[PATCH] Import cpsw driver and smscphy driver from FreeBSD
ragunath ragunath3252 at gmail.com
Fri Jun 26 20:39:58 UTC 2015
 Makefile                             |    2 +
 freebsd/sys/arm/ti/cpsw/if_cpsw.c    | 2198 ++++++++++++++++++++++++++++++++++
 freebsd/sys/arm/ti/cpsw/if_cpswreg.h |  137 +++
 freebsd/sys/arm/ti/cpsw/if_cpswvar.h |  124 ++
 freebsd/sys/dev/mii/smscphy.c        |  227 ++++
 libbsd.py                            |    4 +
 wscript                              |    4 +-
 7 files changed, 2695 insertions(+), 1 deletion(-)
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpsw.c
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswreg.h
 create mode 100644 freebsd/sys/arm/ti/cpsw/if_cpswvar.h
 create mode 100644 freebsd/sys/dev/mii/smscphy.c
diff --git a/Makefile b/Makefile
index da2a5ef..4b9f2c7 100644
--- a/Makefile
+++ b/Makefile
@@ -182,10 +182,12 @@ LIB_C_FILES += freebsd/sys/dev/mii/brgphy.c
 LIB_C_FILES += freebsd/sys/dev/mii/micphy.c
 LIB_C_FILES += freebsd/sys/dev/mii/ukphy.c
 LIB_C_FILES += freebsd/sys/dev/mii/ukphy_subr.c
+LIB_C_FILES += freebsd/sys/dev/mii/smscphy.c
 LIB_C_FILES += freebsd/sys/dev/tsec/if_tsec.c
 LIB_C_FILES += freebsd/sys/dev/cadence/if_cgem.c
 LIB_C_FILES += freebsd/sys/dev/dwc/if_dwc.c
 LIB_C_FILES += freebsd/sys/arm/xilinx/zy7_slcr.c
+LIB_C_FILES += freebsd/sys/arm/ti/cpsw/if_cpsw.c
 LIB_C_FILES += freebsd/sys/dev/random/harvest.c
 LIB_C_FILES += freebsd/sys/netinet/tcp_hostcache.c
 LIB_C_FILES += freebsd/sys/dev/led/led.c
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpsw.c b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
new file mode 100644
index 0000000..c3ba0c8
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpsw.c
@@ -0,0 +1,2198 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * TI Common Platform Ethernet Switch (CPSW) Driver
+ * Found in TI8148 "DaVinci" and AM335x "Sitara" SoCs.
+ * This controller is documented in the AM335x Technical Reference
+ * Manual, in the TMS320DM814x DaVinci Digital Video Processors TRM
+ * and in the TMS320C6452 3 Port Switch Ethernet Subsystem TRM.
+ * It is basically a single Ethernet port (port 0) wired internally to
+ * a 3-port store-and-forward switch connected to two independent
+ * "sliver" controllers (port 1 and port 2).  You can operate the
+ * controller in a variety of different ways by suitably configuring
+ * the slivers and the Address Lookup Engine (ALE) that routes packets
+ * between the ports.
+ * This code was developed and tested on a BeagleBone with
+ * an AM335x SoC.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/endian.h>
+#include <sys/mbuf.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/socket.h>
+#include <sys/sysctl.h>
+#include <net/ethernet.h>
+#include <net/bpf.h>
+#include <net/if.h>
+#include <net/if_arp.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <net/if_vlan_var.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <sys/sockio.h>
+#include <sys/bus.h>
+#include <machine/bus.h>
+#include <sys/rman.h>
+#include <machine/resource.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include "if_cpswreg.h"
+#include "if_cpswvar.h"
+#include <arm/ti/ti_scm.h>
+#include "miibus_if.h"
+/* Device probe/attach/detach. */
+static int cpsw_probe(device_t);
+static void cpsw_init_slots(struct cpsw_softc *);
+static int cpsw_attach(device_t);
+static void cpsw_free_slot(struct cpsw_softc *, struct cpsw_slot *);
+static int cpsw_detach(device_t);
+/* Device Init/shutdown. */
+static void cpsw_init(void *);
+static void cpsw_init_locked(void *);
+static int cpsw_shutdown(device_t);
+static void cpsw_shutdown_locked(struct cpsw_softc *);
+/* Device Suspend/Resume. */
+static int cpsw_suspend(device_t);
+static int cpsw_resume(device_t);
+/* Ioctl. */
+static int cpsw_ioctl(struct ifnet *, u_long command, caddr_t data);
+static int cpsw_miibus_readreg(device_t, int phy, int reg);
+static int cpsw_miibus_writereg(device_t, int phy, int reg, int value);
+/* Send/Receive packets. */
+static void cpsw_intr_rx(void *arg);
+static struct mbuf *cpsw_rx_dequeue(struct cpsw_softc *);
+static void cpsw_rx_enqueue(struct cpsw_softc *);
+static void cpsw_start(struct ifnet *);
+static void cpsw_tx_enqueue(struct cpsw_softc *);
+static int cpsw_tx_dequeue(struct cpsw_softc *);
+/* Misc interrupts and watchdog. */
+static void cpsw_intr_rx_thresh(void *);
+static void cpsw_intr_misc(void *);
+static void cpsw_tick(void *);
+static void cpsw_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+static int cpsw_ifmedia_upd(struct ifnet *);
+static void cpsw_tx_watchdog(struct cpsw_softc *);
+/* ALE support */
+static void cpsw_ale_read_entry(struct cpsw_softc *, uint16_t idx, uint32_t *ale_entry);
+static void cpsw_ale_write_entry(struct cpsw_softc *, uint16_t idx, uint32_t *ale_entry);
+static int cpsw_ale_mc_entry_set(struct cpsw_softc *, uint8_t portmap, uint8_t *mac);
+static int cpsw_ale_update_addresses(struct cpsw_softc *, int purge);
+static void cpsw_ale_dump_table(struct cpsw_softc *);
+/* Statistics and sysctls. */
+static void cpsw_add_sysctls(struct cpsw_softc *);
+static void cpsw_stats_collect(struct cpsw_softc *);
+static int cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS);
+ * Arbitrary limit on number of segments in an mbuf to be transmitted.
+ * Packets with more segments than this will be defragmented before
+ * they are queued.
+#define CPSW_TXFRAGS 8
+ * TODO: The CPSW subsystem (CPSW_SS) can drive two independent PHYs
+ * as separate Ethernet ports.  To properly support this, we should
+ * break this into two separate devices: a CPSW_SS device that owns
+ * the interrupts and actually talks to the CPSW hardware, and a
+ * separate CPSW Ethernet child device for each Ethernet port.  The RX
+ * interrupt, for example, would be part of CPSW_SS; it would receive
+ * a packet, note the input port, and then dispatch it to the child
+ * device's interface queue.  Similarly for transmit.
+ * It's not clear to me whether the device tree should be restructured
+ * with a cpsw_ss node and two child nodes.  That would allow specifying
+ * MAC addresses for each port, for example, but might be overkill.
+ * Unfortunately, I don't have hardware right now that supports two
+ * Ethernet ports via CPSW.
+static device_method_t cpsw_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		cpsw_probe),
+	DEVMETHOD(device_attach,	cpsw_attach),
+	DEVMETHOD(device_detach,	cpsw_detach),
+	DEVMETHOD(device_shutdown,	cpsw_shutdown),
+	DEVMETHOD(device_suspend,	cpsw_suspend),
+	DEVMETHOD(device_resume,	cpsw_resume),
+	/* MII interface */
+	DEVMETHOD(miibus_readreg,	cpsw_miibus_readreg),
+	DEVMETHOD(miibus_writereg,	cpsw_miibus_writereg),
+	{ 0, 0 }
+static driver_t cpsw_driver = {
+	"cpsw",
+	cpsw_methods,
+	sizeof(struct cpsw_softc),
+static devclass_t cpsw_devclass;
+DRIVER_MODULE(cpsw, simplebus, cpsw_driver, cpsw_devclass, 0, 0);
+DRIVER_MODULE(miibus, cpsw, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(cpsw, ether, 1, 1, 1);
+MODULE_DEPEND(cpsw, miibus, 1, 1, 1);
+static struct resource_spec res_spec[] = {
+	{ SYS_RES_MEMORY, 0, RF_ACTIVE },
+	{ SYS_RES_IRQ, 0, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 1, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 2, RF_ACTIVE | RF_SHAREABLE },
+	{ SYS_RES_IRQ, 3, RF_ACTIVE | RF_SHAREABLE },
+	{ -1, 0 }
+/* Number of entries here must match size of stats
+ * array in struct cpsw_softc. */
+static struct cpsw_stat {
+	int	reg;
+	char *oid;
+} cpsw_stat_sysctls[CPSW_SYSCTL_COUNT] = {
+	{0x00, "GoodRxFrames"},
+	{0x04, "BroadcastRxFrames"},
+	{0x08, "MulticastRxFrames"},
+	{0x0C, "PauseRxFrames"},
+	{0x10, "RxCrcErrors"},
+	{0x14, "RxAlignErrors"},
+	{0x18, "OversizeRxFrames"},
+	{0x1c, "RxJabbers"},
+	{0x20, "ShortRxFrames"},
+	{0x24, "RxFragments"},
+	{0x30, "RxOctets"},
+	{0x34, "GoodTxFrames"},
+	{0x38, "BroadcastTxFrames"},
+	{0x3c, "MulticastTxFrames"},
+	{0x40, "PauseTxFrames"},
+	{0x44, "DeferredTxFrames"},
+	{0x48, "CollisionsTxFrames"},
+	{0x4c, "SingleCollisionTxFrames"},
+	{0x50, "MultipleCollisionTxFrames"},
+	{0x54, "ExcessiveCollisions"},
+	{0x58, "LateCollisions"},
+	{0x5c, "TxUnderrun"},
+	{0x60, "CarrierSenseErrors"},
+	{0x64, "TxOctets"},
+	{0x68, "RxTx64OctetFrames"},
+	{0x6c, "RxTx65to127OctetFrames"},
+	{0x70, "RxTx128to255OctetFrames"},
+	{0x74, "RxTx256to511OctetFrames"},
+	{0x78, "RxTx512to1024OctetFrames"},
+	{0x7c, "RxTx1024upOctetFrames"},
+	{0x80, "NetOctets"},
+	{0x84, "RxStartOfFrameOverruns"},
+	{0x88, "RxMiddleOfFrameOverruns"},
+	{0x8c, "RxDmaOverruns"}
+ * Basic debug support.
+#define IF_DEBUG(sc)  if (sc->cpsw_if_flags & IFF_DEBUG)
+static void
+cpsw_debugf_head(const char *funcname)
+	int t = (int)(time_second % (24 * 60 * 60));
+	printf("%02d:%02d:%02d %s ", t / (60 * 60), (t / 60) % 60, t % 60, funcname);
+#include <machine/stdarg.h>
+static void
+cpsw_debugf(const char *fmt, ...)
+	va_list ap;
+	va_start(ap, fmt);
+	vprintf(fmt, ap);
+	va_end(ap);
+	printf("\n");
+#define CPSW_DEBUGF(a) do {					\
+	IF_DEBUG(sc) {						\
+		cpsw_debugf_head(__func__);			\
+		cpsw_debugf a;					\
+} while (0)
+ * Locking macros
+#define CPSW_TX_LOCK(sc) do {					\
+		mtx_assert(&(sc)->rx.lock, MA_NOTOWNED);		\
+		mtx_lock(&(sc)->tx.lock);				\
+} while (0)
+#define CPSW_TX_UNLOCK(sc)	mtx_unlock(&(sc)->tx.lock)
+#define CPSW_TX_LOCK_ASSERT(sc)	mtx_assert(&(sc)->tx.lock, MA_OWNED)
+#define CPSW_RX_LOCK(sc) do {					\
+		mtx_assert(&(sc)->tx.lock, MA_NOTOWNED);		\
+		mtx_lock(&(sc)->rx.lock);				\
+} while (0)
+#define CPSW_RX_UNLOCK(sc)		mtx_unlock(&(sc)->rx.lock)
+#define CPSW_RX_LOCK_ASSERT(sc)	mtx_assert(&(sc)->rx.lock, MA_OWNED)
+#define CPSW_GLOBAL_LOCK(sc) do {					\
+		if ((mtx_owned(&(sc)->tx.lock) ? 1 : 0) !=	\
+		    (mtx_owned(&(sc)->rx.lock) ? 1 : 0)) {		\
+			panic("cpsw deadlock possibility detection!");	\
+} while (0)
+#define CPSW_GLOBAL_UNLOCK(sc) do {					\
+		CPSW_RX_UNLOCK(sc);				\
+		CPSW_TX_UNLOCK(sc);				\
+} while (0)
+#define CPSW_GLOBAL_LOCK_ASSERT(sc) do {				\
+		CPSW_TX_LOCK_ASSERT(sc);				\
+		CPSW_RX_LOCK_ASSERT(sc);				\
+} while (0)
+ * Read/Write macros
+#define	cpsw_read_4(sc, reg)		bus_read_4(sc->res[0], reg)
+#define	cpsw_write_4(sc, reg, val)	bus_write_4(sc->res[0], reg, val)
+#define	cpsw_cpdma_bd_offset(i)	(CPSW_CPPI_RAM_OFFSET + ((i)*16))
+#define	cpsw_cpdma_bd_paddr(sc, slot)				\
+	BUS_SPACE_PHYSADDR(sc->res[0], slot->bd_offset)
+#define	cpsw_cpdma_read_bd(sc, slot, val)				\
+	bus_read_region_4(sc->res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define	cpsw_cpdma_write_bd(sc, slot, val)				\
+	bus_write_region_4(sc->res[0], slot->bd_offset, (uint32_t *) val, 4)
+#define	cpsw_cpdma_write_bd_next(sc, slot, next_slot)			\
+	cpsw_write_4(sc, slot->bd_offset, cpsw_cpdma_bd_paddr(sc, next_slot))
+#define	cpsw_cpdma_read_bd_flags(sc, slot)		\
+	bus_read_2(sc->res[0], slot->bd_offset + 14)
+#define	cpsw_write_hdp_slot(sc, queue, slot)				\
+	cpsw_write_4(sc, (queue)->hdp_offset, cpsw_cpdma_bd_paddr(sc, slot))
+#define	CP_OFFSET (CPSW_CPDMA_TX_CP(0) - CPSW_CPDMA_TX_HDP(0))
+#define	cpsw_read_cp(sc, queue)				\
+	cpsw_read_4(sc, (queue)->hdp_offset + CP_OFFSET)
+#define	cpsw_write_cp(sc, queue, val)				\
+	cpsw_write_4(sc, (queue)->hdp_offset + CP_OFFSET, (val))
+#define	cpsw_write_cp_slot(sc, queue, slot)		\
+	cpsw_write_cp(sc, queue, cpsw_cpdma_bd_paddr(sc, slot))
+#if 0
+/* XXX temporary function versions for debugging. */
+static void
+cpsw_write_hdp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+	uint32_t reg = queue->hdp_offset;
+	uint32_t v = cpsw_cpdma_bd_paddr(sc, slot);
+	CPSW_DEBUGF(("HDP <=== 0x%08x (was 0x%08x)", v, cpsw_read_4(sc, reg)));
+	cpsw_write_4(sc, reg, v);
+static void
+cpsw_write_cp_slotX(struct cpsw_softc *sc, struct cpsw_queue *queue, struct cpsw_slot *slot)
+	CPSW_DEBUGF(("CP <=== 0x%08x (expecting 0x%08x)", v, cpsw_read_cp(sc, queue)));
+	cpsw_write_cp(sc, queue, v);
+#endif
+ * Expanded dump routines for verbose debugging.
+static void
+cpsw_dump_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+	static const char *flags[] = {"SOP", "EOP", "Owner", "EOQ",
+	    "TDownCmplt", "PassCRC", "Long", "Short", "MacCtl", "Overrun",
+	    "PktErr1", "PortEn/PktErr0", "RxVlanEncap", "Port2", "Port1",
+	    "Port0"};
+	struct cpsw_cpdma_bd bd;
+	const char *sep;
+	int i;
+	cpsw_cpdma_read_bd(sc, slot, &bd);
+	printf("BD Addr: 0x%08x   Next: 0x%08x\n", cpsw_cpdma_bd_paddr(sc, slot), bd.next);
+	printf("  BufPtr: 0x%08x   BufLen: 0x%08x\n", bd.bufptr, bd.buflen);
+	printf("  BufOff: 0x%08x   PktLen: 0x%08x\n", bd.bufoff, bd.pktlen);
+	printf("  Flags: ");
+	sep = "";
+	for (i = 0; i < 16; ++i) {
+		if (bd.flags & (1 << (15 - i))) {
+			printf("%s%s", sep, flags[i]);
+			sep = ",";
+	printf("\n");
+	if (slot->mbuf) {
+		printf("  Ether:  %14D\n",
+		    (char *)(slot->mbuf->m_data), " ");
+		printf("  Packet: %16D\n",
+		    (char *)(slot->mbuf->m_data) + 14, " ");
+#define CPSW_DUMP_SLOT(cs, slot) do {				\
+	IF_DEBUG(sc) {						\
+		cpsw_dump_slot(sc, slot);			\
+} while (0)
+static void
+cpsw_dump_queue(struct cpsw_softc *sc, struct cpsw_slots *q)
+	struct cpsw_slot *slot;
+	int i = 0;
+	int others = 0;
+	STAILQ_FOREACH(slot, q, next) {
+		if (i > 4)
+			++others;
+		else
+		++i;
+	if (others)
+		printf(" ... and %d more.\n", others);
+	printf("\n");
+#define CPSW_DUMP_QUEUE(sc, q) do {				\
+	IF_DEBUG(sc) {						\
+		cpsw_dump_queue(sc, q);				\
+} while (0)
+ * Device Probe, Attach, Detach.
+static int
+cpsw_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,cpsw"))
+		return (ENXIO);
+	device_set_desc(dev, "3-port Switch Ethernet Subsystem");
+	return (BUS_PROBE_DEFAULT);
+static void
+cpsw_init_slots(struct cpsw_softc *sc)
+	int i;
+	STAILQ_INIT(&sc->avail);
+	/* Put the slot descriptors onto the global avail list. */
+	for (i = 0; i < sizeof(sc->_slots) / sizeof(sc->_slots[0]); i++) {
+		slot = &sc->_slots[i];
+		slot->bd_offset = cpsw_cpdma_bd_offset(i);
+		STAILQ_INSERT_TAIL(&sc->avail, slot, next);
+ * bind an interrupt, add the relevant info to sc->interrupts
+static int
+cpsw_attach_interrupt(struct cpsw_softc *sc, struct resource *res, driver_intr_t *handler, const char *description)
+	void **pcookie;
+	int error;
+	sc->interrupts[sc->interrupt_count].res = res;
+	sc->interrupts[sc->interrupt_count].description = description;
+	pcookie = &sc->interrupts[sc->interrupt_count].ih_cookie;
+	error = bus_setup_intr(sc->dev, res, INTR_TYPE_NET | INTR_MPSAFE,
+	    NULL, *handler, sc, pcookie);
+	if (error)
+		device_printf(sc->dev,
+		    "could not setup %s\n", description);
+	else
+		++sc->interrupt_count;
+	return (error);
+ * teardown everything in sc->interrupts.
+static void
+cpsw_detach_interrupts(struct cpsw_softc *sc)
+	int error;
+	int i;
+	for (i = 0; i < sizeof(sc->interrupts) / sizeof(sc->interrupts[0]); ++i) {
+		if (!sc->interrupts[i].ih_cookie)
+			continue;
+		error = bus_teardown_intr(sc->dev,
+		    sc->interrupts[i].res, sc->interrupts[i].ih_cookie);
+		if (error)
+			device_printf(sc->dev, "could not release %s\n",
+			    sc->interrupts[i].description);
+		sc->interrupts[i].ih_cookie = NULL;
+static int
+cpsw_add_slots(struct cpsw_softc *sc, struct cpsw_queue *queue, int requested)
+	const int max_slots = sizeof(sc->_slots) / sizeof(sc->_slots[0]);
+	int i;
+	if (requested < 0)
+		requested = max_slots;
+	for (i = 0; i < requested; ++i) {
+		slot = STAILQ_FIRST(&sc->avail);
+		if (slot == NULL)
+			return (0);
+		if (bus_dmamap_create(sc->mbuf_dtag, 0, &slot->dmamap)) {
+			if_printf(sc->ifp, "failed to create dmamap\n");
+			return (ENOMEM);
+		STAILQ_REMOVE_HEAD(&sc->avail, next);
+		STAILQ_INSERT_TAIL(&queue->avail, slot, next);
+		++queue->avail_queue_len;
+		++queue->queue_slots;
+	return (0);
+static int
+cpsw_attach(device_t dev)
+	bus_dma_segment_t segs[1];
+	struct cpsw_softc *sc = device_get_softc(dev);
+	struct mii_softc *miisc;
+	struct ifnet *ifp;
+	void *phy_sc;
+	int error, phy, nsegs;
+	uint32_t reg;
+	CPSW_DEBUGF((""));
+	getbinuptime(&sc->attach_uptime);
+	sc->dev = dev;
+	sc->node = ofw_bus_get_node(dev);
+	/* Get phy address from fdt */
+	if (fdt_get_phyaddr(sc->node, sc->dev, &phy, &phy_sc) != 0) {
+		device_printf(dev, "failed to get PHY address from FDT\n");
+		return (ENXIO);
+	/* Initialize mutexes */
+	mtx_init(&sc->tx.lock, device_get_nameunit(dev),
+	    "cpsw TX lock", MTX_DEF);
+	mtx_init(&sc->rx.lock, device_get_nameunit(dev),
+	    "cpsw RX lock", MTX_DEF);
+	/* Allocate IO and IRQ resources */
+	error = bus_alloc_resources(dev, res_spec, sc->res);
+	if (error) {
+		device_printf(dev, "could not allocate resources\n");
+		cpsw_detach(dev);
+		return (ENXIO);
+	reg = cpsw_read_4(sc, CPSW_SS_IDVER);
+	device_printf(dev, "CPSW SS Version %d.%d (%d)\n", (reg >> 8 & 0x7),
+		reg & 0xFF, (reg >> 11) & 0x1F);
+	cpsw_add_sysctls(sc);
+	/* Allocate a busdma tag and DMA safe memory for mbufs. */
+	error = bus_dma_tag_create(
+		bus_get_dma_tag(sc->dev),	/* parent */
+		1, 0,				/* alignment, boundary */
+		BUS_SPACE_MAXADDR_32BIT,	/* lowaddr */
+		BUS_SPACE_MAXADDR,		/* highaddr */
+		NULL, NULL,			/* filtfunc, filtfuncarg */
+		MCLBYTES, CPSW_TXFRAGS,		/* maxsize, nsegments */
+		MCLBYTES, 0,			/* maxsegsz, flags */
+		NULL, NULL,			/* lockfunc, lockfuncarg */
+		&sc->mbuf_dtag);		/* dmatag */
+	if (error) {
+		device_printf(dev, "bus_dma_tag_create failed\n");
+		cpsw_detach(dev);
+		return (error);
+	/* Allocate network interface */
+	ifp = sc->ifp = if_alloc(IFT_ETHER);
+	if (ifp == NULL) {
+		device_printf(dev, "if_alloc() failed\n");
+		cpsw_detach(dev);
+		return (ENOMEM);
+	/* Allocate the null mbuf and pre-sync it. */
+	sc->null_mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+	memset(sc->null_mbuf->m_data, 0, sc->null_mbuf->m_ext.ext_size);
+	bus_dmamap_create(sc->mbuf_dtag, 0, &sc->null_mbuf_dmamap);
+	bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, sc->null_mbuf_dmamap,
+	    sc->null_mbuf, segs, &nsegs, BUS_DMA_NOWAIT);
+	bus_dmamap_sync(sc->mbuf_dtag, sc->null_mbuf_dmamap,
+	    BUS_DMASYNC_PREWRITE);
+	sc->null_mbuf_paddr = segs[0].ds_addr;
+	if_initname(ifp, device_get_name(dev), device_get_unit(dev));
+	ifp->if_softc = sc;
+	ifp->if_flags = IFF_SIMPLEX | IFF_MULTICAST | IFF_BROADCAST;
+	ifp->if_capabilities = IFCAP_VLAN_MTU | IFCAP_HWCSUM; //FIXME VLAN?
+	ifp->if_capenable = ifp->if_capabilities;
+	ifp->if_init = cpsw_init;
+	ifp->if_start = cpsw_start;
+	ifp->if_ioctl = cpsw_ioctl;
+	cpsw_init_slots(sc);
+	/* Allocate slots to TX and RX queues. */
+	STAILQ_INIT(&sc->rx.avail);
+	STAILQ_INIT(&sc->rx.active);
+	STAILQ_INIT(&sc->tx.avail);
+	STAILQ_INIT(&sc->tx.active);
+	// For now:  128 slots to TX, rest to RX.
+	// XXX TODO: start with 32/64 and grow dynamically based on demand.
+	if (cpsw_add_slots(sc, &sc->tx, 128) || cpsw_add_slots(sc, &sc->rx, -1)) {
+		device_printf(dev, "failed to allocate dmamaps\n");
+		cpsw_detach(dev);
+		return (ENOMEM);
+	device_printf(dev, "Initial queue size TX=%d RX=%d\n",
+	    sc->tx.queue_slots, sc->rx.queue_slots);
+	ifp->if_snd.ifq_drv_maxlen = sc->tx.queue_slots;
+	IFQ_SET_MAXLEN(&ifp->if_snd, ifp->if_snd.ifq_drv_maxlen);
+	IFQ_SET_READY(&ifp->if_snd);
+	sc->tx.hdp_offset = CPSW_CPDMA_TX_HDP(0);
+	sc->rx.hdp_offset = CPSW_CPDMA_RX_HDP(0);
+	/* Get high part of MAC address from control module (mac_id0_hi) */
+	/* TODO: Get MAC ID1 as well as MAC ID0. */
+	ti_scm_reg_read_4(0x634, &reg);
+	sc->mac_addr[0] = reg & 0xFF;
+	sc->mac_addr[1] = (reg >>  8) & 0xFF;
+	sc->mac_addr[2] = (reg >> 16) & 0xFF;
+	sc->mac_addr[3] = (reg >> 24) & 0xFF;
+	/* Get low part of MAC address from control module (mac_id0_lo) */
+	ti_scm_reg_read_4(0x630, &reg);
+	sc->mac_addr[4] = reg & 0xFF;
+	sc->mac_addr[5] = (reg >>  8) & 0xFF;
+	/* Initialze MDIO - ENABLE, PREAMBLE=0, FAULTENB, CLKDIV=0xFF */
+	/* TODO Calculate MDCLK=CLK/(CLKDIV+1) */
+	cpsw_write_4(sc, MDIOCONTROL, 1 << 30 | 1 << 18 | 0xFF);
+	/* Clear ALE */
+	cpsw_write_4(sc, CPSW_ALE_CONTROL, 1 << 30);
+	/* Attach PHY(s) */
+	error = mii_attach(dev, &sc->miibus, ifp, cpsw_ifmedia_upd,
+	    cpsw_ifmedia_sts, BMSR_DEFCAPMASK, phy, MII_OFFSET_ANY, 0);
+	if (error) {
+		device_printf(dev, "attaching PHYs failed\n");
+		cpsw_detach(dev);
+		return (error);
+	sc->mii = device_get_softc(sc->miibus);
+	/* Tell the MAC where to find the PHY so autoneg works */
+	miisc = LIST_FIRST(&sc->mii->mii_phys);
+	/* Select PHY and enable interrupts */
+	cpsw_write_4(sc, MDIOUSERPHYSEL0, 1 << 6 | (miisc->mii_phy & 0x1F));
+	/* Note: We don't use sc->res[3] (TX interrupt) */
+	if (cpsw_attach_interrupt(sc, sc->res[1],
+		cpsw_intr_rx_thresh, "CPSW RX threshold interrupt") ||
+	    cpsw_attach_interrupt(sc, sc->res[2],
+		cpsw_intr_rx, "CPSW RX interrupt") ||
+	    cpsw_attach_interrupt(sc, sc->res[4],
+		cpsw_intr_misc, "CPSW misc interrupt")) {
+		cpsw_detach(dev);
+		return (ENXIO);
+	ether_ifattach(ifp, sc->mac_addr);
+	callout_init(&sc->watchdog.callout, 0);
+	return (0);
+static void
+cpsw_free_slot(struct cpsw_softc *sc, struct cpsw_slot *slot)
+	int error;
+	if (slot->dmamap) {
+		error = bus_dmamap_destroy(sc->mbuf_dtag, slot->dmamap);
+		KASSERT(error == 0, ("Mapping still active"));
+		slot->dmamap = NULL;
+	if (slot->mbuf) {
+		m_freem(slot->mbuf);
+		slot->mbuf = NULL;
+static int
+cpsw_detach(device_t dev)
+	int error, i;
+	/* Stop controller and free TX queue */
+	if (device_is_attached(dev)) {
+		ether_ifdetach(sc->ifp);
+		CPSW_GLOBAL_LOCK(sc);
+		cpsw_shutdown_locked(sc);
+		CPSW_GLOBAL_UNLOCK(sc);
+		callout_drain(&sc->watchdog.callout);
+	bus_generic_detach(dev);
+	if (sc->miibus)
+		device_delete_child(dev, sc->miibus);
+	/* Stop and release all interrupts */
+	cpsw_detach_interrupts(sc);
+	/* Free dmamaps and mbufs */
+	for (i = 0; i < sizeof(sc->_slots) / sizeof(sc->_slots[0]); ++i)
+		cpsw_free_slot(sc, &sc->_slots[i]);
+	if (sc->null_mbuf_dmamap) {
+		error = bus_dmamap_destroy(sc->mbuf_dtag, sc->null_mbuf_dmamap);
+	if (sc->null_mbuf)
+		m_freem(sc->null_mbuf);
+	/* Free DMA tag */
+	error = bus_dma_tag_destroy(sc->mbuf_dtag);
+	KASSERT(error == 0, ("Unable to destroy DMA tag"));
+	/* Free IO memory handler */
+	bus_release_resources(dev, res_spec, sc->res);
+	if (sc->ifp != NULL)
+		if_free(sc->ifp);
+	/* Destroy mutexes */
+	mtx_destroy(&sc->rx.lock);
+	mtx_destroy(&sc->tx.lock);
+	return (0);
+ * Init/Shutdown.
+static void
+cpsw_reset(struct cpsw_softc *sc)
+	int i;
+	/* Reset RMII/RGMII wrapper. */
+	cpsw_write_4(sc, CPSW_WR_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_WR_SOFT_RESET) & 1)
+	/* Disable TX and RX interrupts for all cores. */
+	for (i = 0; i < 3; ++i) {
+		cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_TX_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_RX_EN(i), 0x00);
+		cpsw_write_4(sc, CPSW_WR_C_MISC_EN(i), 0x00);
+	/* Reset CPSW subsystem. */
+	cpsw_write_4(sc, CPSW_SS_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_SS_SOFT_RESET) & 1)
+	/* Reset Sliver port 1 and 2 */
+	for (i = 0; i < 2; i++) {
+		/* Reset */
+		cpsw_write_4(sc, CPSW_SL_SOFT_RESET(i), 1);
+		while (cpsw_read_4(sc, CPSW_SL_SOFT_RESET(i)) & 1)
+	/* Reset DMA controller. */
+	cpsw_write_4(sc, CPSW_CPDMA_SOFT_RESET, 1);
+	while (cpsw_read_4(sc, CPSW_CPDMA_SOFT_RESET) & 1)
+	/* Disable TX & RX DMA */
+	cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 0);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 0);
+	/* Clear all queues. */
+	for (i = 0; i < 8; i++) {
+		cpsw_write_4(sc, CPSW_CPDMA_TX_HDP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_RX_HDP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_TX_CP(i), 0);
+		cpsw_write_4(sc, CPSW_CPDMA_RX_CP(i), 0);
+	/* Clear all interrupt Masks */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_CLEAR, 0xFFFFFFFF);
+	cpsw_write_4(sc, CPSW_CPDMA_TX_INTMASK_CLEAR, 0xFFFFFFFF);
+static void
+cpsw_init(void *arg)
+	struct cpsw_softc *sc = arg;
+	cpsw_init_locked(arg);
+static void
+cpsw_init_locked(void *arg)
+	uint32_t i;
+	ifp = sc->ifp;
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) != 0)
+		return;
+	getbinuptime(&sc->init_uptime);
+	/* Reset the controller. */
+	cpsw_reset(sc);
+	/* Enable ALE */
+	cpsw_write_4(sc, CPSW_ALE_CONTROL, 1 << 31 | 1 << 4);
+	/* Init Sliver port 1 and 2 */
+		/* Set Slave Mapping */
+		cpsw_write_4(sc, CPSW_SL_RX_PRI_MAP(i), 0x76543210);
+		cpsw_write_4(sc, CPSW_PORT_P_TX_PRI_MAP(i + 1), 0x33221100);
+		cpsw_write_4(sc, CPSW_SL_RX_MAXLEN(i), 0x5f2);
+		/* Set MACCONTROL for ports 0,1: IFCTL_B(16), IFCTL_A(15),
+		   GMII_EN(5), FULLDUPLEX(1) */
+		/* TODO: Docs claim that IFCTL_B and IFCTL_A do the same thing? */
+		/* Huh?  Docs call bit 0 "Loopback" some places, "FullDuplex" others. */
+		cpsw_write_4(sc, CPSW_SL_MACCONTROL(i), 1 << 15 | 1 << 5 | 1);
+	/* Set Host Port Mapping */
+	cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_TX_PRI_MAP, 0x76543210);
+	cpsw_write_4(sc, CPSW_PORT_P0_CPDMA_RX_CH_MAP, 0);
+	/* Initialize ALE: all ports set to forwarding(3), initialize addrs */
+	for (i = 0; i < 3; i++)
+		cpsw_write_4(sc, CPSW_ALE_PORTCTL(i), 3);
+	cpsw_ale_update_addresses(sc, 1);
+	cpsw_write_4(sc, CPSW_SS_PTYPE, 0);
+	/* Enable statistics for ports 0, 1 and 2 */
+	cpsw_write_4(sc, CPSW_SS_STAT_PORT_EN, 7);
+	/* Experiment:  Turn off flow control */
+	/* This seems to fix the watchdog resets that have plagued
+	   earlier versions of this driver; I'm not yet sure if there
+	   are negative effects yet. */
+	cpsw_write_4(sc, CPSW_SS_FLOW_CONTROL, 0);
+	/* Make IP hdr aligned with 4 */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_BUFFER_OFFSET, 2);
+	/* Initialize RX Buffer Descriptors */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_FREEBUFFER(0), 0);
+	/* Enable TX & RX DMA */
+	cpsw_write_4(sc, CPSW_CPDMA_TX_CONTROL, 1);
+	cpsw_write_4(sc, CPSW_CPDMA_RX_CONTROL, 1);
+	/* Enable Interrupts for core 0 */
+	cpsw_write_4(sc, CPSW_WR_C_RX_THRESH_EN(0), 0xFF);
+	cpsw_write_4(sc, CPSW_WR_C_RX_EN(0), 0xFF);
+	cpsw_write_4(sc, CPSW_WR_C_MISC_EN(0), 0x3F);
+	/* Enable host Error Interrupt */
+	cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_SET, 3);
+	/* Enable interrupts for RX Channel 0 */
+	cpsw_write_4(sc, CPSW_CPDMA_RX_INTMASK_SET, 1);
+	/* Select MII in GMII_SEL, Internal Delay mode */
+	//ti_scm_reg_write_4(0x650, 0);
+	/* Initialize active queues. */
+	slot = STAILQ_FIRST(&sc->tx.active);
+	if (slot != NULL)
+		cpsw_write_hdp_slot(sc, &sc->tx, slot);
+	slot = STAILQ_FIRST(&sc->rx.active);
+	if (slot != NULL)
+		cpsw_write_hdp_slot(sc, &sc->rx, slot);
+	cpsw_rx_enqueue(sc);
+	/* Activate network interface */
+	sc->rx.running = 1;
+	sc->tx.running = 1;
+	sc->watchdog.timer = 0;
+	callout_reset(&sc->watchdog.callout, hz, cpsw_tick, sc);
+	sc->ifp->if_drv_flags |= IFF_DRV_RUNNING;
+	sc->ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+static int
+cpsw_shutdown(device_t dev)
+	return (0);
+static void
+cpsw_rx_teardown_locked(struct cpsw_softc *sc)
+	struct mbuf *received, *next;
+	int i = 0;
+	CPSW_DEBUGF(("starting RX teardown"));
+	cpsw_write_4(sc, CPSW_CPDMA_RX_TEARDOWN, 0);
+	for (;;) {
+		received = cpsw_rx_dequeue(sc);
+		while (received != NULL) {
+			next = received->m_nextpkt;
+			received->m_nextpkt = NULL;
+			(*sc->ifp->if_input)(sc->ifp, received);
+			received = next;
+		if (!sc->rx.running) {
+			CPSW_DEBUGF(("finished RX teardown (%d retries)", i));
+			return;
+		if (++i > 10) {
+			if_printf(sc->ifp, "Unable to cleanly shutdown receiver\n");
+			return;
+		DELAY(10);
+static void
+cpsw_tx_teardown_locked(struct cpsw_softc *sc)
+	int i = 0;
+	CPSW_DEBUGF(("starting TX teardown"));
+	cpsw_write_4(sc, CPSW_CPDMA_TX_TEARDOWN, 0);
+	cpsw_tx_dequeue(sc);
+	while (sc->tx.running && ++i < 10) {
+		DELAY(10);
+	if (sc->tx.running)
+		if_printf(sc->ifp, "Unable to cleanly shutdown transmitter\n");
+	CPSW_DEBUGF(("finished TX teardown (%d retries, %d idle buffers)",
+	    i, sc->tx.active_queue_len));
+static void
+cpsw_shutdown_locked(struct cpsw_softc *sc)
+	CPSW_GLOBAL_LOCK_ASSERT(sc);
+	ifp = sc->ifp;
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0)
+		return;
+	/* Disable interface */
+	ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+	ifp->if_drv_flags |= IFF_DRV_OACTIVE;
+	/* Stop ticker */
+	callout_stop(&sc->watchdog.callout);
+	/* Tear down the RX/TX queues. */
+	cpsw_rx_teardown_locked(sc);
+	cpsw_tx_teardown_locked(sc);
+	/* Capture stats before we reset controller. */
+	cpsw_stats_collect(sc);
+	cpsw_reset(sc);
+ *  Suspend/Resume.
+static int
+cpsw_suspend(device_t dev)
+	return (0);
+static int
+cpsw_resume(device_t dev)
+	CPSW_DEBUGF(("UNIMPLEMENTED"));
+	return (0);
+ *  IOCTL
+static void
+cpsw_set_promisc(struct cpsw_softc *sc, int set)
+	 * Enabling promiscuous mode requires two bits of work: First,
+	 * ALE_BYPASS needs to be enabled.  That disables the ALE
+	 * forwarding logic and causes every packet to be sent to the
+	 * host port.  That makes us promiscuous wrt received packets.
+	 * With ALE forwarding disabled, the transmitter needs to set
+	 * an explicit output port on every packet to route it to the
+	 * correct egress.  This should be doable for systems such as
+	 * BeagleBone where only one egress port is actually wired to
+	 * a PHY.  If you have both egress ports wired up, life gets a
+	 * lot more interesting.
+	 * Hmmm.... NetBSD driver uses ALE_BYPASS always and doesn't
+	 * seem to set explicit egress ports.  Does that mean they
+	 * are always promiscuous?
+	if (set) {
+		printf("Promiscuous mode unimplemented\n");
+static void
+cpsw_set_allmulti(struct cpsw_softc *sc, int set)
+	if (set) {
+		printf("All-multicast mode unimplemented\n");
+static int
+cpsw_ioctl(struct ifnet *ifp, u_long command, caddr_t data)
+	struct cpsw_softc *sc = ifp->if_softc;
+	struct ifreq *ifr = (struct ifreq *)data;
+	int error;
+	uint32_t changed;
+	error = 0;
+	switch (command) {
+	case SIOCSIFFLAGS:
+		if (ifp->if_flags & IFF_UP) {
+			if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+				changed = ifp->if_flags ^ sc->cpsw_if_flags;
+				CPSW_DEBUGF(("SIOCSIFFLAGS: UP & RUNNING (changed=0x%x)", changed));
+				if (changed & IFF_PROMISC)
+					cpsw_set_promisc(sc,
+					    ifp->if_flags & IFF_PROMISC);
+				if (changed & IFF_ALLMULTI)
+					cpsw_set_allmulti(sc,
+					    ifp->if_flags & IFF_ALLMULTI);
+			} else {
+				CPSW_DEBUGF(("SIOCSIFFLAGS: UP but not RUNNING; starting up"));
+				cpsw_init_locked(sc);
+		} else if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+			CPSW_DEBUGF(("SIOCSIFFLAGS: not UP but RUNNING; shutting down"));
+		sc->cpsw_if_flags = ifp->if_flags;
+		break;
+	case SIOCADDMULTI:
+		cpsw_ale_update_addresses(sc, 0);
+		break;
+	case SIOCDELMULTI:
+		/* Ugh.  DELMULTI doesn't provide the specific address
+		   being removed, so the best we can do is remove
+		   everything and rebuild it all. */
+		break;
+	case SIOCGIFMEDIA:
+	case SIOCSIFMEDIA:
+		error = ifmedia_ioctl(ifp, ifr, &sc->mii->mii_media, command);
+		break;
+	default:
+		error = ether_ioctl(ifp, command, data);
+	return (error);
+ * MIIBUS
+static int
+cpsw_miibus_ready(struct cpsw_softc *sc)
+	uint32_t r, retries = CPSW_MIIBUS_RETRIES;
+	while (--retries) {
+		r = cpsw_read_4(sc, MDIOUSERACCESS0);
+		if ((r & 1 << 31) == 0)
+			return 1;
+		DELAY(CPSW_MIIBUS_DELAY);
+	return 0;
+static int
+cpsw_miibus_readreg(device_t dev, int phy, int reg)
+	uint32_t cmd, r;
+	if (!cpsw_miibus_ready(sc)) {
+		device_printf(dev, "MDIO not ready to read\n");
+		return 0;
+	/* Set GO, reg, phy */
+	cmd = 1 << 31 | (reg & 0x1F) << 21 | (phy & 0x1F) << 16;
+	cpsw_write_4(sc, MDIOUSERACCESS0, cmd);
+		device_printf(dev, "MDIO timed out during read\n");
+		return 0;
+	if((r & 1 << 29) == 0) {
+		device_printf(dev, "Failed to read from PHY.\n");
+		r = 0;
+	return (r & 0xFFFF);
+static int
+cpsw_miibus_writereg(device_t dev, int phy, int reg, int value)
+	uint32_t cmd;
+		device_printf(dev, "MDIO not ready to write\n");
+		return 0;
+	/* Set GO, WRITE, reg, phy, and value */
+	cmd = 3 << 30 | (reg & 0x1F) << 21 | (phy & 0x1F) << 16
+	    | (value & 0xFFFF);
+		device_printf(dev, "MDIO timed out during write\n");
+		return 0;
+	if((cpsw_read_4(sc, MDIOUSERACCESS0) & (1 << 29)) == 0)
+		device_printf(dev, "Failed to write to PHY.\n");
+	return 0;
+ * Transmit/Receive Packets.
+static void
+cpsw_intr_rx(void *arg)
+	CPSW_RX_LOCK(sc);
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 1);
+		received = next;
+cpsw_rx_dequeue(struct cpsw_softc *sc)
+	struct mbuf *mb_head, *mb_tail;
+	int removed = 0;
+	ifp = sc->ifp;
+	mb_head = mb_tail = NULL;
+	/* Pull completed packets off hardware RX queue. */
+	while ((slot = STAILQ_FIRST(&sc->rx.active)) != NULL) {
+		if (bd.flags & CPDMA_BD_OWNER)
+			break; /* Still in use by hardware */
+		CPSW_DEBUGF(("Removing received packet from RX queue"));
+		++removed;
+		STAILQ_REMOVE_HEAD(&sc->rx.active, next);
+		STAILQ_INSERT_TAIL(&sc->rx.avail, slot, next);
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTREAD);
+		bus_dmamap_unload(sc->mbuf_dtag, slot->dmamap);
+		if (bd.flags & CPDMA_BD_TDOWNCMPLT) {
+			CPSW_DEBUGF(("RX teardown in progress"));
+			cpsw_write_cp(sc, &sc->rx, 0xfffffffc);
+			sc->rx.running = 0;
+			break;
+		cpsw_write_cp_slot(sc, &sc->rx, slot);
+		/* Set up mbuf */
+		/* TODO: track SOP/EOP bits to assemble a full mbuf
+		   out of received fragments. */
+		slot->mbuf->m_data += bd.bufoff;
+		slot->mbuf->m_len = bd.pktlen - 4;
+		slot->mbuf->m_pkthdr.len = bd.pktlen - 4;
+		slot->mbuf->m_flags |= M_PKTHDR;
+		slot->mbuf->m_pkthdr.rcvif = ifp;
+		slot->mbuf->m_nextpkt = NULL;
+		if ((ifp->if_capenable & IFCAP_RXCSUM) != 0) {
+			/* check for valid CRC by looking into pkt_err[5:4] */
+			if ((bd.flags & CPDMA_BD_PKT_ERR_MASK) == 0) {
+				slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_CHECKED;
+				slot->mbuf->m_pkthdr.csum_flags |= CSUM_IP_VALID;
+				slot->mbuf->m_pkthdr.csum_data = 0xffff;
+		/* Add mbuf to packet list to be returned. */
+		if (mb_tail) {
+			mb_tail->m_nextpkt = slot->mbuf;
+		} else {
+			mb_head = slot->mbuf;
+		mb_tail = slot->mbuf;
+	if (removed != 0) {
+		sc->rx.queue_removes += removed;
+		sc->rx.active_queue_len -= removed;
+		sc->rx.avail_queue_len += removed;
+		if (sc->rx.avail_queue_len > sc->rx.max_avail_queue_len)
+			sc->rx.max_avail_queue_len = sc->rx.avail_queue_len;
+	return (mb_head);
+static void
+cpsw_rx_enqueue(struct cpsw_softc *sc)
+	bus_dma_segment_t seg[1];
+	struct ifnet *ifp = sc->ifp;
+	struct cpsw_slots tmpqueue = STAILQ_HEAD_INITIALIZER(tmpqueue);
+	struct cpsw_slot *slot, *prev_slot = NULL;
+	struct cpsw_slot *last_old_slot, *first_new_slot;
+	int error, nsegs, added = 0;
+	/* Register new mbufs with hardware. */
+	while ((slot = STAILQ_FIRST(&sc->rx.avail)) != NULL) {
+		if (slot->mbuf == NULL) {
+			slot->mbuf = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+				if_printf(sc->ifp, "Unable to fill RX queue\n");
+				break;
+			    slot->mbuf->m_ext.ext_size;
+		error = bus_dmamap_load_mbuf_sg(sc->mbuf_dtag, slot->dmamap,
+		    slot->mbuf, seg, &nsegs, BUS_DMA_NOWAIT);
+		KASSERT(nsegs == 1, ("More than one segment (nsegs=%d)", nsegs));
+		KASSERT(error == 0, ("DMA error (error=%d)", error));
+		if (error != 0 || nsegs != 1) {
+			if_printf(ifp,
+			    "%s: Can't prep RX buf for DMA (nsegs=%d, error=%d)\n",
+			    __func__, nsegs, error);
+			break;
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_PREREAD);
+		/* Create and submit new rx descriptor*/
+		bd.next = 0;
+		bd.bufptr = seg->ds_addr;
+		bd.bufoff = 0;
+		bd.buflen = MCLBYTES - 1;
+		bd.pktlen = bd.buflen;
+		bd.flags = CPDMA_BD_OWNER;
+		cpsw_cpdma_write_bd(sc, slot, &bd);
+		++added;
+		if (prev_slot != NULL)
+			cpsw_cpdma_write_bd_next(sc, prev_slot, slot);
+		prev_slot = slot;
+		STAILQ_REMOVE_HEAD(&sc->rx.avail, next);
+		sc->rx.avail_queue_len--;
+		STAILQ_INSERT_TAIL(&tmpqueue, slot, next);
+	if (added == 0)
+		return;
+	CPSW_DEBUGF(("Adding %d buffers to RX queue", added));
+	/* Link new entries to hardware RX queue. */
+	last_old_slot = STAILQ_LAST(&sc->rx.active, cpsw_slot, next);
+	first_new_slot = STAILQ_FIRST(&tmpqueue);
+	STAILQ_CONCAT(&sc->rx.active, &tmpqueue);
+	if (first_new_slot == NULL) {
+		return;
+	} else if (last_old_slot == NULL) {
+		/* Start a fresh queue. */
+		cpsw_write_hdp_slot(sc, &sc->rx, first_new_slot);
+	} else {
+		/* Add buffers to end of current queue. */
+		cpsw_cpdma_write_bd_next(sc, last_old_slot, first_new_slot);
+		/* If underrun, restart queue. */
+		if (cpsw_cpdma_read_bd_flags(sc, last_old_slot) & CPDMA_BD_EOQ) {
+	sc->rx.queue_adds += added;
+	sc->rx.active_queue_len += added;
+	if (sc->rx.active_queue_len > sc->rx.max_active_queue_len) {
+		sc->rx.max_active_queue_len = sc->rx.active_queue_len;
+static void
+cpsw_start(struct ifnet *ifp)
+	CPSW_TX_LOCK(sc);
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) && sc->tx.running) {
+		cpsw_tx_enqueue(sc);
+static void
+cpsw_tx_enqueue(struct cpsw_softc *sc)
+	bus_dma_segment_t segs[CPSW_TXFRAGS];
+	struct mbuf *m0;
+	int error, nsegs, seg, added = 0, padlen;
+	/* Pull pending packets from IF queue and prep them for DMA. */
+	while ((slot = STAILQ_FIRST(&sc->tx.avail)) != NULL) {
+		IF_DEQUEUE(&sc->ifp->if_snd, m0);
+		if (m0 == NULL)
+			break;
+		slot->mbuf = m0;
+		padlen = ETHER_MIN_LEN - slot->mbuf->m_pkthdr.len;
+		if (padlen < 0)
+			padlen = 0;
+		/* Create mapping in DMA memory */
+		    slot->mbuf, segs, &nsegs, BUS_DMA_NOWAIT);
+		/* If the packet is too fragmented, try to simplify. */
+		if (error == EFBIG ||
+		    (error == 0 &&
+			nsegs + (padlen > 0 ? 1 : 0) > sc->tx.avail_queue_len)) {
+			if (padlen > 0) /* May as well add padding. */
+				m_append(slot->mbuf, padlen,
+				    sc->null_mbuf->m_data);
+			m0 = m_defrag(slot->mbuf, M_NOWAIT);
+			if (m0 == NULL) {
+				    "Can't defragment packet; dropping\n");
+			} else {
+				CPSW_DEBUGF(("Requeueing defragmented packet"));
+				IF_PREPEND(&sc->ifp->if_snd, m0);
+			continue;
+		if (error != 0) {
+			    "%s: Can't setup DMA (error=%d), dropping packet\n",
+			    __func__, error);
+			break;
+		CPSW_DEBUGF(("Queueing TX packet: %d segments + %d pad bytes",
+			nsegs, padlen));
+		/* If there is only one segment, the for() loop
+		 * gets skipped and the single buffer gets set up
+		 * as both SOP and EOP. */
+		/* Start by setting up the first buffer */
+		bd.next = 0;
+		bd.bufptr = segs[0].ds_addr;
+		bd.bufoff = 0;
+		bd.buflen = segs[0].ds_len;
+		bd.pktlen = m_length(slot->mbuf, NULL) + padlen;
+		bd.flags =  CPDMA_BD_SOP | CPDMA_BD_OWNER;
+		for (seg = 1; seg < nsegs; ++seg) {
+			/* Save the previous buffer (which isn't EOP) */
+			prev_slot = slot;
+			STAILQ_REMOVE_HEAD(&sc->tx.avail, next);
+			sc->tx.avail_queue_len--;
+			++added;
+			slot = STAILQ_FIRST(&sc->tx.avail);
+			/* Setup next buffer (which isn't SOP) */
+			bd.next = 0;
+			bd.bufptr = segs[seg].ds_addr;
+			bd.bufoff = 0;
+			bd.buflen = segs[seg].ds_len;
+			bd.pktlen = 0;
+		/* Save the final buffer. */
+		if (padlen <= 0)
+			bd.flags |= CPDMA_BD_EOP;
+		prev_slot = slot;
+		++added;
+		if (padlen > 0) {
+			++added;
+			/* Setup buffer of null pad bytes (definitely EOP) */
+			prev_slot = slot;
+			bd.next = 0;
+			bd.bufptr = sc->null_mbuf_paddr;
+			bd.bufoff = 0;
+			bd.buflen = padlen;
+			bd.pktlen = 0;
+			bd.flags = CPDMA_BD_EOP | CPDMA_BD_OWNER;
+			++nsegs;
+		if (nsegs > sc->tx.longest_chain)
+			sc->tx.longest_chain = nsegs;
+		// TODO: Should we defer the BPF tap until
+		// after all packets are queued?
+		BPF_MTAP(sc->ifp, m0);
+	/* Attach the list of new buffers to the hardware TX queue. */
+	last_old_slot = STAILQ_LAST(&sc->tx.active, cpsw_slot, next);
+	STAILQ_CONCAT(&sc->tx.active, &tmpqueue);
+		return;
+		cpsw_write_hdp_slot(sc, &sc->tx, first_new_slot);
+	} else {
+	sc->tx.queue_adds += added;
+	sc->tx.active_queue_len += added;
+	if (sc->tx.active_queue_len > sc->tx.max_active_queue_len) {
+		sc->tx.max_active_queue_len = sc->tx.active_queue_len;
+static int
+cpsw_tx_dequeue(struct cpsw_softc *sc)
+	struct cpsw_slot *slot, *last_removed_slot = NULL;
+	uint32_t flags, removed = 0;
+	if (slot == NULL && cpsw_read_cp(sc, &sc->tx) == 0xfffffffc) {
+		CPSW_DEBUGF(("TX teardown of an empty queue"));
+		cpsw_write_cp(sc, &sc->tx, 0xfffffffc);
+		sc->tx.running = 0;
+		return (0);
+	/* Pull completed buffers off the hardware TX queue. */
+	while (slot != NULL) {
+		flags = cpsw_cpdma_read_bd_flags(sc, slot);
+		if (flags & CPDMA_BD_OWNER)
+			break; /* Hardware is still using this packet. */
+		CPSW_DEBUGF(("TX removing completed packet"));
+		bus_dmamap_sync(sc->mbuf_dtag, slot->dmamap, BUS_DMASYNC_POSTWRITE);
+		/* Dequeue any additional buffers used by this packet. */
+		while (slot != NULL && slot->mbuf == NULL) {
+			STAILQ_REMOVE_HEAD(&sc->tx.active, next);
+			STAILQ_INSERT_TAIL(&sc->tx.avail, slot, next);
+			++removed;
+			last_removed_slot = slot;
+		/* TearDown complete is only marked on the SOP for the packet. */
+		if (flags & CPDMA_BD_TDOWNCMPLT) {
+			CPSW_DEBUGF(("TX teardown in progress"));
+			// TODO: Increment a count of dropped TX packets
+			break;
+		cpsw_write_cp_slot(sc, &sc->tx, last_removed_slot);
+		sc->tx.queue_removes += removed;
+		sc->tx.active_queue_len -= removed;
+		sc->tx.avail_queue_len += removed;
+		if (sc->tx.avail_queue_len > sc->tx.max_avail_queue_len)
+			sc->tx.max_avail_queue_len = sc->tx.avail_queue_len;
+	return (removed);
+ * Miscellaneous interrupts.
+static void
+cpsw_intr_rx_thresh(void *arg)
+	uint32_t stat = cpsw_read_4(sc, CPSW_WR_C_RX_THRESH_STAT(0));
+	CPSW_DEBUGF(("stat=%x", stat));
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 0);
+static void
+cpsw_intr_misc_host_error(struct cpsw_softc *sc)
+	uint32_t intstat;
+	uint32_t dmastat;
+	int txerr, rxerr, txchan, rxchan;
+	printf("\n\n");
+	    "HOST ERROR:  PROGRAMMING ERROR DETECTED BY HARDWARE\n");
+	printf("\n\n");
+	intstat = cpsw_read_4(sc, CPSW_CPDMA_DMA_INTSTAT_MASKED);
+	device_printf(sc->dev, "CPSW_CPDMA_DMA_INTSTAT_MASKED=0x%x\n", intstat);
+	dmastat = cpsw_read_4(sc, CPSW_CPDMA_DMASTATUS);
+	device_printf(sc->dev, "CPSW_CPDMA_DMASTATUS=0x%x\n", dmastat);
+	txerr = (dmastat >> 20) & 15;
+	txchan = (dmastat >> 16) & 7;
+	rxerr = (dmastat >> 12) & 15;
+	rxchan = (dmastat >> 8) & 7;
+	switch (txerr) {
+	case 0: break;
+	case 1:	printf("SOP error on TX channel %d\n", txchan);
+		break;
+	case 2:	printf("Ownership bit not set on SOP buffer on TX channel %d\n", txchan);
+		break;
+	case 3:	printf("Zero Next Buffer but not EOP on TX channel %d\n", txchan);
+		break;
+	case 4:	printf("Zero Buffer Pointer on TX channel %d\n", txchan);
+		break;
+	case 5:	printf("Zero Buffer Length on TX channel %d\n", txchan);
+		break;
+	case 6:	printf("Packet length error on TX channel %d\n", txchan);
+		break;
+	default: printf("Unknown error on TX channel %d\n", txchan);
+		break;
+	if (txerr != 0) {
+		printf("CPSW_CPDMA_TX%d_HDP=0x%x\n",
+		    txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_HDP(txchan)));
+		printf("CPSW_CPDMA_TX%d_CP=0x%x\n",
+		    txchan, cpsw_read_4(sc, CPSW_CPDMA_TX_CP(txchan)));
+		cpsw_dump_queue(sc, &sc->tx.active);
+	switch (rxerr) {
+	case 0: break;
+	case 2:	printf("Ownership bit not set on RX channel %d\n", rxchan);
+		break;
+	case 4:	printf("Zero Buffer Pointer on RX channel %d\n", rxchan);
+		break;
+	case 5:	printf("Zero Buffer Length on RX channel %d\n", rxchan);
+		break;
+	case 6:	printf("Buffer offset too big on RX channel %d\n", rxchan);
+		break;
+	default: printf("Unknown RX error on RX channel %d\n", rxchan);
+		break;
+	if (rxerr != 0) {
+		printf("CPSW_CPDMA_RX%d_HDP=0x%x\n",
+		    rxchan, cpsw_read_4(sc,CPSW_CPDMA_RX_HDP(rxchan)));
+		printf("CPSW_CPDMA_RX%d_CP=0x%x\n",
+		    rxchan, cpsw_read_4(sc, CPSW_CPDMA_RX_CP(rxchan)));
+		cpsw_dump_queue(sc, &sc->rx.active);
+	printf("\nALE Table\n");
+	cpsw_ale_dump_table(sc);
+	// XXX do something useful here??
+	panic("CPSW HOST ERROR INTERRUPT");
+	// Suppress this interrupt in the future.
+	cpsw_write_4(sc, CPSW_CPDMA_DMA_INTMASK_CLEAR, intstat);
+	printf("XXX HOST ERROR INTERRUPT SUPPRESSED\n");
+	// The watchdog will probably reset the controller
+	// in a little while.  It will probably fail again.
+static void
+cpsw_intr_misc(void *arg)
+	uint32_t stat = cpsw_read_4(sc, CPSW_WR_C_MISC_STAT(0));
+	if (stat & 16)
+		CPSW_DEBUGF(("Time sync event interrupt unimplemented"));
+	if (stat & 8)
+	if (stat & 4)
+		cpsw_intr_misc_host_error(sc);
+	if (stat & 2)
+		CPSW_DEBUGF(("MDIO link change interrupt unimplemented"));
+	if (stat & 1)
+		CPSW_DEBUGF(("MDIO operation completed interrupt unimplemented"));
+	cpsw_write_4(sc, CPSW_CPDMA_CPDMA_EOI_VECTOR, 3);
+ * Periodic Checks and Watchdog.
+static void
+cpsw_tick(void *msc)
+	struct cpsw_softc *sc = msc;
+	/* Check for TX timeout */
+	cpsw_tx_watchdog(sc);
+	/* Check for media type change */
+	mii_tick(sc->mii);
+	if(sc->cpsw_media_status != sc->mii->mii_media.ifm_media) {
+		printf("%s: media type changed (ifm_media=%x)\n", __func__,
+			sc->mii->mii_media.ifm_media);
+		cpsw_ifmedia_upd(sc->ifp);
+	/* Schedule another timeout one second from now */
+static void
+cpsw_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
+	struct mii_data *mii;
+	CPSW_TX_LOCK(sc);
+	mii = sc->mii;
+	mii_pollstat(mii);
+	ifmr->ifm_active = mii->mii_media_active;
+	ifmr->ifm_status = mii->mii_media_status;
+static int
+cpsw_ifmedia_upd(struct ifnet *ifp)
+		sc->cpsw_media_status = sc->mii->mii_media.ifm_media;
+		mii_mediachg(sc->mii);
+	return (0);
+static void
+cpsw_tx_watchdog_full_reset(struct cpsw_softc *sc)
+	cpsw_debugf_head("CPSW watchdog");
+	if_printf(sc->ifp, "watchdog timeout\n");
+static void
+cpsw_tx_watchdog(struct cpsw_softc *sc)
+	if (sc->tx.active_queue_len == 0 || (ifp->if_flags & IFF_UP) == 0 ||
+	    (ifp->if_drv_flags & IFF_DRV_RUNNING) == 0 || !sc->tx.running) {
+		sc->watchdog.timer = 0; /* Nothing to do. */
+	} else if (sc->tx.queue_removes > sc->tx.queue_removes_at_last_tick) {
+		sc->watchdog.timer = 0;  /* Stuff done while we weren't looking. */
+	} else if (cpsw_tx_dequeue(sc) > 0) {
+		sc->watchdog.timer = 0;  /* We just did something. */
+	} else {
+		/* There was something to do but it didn't get done. */
+		++sc->watchdog.timer;
+		if (sc->watchdog.timer > 2) {
+			if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
+			++sc->watchdog.resets;
+			cpsw_tx_watchdog_full_reset(sc);
+	sc->tx.queue_removes_at_last_tick = sc->tx.queue_removes;
+ * ALE support routines.
+static void
+cpsw_ale_read_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
+	cpsw_write_4(sc, CPSW_ALE_TBLCTL, idx & 1023);
+	ale_entry[0] = cpsw_read_4(sc, CPSW_ALE_TBLW0);
+	ale_entry[1] = cpsw_read_4(sc, CPSW_ALE_TBLW1);
+	ale_entry[2] = cpsw_read_4(sc, CPSW_ALE_TBLW2);
+static void
+cpsw_ale_write_entry(struct cpsw_softc *sc, uint16_t idx, uint32_t *ale_entry)
+	cpsw_write_4(sc, CPSW_ALE_TBLW0, ale_entry[0]);
+	cpsw_write_4(sc, CPSW_ALE_TBLW1, ale_entry[1]);
+	cpsw_write_4(sc, CPSW_ALE_TBLW2, ale_entry[2]);
+	cpsw_write_4(sc, CPSW_ALE_TBLCTL, 1 << 31 | (idx & 1023));
+static int
+cpsw_ale_remove_all_mc_entries(struct cpsw_softc *sc)
+	int i;
+	uint32_t ale_entry[3];
+	/* First two entries are link address and broadcast. */
+	for (i = 2; i < CPSW_MAX_ALE_ENTRIES; i++) {
+		cpsw_ale_read_entry(sc, i, ale_entry);
+		if (((ale_entry[1] >> 28) & 3) == 1 && /* Address entry */
+		    ((ale_entry[1] >> 8) & 1) == 1) { /* MCast link addr */
+			ale_entry[0] = ale_entry[1] = ale_entry[2] = 0;
+			cpsw_ale_write_entry(sc, i, ale_entry);
+	return CPSW_MAX_ALE_ENTRIES;
+static int
+cpsw_ale_mc_entry_set(struct cpsw_softc *sc, uint8_t portmap, uint8_t *mac)
+	int free_index = -1, matching_index = -1, i;
+	/* Find a matching entry or a free entry. */
+	for (i = 0; i < CPSW_MAX_ALE_ENTRIES; i++) {
+		/* Entry Type[61:60] is 0 for free entry */
+		if (free_index < 0 && ((ale_entry[1] >> 28) & 3) == 0) {
+			free_index = i;
+		if ((((ale_entry[1] >> 8) & 0xFF) == mac[0]) &&
+		    (((ale_entry[1] >> 0) & 0xFF) == mac[1]) &&
+		    (((ale_entry[0] >>24) & 0xFF) == mac[2]) &&
+		    (((ale_entry[0] >>16) & 0xFF) == mac[3]) &&
+		    (((ale_entry[0] >> 8) & 0xFF) == mac[4]) &&
+		    (((ale_entry[0] >> 0) & 0xFF) == mac[5])) {
+			matching_index = i;
+			break;
+	if (matching_index < 0) {
+		if (free_index < 0)
+			return (ENOMEM);
+		i = free_index;
+	/* Set MAC address */
+	ale_entry[0] = mac[2] << 24 | mac[3] << 16 | mac[4] << 8 | mac[5];
+	ale_entry[1] = mac[0] << 8 | mac[1];
+	/* Entry type[61:60] is addr entry(1), Mcast fwd state[63:62] is fw(3)*/
+	ale_entry[1] |= 0xd0 << 24;
+	/* Set portmask [68:66] */
+	ale_entry[2] = (portmap & 7) << 2;
+	return 0;
+static void
+cpsw_ale_dump_table(struct cpsw_softc *sc) {
+	int i;
+		if (ale_entry[0] || ale_entry[1] || ale_entry[2]) {
+			printf("ALE[%4u] %08x %08x %08x ", i, ale_entry[0],
+				ale_entry[1], ale_entry[2]);
+			printf("mac: %02x:%02x:%02x:%02x:%02x:%02x ",
+				(ale_entry[1] >> 8) & 0xFF,
+				(ale_entry[1] >> 0) & 0xFF,
+				(ale_entry[0] >>24) & 0xFF,
+				(ale_entry[0] >>16) & 0xFF,
+				(ale_entry[0] >> 8) & 0xFF,
+				(ale_entry[0] >> 0) & 0xFF);
+			printf(((ale_entry[1] >> 8) & 1) ? "mcast " : "ucast ");
+			printf("type: %u ", (ale_entry[1] >> 28) & 3);
+			printf("port: %u ", (ale_entry[2] >> 2) & 7);
+			printf("\n");
+	printf("\n");
+static int
+cpsw_ale_update_addresses(struct cpsw_softc *sc, int purge)
+	uint8_t *mac;
+	struct ifmultiaddr *ifma;
+	int i;
+	/* Route incoming packets for our MAC address to Port 0 (host). */
+	/* For simplicity, keep this entry at table index 0 in the ALE. */
+        if_addr_rlock(ifp);
+	mac = LLADDR((struct sockaddr_dl *)ifp->if_addr->ifa_addr);
+	ale_entry[1] = 0x10 << 24 | mac[0] << 8 | mac[1]; /* addr entry + mac */
+	ale_entry[2] = 0; /* port = 0 */
+	cpsw_ale_write_entry(sc, 0, ale_entry);
+	/* Set outgoing MAC Address for Ports 1 and 2. */
+	for (i = 1; i < 3; ++i) {
+		cpsw_write_4(sc, CPSW_PORT_P_SA_HI(i),
+		    mac[3] << 24 | mac[2] << 16 | mac[1] << 8 | mac[0]);
+		cpsw_write_4(sc, CPSW_PORT_P_SA_LO(i),
+		    mac[5] << 8 | mac[4]);
+        if_addr_runlock(ifp);
+	/* Keep the broadcast address at table entry 1. */
+	ale_entry[0] = 0xffffffff; /* Lower 32 bits of MAC */
+	ale_entry[1] = 0xd000ffff; /* FW (3 << 30), Addr entry (1 << 24), upper 16 bits of Mac */
+	ale_entry[2] = 0x0000001c; /* Forward to all ports */
+	cpsw_ale_write_entry(sc, 1, ale_entry);
+	/* SIOCDELMULTI doesn't specify the particular address
+	   being removed, so we have to remove all and rebuild. */
+	if (purge)
+		cpsw_ale_remove_all_mc_entries(sc);
+        /* Set other multicast addrs desired. */
+        if_maddr_rlock(ifp);
+        TAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
+                if (ifma->ifma_addr->sa_family != AF_LINK)
+                        continue;
+		cpsw_ale_mc_entry_set(sc, 7,
+		    LLADDR((struct sockaddr_dl *)ifma->ifma_addr));
+        if_maddr_runlock(ifp);
+	return (0);
+ * Statistics and Sysctls.
+#if 0
+static void
+cpsw_stats_dump(struct cpsw_softc *sc)
+	int i;
+	uint32_t r;
+	for (i = 0; i < CPSW_SYSCTL_COUNT; ++i) {
+		r = cpsw_read_4(sc, CPSW_STATS_OFFSET +
+		    cpsw_stat_sysctls[i].reg);
+		CPSW_DEBUGF(("%s: %ju + %u = %ju", cpsw_stat_sysctls[i].oid,
+			     (intmax_t)sc->shadow_stats[i], r,
+			     (intmax_t)sc->shadow_stats[i] + r));
+#endif
+static void
+cpsw_stats_collect(struct cpsw_softc *sc)
+	int i;
+	uint32_t r;
+	CPSW_DEBUGF(("Controller shadow statistics updated."));
+		sc->shadow_stats[i] += r;
+		cpsw_write_4(sc, CPSW_STATS_OFFSET + cpsw_stat_sysctls[i].reg, r);
+static int
+cpsw_stats_sysctl(SYSCTL_HANDLER_ARGS)
+	struct cpsw_softc *sc;
+	struct cpsw_stat *stat;
+	uint64_t result;
+	sc = (struct cpsw_softc *)arg1;
+	stat = &cpsw_stat_sysctls[oidp->oid_number];
+	result = sc->shadow_stats[oidp->oid_number];
+	result += cpsw_read_4(sc, CPSW_STATS_OFFSET + stat->reg);
+	return (sysctl_handle_64(oidp, &result, 0, req));
+static int
+cpsw_stat_attached(SYSCTL_HANDLER_ARGS)
+	struct bintime t;
+	unsigned result;
+	getbinuptime(&t);
+	bintime_sub(&t, &sc->attach_uptime);
+	result = t.sec;
+	return (sysctl_handle_int(oidp, &result, 0, req));
+static int
+cpsw_stat_uptime(SYSCTL_HANDLER_ARGS)
+	struct bintime t;
+	unsigned result;
+	if (sc->ifp->if_drv_flags & IFF_DRV_RUNNING) {
+		getbinuptime(&t);
+		bintime_sub(&t, &sc->init_uptime);
+		result = t.sec;
+	} else
+		result = 0;
+static void
+cpsw_add_queue_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node, struct cpsw_queue *queue)
+	struct sysctl_oid_list *parent;
+	parent = SYSCTL_CHILDREN(node);
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "totalBuffers",
+	    CTLFLAG_RD, &queue->queue_slots, 0,
+	    "Total buffers currently assigned to this queue");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "activeBuffers",
+	    CTLFLAG_RD, &queue->active_queue_len, 0,
+	    "Buffers currently registered with hardware controller");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxActiveBuffers",
+	    CTLFLAG_RD, &queue->max_active_queue_len, 0,
+	    "Max value of activeBuffers since last driver reset");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "availBuffers",
+	    CTLFLAG_RD, &queue->avail_queue_len, 0,
+	    "Buffers allocated to this queue but not currently "
+	    "registered with hardware controller");
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "maxAvailBuffers",
+	    CTLFLAG_RD, &queue->max_avail_queue_len, 0,
+	    "Max value of availBuffers since last driver reset");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalEnqueued",
+	    CTLFLAG_RD, &queue->queue_adds, 0,
+	    "Total buffers added to queue");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "totalDequeued",
+	    CTLFLAG_RD, &queue->queue_removes, 0,
+	    "Total buffers removed from queue");
+	SYSCTL_ADD_UINT(ctx, parent, OID_AUTO, "longestChain",
+	    CTLFLAG_RD, &queue->longest_chain, 0,
+	    "Max buffers used for a single packet");
+static void
+cpsw_add_watchdog_sysctls(struct sysctl_ctx_list *ctx, struct sysctl_oid *node, struct cpsw_softc *sc)
+	SYSCTL_ADD_INT(ctx, parent, OID_AUTO, "resets",
+	    CTLFLAG_RD, &sc->watchdog.resets, 0,
+	    "Total number of watchdog resets");
+static void
+cpsw_add_sysctls(struct cpsw_softc *sc)
+	struct sysctl_ctx_list *ctx;
+	struct sysctl_oid *stats_node, *queue_node, *node;
+	struct sysctl_oid_list *parent, *stats_parent, *queue_parent;
+	int i;
+	ctx = device_get_sysctl_ctx(sc->dev);
+	parent = SYSCTL_CHILDREN(device_get_sysctl_tree(sc->dev));
+	SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "attachedSecs",
+	    CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_attached, "IU",
+	    "Time since driver attach");
+	SYSCTL_ADD_PROC(ctx, parent, OID_AUTO, "uptime",
+	    CTLTYPE_UINT | CTLFLAG_RD, sc, 0, cpsw_stat_uptime, "IU",
+	    "Seconds since driver init");
+	stats_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "stats",
+				     CTLFLAG_RD, NULL, "CPSW Statistics");
+	stats_parent = SYSCTL_CHILDREN(stats_node);
+		SYSCTL_ADD_PROC(ctx, stats_parent, i,
+				cpsw_stat_sysctls[i].oid,
+				CTLTYPE_U64 | CTLFLAG_RD, sc, 0,
+				cpsw_stats_sysctl, "IU",
+				cpsw_stat_sysctls[i].oid);
+	queue_node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "queue",
+	    CTLFLAG_RD, NULL, "CPSW Queue Statistics");
+	queue_parent = SYSCTL_CHILDREN(queue_node);
+	node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "tx",
+	    CTLFLAG_RD, NULL, "TX Queue Statistics");
+	cpsw_add_queue_sysctls(ctx, node, &sc->tx);
+	node = SYSCTL_ADD_NODE(ctx, queue_parent, OID_AUTO, "rx",
+	    CTLFLAG_RD, NULL, "RX Queue Statistics");
+	cpsw_add_queue_sysctls(ctx, node, &sc->rx);
+	node = SYSCTL_ADD_NODE(ctx, parent, OID_AUTO, "watchdog",
+	    CTLFLAG_RD, NULL, "Watchdog Statistics");
+	cpsw_add_watchdog_sysctls(ctx, node, sc);
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswreg.h b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
index 0000000..46f8417
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
@@ -0,0 +1,137 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_IF_CPSWREG_H
+#define	_IF_CPSWREG_H
+#define CPSW_SS_OFFSET			0x0000
+#define CPSW_SS_IDVER			(CPSW_SS_OFFSET + 0x00)
+#define CPSW_SS_SOFT_RESET		(CPSW_SS_OFFSET + 0x08)
+#define CPSW_SS_STAT_PORT_EN		(CPSW_SS_OFFSET + 0x0C)
+#define CPSW_SS_PTYPE			(CPSW_SS_OFFSET + 0x10)
+#define	CPSW_SS_FLOW_CONTROL		(CPSW_SS_OFFSET + 0x24)
+#define CPSW_PORT_OFFSET		0x0100
+#define	CPSW_PORT_P_MAX_BLKS(p)		(CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
+#define	CPSW_PORT_P_BLK_CNT(p)		(CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
+#define CPSW_PORT_P_TX_PRI_MAP(p)	(CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
+#define CPSW_PORT_P0_CPDMA_TX_PRI_MAP	(CPSW_PORT_OFFSET + 0x01C)
+#define CPSW_PORT_P0_CPDMA_RX_CH_MAP	(CPSW_PORT_OFFSET + 0x020)
+#define CPSW_PORT_P_SA_LO(p)		(CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
+#define CPSW_PORT_P_SA_HI(p)		(CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
+#define CPSW_CPDMA_OFFSET		0x0800
+#define CPSW_CPDMA_TX_CONTROL		(CPSW_CPDMA_OFFSET + 0x04)
+#define CPSW_CPDMA_TX_TEARDOWN		(CPSW_CPDMA_OFFSET + 0x08)
+#define CPSW_CPDMA_RX_CONTROL		(CPSW_CPDMA_OFFSET + 0x14)
+#define CPSW_CPDMA_RX_TEARDOWN		(CPSW_CPDMA_OFFSET + 0x18)
+#define CPSW_CPDMA_SOFT_RESET		(CPSW_CPDMA_OFFSET + 0x1c)
+#define CPSW_CPDMA_DMACONTROL		(CPSW_CPDMA_OFFSET + 0x20)
+#define CPSW_CPDMA_DMASTATUS		(CPSW_CPDMA_OFFSET + 0x24)
+#define CPSW_CPDMA_RX_BUFFER_OFFSET	(CPSW_CPDMA_OFFSET + 0x28)
+#define CPSW_CPDMA_TX_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0x80)
+#define CPSW_CPDMA_TX_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0x84)
+#define CPSW_CPDMA_TX_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0x88)
+#define CPSW_CPDMA_TX_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0x8C)
+#define CPSW_CPDMA_CPDMA_EOI_VECTOR	(CPSW_CPDMA_OFFSET + 0x94)
+#define CPSW_CPDMA_RX_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0xA0)
+#define CPSW_CPDMA_RX_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0xA4)
+#define CPSW_CPDMA_RX_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0xA8)
+#define CPSW_CPDMA_RX_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0xAc)
+#define CPSW_CPDMA_DMA_INTSTAT_RAW	(CPSW_CPDMA_OFFSET + 0xB0)
+#define CPSW_CPDMA_DMA_INTSTAT_MASKED	(CPSW_CPDMA_OFFSET + 0xB4)
+#define CPSW_CPDMA_DMA_INTMASK_SET	(CPSW_CPDMA_OFFSET + 0xB8)
+#define CPSW_CPDMA_DMA_INTMASK_CLEAR	(CPSW_CPDMA_OFFSET + 0xBC)
+#define CPSW_CPDMA_RX_FREEBUFFER(p)	(CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
+#define CPSW_STATS_OFFSET		0x0900
+#define CPSW_STATERAM_OFFSET		0x0A00
+#define CPSW_CPDMA_TX_HDP(p)		(CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_HDP(p)		(CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
+#define CPSW_CPDMA_TX_CP(p)		(CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_CP(p)		(CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
+#define CPSW_CPTS_OFFSET		0x0C00
+#define CPSW_ALE_OFFSET			0x0D00
+#define CPSW_ALE_CONTROL		(CPSW_ALE_OFFSET + 0x08)
+#define CPSW_ALE_TBLCTL			(CPSW_ALE_OFFSET + 0x20)
+#define CPSW_ALE_TBLW2			(CPSW_ALE_OFFSET + 0x34)
+#define CPSW_ALE_TBLW1			(CPSW_ALE_OFFSET + 0x38)
+#define CPSW_ALE_TBLW0			(CPSW_ALE_OFFSET + 0x3C)
+#define CPSW_ALE_PORTCTL(p)		(CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
+/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
+#define CPSW_SL_OFFSET			0x0D80
+#define CPSW_SL_MACCONTROL(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
+#define CPSW_SL_MACSTATUS(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
+#define CPSW_SL_SOFT_RESET(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
+#define CPSW_SL_RX_MAXLEN(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
+#define CPSW_SL_RX_PAUSE(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
+#define CPSW_SL_TX_PAUSE(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
+#define CPSW_SL_RX_PRI_MAP(p)		(CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
+#define MDIO_OFFSET			0x1000
+#define MDIOCONTROL			(MDIO_OFFSET + 0x04)
+#define MDIOUSERACCESS0			(MDIO_OFFSET + 0x80)
+#define MDIOUSERPHYSEL0			(MDIO_OFFSET + 0x84)
+#define CPSW_WR_OFFSET			0x1200
+#define CPSW_WR_SOFT_RESET		(CPSW_WR_OFFSET + 0x04)
+#define CPSW_WR_CONTROL			(CPSW_WR_OFFSET + 0x08)
+#define CPSW_WR_INT_CONTROL		(CPSW_WR_OFFSET + 0x0c)
+#define CPSW_WR_C_RX_THRESH_EN(p)	(CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
+#define CPSW_WR_C_RX_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
+#define CPSW_WR_C_TX_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
+#define CPSW_WR_C_MISC_EN(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
+#define CPSW_WR_C_RX_THRESH_STAT(p)	(CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
+#define CPSW_WR_C_RX_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
+#define CPSW_WR_C_TX_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
+#define CPSW_WR_C_MISC_STAT(p)		(CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
+#define CPSW_CPPI_RAM_OFFSET		0x2000
+#define	CPSW_CPPI_RAM_SIZE		0x2000
+#define CPDMA_BD_SOP		(1<<15)
+#define CPDMA_BD_EOP		(1<<14)
+#define CPDMA_BD_OWNER		(1<<13)
+#define CPDMA_BD_EOQ		(1<<12)
+#define CPDMA_BD_TDOWNCMPLT	(1<<11)
+#define CPDMA_BD_PKT_ERR_MASK	(3<< 4)
+struct cpsw_cpdma_bd {
+	volatile uint32_t next;
+	volatile uint32_t bufptr;
+	volatile uint16_t buflen;
+	volatile uint16_t bufoff;
+	volatile uint16_t pktlen;
+	volatile uint16_t flags;
+#endif /*_IF_CPSWREG_H */
diff --git a/freebsd/sys/arm/ti/cpsw/if_cpswvar.h b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
index 0000000..2aebb0f
--- /dev/null
+++ b/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
@@ -0,0 +1,124 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_IF_CPSWVAR_H
+#define	_IF_CPSWVAR_H
+#define CPSW_INTR_COUNT		4
+/* MII BUS  */
+#define CPSW_MIIBUS_RETRIES	5
+#define CPSW_MIIBUS_DELAY	1000
+#define CPSW_MAX_ALE_ENTRIES	1024
+#define CPSW_SYSCTL_COUNT 34
+struct cpsw_slot {
+	uint32_t bd_offset;  /* Offset of corresponding BD within CPPI RAM. */
+	bus_dmamap_t dmamap;
+	struct mbuf *mbuf;
+	STAILQ_ENTRY(cpsw_slot) next;
+STAILQ_HEAD(cpsw_slots, cpsw_slot);
+struct cpsw_queue {
+	struct mtx	lock;
+	int		running;
+	struct cpsw_slots active;
+	struct cpsw_slots avail;
+	uint32_t	queue_adds; /* total bufs added */
+	uint32_t	queue_removes; /* total bufs removed */
+	uint32_t	queue_removes_at_last_tick; /* Used by watchdog */
+	int		queue_slots;
+	int		active_queue_len;
+	int		max_active_queue_len;
+	int		avail_queue_len;
+	int		max_avail_queue_len;
+	int		longest_chain; /* Largest # segments in a single packet. */
+	int		hdp_offset;
+struct cpsw_softc {
+	phandle_t	node;
+	device_t	dev;
+	struct bintime	attach_uptime; /* system uptime when attach happened. */
+	struct bintime	init_uptime; /* system uptime when init happened. */
+	/* TODO: We should set up a child structure for each port;
+	   store mac, phy information, etc, in that structure. */
+	uint8_t		mac_addr[ETHER_ADDR_LEN];
+	device_t	miibus;
+	/* We expect 1 memory resource and 4 interrupts from the device tree. */
+	struct resource	*res[1 + CPSW_INTR_COUNT];
+	/* Interrupts get recorded here as we initialize them. */
+	/* Interrupt teardown just walks this list. */
+	struct {
+		struct resource *res;
+		void		*ih_cookie;
+		const char *description;
+	} interrupts[CPSW_INTR_COUNT];
+	int		interrupt_count;
+	uint32_t	cpsw_if_flags;
+	int		cpsw_media_status;
+	struct {
+		int resets;
+		int timer;
+		struct callout	callout;
+	} watchdog;
+	bus_dma_tag_t	mbuf_dtag;
+	/* An mbuf full of nulls for TX padding. */
+	bus_dmamap_t null_mbuf_dmamap;
+	struct mbuf *null_mbuf;
+	bus_addr_t null_mbuf_paddr;
+	/* RX and TX buffer tracking */
+	struct cpsw_queue rx, tx;
+	/* 64-bit versions of 32-bit hardware statistics counters */
+	uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
+	/* CPPI STATERAM has 512 slots for building TX/RX queues. */
+	/* TODO: Size here supposedly varies with different versions
+	   of the controller.  Check DaVinci specs and find a good
+	   way to adjust this.  One option is to have a separate
+	   Device Tree parameter for number slots; another option
+	   is to calculate it from the memory size in the device tree. */
+	struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
+#endif /*_IF_CPSWVAR_H */
diff --git a/freebsd/sys/dev/mii/smscphy.c b/freebsd/sys/dev/mii/smscphy.c
new file mode 100644
index 0000000..601ec1b
--- /dev/null
+++ b/freebsd/sys/dev/mii/smscphy.c
@@ -0,0 +1,227 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2006 Benno Rice.  All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * Driver for the SMSC LAN8710A
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/socket.h>
+#include <sys/errno.h>
+#include <sys/module.h>
+#include <sys/bus.h>
+#include <sys/malloc.h>
+#include <machine/bus.h>
+#include <net/if.h>
+#include <net/if_media.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include "miidevs.h"
+#include "miibus_if.h"
+static int	smscphy_probe(device_t);
+static int	smscphy_attach(device_t);
+static int	smscphy_service(struct mii_softc *, struct mii_data *, int);
+static void	smscphy_auto(struct mii_softc *, int);
+static void	smscphy_status(struct mii_softc *);
+static device_method_t smscphy_methods[] = {
+	/* device interface */
+	DEVMETHOD(device_probe,		smscphy_probe),
+	DEVMETHOD(device_attach,	smscphy_attach),
+	DEVMETHOD(device_detach,	mii_phy_detach),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	DEVMETHOD_END
+static devclass_t smscphy_devclass;
+static driver_t smscphy_driver = {
+	"smscphy",
+	smscphy_methods,
+	sizeof(struct mii_softc)
+DRIVER_MODULE(smscphy, miibus, smscphy_driver, smscphy_devclass, 0, 0);
+static const struct mii_phydesc smscphys[] = {
+	MII_PHY_DESC(SMC, LAN8710A),
+	MII_PHY_END
+static const struct mii_phy_funcs smscphy_funcs = {
+	smscphy_service,
+	smscphy_status,
+	mii_phy_reset
+static int
+smscphy_probe(device_t dev)
+	return (mii_phy_dev_probe(dev, smscphys, BUS_PROBE_DEFAULT));
+static int
+smscphy_attach(device_t dev)
+	struct mii_softc *sc;
+	const struct mii_phy_funcs *mpf;
+	sc = device_get_softc(dev);
+	mpf = &smscphy_funcs;
+	mii_phy_dev_attach(dev, MIIF_NOISOLATE | MIIF_NOMANPAUSE, mpf, 1);
+	mii_phy_setmedia(sc);
+	return (0);
+static int
+smscphy_service(struct mii_softc *sc, struct mii_data *mii, int cmd)
+        struct	ifmedia_entry *ife;
+        int	reg;
+	ife = mii->mii_media.ifm_cur;
+        switch (cmd) {
+        case MII_POLLSTAT:
+                break;
+        case MII_MEDIACHG:
+		switch (IFM_SUBTYPE(ife->ifm_media)) {
+		case IFM_AUTO:
+			smscphy_auto(sc, ife->ifm_media);
+			break;
+		default:
+			break;
+                break;
+        case MII_TICK:
+		if (IFM_SUBTYPE(ife->ifm_media) != IFM_AUTO) {
+			break;
+		/* I have no idea why BMCR_ISO gets set. */
+		reg = PHY_READ(sc, MII_BMCR);
+		if (reg & BMCR_ISO) {
+			PHY_WRITE(sc, MII_BMCR, reg & ~BMCR_ISO);
+		reg = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
+		if (reg & BMSR_LINK) {
+			sc->mii_ticks = 0;
+			break;
+		if (++sc->mii_ticks <= MII_ANEGTICKS) {
+			break;
+		PHY_RESET(sc);
+                break;
+        /* Update the media status. */
+        PHY_STATUS(sc);
+        /* Callback if something changed. */
+        mii_phy_update(sc, cmd);
+        return (0);
+static void
+smscphy_auto(struct mii_softc *sc, int media)
+	uint16_t	anar;
+	anar = BMSR_MEDIA_TO_ANAR(sc->mii_capabilities) | ANAR_CSMA;
+	if ((media & IFM_FLOW) != 0 || (sc->mii_flags & MIIF_FORCEPAUSE) != 0)
+		anar |= ANAR_FC;
+	PHY_WRITE(sc, MII_ANAR, anar);
+	/* Apparently this helps. */
+	anar = PHY_READ(sc, MII_ANAR);
+	PHY_WRITE(sc, MII_BMCR, BMCR_AUTOEN | BMCR_STARTNEG);
+static void
+smscphy_status(struct mii_softc *sc)
+	uint32_t bmcr, bmsr, status;
+	mii = sc->mii_pdata;
+	mii->mii_media_status = IFM_AVALID;
+	mii->mii_media_active = IFM_ETHER;
+	bmsr = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
+	if ((bmsr & BMSR_LINK) != 0)
+		mii->mii_media_status |= IFM_ACTIVE;
+	bmcr = PHY_READ(sc, MII_BMCR);
+	if ((bmcr & BMCR_ISO) != 0) {
+		mii->mii_media_active |= IFM_NONE;
+		mii->mii_media_status = 0;
+		return;
+	if ((bmcr & BMCR_LOOP) != 0)
+		mii->mii_media_active |= IFM_LOOP;
+	if ((bmcr & BMCR_AUTOEN) != 0) {
+		if ((bmsr & BMSR_ACOMP) == 0) {
+			/* Erg, still trying, I guess... */
+			return;
+	status = PHY_READ(sc, 0x1F);
+	if (status & 0x0008)
+		mii->mii_media_active |= IFM_100_TX;
+	else
+		mii->mii_media_active |= IFM_10_T;
+	if (status & 0x0010)
+		mii->mii_media_active |= IFM_FDX | mii_phy_flowstatus(sc);
+	else
+		mii->mii_media_active |= IFM_HDX;
diff --git a/libbsd.py b/libbsd.py
index ebbdc98..776e228 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -810,6 +810,8 @@ def dev_net(mm):
             'sys/dev/cadence/if_cgem_hw.h',
             'sys/dev/dwc/if_dwc.h',
             'sys/arm/xilinx/zy7_slcr.h',
+            'sys/arm/ti/cpsw/if_cpswreg.h',
+            'sys/arm/ti/cpsw/if_cpswvar.h',
     mod.addKernelSpaceSourceFiles(
@@ -823,10 +825,12 @@ def dev_net(mm):
             'sys/dev/mii/micphy.c',
             'sys/dev/mii/ukphy.c',
             'sys/dev/mii/ukphy_subr.c',
+            'sys/dev/mii/smscphy.c',
             'sys/dev/tsec/if_tsec.c',
             'sys/dev/cadence/if_cgem.c',
             'sys/dev/dwc/if_dwc.c',
             'sys/arm/xilinx/zy7_slcr.c',
+            'sys/arm/ti/cpsw/if_cpsw.c',
 	mm.generator['source']()
diff --git a/wscript b/wscript
index 86d3ccf..94632a7 100644
--- a/wscript
+++ b/wscript
@@ -625,7 +625,8 @@ def build(bld):
                 source = objs06_source)
     libbsd_use += ["objs06"]
-    source = ['freebsd/sys/arm/xilinx/zy7_slcr.c',
+    source = ['freebsd/sys/arm/ti/cpsw/if_cpsw.c',
+              'freebsd/sys/arm/xilinx/zy7_slcr.c',
               'freebsd/sys/cam/cam.c',
               'freebsd/sys/cam/scsi/scsi_all.c',
               'freebsd/sys/contrib/altq/altq/altq_cbq.c',
@@ -697,6 +698,7 @@ def build(bld):
               'freebsd/sys/dev/mii/mii.c',
               'freebsd/sys/dev/mii/mii_bitbang.c',
               'freebsd/sys/dev/mii/mii_physubr.c',
+              'freebsd/sys/dev/mii/smscphy.c',
               'freebsd/sys/dev/mii/ukphy.c',
               'freebsd/sys/dev/mii/ukphy_subr.c',
               'freebsd/sys/dev/mmc/mmc.c',
1.9.1
