[PATCH] Test_environment: cascading option implemented
Alexander Krutwig alexander.krutwig at embedded-brains.de
Fri Mar 6 13:49:06 UTC 2015
 cpukit/libmisc/testsupport/test.h         | 23 ++++++++-
 cpukit/libmisc/testsupport/testparallel.c | 24 +++++----
 testsuites/smptests/smpatomic01/init.c    | 84 ++++++++++++++++++++-----------
 3 files changed, 90 insertions(+), 41 deletions(-)
diff --git a/cpukit/libmisc/testsupport/test.h b/cpukit/libmisc/testsupport/test.h
index afed462..6b46244 100644
--- a/cpukit/libmisc/testsupport/test.h
+++ b/cpukit/libmisc/testsupport/test.h
@@ -141,13 +141,16 @@ typedef struct {
    * @param[in] ctx The parallel context.
    * @param[in] arg The user specified argument.
+   * @param[in] active_workers Count of active workers.  Depends on the cascade
+   *   option.
    * @return The desired job body execution time in clock ticks.  See
    *   rtems_test_parallel_stop_job().
   rtems_interval (*init)(
     rtems_test_parallel_context *ctx,
-    void *arg
+    void *arg,
+    size_t active_workers
@@ -172,13 +175,29 @@ typedef struct {
+   *   option.
   void (*fini)(
-    void *arg
+    void *arg,
+   * @brief Job specific argument.
   void *arg;
+   * @brief Job cascading flag.
+   * This flag indicates whether the job should be executed in a cascaded
+   * manner (if n processors are available, test is executed on one processor
+   * first, two processors afterwards and incremented step by step until all
+   * processors are used)
+  bool cascade;
 } rtems_test_parallel_job;
diff --git a/cpukit/libmisc/testsupport/testparallel.c b/cpukit/libmisc/testsupport/testparallel.c
index 681f769..5e572b5 100644
--- a/cpukit/libmisc/testsupport/testparallel.c
+++ b/cpukit/libmisc/testsupport/testparallel.c
@@ -58,21 +58,27 @@ static void run_tests(
   for (i = 0; i < job_count; ++i) {
     const rtems_test_parallel_job *job = &jobs[i];
+    size_t n = job->cascade ? rtems_get_processor_count() : 1;
+    size_t j;
-    if (rtems_test_parallel_is_master_worker(worker_index)) {
-      rtems_interval duration = (*job->init)(ctx, job->arg);
+    for (j = 0; j < n; ++j) {
+      if (rtems_test_parallel_is_master_worker(worker_index)) {
+        rtems_interval duration = (*job->init)(ctx, job->arg, j + 1);
-      start_worker_stop_timer(ctx, duration);
+        start_worker_stop_timer(ctx, duration);
-    _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
+      _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
-    (*job->body)(ctx, job->arg, worker_index);
+      if (worker_index <= j) {
+        (*job->body)(ctx, job->arg, worker_index);
-      (*job->fini)(ctx, job->arg);
+        (*job->fini)(ctx, job->arg, j + 1);
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index fbd20fa..53d32c2 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -98,7 +98,8 @@ static void test_fini(
 static rtems_interval test_atomic_add_init(
   rtems_test_parallel_context *base,
-  void *arg
+  void *arg,
   smpatomic01_context *ctx = (smpatomic01_context *) base;
@@ -125,7 +126,11 @@ static void test_atomic_add_body(
   ctx->per_worker_value[worker_index] = counter;
-static void test_atomic_add_fini(rtems_test_parallel_context *base, void *arg)
+static void test_atomic_add_fini(
+  rtems_test_parallel_context *base,
+  void *arg,
@@ -134,7 +139,8 @@ static void test_atomic_add_fini(rtems_test_parallel_context *base, void *arg)
 static rtems_interval test_atomic_flag_init(
-  void *arg
+  void *arg,
@@ -168,7 +174,11 @@ static void test_atomic_flag_body(
-static void test_atomic_flag_fini(rtems_test_parallel_context *base, void *arg)
+static void test_atomic_flag_fini(
+  void *arg,
@@ -177,7 +187,8 @@ static void test_atomic_flag_fini(rtems_test_parallel_context *base, void *arg)
 static rtems_interval test_atomic_sub_init(
-  void *arg
+  void *arg,
@@ -204,7 +215,11 @@ static void test_atomic_sub_body(
-static void test_atomic_sub_fini(rtems_test_parallel_context *base, void *arg)
+static void test_atomic_sub_fini(
+  void *arg,
@@ -213,7 +228,8 @@ static void test_atomic_sub_fini(rtems_test_parallel_context *base, void *arg)
 static rtems_interval test_atomic_compare_exchange_init(
-  void *arg
+  void *arg,
@@ -259,7 +275,8 @@ static void test_atomic_compare_exchange_body(
 static void test_atomic_compare_exchange_fini(
-  void *arg
+  void *arg,
@@ -269,7 +286,8 @@ static void test_atomic_compare_exchange_fini(
 static rtems_interval test_atomic_or_and_init(
-  void *arg
+  void *arg,
@@ -316,7 +334,8 @@ static void test_atomic_or_and_body(
 static void test_atomic_or_and_fini(
-  void *arg
+  void *arg,
@@ -326,7 +345,8 @@ static void test_atomic_or_and_fini(
 static rtems_interval test_atomic_fence_init(
-  void *arg
+  void *arg,
@@ -369,7 +389,11 @@ static void test_atomic_fence_body(
-static void test_atomic_fence_fini(rtems_test_parallel_context *base, void *arg)
+static void test_atomic_fence_fini(
+  void *arg,
@@ -383,29 +407,29 @@ static void test_atomic_fence_fini(rtems_test_parallel_context *base, void *arg)
 static const rtems_test_parallel_job test_jobs[] = {
-    test_atomic_add_init,
-    test_atomic_add_body,
-    test_atomic_add_fini
+    .init = test_atomic_add_init,
+    .body = test_atomic_add_body,
+    .fini = test_atomic_add_fini
-    test_atomic_flag_init,
-    test_atomic_flag_body,
-    test_atomic_flag_fini
+    .init = test_atomic_flag_init,
+    .body =test_atomic_flag_body,
+    .fini =test_atomic_flag_fini
-    test_atomic_sub_init,
-    test_atomic_sub_body,
-    test_atomic_sub_fini
+    .init = test_atomic_sub_init,
+    .body =test_atomic_sub_body,
+    .fini =test_atomic_sub_fini
-    test_atomic_compare_exchange_init,
-    test_atomic_compare_exchange_body,
-    test_atomic_compare_exchange_fini
+    .init = test_atomic_compare_exchange_init,
+    .body =test_atomic_compare_exchange_body,
+    .fini =test_atomic_compare_exchange_fini
-    test_atomic_or_and_init,
-    test_atomic_or_and_body,
-    test_atomic_or_and_fini
+    .init = test_atomic_or_and_init,
+    .body =test_atomic_or_and_body,
+    .fini =test_atomic_or_and_fini
-    test_atomic_fence_init,
-    test_atomic_fence_body,
-    test_atomic_fence_fini
+    .init = test_atomic_fence_init,
+    .body =test_atomic_fence_body,
+    .fini =test_atomic_fence_fini
1.8.4.5
