[PATCH 7/7] score: Hide SMP lock profiling impl if disabled
Fri Jun 26 07:01:47 UTC 2015
On 26/06/15 01:45, Chris Johns wrote:
> On 25/06/2015 11:17 pm, Sebastian Huber wrote:
>> The problem is that empty structures have a different size in C and C++.
>>   cpukit/score/include/rtems/score/percpu.h  |  17 ++-
>>   cpukit/score/include/rtems/score/smplock.h | 167 +++++++++++++++++------------
>>   cpukit/score/src/profilingsmplock.c        |  18 ++--
>>   cpukit/score/src/smp.c                     |   5 +-
>>   4 files changed, 127 insertions(+), 80 deletions(-)
>> diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
>> index a6f7a25..088c31f 100644
>> --- a/cpukit/score/include/rtems/score/percpu.h
>> +++ b/cpukit/score/include/rtems/score/percpu.h
>> @@ -319,10 +319,17 @@ typedef struct Per_CPU_Control {
>>       SMP_ticket_lock_Control Lock;
>> -     * @brief Lock statistics context for the per-CPU lock.
>> -    SMP_lock_Stats_context Lock_stats_context;
>> +    #if defined( RTEMS_PROFILING )
>> +       * @brief Lock statistics for the per-CPU lock.
>> +      SMP_lock_Stats Lock_stats;
>> +       * @brief Lock statistics context for the per-CPU lock.
>> +      SMP_lock_Stats_context Lock_stats_context;
>> +    #endif
> My only comment is the ability to get any SMP status is difficult. It is
> either all on or you get nothing. Moving all stats related defines
> inside #ifdefs and into the global RTEMS_PROFILING define make this
> harder to do. This is not specifically addressing this lock stats change
> but on a more general level and this change reminded me.
This patch changes nothing in terms of functionality.  It just avoids
zero size structures which unfortunately are implementation-defined in C
(size is zero with GCC) and C++ (size must be non-zero and is 1 in GCC).
> I looked into adding some SMP stats to top not long ago I found there
> was nothing I report on unless profiling was on and if I turned on
> profiling I got too much such as timing and other nice features.
> I could not see how to show how many context switches each core had, how
> many interrupts each core serviced.
We can enable such things individually.
> I understand the desire to push the limits and not waste a single cycle
> if we can help it but I actually found it difficult to know if I had SMP
> built correctly and if it was working from a shell command line. I feel
> we need some standard stats users can depend on that help us know things
> are basically working.
> Chris
Is this not something that can be done with the linker based tracing?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
