Error while compiling rtems main branch for sparc
Saurabh Gadia gadia at usc.edu
Fri Jun 5 01:08:59 UTC 2015
Hi,
I worked out that bug related to strict_mutex and gone past that bug. But
now I have issue while compiling the libtests. Below is the error log:
sparc-rtems4.11-size syscall01.exe
   text       data        bss        dec        hex    filename
 266128       6064      11456     283648      45400    syscall01.exe
cp syscall01.exe syscall01.ralf
make[6]: Leaving directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/syscall01'
Making all in dl01
make[6]: Entering directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/dl01'
sparc-rtems4.11-gcc -B../../../../../sis/lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H -I.
-I../../../../../../../rtems/c/src/../../testsuites/libtests/dl01 -I..
-I../../../../../../../rtems/c/src/../../testsuites/libtests/../support/include
-mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o dl-o1.o
../../../../../../../rtems/c/src/../../testsuites/libtests/dl01/dl-o1.c
mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
w -f dl.tar dl-o1.o
 17:44:17 up  2:31,  2 users,  load average: 2.27, 0.99, 0.53
USER     TTY        LOGIN@   IDLE   JCPU   PCPU WHAT
../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
cannot open dl.tar for reading
make[6]: *** [dl-tar.c] Error 1
make[5]: *** [all-local] Error 1
make[5]: Leaving directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests'
make[4]: *** [all] Error 2
make[4]: Leaving directory
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c'
make: *** [all-recursive] Error 1
saurabh at saurabh-Inspiron-N5010:~/dev1/kernel/b-sis$ ls
I am not able to find dl-tar.c but we have dl-tar.Po. Can anyone guide me
on this.  How should I proceed with this.
Thanks,
Saurabh Gadia
On Mon, Jun 1, 2015 at 7:48 AM, Saurabh Gadia <gadia at usc.edu> wrote:
> I am on it.
> On Monday, June 1, 2015, Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Saurabh,
>> Please try to figure out how to fix the compile-error. You can see
>> that the problem occurs in the #ifdef'd STRICT_ORDER_MUTEX_CODE, so
>> that makes sense why others have not observed the same issue. It
>> appears you will have to reconcile the new _Thread_Change_priority
>> arguments with what is being used in that block of code. If you need
>> more guidance please ask.
>> Gedare
>> On Mon, Jun 1, 2015 at 12:35 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>> > I wanted to test the ENABLE_STRICT_ORDER_MUTEX=1 related sptests for
>> "nested
>> > mutex" GSOC project. So please let me know what can be done.
>> > Thanks,
>> > Saurabh Gadia
>> > On Sun, May 31, 2015 at 9:33 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>> >> Hi,
>> >> so I am working for sparc-sis setting and master branch. And if you see
>> >> the code in threadimpl.h and threadchangepriority.c and
>> coremutexsurrender.c
>> >> the definition of _Thread_Change_priority() is having mismatch
>> calling. Git
>> >> records says that there was change to above function structure done by
>> >> sebastian huber. But I guess he forgot to change the definition of
>> >> _Thread_Change_priority() in threadimpl.h and call in
>> >> Configuration command:
>> >> ./configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
>> --enable-tests
>> >> --disable-posix ENABLE_STRICT_ORDER_MUTEX=1
>> >> Error Log:
>> >> In file included from
>> >> ../../cpukit/../../../sis/lib/include/rtems/score/coremuteximpl.h:24:0,
>> >>                  from
>> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:23:
>> >> ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:394:6:
>> >> note: expected 'void *' but argument is of type 'int'
>> >>  void _Thread_Change_priority(
>> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:60:7:
>> >> error: too few arguments to function '_Thread_Change_priority'
>> >>        _Thread_Change_priority( holder, mutex->queue.priority_before,
>> true
>> >>                  from
>> >> note: declared here
>> >> make[6]: *** [src/libscore_a-coremutexsurrender.o] Error 1
>> >> Thanks,
>> >> Saurabh Gadia
>> >> On Sun, May 31, 2015 at 8:25 PM, Nick Withers <nick.withers at anu.edu.au
>> >> wrote:
>> >>> Does re-running bootstrap in the source dir and re-configuring sort
>> it?
>> >>> Nick Withers
>> >>> Embedded Systems Programmer
>> >>> Department of Nuclear Physics, Research School of Physics and
>> Engineering
>> >>> The Australian National University (CRICOS: 00120C)
>> >>> On Sun, 2015-05-31 at 20:31 -0400, Joel Sherrill wrote:
>> >>> > More information is needed. Target architecture, bsp, configure
>> >>> > command.
>> >>> > I have been building all bsps regularly and unless it got broken
>> this
>> >>> > weekend, something else is up
>> >>> > On May 31, 2015 7:57:04 PM EDT, Saurabh Gadia <gadia at usc.edu>
>> wrote:
>> >>> > >The problem is on master branch
>> >>> > >Thanks,
>> >>> > >Saurabh Gadia
>> >>> > >On Sun, May 31, 2015 at 4:44 PM, Saurabh Gadia <gadia at usc.edu>
>> wrote:
>> >>> > >Logs:
>> >`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
>> >>> > >make[6]: *** No rule to make target `src/apimutexislocked.c',
>> needed
>> >>> > > by
>> >>> > >`src/libscore_a-apimutexislocked.o'.  Stop.
>> >>> > >make[5]: *** [all-recursive] Error 1
>> >>> > >There is no makefile but I am also not able to find
>> apimutexislocked.c
>> >>> > >How do I proceed about this.
>> >>> > >Thanks,
>> >>> > >Saurabh Gadia
>> >>> > --joel
>> >>> > _______________________________________________
>> >>> > devel mailing list
>> >>> > devel at rtems.org
>> >>> > http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
> Thanks,
> Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150604/c65d4642/attachment-0002.html>
