[PATCH] GPIO Driver Sample Application
Gedare Bloom
gedare at gwu.edu
Tue Jun 30 16:52:24 UTC 2015
Try to figure out how to make the sample not be BSP (BBB)-specific. If
you can't then instead this should probably go into examples-v2 and
use a similar model as the LED example there. Speaking of which,
perhaps the LED example should be extended to be supported on the BBB?
Gedare
On Tue, Jun 30, 2015 at 6:01 AM, Ketul Shah <ketulshah1993 at gmail.com> wrote:
> diff --git a/testsuites/samples/gpio/init.c b/testsuites/samples/gpio/init.c
> new file mode 100644
> index 0000000..391d80c
> --- /dev/null
> +++ b/testsuites/samples/gpio/init.c
> @@ -0,0 +1,94 @@
> + * Copyright (c) 2015 Ketul Shah <ketulshah1993 at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/test.h>
> +#include <bsp/beagleboneblack.h> /* Calls the BBB specific library */
> +#include <rtems/gpio.h> /* Calls the BSP gpio library */
> +#include <stdio.h>
> +#include <stdlib.h>
> +static void inline delay_sec(int sec)
> + rtems_task_wake_after(sec*rtems_clock_get_ticks_per_second());
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument argument);
> +const char rtems_test_name[] = "Gpio Test";
> +rtems_task Init(
> + rtems_task_argument ignored
> + rtems_test_begin();
> + printf("Starting Gpio Testing\n");
> + /* Intializing GPIO API */
> + rtems_gpio_initialize();
> + static gpio_pin_handle led_usr0_handle, led_usr1_handle, led_usr2_handle;
> + static gpio_pin_handle led_usr3_handle;
> + static unsigned int status;
> + status = rtems_gpio_configure_pin_digital_out(&led_usr0_handle, BBB_LED_USR0);
> + if (status == GPIO_SUCCESSFUL) {
> + rtems_gpio_digital_set(&led_usr0_handle);
> + delay_sec(1);
> + rtems_gpio_digital_clear(&led_usr0_handle);
> + delay_sec(1);
> + rtems_gpio_release_pin(&led_usr0_handle);
> + status = rtems_gpio_configure_pin_digital_out(&led_usr1_handle, BBB_LED_USR1);
> + rtems_gpio_digital_set(&led_usr1_handle);
> + delay_sec(1);
> + rtems_gpio_digital_clear(&led_usr1_handle);
> + delay_sec(1);
> + rtems_gpio_release_pin(&led_usr1_handle);
> + status = rtems_gpio_configure_pin_digital_out(&led_usr2_handle, BBB_LED_USR2);
> + rtems_gpio_digital_set(&led_usr2_handle);
> + delay_sec(1);
> + rtems_gpio_digital_clear(&led_usr2_handle);
> + delay_sec(1);
> + rtems_gpio_release_pin(&led_usr2_handle);
> + status = rtems_gpio_configure_pin_digital_out(&led_usr3_handle, BBB_LED_USR3);
> + rtems_gpio_digital_set(&led_usr3_handle);
> + delay_sec(1);
> + rtems_gpio_digital_clear(&led_usr3_handle);
> + delay_sec(1);
> + rtems_gpio_release_pin(&led_usr3_handle);
> + printf("Gpio Test Completed\n");
> + rtems_test_end();
> + exit( 0 );
> +/* NOTICE: the clock driver is enabled */
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_MAXIMUM_SEMAPHORES 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_EXTRA_TASK_STACKS (2 * RTEMS_MINIMUM_STACK_SIZE)
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> \ No newline at end of file
> diff --git a/testsuites/samples/gpio/gpio.doc b/testsuites/samples/gpio/gpio.doc
> index 0000000..9812864
> --- /dev/null
> +++ b/testsuites/samples/gpio/gpio.doc
> @@ -0,0 +1,9 @@
> +# COPYRIGHT (c) 1989-1999.
> +# On-Line Applications Research Corporation (OAR).
> +# The license and distribution terms for this file may be
> +# found in the file LICENSE in this distribution or at
> +# http://www.rtems.org/license/LICENSE.
> diff --git a/testsuites/samples/gpio/gpio.scn b/testsuites/samples/gpio/gpio.scn
> index 0000000..057ab6e
> --- /dev/null
> +++ b/testsuites/samples/gpio/gpio.scn
> @@ -0,0 +1,3 @@
> +*** GPIO TEST ***
> +Gpio Testing
> +*** END OF GPIO TEST ***
> devel mailing list
> devel at rtems.org
