Mailbox methods for RPi
QIAO YANG yangqiao0505 at me.com
Mon Jun 1 19:41:23 UTC 2015
It's using the mailbox property channel to communicate with the videocore. I've noted down all available properties and the addresses used in a header file but not yet implemented all of them. I'm working on it this week. If you need this, you may put some marks here and I'll send a patch for the methodes as soon as possible. Latest this weekend I'll complete what we need for the moment as there are plenty of them. I don't think they are all useful, but should be completed.
On Jun 01, 2015, at 08:33 AM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> I have this lines in FreeBSD driver:
> | bcm2835_mbox_set_power_state(dev, BCM2835_MBOX_POWER_ID_USB_HCD, TRUE);
> How should I replace it?
> Thanks in advance)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150601/afaaeade/attachment-0002.html>
