Why is CPU_INLINE_ENABLE_DISPATCH defined to TRUE on SPARC?
Wed Mar 4 15:52:32 UTC 2015
Because it has been that way since 1999?
The only reason I can think would be to curtail register window
side-effects if there are any. I doubt there would be.
Gedare
On Wed, Mar 4, 2015 at 10:10 AM, Sebastian Huber
> Hello,
> why is CPU_INLINE_ENABLE_DISPATCH defined to TRUE on SPARC? You can say a
> lot about SPARC, but not that function calls are slow.  Is it not better to
> reduce the code size and don't inline the _Thread_Enable_dispatch()?
> devel mailing list
> devel at rtems.org
