[PATCH] tests: Refactor parallel test execution
Wed Mar 4 15:43:31 UTC 2015
Would it at least make sense to add a subdirectory with a different name
in cpukit?
You could add libmisc/test_support and only have to add a few lines to
libmisc/Makefile.am. That would contain this stuff better.
On 3/4/2015 9:41 AM, Gedare Bloom wrote:
> OK.
> On Wed, Mar 4, 2015 at 9:22 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 04/03/15 15:17, Gedare Bloom wrote:
>>> It seems that these changes to test.h and the new testparallel.c
>>> belong in the testsuites/smptests area, perhaps in a shared/
>>> subdirectory. Certainly I don't see why testparallel.c is in sapi. (I
>>> don't recall why we have testing framework in the sapi though...)
>> The problem with this shared subdirectory in the testsuite area is that this
>> leads to copy and paste in the Makefiles and this is a maintenance
>> nightmare.  We probably need a library for all tests. This is a build system
>> issue, which I would like to postpone after the waf integration.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
