[PATCH 1/8] score: Update _Thread_Heir only if necessary
Wed Mar 4 15:44:36 UTC 2015
On Wed, Mar 4, 2015 at 10:42 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 3/4/2015 9:07 AM, Sebastian Huber wrote:
>> Previously, the _Thread_Heir was updated unconditionally in case a new
>> heir was determined.  The _Thread_Dispatch_necessary was only updated in
>> case the executing thread was preemptible or an internal thread was
>> unblocked.  Change this to update the _Thread_Heir and
>> _Thread_Dispatch_necessary only in case the currently selected heir
>> thread is preemptible or a dispatch is forced.  Move the schedule
>> decision into the change priority operation and use the schedule
>> operation only in rtems_task_mode() in case preemption is enabled or an
>> ASR dispatch is necessary.  This is a behaviour change.  Previously, the
>> RTEMS_NO_PREEMPT also prevented signal delivery in certain cases (not
>> always).  Now, signal delivery is no longer influenced by
>> RTEMS_NO_PREEMPT.  Since the currently selected heir thread is used to
>> determine if a new heir is chosen, non-preemptible heir threads
>> currently not executing now prevent a new heir.  This may have an
>> application impact, see change test tm04.  Document this change in sp04.
>> Update #2273.
>> diff --git a/cpukit/score/src/schedulercbsunblock.c b/cpukit/score/src/schedulercbsunblock.c
>> index 688253c..bd27aff 100644
>> --- a/cpukit/score/src/schedulercbsunblock.c
>> +++ b/cpukit/score/src/schedulercbsunblock.c
>> @@ -79,10 +79,10 @@ Scheduler_Void_or_thread _Scheduler_CBS_Unblock(
>>         _Thread_Heir->current_priority
>> -    _Thread_Heir = the_thread;
>> -    if ( _Thread_Executing->is_preemptible ||
>> -         the_thread->current_priority == 0 )
>> -      _Thread_Dispatch_necessary = true;
>> +    _Scheduler_Update_heir(
>> +      the_thread,
>> +      the_thread->current_priority == 0
> The use of an expression without parentheses seems inconsistent
> style-wise. I don't think this type of code is used often but could
> you please put parentheses around this?
This conflicts with our coding conventions to avoid excess parens.
> This same pattern is in other places so please do it globally across
> this patch.
> I think I spotted a total of four places.
> Also since this indicates that the thread is at the pseudo-interrupt
> priority,
> maybe a macro/static inline with a meaningful name would be even
> better.
Yes a macro might be good for this test.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
