Cache issue with BBB networking
Marcos Díaz marcos.diaz at tallertechnologies.com
Tue Jun 30 13:44:12 UTC 2015
I have a question about this, the frebsd driver, was prepared to be used
with cache enabled?
I mean, in freeBSD OS the cache is enabled?
On Tue, Jun 30, 2015 at 12:46 AM, Daniel Gutson <
daniel.gutson at tallertechnologies.com> wrote:
> Ragu,
>    Please ensure that you are getting cache coherence right. That is,
> there are no packets crossing the cache lines.
> FWIW, in a life ago, i got a problem with an eth driver where the
> descriptors ring was not properly sized (ie no modulus cache line).
> El 29/6/2015 17:23, "ragu nath" <ragunath3252 at gmail.com> escribió:
>> Thanks Marcos. I will let you know if there is any progress.
>> Regards,
>> Ragunath
>> On Tue, Jun 30, 2015 at 12:50 AM, Marcos Díaz <
>> marcos.diaz at tallertechnologies.com> wrote:
>>> Hi,
>>> I'm sorry but in the development of the porting of LWIP i couldn't give
>>> any more time to the task, so when I reached that stage I just disabled the
>>> cache.
>>> I will try to give some time to that to see if i can help you, and of
>>> course, let me know if you find something.
>>> Sorry again
>>> On Mon, Jun 29, 2015 at 3:16 PM, ragu nath <ragunath3252 at gmail.com>
>>> wrote:
>>>> Hi Marcos,
>>>> I am working on porting ethernet driver for Beaglebone black from
>>>> FreeBSD to rtems-libbsd as part of GSOC 2015. I ported the driver and
>>>> got it working.
>>>> But there was one issue I faced, similar to the one you mentioned in
>>>> our earlier correspondence (regarding lwIP). You mentioned that the
>>>> system crashes if cache is enabled.
>>>> In my case, the Address Lookup Engine (ALE) is getting corrupted if
>>>> cache is enabled. Because of this packet transmission failed sending
>>>> out random junk packets. With cache disabled, networking is working.
>>>> I am looking for options other than disabling cache as a whole. Is
>>>> there any other option available?  Can you share the details of any of
>>>> the things you tried and found not working?
>>>> Thanks,
>>>> Ragunath
>>> ______________________________
>>> <http://www.tallertechnologies.com>
>>> Marcos Díaz
>>> Software Engineer
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>> Skype: markdiaz22
>> ragu
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150630/d3e225ec/attachment-0002.html>
