr *ifma;
>> +       int i;
>> +       /* Route incoming packets for our MAC address to Port 0 (host). */
>> +       /* For simplicity, keep this entry at table index 0 in the ALE. */
>> +        if_addr_rlock(ifp);
>> +       mac = LLADDR((struct sockaddr_dl *)ifp->if_addr->ifa_addr);
>> +       ale_entry[1] = 0x10 << 24 | mac[0] << 8 | mac[1]; /* addr entry + mac */
>> +       ale_entry[2] = 0; /* port = 0 */
>> +       cpsw_ale_write_entry(sc, 0, ale_entry);
>> +       /* Set outgoing MAC Address for Ports 1 and 2. */
>> +       for (i = 1; i < 3; ++i) {
>> +               cpsw_write_4(sc, CPSW_PORT_P_SA_HI(i),
>> +                   mac[3] << 24 | mac[2] << 16 | mac[1] << 8 | mac[0]);
>> +               cpsw_write_4(sc, CPSW_PORT_P_SA_LO(i),
>> +                   mac[5] << 8 | mac[4]);
>> +        if_addr_runlock(ifp);
>> +       /* Keep the broadcast address at table entry 1. */
>> +       ale_entry[0] = 0xffffffff; /* Lower 32 bits of MAC */
>> +       ale_entry[1] = 0xd000ffff; /* FW (3 << 30), Addr entry (1 << 24), upper 16 bits of Mac */
>> +       ale_entry[2] = 0x0000001c; /* Forward to all ports */
>> +       cpsw_ale_write_entry(sc, 1, ale_entry);
>> +       /* SIOCDELMULTI doesn't specify the particular address
>> +          being removed, so we have to remove all and rebuild. */
>> +       if (purge)
>> +               cpsw_ale_remove_all_mc_entries(sc);
>> +        /* Set other multicast addrs desired. */
>> +        if_maddr_rlock(ifp);
>> +        TAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
>> +                if (ifma->ifma_addr->sa_family != AF_LINK)
>> +                        continue;
>> +               cpsw_ale_mc_entry_set(sc, 7,
>> +                   LLADDR((struct sockaddr_dl *)ifma->ifma_addr));
>> +        if_maddr_runlock(ifp);
>> +       return (0);
>> + * Statistics and Sysctls.
>> +#if 0
>> +static void
>> +cpsw_stats_dump(struct cpsw_softc *sc)
>> +       int i;
>> +       uint32_t r;
>> +       for (i = 0; i < CPSW_SYSCTL_COUNT; ++i) {
>> +               r = cpsw_read_4(sc, CPSW_STATS_OFFSET +
>> +                   cpsw_stat_sysctls[i].reg);
>> +               CPSW_DEBUGF(("%s: %ju + %u = %ju", cpsw_stat_sysctls[i].oid,
>> +                            (intmax_t)sc->shadow_stats[i], r,
>> +                            (intmax_t)sc->shadow_stats[i] + r));
>> +#endif
>> +#ifndef __rtems__
>> +static void
>> +cpsw_stats_collect(struct cpsw_softc *sc)
>> +       int i;
>> +       uint32_t r;
>> +       CPSW_DEBUGF(("Controller shadow statistics updated."));
>> +               sc->shadow_stats[i] += r;
>> +               cpsw_write_4(sc, CPSW_STATS_OFFSET + cpsw_stat_sysctls[i].reg, r);
>> +static int
>> +cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS)
>> +       struct cpsw_softc *sc;
>> +       struct cpsw_stat *stat;
>> +       uint64_t result;
>> +       sc = (struct cpsw_softc *)arg1;
>> +       stat = &cpsw_stat_sysctls[oidp->oid_number];
>> +       result = sc->shadow_stats[oidp->oid_number];
>> +       result += cpsw_read_4(sc, CPSW_STATS_OFFSET + stat->reg);
>> +       return (sysctl_handle_64(oidp, &result, 0, req));
>> +static int
>> +cpsw_stat_attached(SYSCTL_HANDLER_ARGS)
>> +       struct bintime t;
>> +       unsigned result;
>> +       getbinuptime(&t);
>> +       bintime_sub(&t, &sc->attach_uptime);
>> +       result = t.sec;
>> +       return (sysctl_handle_int(oidp, &result, 0, req));
>> +static int
>> +cpsw_stat_uptime(SYSCTL_HANDLER_ARGS)
>> +       struct bintime t;
>> +       unsigned result;
>> +       if (sc->ifp->if_drv_flags & IFF_DRV_RUNNING) {
>> +               getbinuptime(&t);
>> +               bintime_sub(&t, &sc->init_uptime);
>> +               result = t.sec;
>> +       } else
>> +               result = 0;
>> +static void
>> +cpsw_add_queue_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node, struct cpsw_queue *queue)
>> +       struct sysctl_oid_list *parent;
>> +       parent = SYSCTL_CHILDREN(node);
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "totalBuffers",
>> +           CTLFLAG_RD, &queue->queue_slots, 0,
>> +           "Total buffers currently assigned to this queue");
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "activeBuffers",
>> +           CTLFLAG_RD, &queue->active_queue_len, 0,
>> +           "Buffers currently registered with hardware controller");
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxActiveBuffers",
>> +           CTLFLAG_RD, &queue->max_active_queue_len, 0,
>> +           "Max value of activeBuffers since last driver reset");
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "availBuffers",
>> +           CTLFLAG_RD, &queue->avail_queue_len, 0,
>> +           "Buffers allocated to this queue but not currently "
>> +           "registered with hardware controller");
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxAvailBuffers",
>> +           CTLFLAG_RD, &queue->max_avail_queue_len, 0,
>> +           "Max value of availBuffers since last driver reset");
>> +       SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalEnqueued",
>> +           CTLFLAG_RD, &queue->queue_adds, 0,
>> +           "Total buffers added to queue");
>> +       SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalDequeued",
>> +           CTLFLAG_RD, &queue->queue_removes, 0,
>> +           "Total buffers removed from queue");
>> +       SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "longestChain",
>> +           CTLFLAG_RD, &queue->longest_chain, 0,
>> +           "Max buffers used for a single packet");
>> +static void
>> +cpsw_add_watchdog_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node, struct cpsw_softc *sc)
>> +       SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "resets",
>> +           CTLFLAG_RD, &sc->watchdog.resets, 0,
>> +           "Total number of watchdog resets");
>> +static void
>> +cpsw_add_sysctls(struct cpsw_softc *sc)
>> +       struct sysctl_ctx_list *ctx;
>> +       struct sysctl_oid *stats_node, *queue_node, *node;
>> +       struct sysctl_oid_list *parent, *stats_parent, *queue_parent;
>> +       int i;
>> +       ctx = device_get_sysctl_ctx(sc->dev);
>> +       parent = SYSCTL_CHILDREN(device_get_sysctl_tree(sc->dev));
>> +       SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "attachedSecs",
>> +           CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_attached, "IU",
>> +           "Time since driver attach");
>> +       SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "uptime",
>> +           CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_uptime, "IU",
>> +           "Seconds since driver init");
>> +       stats_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "stats",
>> +                                    CTLFLAG_RD, NULL, "CPSW Statistics");
>> +       stats_parent = SYSCTL_CHILDREN(stats_node);
>> +               SYSCTL_ADD_PROC(ctx, stats_parent, i,
>> +                               cpsw_stat_sysctls[i].oid,
>> +                               CTLTYPE_U64 | CTLFLAG_RD, sc, 0,
>> +                               cpsw_stats_sysctl, "IU",
>> +                               cpsw_stat_sysctls[i].oid);
>> +       queue_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "queue",
>> +           CTLFLAG_RD, NULL, "CPSW Queue Statistics");
>> +       queue_parent = SYSCTL_CHILDREN(queue_node);
>> +       node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "tx",
>> +           CTLFLAG_RD, NULL, "TX Queue Statistics");
>> +       cpsw_add_queue_sysctls(ctx, node, &sc->tx);
>> +       node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "rx",
>> +           CTLFLAG_RD, NULL, "RX Queue Statistics");
>> +       cpsw_add_queue_sysctls(ctx, node, &sc->rx);
>> +       node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "watchdog",
>> +           CTLFLAG_RD, NULL, "Watchdog Statistics");
>> +       cpsw_add_watchdog_sysctls(ctx, node, sc);
>> +#endif
>> diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswreg.h b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
>> index 0000000..46f8417
>> --- /dev/null
>> +++ b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
>> @@ -0,0 +1,137 @@
>> + * are met:
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef        _IF_CPSWREG_H
>> +#define        _IF_CPSWREG_H
>> +#define CPSW_SS_OFFSET                 0x0000
>> +#define CPSW_SS_IDVER                  (CPSW_SS_OFFSET + 0x00)
>> +#define CPSW_SS_SOFT_RESET             (CPSW_SS_OFFSET + 0x08)
>> +#define CPSW_SS_STAT_PORT_EN           (CPSW_SS_OFFSET + 0x0C)
>> +#define CPSW_SS_PTYPE                  (CPSW_SS_OFFSET + 0x10)
>> +#define        CPSW_SS_FLOW_CONTROL            (CPSW_SS_OFFSET + 0x24)
>> +#define CPSW_PORT_OFFSET               0x0100
>> +#define        CPSW_PORT_P_MAX_BLKS(p)         (CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
>> +#define        CPSW_PORT_P_BLK_CNT(p)          (CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
>> +#define CPSW_PORT_P_TX_PRI_MAP(p)      (CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
>> +#define CPSW_PORT_P0_CPDMA_TX_PRI_MAP  (CPSW_PORT_OFFSET + 0x01C)
>> +#define CPSW_PORT_P0_CPDMA_RX_CH_MAP   (CPSW_PORT_OFFSET + 0x020)
>> +#define CPSW_PORT_P_SA_LO(p)           (CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
>> +#define CPSW_PORT_P_SA_HI(p)           (CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
>> +#define CPSW_CPDMA_OFFSET              0x0800
>> +#define CPSW_CPDMA_TX_CONTROL          (CPSW_CPDMA_OFFSET + 0x04)
>> +#define CPSW_CPDMA_TX_TEARDOWN         (CPSW_CPDMA_OFFSET + 0x08)
>> +#define CPSW_CPDMA_RX_CONTROL          (CPSW_CPDMA_OFFSET + 0x14)
>> +#define CPSW_CPDMA_RX_TEARDOWN         (CPSW_CPDMA_OFFSET + 0x18)
>> +#define CPSW_CPDMA_SOFT_RESET          (CPSW_CPDMA_OFFSET + 0x1c)
>> +#define CPSW_CPDMA_DMACONTROL          (CPSW_CPDMA_OFFSET + 0x20)
>> +#define CPSW_CPDMA_DMASTATUS           (CPSW_CPDMA_OFFSET + 0x24)
>> +#define CPSW_CPDMA_RX_BUFFER_OFFSET    (CPSW_CPDMA_OFFSET + 0x28)
>> +#define CPSW_CPDMA_TX_INTSTAT_RAW      (CPSW_CPDMA_OFFSET + 0x80)
>> +#define CPSW_CPDMA_TX_INTSTAT_MASKED   (CPSW_CPDMA_OFFSET + 0x84)
>> +#define CPSW_CPDMA_TX_INTMASK_SET      (CPSW_CPDMA_OFFSET + 0x88)
>> +#define CPSW_CPDMA_TX_INTMASK_CLEAR    (CPSW_CPDMA_OFFSET + 0x8C)
>> +#define CPSW_CPDMA_CPDMA_EOI_VECTOR    (CPSW_CPDMA_OFFSET + 0x94)
>> +#define CPSW_CPDMA_RX_INTSTAT_RAW      (CPSW_CPDMA_OFFSET + 0xA0)
>> +#define CPSW_CPDMA_RX_INTSTAT_MASKED   (CPSW_CPDMA_OFFSET + 0xA4)
>> +#define CPSW_CPDMA_RX_INTMASK_SET      (CPSW_CPDMA_OFFSET + 0xA8)
>> +#define CPSW_CPDMA_RX_INTMASK_CLEAR    (CPSW_CPDMA_OFFSET + 0xAc)
>> +#define CPSW_CPDMA_DMA_INTSTAT_RAW     (CPSW_CPDMA_OFFSET + 0xB0)
>> +#define CPSW_CPDMA_DMA_INTSTAT_MASKED  (CPSW_CPDMA_OFFSET + 0xB4)
>> +#define CPSW_CPDMA_DMA_INTMASK_SET     (CPSW_CPDMA_OFFSET + 0xB8)
>> +#define CPSW_CPDMA_DMA_INTMASK_CLEAR   (CPSW_CPDMA_OFFSET + 0xBC)
>> +#define CPSW_CPDMA_RX_FREEBUFFER(p)    (CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
>> +#define CPSW_STATS_OFFSET              0x0900
>> +#define CPSW_STATERAM_OFFSET           0x0A00
>> +#define CPSW_CPDMA_TX_HDP(p)           (CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
>> +#define CPSW_CPDMA_RX_HDP(p)           (CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
>> +#define CPSW_CPDMA_TX_CP(p)            (CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
>> +#define CPSW_CPDMA_RX_CP(p)            (CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
>> +#define CPSW_CPTS_OFFSET               0x0C00
>> +#define CPSW_ALE_OFFSET                        0x0D00
>> +#define CPSW_ALE_CONTROL               (CPSW_ALE_OFFSET + 0x08)
>> +#define CPSW_ALE_TBLCTL                        (CPSW_ALE_OFFSET + 0x20)
>> +#define CPSW_ALE_TBLW2                 (CPSW_ALE_OFFSET + 0x34)
>> +#define CPSW_ALE_TBLW1                 (CPSW_ALE_OFFSET + 0x38)
>> +#define CPSW_ALE_TBLW0                 (CPSW_ALE_OFFSET + 0x3C)
>> +#define CPSW_ALE_PORTCTL(p)            (CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
>> +/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
>> +#define CPSW_SL_OFFSET                 0x0D80
>> +#define CPSW_SL_MACCONTROL(p)          (CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
>> +#define CPSW_SL_MACSTATUS(p)           (CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
>> +#define CPSW_SL_SOFT_RESET(p)          (CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
>> +#define CPSW_SL_RX_MAXLEN(p)           (CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
>> +#define CPSW_SL_RX_PAUSE(p)            (CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
>> +#define CPSW_SL_TX_PAUSE(p)            (CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
>> +#define CPSW_SL_RX_PRI_MAP(p)          (CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
>> +#define MDIO_OFFSET                    0x1000
>> +#define MDIOCONTROL                    (MDIO_OFFSET + 0x04)
>> +#define MDIOUSERACCESS0                        (MDIO_OFFSET + 0x80)
>> +#define MDIOUSERPHYSEL0                        (MDIO_OFFSET + 0x84)
>> +#define CPSW_WR_OFFSET                 0x1200
>> +#define CPSW_WR_SOFT_RESET             (CPSW_WR_OFFSET + 0x04)
>> +#define CPSW_WR_CONTROL                        (CPSW_WR_OFFSET + 0x08)
>> +#define CPSW_WR_INT_CONTROL            (CPSW_WR_OFFSET + 0x0c)
>> +#define CPSW_WR_C_RX_THRESH_EN(p)      (CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
>> +#define CPSW_WR_C_RX_EN(p)             (CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
>> +#define CPSW_WR_C_TX_EN(p)             (CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
>> +#define CPSW_WR_C_MISC_EN(p)           (CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
>> +#define CPSW_WR_C_RX_THRESH_STAT(p)    (CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
>> +#define CPSW_WR_C_RX_STAT(p)           (CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
>> +#define CPSW_WR_C_TX_STAT(p)           (CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
>> +#define CPSW_WR_C_MISC_STAT(p)         (CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
>> +#define CPSW_CPPI_RAM_OFFSET           0x2000
>> +#define        CPSW_CPPI_RAM_SIZE              0x2000
>> +#define CPDMA_BD_SOP           (1<<15)
>> +#define CPDMA_BD_EOP           (1<<14)
>> +#define CPDMA_BD_OWNER         (1<<13)
>> +#define CPDMA_BD_EOQ           (1<<12)
>> +#define CPDMA_BD_TDOWNCMPLT    (1<<11)
>> +#define CPDMA_BD_PKT_ERR_MASK  (3<< 4)
>> +struct cpsw_cpdma_bd {
>> +       volatile uint32_t next;
>> +       volatile uint32_t bufptr;
>> +       volatile uint16_t buflen;
>> +       volatile uint16_t bufoff;
>> +       volatile uint16_t pktlen;
>> +       volatile uint16_t flags;
>> +#endif /*_IF_CPSWREG_H */
>> diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswvar.h b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
>> new file mode 100644
>> index 0000000..7ca640f
>> --- /dev/null
>> +++ b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
>> @@ -0,0 +1,126 @@
>> + * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
>> + * All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef        _IF_CPSWVAR_H
>> +#define        _IF_CPSWVAR_H
>> +#define CPSW_INTR_COUNT                4
>> +/* MII BUS  */
>> +#define CPSW_MIIBUS_RETRIES    5
>> +#define CPSW_MIIBUS_DELAY      1000
>> +#define CPSW_MAX_ALE_ENTRIES   1024
>> +#define CPSW_SYSCTL_COUNT 34
>> +struct cpsw_slot {
>> +       uint32_t bd_offset;  /* Offset of corresponding BD within CPPI RAM. */
>> +       bus_dmamap_t dmamap;
>> +       struct mbuf *mbuf;
>> +       STAILQ_ENTRY(cpsw_slot) next;
>> +STAILQ_HEAD(cpsw_slots, cpsw_slot);
>> +struct cpsw_queue {
>> +       struct mtx      lock;
>> +       int             running;
>> +       struct cpsw_slots active;
>> +       struct cpsw_slots avail;
>> +       uint32_t        queue_adds; /* total bufs added */
>> +       uint32_t        queue_removes; /* total bufs removed */
>> +       uint32_t        queue_removes_at_last_tick; /* Used by watchdog */
>> +       int             queue_slots;
>> +       int             active_queue_len;
>> +       int             max_active_queue_len;
>> +       int             avail_queue_len;
>> +       int             max_avail_queue_len;
>> +       int             longest_chain; /* Largest # segments in a single packet. */
>> +       int             hdp_offset;
>> +struct cpsw_softc {
>> +#ifndef __rtems__
>> +       phandle_t       node;
>> +#endif
>> +       device_t        dev;
>> +       struct bintime  attach_uptime; /* system uptime when attach happened. */
>> +       struct bintime  init_uptime; /* system uptime when init happened. */
>> +       /* TODO: We should set up a child structure for each port;
>> +          store mac, phy information, etc, in that structure. */
>> +       uint8_t         mac_addr[ETHER_ADDR_LEN];
>> +       device_t        miibus;
>> +       /* We expect 1 memory resource and 4 interrupts from the device tree. */
>> +       struct resource *res[1 + CPSW_INTR_COUNT];
>> +       /* Interrupts get recorded here as we initialize them. */
>> +       /* Interrupt teardown just walks this list. */
>> +       struct {
>> +               struct resource *res;
>> +               void            *ih_cookie;
>> +               const char *description;
>> +       } interrupts[CPSW_INTR_COUNT];
>> +       int             interrupt_count;
>> +       uint32_t        cpsw_if_flags;
>> +       int             cpsw_media_status;
>> +       struct {
>> +               int resets;
>> +               int timer;
>> +               struct callout  callout;
>> +       } watchdog;
>> +       bus_dma_tag_t   mbuf_dtag;
>> +       /* An mbuf full of nulls for TX padding. */
>> +       bus_dmamap_t null_mbuf_dmamap;
>> +       struct mbuf *null_mbuf;
>> +       bus_addr_t null_mbuf_paddr;
>> +       /* RX and TX buffer tracking */
>> +       struct cpsw_queue rx, tx;
>> +       /* 64-bit versions of 32-bit hardware statistics counters */
>> +       uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
>> +       /* CPPI STATERAM has 512 slots for building TX/RX queues. */
>> +       /* TODO: Size here supposedly varies with different versions
>> +          of the controller.  Check DaVinci specs and find a good
>> +          way to adjust this.  One option is to have a separate
>> +          Device Tree parameter for number slots; another option
>> +          is to calculate it from the memory size in the device tree. */
>> +       struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
>> +#endif /*_IF_CPSWVAR_H */
>> diff --git a/freebsd/sys/dev/mii/smscphy.c b/freebsd/sys/dev/mii/smscphy.c
>> index 0000000..85893b2
>> --- /dev/null
>> +++ b/freebsd/sys/dev/mii/smscphy.c
>> @@ -0,0 +1,227 @@
>> +#include <machine/rtems-bsd-kernel-space.h>
>> + * Copyright (c) 2006 Benno Rice.  All rights reserved.
>> + * are met:
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
>> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
>> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
>> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
>> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
>> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>> + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>> + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
>> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> +#include <sys/cdefs.h>
>> +__FBSDID("$FreeBSD$");
>> + * Driver for the SMSC LAN8710A
>> +#include <sys/param.h>
>> +#include <sys/systm.h>
>> +#include <sys/kernel.h>
>> +#include <sys/socket.h>
>> +#include <sys/errno.h>
>> +#include <sys/module.h>
>> +#include <sys/bus.h>
>> +#include <sys/malloc.h>
>> +#include <machine/bus.h>
>> +#include <net/if.h>
>> +#include <net/if_media.h>
>> +#include <dev/mii/mii.h>
>> +#include <dev/mii/miivar.h>
>> +#include "miidevs.h"
>> +#include "miibus_if.h"
>> +static int     smscphy_probe(device_t);
>> +static int     smscphy_attach(device_t);
>> +static int     smscphy_service(struct mii_softc *, struct mii_data *, int);
>> +static void    smscphy_auto(struct mii_softc *, int);
>> +static void    smscphy_status(struct mii_softc *);
>> +static device_method_t smscphy_methods[] = {
>> +       /* device interface */
>> +       DEVMETHOD(device_probe,         smscphy_probe),
>> +       DEVMETHOD(device_attach,        smscphy_attach),
>> +       DEVMETHOD(device_detach,        mii_phy_detach),
>> +       DEVMETHOD(device_shutdown,      bus_generic_shutdown),
>> +       DEVMETHOD_END
>> +static devclass_t smscphy_devclass;
>> +static driver_t smscphy_driver = {
>> +       "smscphy",
>> +       smscphy_methods,
>> +       sizeof(struct mii_softc)
>> +DRIVER_MODULE(smscphy, miibus, smscphy_driver, smscphy_devclass, 0, 0);
>> +static const struct mii_phydesc smscphys[] = {
>> +       MII_PHY_DESC(SMC, LAN8710A),
>> +       MII_PHY_END
>> +static const struct mii_phy_funcs smscphy_funcs = {
>> +       smscphy_service,
>> +       smscphy_status,
>> +       mii_phy_reset
>> +static int
>> +smscphy_probe(device_t dev)
>> +       return (mii_phy_dev_probe(dev, smscphys, BUS_PROBE_DEFAULT));
>> +static int
>> +smscphy_attach(device_t dev)
>> +       struct mii_softc *sc;
>> +       const struct mii_phy_funcs *mpf;
>> +       sc = device_get_softc(dev);
>> +       mpf = &smscphy_funcs;
>> +       mii_phy_dev_attach(dev, MIIF_NOISOLATE | MIIF_NOMANPAUSE, mpf, 1);
>> +       mii_phy_setmedia(sc);
>> +       return (0);
>> +static int
>> +smscphy_service(struct mii_softc *sc, struct mii_data *mii, int cmd)
>> +        struct ifmedia_entry *ife;
>> +        int    reg;
>> +       ife = mii->mii_media.ifm_cur;
>> +        switch (cmd) {
>> +        case MII_POLLSTAT:
>> +                break;
>> +        case MII_MEDIACHG:
>> +               switch (IFM_SUBTYPE(ife->ifm_media)) {
>> +               case IFM_AUTO:
>> +                       smscphy_auto(sc, ife->ifm_media);
>> +                       break;
>> +               default:
>> +                       break;
>> +                break;
>> +        case MII_TICK:
>> +               if (IFM_SUBTYPE(ife->ifm_media) != IFM_AUTO) {
>> +                       break;
>> +               /* I have no idea why BMCR_ISO gets set. */
>> +               reg = PHY_READ(sc, MII_BMCR);
>> +               if (reg & BMCR_ISO) {
>> +                       PHY_WRITE(sc, MII_BMCR, reg & ~BMCR_ISO);
>> +               reg = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
>> +               if (reg & BMSR_LINK) {
>> +                       sc->mii_ticks = 0;
>> +                       break;
>> +               if (++sc->mii_ticks <= MII_ANEGTICKS) {
>> +                       break;
>> +               PHY_RESET(sc);
>> +                break;
>> +        /* Update the media status. */
>> +        PHY_STATUS(sc);
>> +        /* Callback if something changed. */
>> +        mii_phy_update(sc, cmd);
>> +        return (0);
>> +static void
>> +smscphy_auto(struct mii_softc *sc, int media)
>> +       uint16_t        anar;
>> +       anar = BMSR_MEDIA_TO_ANAR(sc->mii_capabilities) | ANAR_CSMA;
>> +       if ((media & IFM_FLOW) != 0 || (sc->mii_flags & MIIF_FORCEPAUSE) != 0)
>> +               anar |= ANAR_FC;
>> +       PHY_WRITE(sc, MII_ANAR, anar);
>> +       /* Apparently this helps. */
>> +       anar = PHY_READ(sc, MII_ANAR);
>> +       PHY_WRITE(sc, MII_BMCR, BMCR_AUTOEN | BMCR_STARTNEG);
>> +static void
>> +smscphy_status(struct mii_softc *sc)
>> +       uint32_t bmcr, bmsr, status;
>> +       mii = sc->mii_pdata;
>> +       mii->mii_media_status = IFM_AVALID;
>> +       mii->mii_media_active = IFM_ETHER;
>> +       bmsr = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
>> +       if ((bmsr & BMSR_LINK) != 0)
>> +               mii->mii_media_status |= IFM_ACTIVE;
>> +       bmcr = PHY_READ(sc, MII_BMCR);
>> +       if ((bmcr & BMCR_ISO) != 0) {
>> +               mii->mii_media_active |= IFM_NONE;
>> +               mii->mii_media_status = 0;
>> +               return;
>> +       if ((bmcr & BMCR_LOOP) != 0)
>> +               mii->mii_media_active |= IFM_LOOP;
>> +       if ((bmcr & BMCR_AUTOEN) != 0) {
>> +               if ((bmsr & BMSR_ACOMP) == 0) {
>> +                       /* Erg, still trying, I guess... */
>> +                       return;
>> +       status = PHY_READ(sc, 0x1F);
>> +       if (status & 0x0008)
>> +               mii->mii_media_active |= IFM_100_TX;
>> +       else
>> +               mii->mii_media_active |= IFM_10_T;
>> +       if (status & 0x0010)
>> +               mii->mii_media_active |= IFM_FDX | mii_phy_flowstatus(sc);
>> +       else
>> +               mii->mii_media_active |= IFM_HDX;
>> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
>> index fcd8775..5b3e811 100644
>> --- a/rtemsbsd/include/bsp/nexus-devices.h
>> +++ b/rtemsbsd/include/bsp/nexus-devices.h
>> @@ -52,6 +52,40 @@ static const rtems_bsd_device_resource smc0_res[] = {
>>  RTEMS_BSD_DEFINE_NEXUS_DEVICE(smc, 0, RTEMS_ARRAY_SIZE(smc0_res),
>>      &smc0_res[0]);
>> +#elif defined(LIBBSP_ARM_BEAGLE_BSP_H)
>> +static const rtems_bsd_device_resource cpsw0_res[] = {
>> +                .type = RTEMS_BSD_RES_MEMORY,
>> +                .start_request = 0,
>> +                .start_actual = 0x4a100000
>> +                .type = RTEMS_BSD_RES_IRQ,
>> +                .start_actual = 0x28
>> +                .start_request = 1,
>> +                .start_actual = 0x29
>> +                .start_request = 2,
>> +                .start_actual = 0x2a
>> +                .start_request = 3,
>> +                .start_actual = 0x2b
>> +RTEMS_BSD_DEFINE_NEXUS_DEVICE(cpsw, 0, RTEMS_ARRAY_SIZE(cpsw0_res),
>> +    &cpsw0_res[0]);
>> +SYSINIT_DRIVER_REFERENCE(smscphy, miibus);
>>  #elif defined(__GENMCF548X_BSP_H)
>>  RTEMS_BSD_DEFINE_NEXUS_DEVICE(fec, 0, 0, NULL);
>> diff --git a/rtemsbsd/include/machine/rtems-bsd-cache.h b/rtemsbsd/include/machine/rtems-bsd-cache.h
>> index b8c4ce7..b8914ec 100644
>> --- a/rtemsbsd/include/machine/rtems-bsd-cache.h
>> +++ b/rtemsbsd/include/machine/rtems-bsd-cache.h
>> @@ -45,7 +45,7 @@
>>  #if defined(LIBBSP_ARM_LPC24XX_BSP_H)
>>    /* No cache */
>>  #elif defined(LIBBSP_ARM_ALTERA_CYCLONE_V_BSP_H) || \
>> -  defined(LIBBSP_ARM_XILINX_ZYNQ_BSP_H)
>> +  defined(LIBBSP_ARM_XILINX_ZYNQ_BSP_H) || defined(LIBBSP_ARM_BEAGLE_BSP_H)
>>    /* With cache, no coherency support in hardware */
>>    #define CPU_DATA_CACHE_ALIGNMENT 32
>>  #elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
>> diff --git a/testsuite/include/rtems/bsd/test/network-config.h.in b/testsuite/include/rtems/bsd/test/network-config.h.in
>> index 30a9c5a..3169e76 100644
>> --- a/testsuite/include/rtems/bsd/test/network-config.h.in
>> +++ b/testsuite/include/rtems/bsd/test/network-config.h.in
>> @@ -42,6 +42,8 @@
>>    #define NET_CFG_INTERFACE_0 "cgem0"
>>    #define NET_CFG_INTERFACE_0 "fec0"
>> +  #define NET_CFG_INTERFACE_0 "cpsw0"
>>  #else
>>    #define NET_CFG_INTERFACE_0 "lo0"
>>  #endif
>> 1.9.1
>> devel mailing list
>> devel at rtems.org
ragu
