Results
Saurabh Gadia
gadia at usc.edu
Fri Jun 26 00:43:06 UTC 2015
O(n) is the least that we can have!!
Thanks,
Saurabh Gadia
On Thu, Jun 25, 2015 at 5:39 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> I mean not recursion. just looping till top of stack of held mutexes.
> check this out:
> https://github.com/saurabhgadia4/lock-model/blob/master/rtems/Mutex.java
> -->updateRecPriority() line 143
> Thanks,
> Saurabh Gadia
> On Thu, Jun 25, 2015 at 5:35 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On June 25, 2015 7:33:24 PM CDT, Saurabh Gadia <gadia at usc.edu> wrote:
>> >@joel: It essentially means finding out the highest priority thread (or
>> >ceiling) of any remaining mutex held, right?
>> >If you are talking this in context of nested mutex problem --->
>> >We never go and find the highest priority thread waiting on held mutex.
>> >Inversely highest priority thread will recursively make changes to top
>> >of stack of held mutexes by the holder. We don't search.
>> True recursion? Or implemented with loop?
>> Ok. Still an O(n) operation. Discuss locking on devel@
>> >Thanks,
>> >Saurabh Gadia
>> >On Thu, Jun 25, 2015 at 5:27 PM, Joel Sherrill
>> ><joel.sherrill at oarcorp.com> wrote:
>> >On June 25, 2015 7:23:06 PM CDT, Cyrille Artho
>> ><cyrille.artho at gmail.com> wrote:
>> >>Hi Gedare and all,
>> >>Good news:
>> >>In this morning's discussion, we fixed some remaining issues in the
>> >>model and now got results.
>> >>The current model shows a case of priority inversion with a simple
>> >>priority reset mechanism and the absence of that problem with the
>> >>proposed strategy.
>> >>There is only one flaw: We had to use a global lock in the model
>> >>(essentially making the entire "lock" and "unlock" operations atomic),
>> >>because so far we couldn't find a way to secure lock the operations on
>> >>a lower level. The model uses a list of locks held (by a thread) and a
>> >>list of threads waiting on a lock (in the lock data structure), so
>> >>these aspects are essentially cross-cutting and very hard to get right
>> >>without a global lock.
>> >>The RTEMS code uses different macros inside these operations (_Seize,
>> >>_Surrender), which do not seem to use a global lock (but I may have
>> >>missed something). It is possible that a data race occurs for a
>> >>complex lock update strategy, if we don't use a global lock.
>> >>Saurabh will clean up the model and provide documentation with
>> >details.
>> >>In the meantime, can you maybe answer these questions for us:
>> >>(1) Did you have any issues with race conditions in the current RTEMS
>> >>code (especially recent changes)?
>> >We haven't observed any but that doesn't mean there aren't any
>> >undiscovered.
>> >>(2) Is a fix using a global lock acceptable? Correctness-wise it's the
>> >>safest thing, but of course performance-wise it's a bottleneck.
>> >The locking strategy needs to be discussed. On a uniprocessor system,
>> >these issues tend to be minor and cause delays. On smp systems, they
>> >become more complex and performance problems.
>> >Bring this up on devel@
>> >--joel
>> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150625/cac4574e/attachment-0001.html>
