[PATCH 5/8] score: Add ISR lock to Objects_Control
Wed Mar 4 15:07:05 UTC 2015
This enables per-object SMP locks on SMP configurations and is the first
step to support fine-grained locking.  On uni-processor configuration
there will be no overhead.  The _Objects_Acquire() is intended to
replace _Objects_Get_isr_disable().
Update #2273.
 cpukit/score/Makefile.am                      |  1 +
 cpukit/score/include/rtems/score/object.h     |  3 +
 cpukit/score/include/rtems/score/objectimpl.h | 80 +++++++++++++++++++++++++++
 cpukit/score/src/objectacquire.c              | 80 +++++++++++++++++++++++++++
 cpukit/score/src/objectclose.c                |  2 +
 5 files changed, 166 insertions(+)
 create mode 100644 cpukit/score/src/objectacquire.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index a2d440b..509a243 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -202,6 +202,7 @@ libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
     src/objectgetinfo.c src/objectgetinfoid.c src/objectapimaximumclass.c \
     src/objectnamespaceremove.c \
     src/objectactivecount.c
+libscore_a_SOURCES += src/objectacquire.c
 ## SCHEDULER_C_FILES
 libscore_a_SOURCES += src/log2table.c
diff --git a/cpukit/score/include/rtems/score/object.h b/cpukit/score/include/rtems/score/object.h
index 70e5fe6..d0cb579 100644
--- a/cpukit/score/include/rtems/score/object.h
+++ b/cpukit/score/include/rtems/score/object.h
@@ -23,6 +23,7 @@
 #include <rtems/score/cpu.h>
+#include <rtems/score/isrlock.h>
 #ifdef __cplusplus
 extern "C" {
@@ -236,6 +237,8 @@ typedef struct {
   Objects_Id     id;
   /** This is the object's name. */
   Objects_Name   name;
+  /** This is the object's ISR lock. */
+  ISR_LOCK_DEFINE( Lock )
 } Objects_Control;
 #if defined( RTEMS_MULTIPROCESSING )
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 2928eff..c681c9a 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -591,6 +591,83 @@ Objects_Control *_Objects_Get_no_protection(
+ * @brief Acquires an object by its identifier.
+ * This function is similar to _Objects_Get_isr_disable().  It acquires the
+ * object specific ISR lock for local objects.  Thread dispatching is not
+ * disabled for local objects.  For remote objects thread dispatching is
+ * disabled.
+ * @param[in] information The object information.
+ * @param[in] id The object identifier.
+ * @param[in] location The location of the object.
+ * @param[in] lock_context The lock context for local objects.
+ * @retval object The object corresponding to the identifier.
+ * @retval NULL No object exists in this domain for this identifer.
+ * @see _Objects_Release(), _Objects_Release_and_ISR_enable(), and
+ * _Objects_Release_and_thread_dispatch_disable().
+Objects_Control *_Objects_Acquire(
+  const Objects_Information *information,
+  Objects_Id                 id,
+  Objects_Locations         *location,
+  ISR_lock_Context          *lock_context
+ * @brief Releases a local object.
+ * @param[in] the_object The local object acquired by _Objects_Acquire().
+ * @param[in] lock_context The lock context initialized by _Objects_Acquire().
+RTEMS_INLINE_ROUTINE void _Objects_Release(
+  Objects_Control  *the_object,
+  _ISR_lock_Release( &the_object->Lock, lock_context );
+ * @brief Releases a local object and restores the interrupt level.
+RTEMS_INLINE_ROUTINE void _Objects_Release_and_ISR_enable(
+  _ISR_lock_Release_and_ISR_enable( &the_object->Lock, lock_context );
+ * @brief Releases a local object, disables thread dispatching and restores the
+ * interrupt level.
+ * @return The current processor.
+RTEMS_INLINE_ROUTINE Per_CPU_Control *
+_Objects_Release_and_thread_dispatch_disable(
+  Per_CPU_Control *cpu_self = _Per_CPU_Get();
+  _Thread_Dispatch_disable_critical( cpu_self );
+  _Objects_Release_and_ISR_enable( the_object, lock_context );
+  return cpu_self;
  *  Like @ref _Objects_Get, but is used to find "next" open object.
  *  @param[in] information points to an object class information block.
@@ -903,6 +980,7 @@ RTEMS_INLINE_ROUTINE void _Objects_Open(
   _Assert( the_object != NULL );
   the_object->name = name;
+  _ISR_lock_Initialize( &the_object->Lock, "Object" );
   _Objects_Set_local_object(
     information,
@@ -927,6 +1005,7 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_u32(
   /* ASSERT: information->is_string == false */
   the_object->name.name_u32 = name;
     information,
@@ -953,6 +1032,7 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_string(
     /* ASSERT: information->is_string */
     the_object->name.name_p = name;
   #endif
     information,
diff --git a/cpukit/score/src/objectacquire.c b/cpukit/score/src/objectacquire.c
new file mode 100644
index 0000000..57d38f4
--- /dev/null
+++ b/cpukit/score/src/objectacquire.c
@@ -0,0 +1,80 @@
+ * @file
+ * @brief Object Acquire
+ * @ingroup ScoreObject
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/objectimpl.h>
+  Objects_Id                 id,
+  Objects_Control *the_object;
+  uint32_t         index;
+  index = id - information->minimum_id + 1;
+  if ( information->maximum >= index ) {
+     * On uni-processor configurations we disable interrupts before we use the
+     * local table.  This prevents use of freed memory in case the object
+     * information is extended in between.  On SMP configurations bad things
+     * can happen, see https://devel.rtems.org/ticket/2280.
+#if !defined(RTEMS_SMP)
+    ISR_Level level;
+    _ISR_Disable( level );
+#endif
+    if ( ( the_object = information->local_table[ index ] ) != NULL ) {
+      *location = OBJECTS_LOCAL;
+#if defined(RTEMS_SMP)
+      _ISR_lock_ISR_disable_and_acquire( &the_object->Lock, lock_context );
+#else
+      lock_context->isr_level = level;
+#endif
+      return the_object;
+    _ISR_Enable( level );
+#endif
+    *location = OBJECTS_ERROR;
+    return NULL;
+#if defined(RTEMS_MULTIPROCESSING)
+  _Objects_MP_Is_remote( information, id, location, &the_object );
+#else
+  return NULL;
+#endif
diff --git a/cpukit/score/src/objectclose.c b/cpukit/score/src/objectclose.c
index 52eb10c..25c7aa1 100644
--- a/cpukit/score/src/objectclose.c
+++ b/cpukit/score/src/objectclose.c
@@ -28,4 +28,6 @@ void _Objects_Close(
   _Objects_Invalidate_Id( information, the_object );
   _Objects_Namespace_remove( information, the_object );
+  _ISR_lock_Destroy( &the_object->Lock );
1.8.4.5
