[RFC] RTEMS GPIO pin references
André Marques
andre.lousa.marques at gmail.com
Thu Jun 25 18:34:29 UTC 2015
Hello,
(sorry for the long email)
I am currently doing an implementation for a generic RTEMS API, and I
would like to inquire potential users about pin references provided by
the API to user applications.
Most platforms use a "global" pin number to refer to a GPIO pin in
documentation, usually in the form of "GPIO_<number>", but in practice
the pins are organized in banks of pins, meaning that a GPIO driver or
API has to map those pin numbers to a bank-pin pair to correctly refer
to a pin.
Because it can be expensive to query the hardware for the current GPIO
status, and because some information may not be even possible to read
back (e.g.: the raspberry does not store any information on its
registers about the pull-resistors state), it makes sense that an GPIO
API stores/manages the GPIO state during execution.
This state is recorded on a struct per pin, and includes information
such as:
- pin current function;
- interrupt information (i.e.: if interrupts are enabled on the pin, and
if so which kind of interrupt; interrupt handler (or handlers in case of
a shared IRQ line));
- pull-resistor state;
- Gpio utilities (software switch debouncing data; applicational logic
invertion; ...);
- any relevant platform specific data.
An array/matrix of these structures is used, but the issue now is how to
deal with the bank-pin pairs. The reason behind this RFC is to evaluate
how this pair of information should be used/processed. Storing this
information in the above list (which applies to every pin in the
system), knowing that for each bank the bank number is the same (if the
bank has 32 pins, all 32 pins from that bank would waste 32bits of
memory each to store the same information), and the bank-pin pair has to
be previously known by the API to retrieve the pin data in the first
place, is a waste of memory.
However, the API must still have a way of knowing the bank-pin pair,
which can be directly received (the application uses that information
directly to refer to a pin), or calculated from the said "global" pin
reference through a couple of division operations. The problem with the
pin calculations, or dynamic pin mapping, is that it has to be done
every time the API is called, but the applications may want to use the
same pin referencing used by documentation/diagrams, as the BSP can
provide constants such as GPIO_40 or ACTIVITY_LED.
If they are to use the bank-pin pair directly, it would be trickier for
the application developer/user to know which combination to use, or
where to attach wires, so the pin mappings would have to be made
available through some sort of documentation by each BSP.
In this case the applications would use an hardcoded reference to the
pin, and developers/users would use the documentation to know which pin
is being referred.
Input is welcome.
Thank you for your time,
André Marques.
