GSOC 2015: Configuration GUI
Anand Krishnan anandkp92 at gmail.com
Tue Jun 16 05:15:50 UTC 2015
Thomas: Apologies. This is the right link:
https://github.com/anandkp92/waf/blob/waf/gui/menu.py
Thanks for the other input. I'll take care of in-code documentation and
making the code modular.
I'll work on the tabs next.
Regards,
Anand
On Tue, Jun 16, 2015 at 4:37 AM, Gedare Bloom <gedare at gwu.edu> wrote:
> I just had one comment from reading the code, it lacks any code-level
> documentation. Granted it is simple now, but as it grows so should the
> doc.
> Also, make sure to watch out for when to break out into more
> functions/modules. Avoid the pitfall of "one block of code to rule
> them all"
> -Gedare
> On Mon, Jun 15, 2015 at 6:49 PM, Amar Takhar <amar at rtems.org> wrote:
> > On 2015-06-15 23:52 +0530, Anand Krishnan wrote:
> >> Hi all,
> >> Currently I have uploaded the first part of the gui - just plain menus
> (with no
> >> event handlers yet) to my github: github.com/anandkp92/waf/gui/menu.py
> . The
> >> purpose of the GUI is for creating the config.cfg file for "waf config"
> of the
> >> waf version of RTEMS.
> > Looks good so far.
> >> I think you might need wxpython also to view it right now: http://
> >> www.pygopar.com/installing-wxpython-3-on-ubuntu14-04/
> > Everyone here will be able to sort that out, thanks for the help. :)
> >> The main thing I want to get reviewed on is the code. I am planning to
> have
> >> different classes for menus, tabs, groups etc and a main class that
> creates
> >> multiple instances of each and puts it all together.
> > It seems like a good start.
> >> Correct me if I am wrong:
> >> For the File options->
> >> 1) New ->  Opens a new instance with all the configuration options set
> to
> >> default again.
> > Yes.
> >> 2) Save -> Save the configuration options chosen so far.
> > Yes.
> >> 3) Open -> Open a previously saved set of configuration options.
> > Yep.
> >> Once this is cleared, I shall move on to implementing these.
> > OK.
> >> Please keep in mind this is a very crude version and the first part of
> many
> >> parts.
> > Right.  Lay out the panes and other UI Details before getting on to
> actual
> > options.  I will help you with that.
> > You will also need to decide how each option should be displayed.
> > Amar.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150616/2459b6d9/attachment-0002.html>
