[PATCH] Beagle BSP Improvements (GPIO driver)
Ketul Shah ketulshah1993 at gmail.com
Tue Jun 23 14:53:01 UTC 2015
Sorry wrong attachment. Kindly review the recent one.
Thanks.
Best Regards,
Ketul
On 23 June 2015 at 20:20, Ketul Shah <ketulshah1993 at gmail.com> wrote:
> Hello all,
> Sorry as I am updating you related to my GPIO API after a huge delay.
> I have developed it and tested it on my BBB. I did some big changes in the
> API taking in the account comment(s)/suggestion(s) from my respective
> mentors.
> I am also looking the API developed by Andre working for Raspberry Pi. Now
> I think it is a good time to merge the gpio code as API is getting more
> stable and generalized.
> So now it is good time to take the best things from API and we can have
> common API for GPIO driver running on every embedded board.
> Your comment(s) are welcomed.
> Thanks.
> Best Regards,
> Ketul
> On 29 April 2015 at 06:39, Chris Johns <chrisj at rtems.org> wrote:
>>  [ Just catching up ]
>> On 26/04/2015 9:26 pm, Ben Gras wrote:
>> > All,
>> > I think the API as it is (for digital GPIO's) is pretty close to
>> > generic. I like my suggestion (gpio_* in my previous mail) better as
>> > more generic. (More configuration is hidden from the application.)
>> > Joel I just read your presentation.
>> > I have come up with a minimal GPIO API based on the above (so
>> > ultimately based on the RPI API) that just covers the GPIO digital out
>> > case but allows expansion (with more defines and functions).
>> > https://devel.rtems.org/wiki/TBR/User/BenGras
>> > Is this an idea? Then we can merge this code implementing a reasonably
>> > generic API without having to flesh out the whole thing.
>> How do we define hardware specific details without bloating the API ?
>> For example on a zynq project I am working on I needed a GPIO interface
>> and I decided to use a struct to define the pin and the API takes
>> references to it. For example to control the write enable pin on a flash
>> device I have:
>> static const gpio_pin_def gpio_Flash_WD =
>>   pin:      4,
>>   output:   true,
>>   on:       GPIO_FLASH_WD_EN,
>>   outen:    true,
>>   volts:    gpio_LVCMOS33,
>>   pullup:   true,
>>   fast:     false,
>>   tristate: false
>> and then I have:
>>    gpio_error ge = gpio_setup_pin(&gpio_Flash_WD);
>>    if (ge != GPIO_NO_ERROR)
>>        return FLASH_WRITE_LOCK_FAIL;
>>     gpio_output(gpio_Flash_WD.pin, GPIO_FLASH_WD_EN);
>> I need to set the voltage on the pin on the Zynq but this is Zynq
>> specific.
>> We need a way to let a user convey specific hardware details to the BSP
>> driver through the API plus we need a light weight API with minimal
>> internal translations. This approach also lets me define an array of
>> pins and a single set up call configures them.
>> So you could have:
>> typedef struct
>>     int   pin;       /* The pin number. */
>>     bool  output;    /* True for output, false for input. */
>>     bool  on;        /* True default output is on */
>>     bool  outen;     /* True for output enable on, false for off. */
>>     bool  pullup;    /* True to enable the pull up. */
>>     bool  tristate;  /* True to enable tri-state. */
>>     void* platform;  /* Opaque hardware specific set up details. */
>> } gpio_pin_def;
>> where the 'platform' references a struct agreed between the BSP (or
>> device layer) and the user code. For the generic cases this is not
>> needed and NULL. It also allows layering where a device set up phase of
>> user code sets the voltages and the generic code can play with the pin
>> at a generic level, eg direction etc.
>> What locking is being considered in this API ?
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150623/644e1d0f/attachment-0002.html>
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index abef8ba..6b876dd 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -39,6 +39,7 @@ include_bsp_HEADERS += ../shared/include/arm-release-id.h
 include_bsp_HEADERS += ../shared/include/start.h
 include_bsp_HEADERS += include/irq.h
 include_bsp_HEADERS += include/i2c.h
+include_bsp_HEADERS += include/beagleboneblack.h
 include_libcpu_HEADERS =
 include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -111,6 +112,9 @@ libbsp_a_SOURCES += ../../shared/console.c \
         ../../shared/console_write.c \
         ../../shared/console_control.c
+# GPIO
+libbsp_a_SOURCES += gpio/gpio.c
 # I2C
 libbsp_a_SOURCES += misc/i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/gpio/gpio.c b/c/src/lib/libbsp/arm/beagle/gpio/gpio.c
new file mode 100644
index 0000000..7ffb17b
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/gpio/gpio.c
@@ -0,0 +1,198 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief Global BSP definitions.
+ * Copyright (c) 2015 Ketul Shah <ketulshah1993 at gmail.com>
+#include <libcpu/am335x.h>
+#include <rtems.h>
+#include <rtems/gpio.h>
+#include <bsp/irq.h>
+#include <bsp/beagleboneblack.h>
+#include <bsp.h>
+#include <stdlib.h>
+#include <stdint.h>
+#include <assert.h>
+ * @brief GPIO API mutex atributes.
+#define MUTEX_ATRIBUTES                         \
+  ( RTEMS_LOCAL                                 \
+    | RTEMS_PRIORITY                            \
+    | RTEMS_BINARY_SEMAPHORE                    \
+    | RTEMS_INHERIT_PRIORITY                    \
+    | RTEMS_NO_PRIORITY_CEILING                 \
+#define OBTAIN_LOCK(s) assert( rtems_semaphore_obtain(s,                \
+                                                      RTEMS_WAIT,       \
+                                                      RTEMS_NO_TIMEOUT  \
+                                                      ) == RTEMS_SUCCESSFUL )
+#define RELEASE_LOCK(s) assert( rtems_semaphore_release(s) == RTEMS_SUCCESSFUL )
+/* GPIO bank pin number as per TRM of AM335X */
+static unsigned int gpio_bank_pin[GPIO_PIN_COUNT];
+/* GPIO bank determines register of AM335X */
+static unsigned int gpio_bank[GPIO_PIN_COUNT];
+/* Pin states for all GPIO pins*/
+static unsigned int gpio_pin_state[GPIO_PIN_COUNT];
+/* Variable for gpio initialization */
+static bool is_initialized = false;
+/* Total number of gpio banks */
+static int gpio_bank_count = GPIO_PIN_COUNT / GPIO_PINS_PER_BANK;
+/* Semaphore for avoiding race condition */
+static rtems_id bank_lock;
+static const uint32_t gpio_bank_addrs[] =
+ { AM335X_GPIO0, AM335X_GPIO1, AM335X_GPIO2, AM335X_GPIO3 };
+static uint32_t inline get_pin_mask(unsigned int pin_number)
+  return (1UL << gpio_bank_pin[pin_number]);
+static void inline reg_update_set(unsigned int pin_number,uint32_t reg)
+ uint32_t gpioreg=gpio_bank[pin_number]+reg;
+ uint32_t gpioreg_val=mmio_read(gpioreg);
+ gpioreg_val |= get_pin_mask(pin_number);
+ mmio_write(gpioreg, gpioreg_val);
+static void inline reg_update_unset(unsigned int pin_number,uint32_t reg)
+ gpioreg_val &= ~get_pin_mask(pin_number);
+ * @brief Initializes the GPIO API.
+ *        Allocates space to gpio_pin_state and sets pin state as UNCONFIGURED.
+ *        Creates Semaphore for avoiding any race condition.
+ *        If the API has already been initialized silently exits.
+void rtems_gpio_initialize(void)
+ int i;
+ rtems_status_code status;
+ if ( is_initialized )
+   return;
+ is_initialized = true;
+ for ( i = 0; i < GPIO_PIN_COUNT; ++i ) {
+   gpio_pin_state[i] = GPIO_PIN_STATE_UNCONFIGURED;
+ /* Create GPIO bank Semaphores */
+    status = rtems_semaphore_create(
+      rtems_build_name('G', 'S', 'E', ' '),
+      1,
+      MUTEX_ATRIBUTES,
+      0,
+      &bank_lock
+    printf("%s %d\n",status,status );
+    assert (status == RTEMS_SUCCESSFUL);
+ * @brief Configures a GPIO pin to perform a digital output.
+ * @retval GPIO_SUCCESSFUL Pin was configured successfully as output.
+ * @retval GPIO_UNKNOWN_PIN Pin is invalid or unknown.
+ * @retval GPIO_MISCONFIGURED_PIN Pin is already configured for another state.
+int rtems_gpio_configure_pin_digital_out(gpio_pin_handle *gpio_pin_assign,unsigned int pin_number)
+ if (pin_number > 128 || pin_number < 0)
+   return GPIO_UNKNOWN_PIN;
+ if (gpio_pin_state[gpio_pin_assign->pin_number] != GPIO_PIN_STATE_UNCONFIGURED &&
+       gpio_pin_state[gpio_pin_assign->pin_number] != GPIO_PIN_STATE_DIGITAL_OUT)
+   return GPIO_MISCONFIGURED_PIN;
+ gpio_pin_state[gpio_pin_assign->pin_number] = GPIO_PIN_STATE_DIGITAL_OUT;
+ gpio_pin_assign->pin_number = pin_number;
+ gpio_bank_pin[pin_number] = pin_number % GPIO_PINS_PER_BANK;
+ gpio_bank[pin_number] = gpio_bank_addrs[pin_number/GPIO_PINS_PER_BANK];
+ OBTAIN_LOCK(bank_lock);
+ reg_update_unset(gpio_pin_assign->pin_number,AM335X_GPIO_OE);
+ RELEASE_LOCK(bank_lock);
+ return GPIO_SUCCESSFUL;
+ * @brief Gives an output GPIO pin the logical value of 1.
+ * @retval GPIO_SUCCESSFUL Pin was set successfully.
+ * @retval GPIO_MISCONFIGURED_PIN The received pin is not configured
+ *         for digital output.
+int rtems_gpio_digital_set(gpio_pin_handle *gpio_pin_assign)
+ if (gpio_pin_state[gpio_pin_assign->pin_number] != GPIO_PIN_STATE_DIGITAL_OUT)
+ reg_update_set(gpio_pin_assign->pin_number,AM335X_GPIO_DATAOUT);
+ * @brief Gives an output GPIO pin the logical value of 0.
+ * @retval GPIO_SUCCESSFUL Pin was cleared successfully.
+int rtems_gpio_digital_clear(gpio_pin_handle *gpio_pin_assign)
+ if (gpio_pin_state[gpio_pin_assign->pin_number] == GPIO_PIN_STATE_DIGITAL_OUT)
+   return GPIO_MISCONFIGURED_PIN ;
+ reg_update_unset(gpio_pin_assign->pin_number,AM335X_GPIO_DATAOUT);
+ * @brief Releases currently configured pin and makes unused for repurposing.
+ * @retval GPIO_SUCCESSFUL Pin was released successfully or it is already
+ *         UNCONFIGURED state.
+int rtems_gpio_release_pin(gpio_pin_handle *gpio_pin_assign)
+ if (gpio_pin_state[gpio_pin_assign->pin_number] == GPIO_PIN_STATE_UNCONFIGURED)
+ gpio_pin_state[gpio_pin_assign->pin_number] = GPIO_PIN_STATE_UNCONFIGURED;
+ reg_update_set(gpio_pin_assign->pin_number,AM335X_GPIO_OE);
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h b/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h
index 0000000..5630645
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h
@@ -0,0 +1,63 @@
+ * @file
+#ifndef LIBBSP_ARM_BEAGLE_BEAGLEBONEBLACK_H
+#define LIBBSP_ARM_BEAGLE_BEAGLEBONEBLACK_H
+/* USER LEDs of BeagleBone Black */
+#define BBB_LED_USR0  53 /* USR LED0 */
+#define BBB_LED_USR1  54 /* USR LED1 */
+#define BBB_LED_USR2  55 /* USR LED2 */
+#define BBB_LED_USR3  56 /* USR LED3 */
+/* Header P8 of BeagleBone Black */
+#define BBB_P8_7      66 /* GPIO2_2 */
+#define BBB_P8_8      67 /* GPIO2_3 */
+#define BBB_P8_9      69 /* GPIO2_5 */
+#define BBB_P8_10     68 /* GPIO2_4 */
+#define BBB_P8_11     45 /* GPIO1_13 */
+#define BBB_P8_12     44 /* GPIO1_12 */
+#define BBB_P8_13     23 /* GPIO0_23 */
+#define BBB_P8_14     26 /* GPIO0_26 */
+#define BBB_P8_15     47 /* GPIO1_15 */
+#define BBB_P8_16     46 /* GPIO1_14 */
+#define BBB_P8_17     27 /* GPIO0_27 */
+#define BBB_P8_18     65 /* GPIO2_1 */
+#define BBB_P8_19     22 /* GPIO0_22 */
+#define BBB_P8_26     61 /* GPIO1_29 */
+/* Header P9 of BeagleBone Black */
+#define BBB_P9_11     30 /* GPIO0_30 */
+#define BBB_P9_12     60 /* GPIO1_28 */
+#define BBB_P9_13     31 /* GPIO0_31 */
+#define BBB_P9_14     50 /* GPIO1_18 */
+#define BBB_P9_15     48 /* GPIO1_16 */
+#define BBB_P9_16     51 /* GPIO1_19 */
+#define BBB_P9_17      5 /* GPIO0_5 */
+#define BBB_P9_18      4 /* GPIO0_4 */
+#define BBB_P9_23     49 /* GPIO1_17 */
+#define BBB_P9_24     15 /* GPIO0_15 */
+#define BBB_P9_26     14 /* GPIO1_14 */
+#define BBB_P9_27     115/* GPIO3_19 */
+#define BBB_P9_30     112/* GPIO3_16 */
+#define BBB_P9_41     20 /* GPIO0_20 */
+#define BBB_P9_42      7 /* GPIO0_7 */
+/* BSP related specifications */
+#define GPIO_PIN_COUNT 128
+#define GPIO_PINS_PER_BANK 32
+#endif /* LIBBSP_ARM_BEAGLE_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/beagle/preinstall.am b/c/src/lib/libbsp/arm/beagle/preinstall.am
index dd1ec95..7802724 100644
--- a/c/src/lib/libbsp/arm/beagle/preinstall.am
+++ b/c/src/lib/libbsp/arm/beagle/preinstall.am
@@ -110,6 +110,10 @@ $(PROJECT_INCLUDE)/bsp/i2c.h: include/i2c.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/i2c.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/i2c.h
+$(PROJECT_INCLUDE)/bsp/beagleboneblack.h: include/beagleboneblack.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/beagleboneblack.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/beagleboneblack.h
 $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: ../../../libcpu/arm/shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index 1f638bd..ebaa703 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -280,3 +280,43 @@
     /* Command posted status */
 #define AM335X_WDT_WSPR                0x48
     /* Activate/deactivate sequence */
+    /*Gpio memory registers am335x*/
+#define AM335X_GPIO0                  0x44E07000
+    /* GPIO Bank 0 base Register */
+#define AM335X_GPIO1                  0x4804C000
+    /* GPIO Bank 1 base Register */
+#define AM335X_GPIO2                  0x481AC000
+    /* GPIO Bank 2 base Register */
+#define AM335X_GPIO3                  0x481AE000
+    /* GPIO Bank 3 base Register */
+#define AM335X_GPIO_OE                0x134
+    /* GPIO Output Enable Register */
+#define AM335X_GPIO_DATAOUT           0x13C
+    /* GPIO Output pin set Register */
+#define AM335X_GPIO_DATAIN            0x138
+    /* GPIO Read Data Register */
+#define AM335X_GPIO_CLEARDATAOUT      0x190
+    /* GPIO Output Clear Register */
+#define AM335X_GPIO_SETDATAOUT        0x194
+    /* GPIO Output Set Register */
+## GPIO API
+include_rtems_HEADERS += include/rtems/gpio.h
 ## libfs
 include_rtems_HEADERS += libfs/src/imfs/imfs.h
diff --git a/cpukit/include/rtems/gpio.h b/cpukit/include/rtems/gpio.h
index 0000000..2b9ebf7
--- /dev/null
+++ b/cpukit/include/rtems/gpio.h
@@ -0,0 +1,65 @@
+ * @file rtems/gpio.h
+ * @brief Global GPIO definitions.
+ * This include the generalized definitions for GPIO
+#ifndef _RTEMS_GPIO_H
+#define _RTEMS_GPIO_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/* Returned Error Codes by function */
+#define GPIO_SUCCESSFUL        0 /* operation is OK */
+#define GPIO_UNKNOWN_PIN       1 /* pin not known by bsp */
+#define GPIO_UNCONFIGURED_PIN  2 /* pin unable to configure */
+#define GPIO_MISCONFIGURED_PIN 3 /* pin configuration can't match operation */
+/* Possible GPIO Pin States */
+#define GPIO_PIN_STATE_UNCONFIGURED 0
+#define GPIO_PIN_STATE_DIGITAL_OUT  1
+#define GPIO_PIN_STATE_DIGITAL_IN   2
+ * @brief Structure contains all the required members for GPIO access.
+typedef struct
+  int   pin_number;/* The pin number. */
+  void* platform;  /* Opaque hardware specific set up details. */
+} gpio_pin_handle;
+extern void rtems_gpio_initialize(void);
+ * @brief Selects a GPIO pin for a digital output.
+extern int rtems_gpio_configure_pin_digital_out(gpio_pin_handle *, unsigned int );
+ * @brief Turns on the given pin.
+extern int rtems_gpio_digital_set(gpio_pin_handle *);
+ * @brief Turns off the given pin.
+extern int rtems_gpio_digital_clear(gpio_pin_handle *);
+ * @brief currently configured pin is released and made UNCONFIGURED.
+extern int rtems_gpio_release_pin(gpio_pin_handle *);
+#endif /* _RTEMS_GPIO_H */
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 08455d3..de4f351 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -1,6 +1,6 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
-_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio
+_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio gpio
 if MPTESTS
 ## base_mp is a sample multiprocessing test
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index e6f12d0..ac32583 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -60,6 +60,7 @@ AC_CHECK_SIZEOF([time_t])
 AC_CONFIG_FILES([Makefile
 base_sp/Makefile
 hello/Makefile
+gpio/Makefile
 loopback/Makefile
 minimum/Makefile
 fileio/Makefile
diff --git a/testsuites/samples/gpio/Makefile.am b/testsuites/samples/gpio/Makefile.am
index 0000000..5f06584
--- /dev/null
+++ b/testsuites/samples/gpio/Makefile.am
@@ -0,0 +1,20 @@
+rtems_tests_PROGRAMS = gpio
+gpio_SOURCES = init.c
+dist_rtems_tests_DATA = gpio.scn
+dist_rtems_tests_DATA += gpio.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+LINK_OBJS = $(gpio_OBJECTS)
+LINK_LIBS = $(gpio_LDLIBS)
+hello$(EXEEXT): $(gpio_OBJECTS) $(gpio_DEPENDENCIES)
+	@rm -f gpio$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/samples/gpio/gpio.doc b/testsuites/samples/gpio/gpio.doc
index 0000000..9812864
--- /dev/null
+++ b/testsuites/samples/gpio/gpio.doc
@@ -0,0 +1,9 @@
+#  COPYRIGHT (c) 1989-1999.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
diff --git a/testsuites/samples/gpio/gpio.scn b/testsuites/samples/gpio/gpio.scn
index 0000000..057ab6e
--- /dev/null
+++ b/testsuites/samples/gpio/gpio.scn
@@ -0,0 +1,3 @@
+*** GPIO TEST ***
+Gpio Testing
+*** END OF GPIO TEST ***
diff --git a/testsuites/samples/gpio/init.c b/testsuites/samples/gpio/init.c
index 0000000..90ab0b0
--- /dev/null
+++ b/testsuites/samples/gpio/init.c
@@ -0,0 +1,91 @@
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <bsp/beagleboneblack.h> /* Calls the BBB specific library */
+#include <rtems/gpio.h> /* Calls the BSP gpio library */
+#include <stdio.h>
+static void inline delay_sec(int sec)
+ rtems_task_wake_after(sec*rtems_clock_get_ticks_per_second());
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "Gpio Test";
+rtems_task Init(
+  rtems_task_argument ignored
+ rtems_test_begin();
+ printf("Starting Gpio Testing\n");
+ rtems_gpio_initialize();
+ static gpio_pin_handle led_usr0_handle,led_usr1_handle,led_usr2_handle,led_usr3_handle;
+  /*Generation of USR LED pattern*/
+ if (rtems_gpio_configure_pin_digital_out(&led_usr0_handle, BBB_LED_USR0) == GPIO_SUCCESSFUL) {
+    rtems_gpio_digital_set(&led_usr0_handle);
+    delay_sec(1);
+    rtems_gpio_digital_clear(&led_usr0_handle);
+    delay_sec(1);
+    rtems_gpio_release_pin(&led_usr0_handle);
+ if (rtems_gpio_configure_pin_digital_out(&led_usr1_handle, BBB_LED_USR1) == GPIO_SUCCESSFUL) {
+    rtems_gpio_digital_set(&led_usr1_handle);
+    delay_sec(1);
+    rtems_gpio_digital_clear(&led_usr1_handle);
+    delay_sec(1);
+    rtems_gpio_release_pin(&led_usr1_handle);
+ if (rtems_gpio_configure_pin_digital_out(&led_usr2_handle, BBB_LED_USR2) == GPIO_SUCCESSFUL) {
+    rtems_gpio_digital_set(&led_usr2_handle);
+    delay_sec(1);
+    rtems_gpio_digital_clear(&led_usr2_handle);
+    delay_sec(1);
+    rtems_gpio_release_pin(&led_usr2_handle);
+ if (rtems_gpio_configure_pin_digital_out(&led_usr3_handle, BBB_LED_USR3) == GPIO_SUCCESSFUL) {
+    rtems_gpio_digital_set(&led_usr3_handle);
+    delay_sec(1);
+    rtems_gpio_digital_clear(&led_usr3_handle);
+    delay_sec(1);
+    rtems_gpio_release_pin(&led_usr3_handle);
+ printf("Gpio Test Completed\n");
+ rtems_test_end();
+ exit( 0 );
+/* NOTICE: the clock driver is enabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_SEMAPHORES    1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS         (2 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spstkalloc02/init.c b/testsuites/sptests/spstkalloc02/init.c
index a01bc5c..9ea5db7 100644
