[PATCH] score: Add and use PRIORITY_PSEUDO_ISR
Thu Mar 5 07:33:51 UTC 2015
 cpukit/rtems/src/timerserver.c              | 2 +-
 cpukit/score/include/rtems/score/priority.h | 7 +++++++
 cpukit/score/src/mpci.c                     | 2 +-
 3 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
index ad32172..e4fe56f 100644
--- a/cpukit/rtems/src/timerserver.c
+++ b/cpukit/rtems/src/timerserver.c
@@ -481,7 +481,7 @@ rtems_status_code rtems_timer_initiate_server(
   if ( !_RTEMS_tasks_Priority_is_valid( priority ) ) {
     if ( priority != RTEMS_TIMER_SERVER_DEFAULT_PRIORITY )
       return RTEMS_INVALID_PRIORITY;
-    _priority = 0;
+    _priority = PRIORITY_PSEUDO_ISR;
diff --git a/cpukit/score/include/rtems/score/priority.h b/cpukit/score/include/rtems/score/priority.h
index f10f731..0a772f6 100644
--- a/cpukit/score/include/rtems/score/priority.h
+++ b/cpukit/score/include/rtems/score/priority.h
@@ -58,6 +58,13 @@ typedef uint32_t   Priority_Control;
 /** This defines the highest (most important) thread priority. */
 #define PRIORITY_MINIMUM      0
+ * @brief This defines the priority of pseudo-ISR threads.
+ * Examples are the MPCI and timer server threads.
+#define PRIORITY_PSEUDO_ISR   PRIORITY_MINIMUM
 /** This defines the default lowest (least important) thread priority. */
 #if defined (CPU_PRIORITY_MAXIMUM)
   #define PRIORITY_DEFAULT_MAXIMUM      CPU_PRIORITY_MAXIMUM
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index e8a8ba2..a2acf89 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -112,7 +112,7 @@ void _MPCI_Create_server( void )
       CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK +
       _Configuration_MP_table->extra_mpci_receive_server_stack,
     CPU_ALL_TASKS_ARE_FP,
-    PRIORITY_MINIMUM,
+    PRIORITY_PSEUDO_ISR,
     false,       /* no preempt */
     THREAD_CPU_BUDGET_ALGORITHM_NONE,
     NULL,        /* no budget algorithm callout */
1.8.4.5
