rtems-libbsd waf params
    Sujay Raj
    sujayraaj at gmail.com
    Fri Jun  5 18:02:30 UTC 2015
>From what I could make out from the documentation in README.waf,
in waf configure , --prefix is where you would like to install rtems-libbsd,
--rtems is where you installed your bsp, that is, the '--prefix' you
passed while configuring the bsp.
'--rtems-tools' points to the tool-set you built using RSB (the
--prefix you passed to the RSB) and
'--rtems-bsps' should be provided with the string 'architecture/bsp'.
 (everything without quotes, quotes are just for illustration)
usually --prefix and --rtems would have the same value, but it depends
on how you are setting things up.
Further, from libbsd.txt, in config.inc BSP should only be the name of
your BSP, not c/raspberrypi/make.
See if this helps.
Regards
On Fri, Jun 5, 2015 at 10:47 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> Since 'waf' requires four params and 'make' only three in config.inc,
> I got confused with waf. Could anyone help me with waf params? Here is
> my config.inc:
>   TARGET = arm-rtems4.11
>   BSP = c/raspberrypi/make
>   PREFIX = /home/gtament/development/rtems/src/b-rpi
> Thanks in advance)
> devel mailing list
> devel at rtems.org
