UART driver: read function
Fri Mar 6 10:20:09 UTC 2015
Hello Daniel,
I would not use the C stdio for this and instead directly use the POSIX
read/write. You have to set up the right Termios settings.  In case you
use RTEMS 4.11 I would use the new Termios device interface (see
rtems_termios_device_install()).
On 06/03/15 10:52, Daniel Krüger wrote:
> Hello,
> what is the right implementation for the UART driver read function
> (console_fns .deviceRead)? It seems to be implemented differently from
> target to target. Some implementations return -1 if the receive FIFO
> is empty and some implementations do a busy waiting for new characters.
> I would like to use some Posix application code, which switches stdin
> into non-blocking mode and uses getchar() to read from UART. getchar()
> shall return EOF if no character is available.
> This code requires that the UART driver read function does not block,
> otherwise getchar() will block. But a non-blocking UART driver is not
> sufficient. The function __srefill_r() in newlib/libc/stdio/refill.c
> sets the flag __SEOF whenever the driver's read function returns no
> characters. So on subsequent calls of getchar() and hence
> __srefill_r() the UART driver's read function is not called anymore,
> because __SEOF flag is set (see if statement at beginning of
> __srefill_r()).
> My current work-around is to call clearerr(stdin) before calling
> getchar(). clearerr() resets the flag __SEOF, so getchar() will get
> the current character from the UART driver.
> There are many other functions and modules (e.g. console*.c,
> rtems_termios*, ...) involved between getchar() and the UART driver's
> read function. So it's a little bit hard to dig into that issue and to
> find a good solution.
> Best regards,
>   Daniel Krüger
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
