GSoC 2015: Raspberry Pi 2 Support
Rohini Kulkarni krohini1593 at gmail.com
Tue Jun 2 11:41:58 UTC 2015
>From what I saw, they have to be enabled separately. Cache/mmu are disabled
upon reset.
On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com> wrote:
> Hi,
> Aren't the MMU/Caches enabled by default for RPi [1]?
> [1]
> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> >>Dr. Joel,
> >>So we can't say something solely on the basis of this result?
> > I don't think so. If Linux performs the same, then what you did is as
> good as it gets.
> > However, if Linux is faster then some setting still isn't right.
> > You need a reference measurement to have any confidence. It is possible
> you did something but didn't actually turn the cache (or all the cache) on.
> >>On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >>I have not run it under linux on pi2 yet. Will have to run and check
> >>the result.
> >>On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> >>On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
> >>wrote:
> >>>HI,
> >>>I tried running the dhrystone benchmark with some changes for
> >>cache/mmu
> >>>set up.
> >>>However, the output shows a reduction in performance.
> >>>The time to run through the dhrystone has increased from 12 to 13 and
> >>>dhrystones run per second decreased.
> >>>According to this result, things were better with caches disabled.
> >>>I have been working on this since two days and could not figure out an
> >>>improvement. Any pointers?
> >>How did it do under Linux on the Pi2?
> >>>Thanks.
> >>>On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
> >>>Hi All,
> >>>I have to implement the cache coherency support for Cortex A7. But for
> >>>A7 MPCore, unlike for A9, I am not able to find any register
> >>>description for the Snoop Control Unit from the TRM.
> >>>I need help here on how to proceed.
> >>>Additionally for A9 there is a single bit for A9 in the Auxiliary
> >>>Control Register which enables cache broadcast operations. The
> >>register
> >>>format is different for A7 and again I am unable to find how to
> >>achieve
> >>>the same for A7.
> >>>Thanks!
> >>>On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
> >>>On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
> >>>Hi,
> >>>I am working with the code for bsp hooks. I am referring to existing
> >>>ARM multicore bsp codes, zync mainly.
> >>>1. There are existing hooks for the raspberry pi. Where should the
> >>code
> >>>for the  Pi2 hooks be added?
> >>>The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
> >>>the Pi BSP directory.
> >>>There is already a Pi2 variant of that code built. But we know
> >>specific
> >>>places where there
> >>>are variances. Depending on the scope of what is different, it can be
> >>>as simple as
> >>>a cpp conditional in a .h to select a value or two implementations of
> >>a
> >>>single method
> >>>and the Makefile.am picking the right file to build based on the board
> >>>variant.
> >>>The big question to always ask is: Is this specific to the Pi2 and
> >>>incompatible with the Pi?
> >>>Since the Pi BSP is still missing capabilities, it is likely code
> >>>common to both will
> >>>be added this summer. For example, did the mailbox interface change? I
> >>>don't know
> >>>but would guess that it didn't.  Each new capability added needs that
> >>>added.
> >>>And any differences need to be analyzed to pick the least intrusive
> >>way
> >>>to provide
> >>>alternate implementations. Or enable special code like the Pi2 SMP
> >>>support which
> >>>is dependent on --enable-smp and being a Pi2.
> >>>2. Am I right in understanding that I will have to implement A7
> >>>specific functions as have been for A9? I am referring specifically to
> >>>the arm-a9mpcore-start.h
> >>>Yes.
> >>>If the code is very similar between the a7 and a9, then a discussion
> >>>on devel@ should occur to decide the best way to minimize duplication.
> >>>If you end up with a7 specific code, you should follow the location
> >>and
> >>>naming patterns already established. That places it in
> >>>libbsp/arm/shared/...
> >>>so it can be used by any BSP with the right SMP core.
> >>>I am referring to existing codes to locate and get hold of what needs
> >>>to be done in the hooks. However, being new to such implementations, I
> >>>am taking longer to understand the details. Any suggestions that might
> >>>help here are welcome
> >>>The answer will depend on the factors listed above. When code can
> >>>be shared, we want to share it across as many BSPs as makes sense.
> >>>When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
> >>>you want to find the way to account for the variation in the least
> >>>intrusive code way possible.
> >>>Thanks!
> >>>On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >>>Hi,
> >>>Excited to be a part of  this edition of GSoC! Thanks to everybody for
> >>>helping me get here and congratulations to all the participating
> >>>students!
> >>>So, now getting to work, firstly I wish to know, specifically from my
> >>>mentors, any changes that must be made to my proposed project or
> >>>schedule.
> >>>Secondly, are there any specifics for the development blog that we
> >>need
> >>>to create for the project? Over time what is the blog expected to
> >>>convey.
> >>>Also, I have to create a new wiki page for my project as none exists.
> >>I
> >>>want to know how to add one.
> >>>Rohini Kulkarni
> >>>-- Joel Sherrill, Ph.D. Director of Research & Development
> >>>joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
> >>>RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
> >>722-9985
> >>>Rohini Kulkarni
> >>>Rohini Kulkarni
> >>--joel
> > --joel
> > devel mailing list
> > devel at rtems.org
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150602/a3454bcd/attachment-0002.html>
