multiple definition of __getreent
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Sat Jun 20 23:30:17 UTC 2015
I suspect it is because he is compiling at -O0.
On June 20, 2015 6:13:23 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>On 20/06/2015 2:34 am, Sujay Raj wrote:
>> Hi ,
>> I am working on porting the monkey http server to rtems.
>> I am working on the bsp: xilinx_zynq_a9_qemu , target: arm-rtems4.11.
>> There are two libraries that I am supposed to link to create my final
>> executable, one is libbsd.a and the other is libc.
>> libbsd.a links alright, but whenever I try to link libc to create the
>> final executable , I get an error:
>/home/raaj/development/rtems/4.11/bsps/arm-rtems4.11/xilinx_zynq_a9_qemu/lib/librtemscpu.a(default-configuration.o):
>> In function `__getreent':
>/home/raaj/development/rtems/xilinx_zynq_a9_qemu/arm-rtems4.11/c/xilinx_zynq_a9_qemu/cpukit/libmisc/../../cpukit/../../../xilinx_zynq_a9_qemu/lib/include/rtems/confdefs.h:2420:
>> multiple definition of `__getreent'
>/home/raaj/development/rtems/4.11/tools/lib/gcc/arm-rtems4.11/4.9.2/../../../../arm-rtems4.11/lib/thumb/armv7-a/neon/hard/libc.a(lib_a-getreent.o):
>/home/raaj/development/rtems/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.2-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/arm-rtems4.11/thumb/armv7-a/neon/hard/newlib/libc/reent/../../../../../../../../../gcc-4.9.2/newlib/libc/reent/getreent.c:13:
>> first defined here
>> The CFLAGS I am using to compile are :
>> -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
>-O0
>> -g -qrtems -B/home/raaj/development/rtems/4.11/bsps/arm-rtems4.11/lib
>-B/home/raaj/development/rtems/4.11/bsps/arm-rtems4.11/xilinx_zynq_a9_qemu/lib/
>> --specs bsp_specs
>> note: I require libc for three function , initgroups, timegm, and
>sendfile.
>> note: I am working on a cmake build system
>> If the information given here is insufficient, kindly ask.
>Can you please post the full command line you are using to link with ?
>Thanks
>Chris
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
