GSoC 2015: Raspberry Pi 2 Support
Alan Cudmore alan.cudmore at gmail.com
Mon Jun 15 14:59:45 UTC 2015
Hi,
Some of the code examples may give you some clues. Like this one:
https://github.com/mrvn/test/blob/master/smp.cc
Or this:
https://github.com/PeterLemon/RaspberryPi/tree/master/SMP/SMPINIT
If you still can't figure it out, you can always join the raspberrypi.org
forums and ask on this thread:
https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
When it comes to the Pi 2 and SMP, you are our RTEMS expert :)
Thanks,
Alan
On Sat, Jun 13, 2015 at 2:29 PM, Rohini Kulkarni <krohini1593 at gmail.com>
wrote:
> Hi,
> This is regarding Pi 2 SMP support. After powering on, the secondary
> mailboxes read one of their four mailbox registers and wait for a non-zero
> content to be written. This content is to be the physical address of the
> location from where the cores are expected to start execution.
> I am stuck at figuring out this address. How should I go about
> understanding this?
> Thanks!
> On 3 Jun 2015 19:44, "Gedare Bloom" <gedare at gwu.edu> wrote:
>> On Wed, Jun 3, 2015 at 2:39 AM, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> > But, I can't say cache configurations have a role here.
>> > I'll push my code to my github project soon.
>> > P.S. The Pi2 board I possess seems to have broken down. It just isn't
>> > turning on. Unable to test further. Will order one immediately.
>> Ouch. Make sure you put it in a safe space for development, clear of
>> threats like moisture, static shock, and cats.
>> > On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> >> Hi,
>> >> Alan, your suggestion has resulted in much improvement
>> >> arm_control=0x1000
>> >> This has simply worked! Looks like the other cores were taking up
>> plenty
>> >> of time.
>> >> I was aware from references that the other cores run a WFI, but ya, did
>> >> not get its impact.
>> >> Time for each dhrystone has reduced to 7 from 13 and the no of
>> dhrystones
>> >> per second also increased.
>> >> But this is a change only in the config.txt not actually in the boot
>> code.
>> >> Thanks
>> >> Rohini
>> >> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore <alan.cudmore at gmail.com>
>> >> wrote:
>> >>> The caches are being enabled on the RPI 1 BSP. The same code is being
>> >>> executed by the RPI 2 BSP, but obviously it’s not sufficient for the
>> cache
>> >>> setup.
>> >>> I have been reading through this long thread, and it is very
>> informative:
>> >>> I am starting to understand the setup that is required to enable
>> caches
>> >>> on the RPI 2. For example this message near the bottom of page 3
>> gives a
>> >>> good indication of the speedup available by configuring the MMU and
>> caches
>> >>> correctly:
>> >>> Quote from above thread
>> >>> Enabling I/D caches and branch prediction, just like the julia demo
>> uses,
>> >>> it takes ~12 seconds, or ~21 fps. It's just one core but also a much
>> smaller
>> >>> loop than the julia demo has.
>> >>> Enabling the MMU and mapping memory inner/outer write-back, write
>> >>> allocate and the framebuffer inner write-through, no write allocate +
>> outer
>> >>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
>> >>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater L2 cache
>> >>> effect.
>> >>> End of quote
>> >>> The person who posted the above comment (mrvn) posted the code here:
>> >>> https://github.com/mrvn/test/blob/master/mmu.cc
>> >>> Also, it seems that when the Pi 2 starts up, cores 1-3 are put in a
>> wait
>> >>> loop always accessing the bus. By putting this option in the
>> config.txt file
>> >>> you can put the other cores to sleep, speeding up the code on core 1.
>> >>>  arm_control=0x1000
>> >>> It would be worth trying that option to see if the benchmark speeds
>> up.
>> >>> Alan
>> >>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary <heshamelmatary at gmail.com
>> >>> wrote:
>> >>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <
>> >>> wrote:
>> >>> From what I saw, they have to be enabled separately. Cache/mmu are
>> >>> disabled
>> >>> upon reset.
>> >>> For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
>> >>> however I don't know about Pi2 and where its code is.
>> >>> [1]
>> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
>> >>> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com>
>> wrote:
>> >>> Hi,
>> >>> Aren't the MMU/Caches enabled by default for RPi [1]?
>> >>> [1]
>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>> >>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
>> >>> <joel.sherrill at oarcorp.com> wrote:
>> >>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <
>> >>> wrote:
>> >>> Dr. Joel,
>> >>> So we can't say something solely on the basis of this result?
>> >>> I don't think so. If Linux performs the same, then what you did is as
>> >>> good as it gets.
>> >>> However, if Linux is faster then some setting still isn't right.
>> >>> You need a reference measurement to have any confidence. It is
>> possible
>> >>> you did something but didn't actually turn the cache (or all the
>> cache)
>> >>> on.
>> >>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> >>> I have not run it under linux on pi2 yet. Will have to run and check
>> >>> the result.
>> >>> On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>> wrote:
>> >>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <
>> >>> wrote:
>> >>> HI,
>> >>> I tried running the dhrystone benchmark with some changes for
>> >>> cache/mmu
>> >>> set up.
>> >>> However, the output shows a reduction in performance.
>> >>> The time to run through the dhrystone has increased from 12 to 13 and
>> >>> dhrystones run per second decreased.
>> >>> According to this result, things were better with caches disabled.
>> >>> I have been working on this since two days and could not figure out an
>> >>> improvement. Any pointers?
>> >>> How did it do under Linux on the Pi2?
>> >>> Thanks.
>> >>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>> >>> Hi All,
>> >>> I have to implement the cache coherency support for Cortex A7. But for
>> >>> A7 MPCore, unlike for A9, I am not able to find any register
>> >>> description for the Snoop Control Unit from the TRM.
>> >>> I need help here on how to proceed.
>> >>> Additionally for A9 there is a single bit for A9 in the Auxiliary
>> >>> Control Register which enables cache broadcast operations. The
>> >>> register
>> >>> format is different for A7 and again I am unable to find how to
>> >>> achieve
>> >>> the same for A7.
>> >>> Thanks!
>> >>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>> >>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>> >>> Hi,
>> >>> I am working with the code for bsp hooks. I am referring to existing
>> >>> ARM multicore bsp codes, zync mainly.
>> >>> 1. There are existing hooks for the raspberry pi. Where should the
>> >>> code
>> >>> for the  Pi2 hooks be added?
>> >>> The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>> >>> the Pi BSP directory.
>> >>> There is already a Pi2 variant of that code built. But we know
>> >>> specific
>> >>> places where there
>> >>> are variances. Depending on the scope of what is different, it can be
>> >>> as simple as
>> >>> a cpp conditional in a .h to select a value or two implementations of
>> >>> a
>> >>> single method
>> >>> and the Makefile.am picking the right file to build based on the board
>> >>> variant.
>> >>> The big question to always ask is: Is this specific to the Pi2 and
>> >>> incompatible with the Pi?
>> >>> Since the Pi BSP is still missing capabilities, it is likely code
>> >>> common to both will
>> >>> be added this summer. For example, did the mailbox interface change? I
>> >>> don't know
>> >>> but would guess that it didn't.  Each new capability added needs that
>> >>> added.
>> >>> And any differences need to be analyzed to pick the least intrusive
>> >>> way
>> >>> to provide
>> >>> alternate implementations. Or enable special code like the Pi2 SMP
>> >>> support which
>> >>> is dependent on --enable-smp and being a Pi2.
>> >>> 2. Am I right in understanding that I will have to implement A7
>> >>> specific functions as have been for A9? I am referring specifically to
>> >>> the arm-a9mpcore-start.h
>> >>> Yes.
>> >>> If the code is very similar between the a7 and a9, then a discussion
>> >>> on devel@ should occur to decide the best way to minimize
>> duplication.
>> >>> If you end up with a7 specific code, you should follow the location
>> >>> and
>> >>> naming patterns already established. That places it in
>> >>> libbsp/arm/shared/...
>> >>> so it can be used by any BSP with the right SMP core.
>> >>> I am referring to existing codes to locate and get hold of what needs
>> >>> to be done in the hooks. However, being new to such implementations, I
>> >>> am taking longer to understand the details. Any suggestions that might
>> >>> help here are welcome
>> >>> The answer will depend on the factors listed above. When code can
>> >>> be shared, we want to share it across as many BSPs as makes sense.
>> >>> When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
>> >>> you want to find the way to account for the variation in the least
>> >>> intrusive code way possible.
>> >>> Thanks!
>> >>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> >>> Hi,
>> >>> Excited to be a part of  this edition of GSoC! Thanks to everybody for
>> >>> helping me get here and congratulations to all the participating
>> >>> students!
>> >>> So, now getting to work, firstly I wish to know, specifically from my
>> >>> mentors, any changes that must be made to my proposed project or
>> >>> schedule.
>> >>> Secondly, are there any specifics for the development blog that we
>> >>> need
>> >>> to create for the project? Over time what is the blog expected to
>> >>> convey.
>> >>> Also, I have to create a new wiki page for my project as none exists.
>> >>> I
>> >>> want to know how to add one.
>> >>> Rohini Kulkarni
>> >>> -- Joel Sherrill, Ph.D. Director of Research & Development
>> >>> joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>> >>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>> >>> 722-9985
>> >>> Rohini Kulkarni
>> >>> Rohini Kulkarni
>> >>> --joel
>> >>> --joel
>> >>> _______________________________________________
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> >>> Hesham
>> >>> Hesham
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >> Rohini Kulkarni
>> > devel mailing list
>> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150615/666e7108/attachment-0002.html>
