Using tar to access files
    Nick Withers
    nick.withers at anu.edu.au
    Tue Jun 30 05:10:00 UTC 2015
On Tue, 2015-06-30 at 10:09 +0530, Sujay Raj wrote:
> I need to access configurations files the for web server I am porting to
> rtems.
> I create a tar archive , that contains the required folders and files ,
> convert it into c source using rtems-bin2c , ( a header file and a c source
> ) and link them with my project.
> In the init, I call
> sc = Untar_FromMemory((void *)TARFILE_START, (size_t)TARFILE_SIZE);
I'm not familiar with that function but I use rtems_tarfs_load()
successfully.
Not sure whether it needs CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS or
other resources off the top of my head.
P.S. It'd probably be best to send help requests like this to the users
list
> where TARFILE_START is the macro with the name of the array , TARFILE_SIZE
> is the size of the array.
> But when I run the program, I get errors of the form
> "Untar: failed to create file <folder>/<filename>"
> for all the files in the tar archive (there are about 10 files, 10 errors).
> There are no build errors, and since my application recognizes files
> present in the tar archive, I think possibly I am missing to initialize
> something.
> Help would be really appreciated.
> Thanks and Regards,
> Sujay Raj
> devel mailing list
> devel at rtems.org
