Test selectpollkqueue01 in rtems-libbsd fails for kqueue.
Sebastian Huber
Wed Jun 10 07:05:00 UTC 2015
Yes, this is due to an update in the memory management. There is
another issue in this test that is a bit harder to chase down.
On 10/06/15 02:16, Sujay Raj wrote:
> I am working on the xilinx_zynq_a9_qemu bsp.
> The output just prior to the error is :
> test kqueue timer
> test kqueue timer
> test kqueue connect
> worker: create new connect socket
> worker: connect
> test kqueue read
> worker: write
> test kqueue write
> assertion "event.data == 20428" failed: file
> "../../testsuite/selectpollkqueue01/test_main.c", line 880, function:
> test_kqueue_write
> devel mailing list
> devel at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
