GSoC 2015: Raspberry Pi 2 Support
Rohini Kulkarni krohini1593 at gmail.com
Wed Jun 3 03:33:48 UTC 2015
Hi,
Alan, your suggestion has resulted in much improvement
arm_control=0x1000
This has simply worked! Looks like the other cores were taking up plenty of
time.
I was aware from references that the other cores run a WFI, but ya, did not
get its impact.
Time for each dhrystone has reduced to 7 from 13 and the no of dhrystones
per second also increased.
But this is a change only in the config.txt not actually in the boot code.
Thanks
Rohini
On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> The caches are being enabled on the RPI 1 BSP. The same code is being
> executed by the RPI 2 BSP, but obviously it’s not sufficient for the cache
> setup.
> I have been reading through this long thread, and it is very informative:
> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
> I am starting to understand the setup that is required to enable caches on
> the RPI 2. For example this message near the bottom of page 3 gives a good
> indication of the speedup available by configuring the MMU and caches
> correctly:
> Quote from above thread
> Enabling I/D caches and branch prediction, just like the julia demo uses,
> it takes ~12 seconds, or ~21 fps. It's just one core but also a much
> smaller loop than the julia demo has.
> Enabling the MMU and mapping memory inner/outer write-back, write allocate
> and the framebuffer inner write-through, no write allocate + outer
> write-back, write-allocate it takes ~8 seconds, of 32 fps.
> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater L2 cache
> effect.
> End of quote
> The person who posted the above comment (mrvn) posted the code here:
> https://github.com/mrvn/test/blob/master/mmu.cc
> Also, it seems that when the Pi 2 starts up, cores 1-3 are put in a wait
> loop always accessing the bus. By putting this option in the config.txt
> file you can put the other cores to sleep, speeding up the code on core 1.
>  arm_control=0x1000
> It would be worth trying that option to see if the benchmark speeds up.
> Alan
> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary <heshamelmatary at gmail.com>
> wrote:
> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> From what I saw, they have to be enabled separately. Cache/mmu are disabled
> upon reset.
> For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
> however I don't know about Pi2 and where its code is.
> [1]
> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com> wrote:
> Hi,
> Aren't the MMU/Caches enabled by default for RPi [1]?
> [1]
> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> Dr. Joel,
> So we can't say something solely on the basis of this result?
> I don't think so. If Linux performs the same, then what you did is as
> good as it gets.
> However, if Linux is faster then some setting still isn't right.
> You need a reference measurement to have any confidence. It is possible
> you did something but didn't actually turn the cache (or all the cache) on.
> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> I have not run it under linux on pi2 yet. Will have to run and check
> the result.
> On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> HI,
> I tried running the dhrystone benchmark with some changes for
> cache/mmu
> set up.
> However, the output shows a reduction in performance.
> The time to run through the dhrystone has increased from 12 to 13 and
> dhrystones run per second decreased.
> According to this result, things were better with caches disabled.
> I have been working on this since two days and could not figure out an
> improvement. Any pointers?
> How did it do under Linux on the Pi2?
> Thanks.
> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
> Hi All,
> I have to implement the cache coherency support for Cortex A7. But for
> A7 MPCore, unlike for A9, I am not able to find any register
> description for the Snoop Control Unit from the TRM.
> I need help here on how to proceed.
> Additionally for A9 there is a single bit for A9 in the Auxiliary
> Control Register which enables cache broadcast operations. The
> register
> format is different for A7 and again I am unable to find how to
> achieve
> the same for A7.
> Thanks!
> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
> Hi,
> I am working with the code for bsp hooks. I am referring to existing
> ARM multicore bsp codes, zync mainly.
> 1. There are existing hooks for the raspberry pi. Where should the
> code
> for the  Pi2 hooks be added?
> The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
> the Pi BSP directory.
> There is already a Pi2 variant of that code built. But we know
> specific
> places where there
> are variances. Depending on the scope of what is different, it can be
> as simple as
> a cpp conditional in a .h to select a value or two implementations of
> a
> single method
> and the Makefile.am picking the right file to build based on the board
> variant.
> The big question to always ask is: Is this specific to the Pi2 and
> incompatible with the Pi?
> Since the Pi BSP is still missing capabilities, it is likely code
> common to both will
> be added this summer. For example, did the mailbox interface change? I
> don't know
> but would guess that it didn't.  Each new capability added needs that
> added.
> And any differences need to be analyzed to pick the least intrusive
> way
> to provide
> alternate implementations. Or enable special code like the Pi2 SMP
> support which
> is dependent on --enable-smp and being a Pi2.
> 2. Am I right in understanding that I will have to implement A7
> specific functions as have been for A9? I am referring specifically to
> the arm-a9mpcore-start.h
> Yes.
> If the code is very similar between the a7 and a9, then a discussion
> on devel@ should occur to decide the best way to minimize duplication.
> If you end up with a7 specific code, you should follow the location
> and
> naming patterns already established. That places it in
> libbsp/arm/shared/...
> so it can be used by any BSP with the right SMP core.
> I am referring to existing codes to locate and get hold of what needs
> to be done in the hooks. However, being new to such implementations, I
> am taking longer to understand the details. Any suggestions that might
> help here are welcome
> The answer will depend on the factors listed above. When code can
> be shared, we want to share it across as many BSPs as makes sense.
> When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
> you want to find the way to account for the variation in the least
> intrusive code way possible.
> Thanks!
> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> Hi,
> Excited to be a part of  this edition of GSoC! Thanks to everybody for
> helping me get here and congratulations to all the participating
> students!
> So, now getting to work, firstly I wish to know, specifically from my
> mentors, any changes that must be made to my proposed project or
> schedule.
> Secondly, are there any specifics for the development blog that we
> need
> to create for the project? Over time what is the blog expected to
> convey.
> Also, I have to create a new wiki page for my project as none exists.
> I
> want to know how to add one.
> Rohini Kulkarni
> -- Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
> 722-9985
> Rohini Kulkarni
> Rohini Kulkarni
> --joel
> --joel
> devel mailing list
> devel at rtems.org
> Hesham
> Hesham
> devel mailing list
> devel at rtems.org
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150603/dca81125/attachment-0002.html>
