GSoC 2015 RPi USB Support
Mon Jun 29 06:43:45 UTC 2015
You can debug this issue on Qemu. The Nexus childes are registered in a
linker set, so I would consult the linker map file.  It should look like
this:
  .rtemsroset.bsd.nexus.begin
                 0x000000000052ef7c        0x0 libbsd.a(rtems-bsd-nexus.o)
                 0x000000000052ef7c _bsd__start_set_nexus
  .rtemsroset.bsd.nexus.content
                 0x000000000052ef7c       0x28
testsuite/telnetd01/test_main.o
  .rtemsroset.bsd.nexus.end
                 0x000000000052efa4        0x0 libbsd.a(rtems-bsd-nexus.o)
                 0x000000000052efa4 _bsd__stop_set_nexus
The  .rtemsroset.bsd.nexus.content section must be non-empty.
On 27/06/15 16:39, Yurii Shevtsov wrote:
> Any ideas? Maybe I did some typo? Maybe you can compile and try it in qemu?
> 2015-06-26 17:05 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>> I would set a break point to nexus_probe(). In this loop
>>>      SET_FOREACH(nd, nexus) {
>>>          device_add_child(dev, nd->name, nd->unit);
>>> your device must get added. I would also set break points to the probe and
>>> attach functions of your device.
>> Added printfs()
>>      printf("before setforeach\n");
>>          printf("setforeach: %s\n", nd->name);
>> Got only 'before setforeach' in console. So it doesn't step into loop.
>> Any ideas? Also I already had printfs in my driver's probe and attach,
>> also got no output.
>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>> This is ping message, with small update: the problem is not on the
>>>> linking stage, driver is linked to testsuite (checked with objdump)
>>>> 2015-06-21 17:57 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>> Hello)
>>>>> Now I have apps from libbsd testsuite running. But DWC OTG driver doesn't
>>>>> loads.
>>>>> I added this lines to init01/test_main.c:
>>>>> +SYSINIT_NEED_USB_CORE;
>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>> (I know it's bad hardcode)
>>>>> If I run it. I get only this:
>>>>>     nexus0: <RTEMS Nexus device>
>>>>>     devctl: +nexus0 at   on root0
>>>>>     devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>> Of course, I modified rtemsbsd/include/machine/rtems-bsd-sysinit.h and
>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from working DTS) and
>>>>> did other nexus-related changes to drivers. You can find changes in my
>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>> So I need some kind of code review, please.
>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs without any
>>>>> output.
>>>>> Thanks in advance!
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
