[PATCH 1/8] score: Update _Thread_Heir only if necessary
Thu Mar 5 06:56:51 UTC 2015
On 04/03/15 20:24, Joel Sherrill wrote:
>>>> This same pattern is in other places so please do it globally across
>>>> >>>this patch.
>>>> >>>I think I spotted a total of four places.
>>>> >>>Also since this indicates that the thread is at the pseudo-interrupt
>>>> >>>priority,
>>>> >>>maybe a macro/static inline with a meaningful name would be even
>>>> >>>better.
>>> >>Yes a macro might be good for this test.
>> >Since we started this discussion. It seems that the MPCI thread is the
>> >only thread with a priority of 0. Should this be #ifdef
>> >RTEMS_MULTIPROCESSING? Looks otherwise like dead code. It is possible to
>> >gain a priority of 0 via the priority ceiling protocol. Is this a bug?
> No. The timer server has a default priority of 0 also.
> I suppose if code called from the timer server used a priority ceiling
> mutex,
> then it could get an error. But you have to be careful of timer service
> routines
> anyway.
Ok, this was a bit difficult to see, since it was obscured by the
RTEMS_SYSTEM_TASK attribute.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
