Error while compiling rtems main branch for sparc
Saurabh Gadia gadia at usc.edu
Fri Jun 5 20:42:34 UTC 2015
Hi,
installing pax work. But you have to again do the bootstrap step,
configuration and compiling.
Thanks.
Thanks,
Saurabh Gadia
On Fri, Jun 5, 2015 at 12:44 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I'm not really sure, but I think you probably have to re-run configure.
> On Fri, Jun 5, 2015 at 3:40 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> > Hi Gedare,
> > I installed pax but same problem persists. So should I again bootstrap
> the
> > complete thing or do we have to refer pax in any make or config files?
> > Thanks,
> > Saurabh Gadia
> > On Fri, Jun 5, 2015 at 10:56 AM, Saurabh Gadia <gadia at usc.edu> wrote:
> >> Ok. Thanks a lot. Will continue with compiling and JPF setup this week
> as
> >> discussed with Cyrille. And if time permits will look into how to
> emulate
> >> the things in JPF. And also provide ppt in deoxygen for revised rtems
> code.
> >> On Friday, June 5, 2015, Gedare Bloom <gedare at rtems.org> wrote:
> >>> Hi Saurabh,
> >>> This is a current problem in RTEMS. You need to have 'pax' installed
> >>> on your development host to build the dl tests. So, it looks good to
> >>> me!
> >>> Gedare
> >>> On Thu, Jun 4, 2015 at 9:16 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> >>> > I am sorry for not attaching the patch and configuration command:
> >>> > ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> >>> > --enable-tests --disable-posix ENABLE_STRICT_ORDER_MUTEX=1
> >>> > Thanks,
> >>> > Saurabh Gadia
> >>> > On Thu, Jun 4, 2015 at 6:08 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> >>> >> Hi,
> >>> >> I worked out that bug related to strict_mutex and gone past that
> bug.
> >>> >> But
> >>> >> now I have issue while compiling the libtests. Below is the error
> log:
> >>> >> sparc-rtems4.11-size syscall01.exe
> >>> >>    text       data        bss        dec        hex    filename
> >>> >>  266128       6064      11456     283648      45400    syscall01.exe
> >>> >> cp syscall01.exe syscall01.ralf
> >>> >> make[6]: Leaving directory
> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/syscall01'
> >>> >> Making all in dl01
> >>> >> make[6]: Entering directory
> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/dl01'
> >>> >> sparc-rtems4.11-gcc -B../../../../../sis/lib/ -specs bsp_specs
> -qrtems
> >>> >> -DHAVE_CONFIG_H -I.
> >>> >> -I../../../../../../../rtems/c/src/../../testsuites/libtests/dl01
> -I..
> -I../../../../../../../rtems/c/src/../../testsuites/libtests/../support/include
> >>> >> -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> >>> >> -Wmissing-prototypes -Wimplicit-function-declaration
> >>> >> -Wstrict-prototypes
> >>> >> -Wnested-externs -MT dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o
> dl-o1.o
> ../../../../../../../rtems/c/src/../../testsuites/libtests/dl01/dl-o1.c
> >>> >> mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
> >>> >> w -f dl.tar dl-o1.o
> >>> >>  17:44:17 up  2:31,  2 users,  load average: 2.27, 0.99, 0.53
> >>> >> USER     TTY        LOGIN@   IDLE   JCPU   PCPU WHAT
> >>> >> ../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
> >>> >> cannot open dl.tar for reading
> >>> >> make[6]: *** [dl-tar.c] Error 1
> >>> >> make[5]: *** [all-local] Error 1
> >>> >> make[5]: Leaving directory
> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests'
> >>> >> make[4]: *** [all] Error 2
> >>> >> make[4]: Leaving directory
> >>> >> make[3]: *** [all-recursive] Error 1
> >>> >> make[3]: Leaving directory
> >>> >> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites'
> >>> >> make[2]: *** [all-recursive] Error 1
> >>> >> make[2]: Leaving directory
> >>> >> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis'
> >>> >> make[1]: *** [all-recursive] Error 1
> >>> >> make[1]: Leaving directory
> >>> >> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c'
> >>> >> make: *** [all-recursive] Error 1
> >>> >> saurabh at saurabh-Inspiron-N5010:~/dev1/kernel/b-sis$ ls
> >>> >> I am not able to find dl-tar.c but we have dl-tar.Po. Can anyone
> guide
> >>> >> me
> >>> >> on this.  How should I proceed with this.
> >>> >> Thanks,
> >>> >> Saurabh Gadia
> >>> >> On Mon, Jun 1, 2015 at 7:48 AM, Saurabh Gadia <gadia at usc.edu>
> wrote:
> >>> >>> I am on it.
> >>> >>> On Monday, June 1, 2015, Gedare Bloom <gedare at rtems.org> wrote:
> >>> >>>> Hi Saurabh,
> >>> >>>> Please try to figure out how to fix the compile-error. You can see
> >>> >>>> that the problem occurs in the #ifdef'd STRICT_ORDER_MUTEX_CODE,
> so
> >>> >>>> that makes sense why others have not observed the same issue. It
> >>> >>>> appears you will have to reconcile the new _Thread_Change_priority
> >>> >>>> arguments with what is being used in that block of code. If you
> need
> >>> >>>> more guidance please ask.
> >>> >>>> Gedare
> >>> >>>> On Mon, Jun 1, 2015 at 12:35 AM, Saurabh Gadia <gadia at usc.edu>
> >>> >>>> wrote:
> >>> >>>> > I wanted to test the ENABLE_STRICT_ORDER_MUTEX=1 related sptests
> >>> >>>> > for
> >>> >>>> > "nested
> >>> >>>> > mutex" GSOC project. So please let me know what can be done.
> >>> >>>> > Thanks,
> >>> >>>> > Saurabh Gadia
> >>> >>>> > On Sun, May 31, 2015 at 9:33 PM, Saurabh Gadia <gadia at usc.edu>
> >>> >>>> > wrote:
> >>> >>>> >> Hi,
> >>> >>>> >> so I am working for sparc-sis setting and master branch. And if
> >>> >>>> >> you
> >>> >>>> >> see
> >>> >>>> >> the code in threadimpl.h and threadchangepriority.c and
> >>> >>>> >> coremutexsurrender.c
> >>> >>>> >> the definition of _Thread_Change_priority() is having mismatch
> >>> >>>> >> calling. Git
> >>> >>>> >> records says that there was change to above function structure
> >>> >>>> >> done
> >>> >>>> >> by
> >>> >>>> >> sebastian huber. But I guess he forgot to change the definition
> >>> >>>> >> of
> >>> >>>> >> _Thread_Change_priority() in threadimpl.h and call in
> >>> >>>> >> Configuration command:
> >>> >>>> >> ./configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> >>> >>>> >> --enable-tests
> >>> >>>> >> Error Log:
> >>> >>>> >> In file included from
> ../../cpukit/../../../sis/lib/include/rtems/score/coremuteximpl.h:24:0,
> >>> >>>> >>                  from
> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:23:
> ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:394:6:
> >>> >>>> >> note: expected 'void *' but argument is of type 'int'
> >>> >>>> >>  void _Thread_Change_priority(
> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:60:7:
> >>> >>>> >> error: too few arguments to function '_Thread_Change_priority'
> >>> >>>> >>        _Thread_Change_priority( holder,
> >>> >>>> >> mutex->queue.priority_before,
> >>> >>>> >> true
> >>> >>>> >>                  from
> >>> >>>> >> note: declared here
> >>> >>>> >> make[6]: *** [src/libscore_a-coremutexsurrender.o] Error 1
> >>> >>>> >> Thanks,
> >>> >>>> >> Saurabh Gadia
> >>> >>>> >> On Sun, May 31, 2015 at 8:25 PM, Nick Withers
> >>> >>>> >> <nick.withers at anu.edu.au>
> >>> >>>> >> wrote:
> >>> >>>> >>> Does re-running bootstrap in the source dir and re-configuring
> >>> >>>> >>> sort
> >>> >>>> >>> it?
> >>> >>>> >>> Nick Withers
> >>> >>>> >>> Embedded Systems Programmer
> >>> >>>> >>> Department of Nuclear Physics, Research School of Physics and
> >>> >>>> >>> Engineering
> >>> >>>> >>> The Australian National University (CRICOS: 00120C)
> >>> >>>> >>> On Sun, 2015-05-31 at 20:31 -0400, Joel Sherrill wrote:
> >>> >>>> >>> > More information is needed. Target architecture, bsp,
> >>> >>>> >>> > configure
> >>> >>>> >>> > command.
> >>> >>>> >>> > I have been building all bsps regularly and unless it got
> >>> >>>> >>> > broken
> >>> >>>> >>> > this
> >>> >>>> >>> > weekend, something else is up
> >>> >>>> >>> > On May 31, 2015 7:57:04 PM EDT, Saurabh Gadia <
> gadia at usc.edu>
> >>> >>>> >>> > wrote:
> >>> >>>> >>> > >The problem is on master branch
> >>> >>>> >>> > >Thanks,
> >>> >>>> >>> > >Saurabh Gadia
> >>> >>>> >>> > >On Sun, May 31, 2015 at 4:44 PM, Saurabh Gadia
> >>> >>>> >>> > > <gadia at usc.edu>
> >>> >>>> >>> > > wrote:
> >>> >>>> >>> > >Logs:
> >`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
> >>> >>>> >>> > >make[6]: *** No rule to make target
> `src/apimutexislocked.c',
> >>> >>>> >>> > > needed
> >>> >>>> >>> > > by
> >>> >>>> >>> > >`src/libscore_a-apimutexislocked.o'.  Stop.
> >>> >>>> >>> > >make[5]: *** [all-recursive] Error 1
> >>> >>>> >>> > >There is no makefile but I am also not able to find
> >>> >>>> >>> > > apimutexislocked.c
> >>> >>>> >>> > >How do I proceed about this.
> >>> >>>> >>> > >Thanks,
> >>> >>>> >>> > >Saurabh Gadia
> >>> >>>> >>> > --joel
> >>> >>>> >>> > _______________________________________________
> >>> >>>> >>> > devel mailing list
> >>> >>>> >>> > devel at rtems.org
> >>> >>>> >>> > http://lists.rtems.org/mailman/listinfo/devel
> >>> >>>> > devel mailing list
> >>> >>>> > devel at rtems.org
> >>> >>> Thanks,
> >>> >>> Saurabh Gadia
> >> Thanks,
> >> Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150605/181f8c71/attachment-0002.html>
