[PATCH 2/2] score: Accept NULL pointer in _Freechain_Put()
Gedare Bloom gedare at gwu.edu
Tue Jun 30 16:50:26 UTC 2015
OK
On Tue, Jun 30, 2015 at 9:29 AM, Sebastian Huber
> With this a _Freechain_Put( _Freechain_Get() ) works always.
>  cpukit/score/include/rtems/score/freechain.h | 3 ++-
>  cpukit/score/src/freechain.c                 | 4 +++-
>  testsuites/sptests/spfreechain01/init.c      | 2 ++
>  3 files changed, 7 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/freechain.h b/cpukit/score/include/rtems/score/freechain.h
> index 7fa580a..1540c0e 100644
> --- a/cpukit/score/include/rtems/score/freechain.h
> +++ b/cpukit/score/include/rtems/score/freechain.h
> @@ -93,7 +93,8 @@ void *_Freechain_Get(
>   * @brief Puts a node back onto the freechain.
>   * @param[in] freechain The freechain control.
> - * @param[in] node The node to put back.
> + * @param[in] node The node to put back.  The node may be @c NULL, in this case
> + *   the function does nothing.
>  void _Freechain_Put(
>    Freechain_Control *freechain,
> diff --git a/cpukit/score/src/freechain.c b/cpukit/score/src/freechain.c
> index 84b4c63..301e9b2 100644
> --- a/cpukit/score/src/freechain.c
> +++ b/cpukit/score/src/freechain.c
> @@ -74,5 +74,7 @@ void *_Freechain_Get(
>  void _Freechain_Put( Freechain_Control *freechain, void *node )
> -  _Chain_Prepend_unprotected( &freechain->Free, node );
> +  if ( node != NULL ) {
> +    _Chain_Prepend_unprotected( &freechain->Free, node );
> diff --git a/testsuites/sptests/spfreechain01/init.c b/testsuites/sptests/spfreechain01/init.c
> index 8963752..6efcd93 100644
> --- a/testsuites/sptests/spfreechain01/init.c
> +++ b/testsuites/sptests/spfreechain01/init.c
> @@ -40,6 +40,8 @@ static rtems_task Init(rtems_task_argument ignored)
>      /* check whether freechain put and get works correctly*/
> +    _Freechain_Put(&fc, NULL);
>      puts( "INIT - Get node from freechain - OK" );
>      node = _Freechain_Get(&fc, malloc, 1, sizeof(test_node));
>      node->x = 1;
> 1.8.4.5
> devel mailing list
> devel at rtems.org
