[PATCH] Beagle BSP Improvements (ADC driver)
Ketul Shah ketulshah1993 at gmail.com
Sat Jun 27 19:54:42 UTC 2015
Hello,
I have developed basic ADC driver for BBB and tested it on hardware by
giving dgnd to the AIN pin and getting 0-4 value for that.
Herewith I am attaching patch for the same. Kindly review it. Your
suggestion(s)/ comment(s) are welcomed.
Also I updated my GitHub
<https://github.com/ketul93/RTEMS-on-BBB/tree/master/ADC-TEST> for ADC
where working .img or .exe file can be found. And the whole code can be
found on RTEMS Repo <https://github.com/ketul93/rtems>.
Also attaching the screenshot of the working code on my pc. :)
Next week also planing to have a video of ADC demo.
Thanks.
Best Regards,
Ketul
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150628/e4b8d20e/attachment-0001.html>
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 6b876dd..debcc88 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -115,6 +115,9 @@ libbsp_a_SOURCES += ../../shared/console.c \
 # GPIO
 libbsp_a_SOURCES += gpio/gpio.c
+#ADC
+libbsp_a_SOURCES += adc/adc.c
 # I2C
 libbsp_a_SOURCES += misc/i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/adc/adc.c b/c/src/lib/libbsp/arm/beagle/adc/adc.c
new file mode 100644
index 0000000..63c3307
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/adc/adc.c
@@ -0,0 +1,97 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief ADC definitions.
+ * Copyright (c) 2015 Ketul Shah <ketulshah1993 at gmail.com>
+#include <libcpu/am335x.h>
+#include <rtems.h>
+#include <rtems/gpio.h>
+#include <bsp/irq.h>
+#include <bsp/beagleboneblack.h>
+#include <bsp.h>
+#include <stdlib.h>
+#include <stdint.h>
+static void inline reg_update_or(uint32_t reg, uint32_t val)
+ uint32_t reg_val=mmio_read(reg);
+ reg_val |= val;
+ mmio_write(reg, reg_val);
+/* Configure STEPCONFIG register with average of 16 */
+static void inline stepc_update_16(uint32_t reg, uint32_t val)
+ mmio_write(reg,(val | AM335X_ADC_AVG16));
+/* Configure STEPDELAY register */
+static void inline stepd_update(uint32_t reg)
+ mmio_write(reg,(0x0F)<<24);
+static uint32_t inline get_val(uint32_t reg, uint32_t val)
+ return (mmio_read(reg) & val);
+void rtems_adc_init(void)
+ /* Enable the CM_WKUP_ADC_CLKCTRL with CM_WKUP_MODUELEMODE_ENABLE */
+ reg_update_or(AM335X_CM_WKUP_ADC_CLKCTRL, AM335X_CM_WKUP_MODULEMODE_ENABLE);
+ while(!(get_val(AM335X_CM_WKUP_ADC_CLKCTRL,AM335X_CM_WKUP_MODULEMODE_ENABLE)))
+		/* Here waiting period for intialization of adc clock module */
+ /* Make sure STEPCONFIG write protect is off */
+ reg_update_or(AM335X_ADC_CTRL, AM335X_ADC_STEPCONFIG_WRITE_PROTECT_OFF);
+ /* ADC_STEPCONFIG for each AIN pin */
+ stepc_update_16(AM335X_ADC_STEPCONFIG1,0x00<<19);
+ stepd_update(AM335X_ADC_STEPDELAY1);
+ stepc_update_16(AM335X_ADC_STEPCONFIG2,0x01<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG3,0x02<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG4,0x03<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG5,0x04<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG6,0x05<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG7,0x06<<19);
+ stepc_update_16(AM335X_ADC_STEPCONFIG8,0x07<<19);
+ /* ADC_CTRL is enabled */
+ reg_update_or(AM335X_ADC_CTRL,0x01);
+int rtems_adc_read(unsigned int pin_number)
+ /* The clock module is not enabled */
+ if(get_val(AM335X_CM_WKUP_ADC_CLKCTRL,AM335X_CM_WKUP_IDLEST_DISABLED))
+	rtems_adc_init();
+ /* Enable the step sequencer for the given pin */
+ reg_update_or(AM335X_ADC_STEPENABLE,(0x01<<(pin_number+1)));
+ /* Return the value of data register FIFO0 */
+ return (get_val(AM335X_ADC_FIFO0DATA,AM335X_ADC_FIFO_MASK));
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h b/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h
index 5630645..4e6b589 100644
--- a/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h
+++ b/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h
@@ -56,6 +56,16 @@
 #define BBB_P9_41     20 /* GPIO0_20 */
 #define BBB_P9_42      7 /* GPIO0_7 */
+/* ADC pins on the BeagleBone Black */
+#define BBB_P9_33      4 /* AIN_4 */
+#define BBB_P9_34      7 /* AIN_7 */
+#define BBB_P9_35      6 /* AIN_6 */
+#define BBB_P9_36      5 /* AIN_5 */
+#define BBB_P9_37      2 /* AIN_2 */
+#define BBB_P9_38      3 /* AIN_3 */
+#define BBB_P9_39      0 /* AIN_0 */
+#define BBB_P9_40      1 /* AIN_1 */
 /* BSP related specifications */
 #define GPIO_PIN_COUNT 128
 #define GPIO_PINS_PER_BANK 32
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index ebaa703..faba28b 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -319,4 +319,42 @@
 #define AM335X_GPIO_CLEARDATAOUT      0x190
     /* GPIO Output Clear Register */
 #define AM335X_GPIO_SETDATAOUT        0x194
-    /* GPIO Output Set Register */
+    /* GPIO Output Set Register */
+/* ADC registers */
+#define AM335X_ADC (0x44E0D000)
+#define AM335X_CM_WKUP (0x44E00400)
+#define AM335X_CM_WKUP_ADC_CLKCTRL (AM335X_CM_WKUP+0xBC)
+#define AM335X_CM_WKUP_MODULEMODE_ENABLE (0x02)
+#define AM335X_CM_WKUP_IDLEST_DISABLED (0x03<<16)
+#define AM335X_ADC_CTRL (AM335X_ADC+0x40)
+#define AM335X_ADC_STEPENABLE (AM335X_ADC+0x54)
+#define AM335X_ADC_STEPCONFIG_WRITE_PROTECT_OFF (0x01<<2)
+#define AM335X_ADC_STEPCONFIG1 (AM335X_ADC+0x64)
+#define AM335X_ADC_STEPDELAY1  (AM335X_ADC+0x68)
+#define AM335X_ADC_STEPCONFIG2 (AM335X_ADC+0x6C)
+#define AM335X_ADC_STEPDELAY2  (AM335X_ADC+0x70)
+#define AM335X_ADC_STEPCONFIG3 (AM335X_ADC+0x74)
+#define AM335X_ADC_STEPDELAY3  (AM335X_ADC+0x78)
+#define AM335X_ADC_STEPCONFIG4 (AM335X_ADC+0x7C)
+#define AM335X_ADC_STEPDELAY4  (AM335X_ADC+0x80)
+#define AM335X_ADC_STEPCONFIG5 (AM335X_ADC+0x84)
+#define AM335X_ADC_STEPDELAY5  (AM335X_ADC+0x88)
+#define AM335X_ADC_STEPCONFIG6 (AM335X_ADC+0x8C)
+#define AM335X_ADC_STEPDELAY6  (AM335X_ADC+0x90)
+#define AM335X_ADC_STEPCONFIG7 (AM335X_ADC+0x94)
+#define AM335X_ADC_STEPDELAY7  (AM335X_ADC+0x98)
+#define AM335X_ADC_STEPCONFIG8 (AM335X_ADC+0x9C)
+#define AM335X_ADC_STEPDELAY8  (AM335X_ADC+0xA0)
+#define AM335X_ADC_AVG0  (0x000)
+#define AM335X_ADC_AVG2  (0x001)
+#define AM335X_ADC_AVG4  (0x010)
+#define AM335X_ADC_AVG8  (0x011)
+#define AM335X_ADC_AVG16 (0x100)
+#define AM335X_ADC_FIFO0DATA (AM335X_ADC+0x100)
+#define AM335X_ADC_FIFO_MASK (0xFFF)
diff --git a/cpukit/include/rtems/gpio.h b/cpukit/include/rtems/gpio.h
index 2b9ebf7..58f1f61 100644
--- a/cpukit/include/rtems/gpio.h
+++ b/cpukit/include/rtems/gpio.h
@@ -61,5 +61,12 @@ extern int rtems_gpio_digital_clear(gpio_pin_handle *);
  * @brief currently configured pin is released and made UNCONFIGURED.
 extern int rtems_gpio_release_pin(gpio_pin_handle *);
+ * @brief ADC intialization.
+extern void rtems_adc_init();
+ * @brief Reads the ADC value for input from pin.
+extern int rtems_adc_read(unsigned int);
 #endif /* _RTEMS_GPIO_H */
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150628/e4b8d20e/attachment-0001.png>
