large G++ locale overhead in g++ 4.9.2
Gedare Bloom gedare at gwu.edu
Mon Jun 29 14:05:30 UTC 2015
On Mon, Jun 29, 2015 at 10:02 AM, Peter Dufault <dufault at hda.com> wrote:
>> On Jun 29, 2015, at 09:28 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>> By only including the RTEMS shell commands I use I reduced the size to 1839664 (latest RTEMS) vs 1624684 (September RTEMS), about a 13% increase, but at least it fits in FLASH.
>>> The overhead appears to be mostly all the locale “stuff” in g++ 4.9.2 vs g++ 4.8.2.  I did some googling but don’t see how to reduce this, does anyone know of a way?  I really don’t need currency customization.
>> What pulls in this locale stuff? Maybe
>> CFLAGS += -ffunction-sections -fdata-sections
>> LDFLAGS = -Wl,--gc-sections
>> helps?
> I don’t know what pulls in the locale stuff or how to disable it.
> Your suggested flags makes a huge difference, it’s now 1424272 bytes in size, at 12% decrease from September and a 22% decrease from building the application with gcc 4.9.2 without the flags. I don’t see as much locale stuff in there.  I only recompiled the user application code and not RTEMS itself.
> Even better the application still runs.
> How can these options change what gets linked in?
These options let the compiler put every function in its own section
and use extra data sections, and the linker to remove any that are
unused. So it can provide a fine-tune way to remove unused code at
link time, but you need to be careful to mark any special sections
that must not be garbage-collected. I think Joel did this for the
SPARC. As you noticed, the options can make a big difference!
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> devel mailing list
> devel at rtems.org
