Fwd: Problem running executable in debugger on Mac OS Mavericks
Fri Mar 6 14:01:24 UTC 2015
Hi Cyrille,
On Fri, Mar 6, 2015 at 12:10 AM, Cyrille Artho <c.artho at aist.go.jp> wrote:
> Hi all,
> I have tried to build rtems-builder and rtems following the "Quick Start"
> instructions on the web page. It seems I can build executables as I can find
> "ticker.exe". However, I cannot run it as shown.
> "tar sim" is not recognized; it seems the simulator is not built correctly.
> Below is the output from gdb. What went wrong?
> I also don't have a binary called "i386-rtems4.11-run", which is mentioned
> on the quick start guide as well.
You made the logical but invalid assumption that every toolchain works
the same. The "run" command is only available for some of the targets
for which RTEMS is cross-compiled. In particular, sparc-sis can be
executed by a simulator in gdb, which is what sparc-rtems4.11-run
wraps. 'tar sim' is available only when the gdb simulator support
exists.
For i386 the recommended simulator to use is Qemu.
Gedare
> i386-rtems4.11-gdb ./ticker.exe
> GNU gdb (GDB) 7.8.2
> Copyright (C) 2014 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later
> <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "--host=x86_64-apple-darwin13.3.0
> --target=i386-rtems4.11".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from ./ticker.exe...done.
> (gdb) tar sim
> Undefined target command: "sim".  Try "help target".
> (gdb) help target
> Connect to a target machine or process.
> The first argument is the type or protocol of the target machine.
> Remaining arguments are interpreted by the target protocol.  For more
> information on the arguments for a particular protocol, type
> `help target ' followed by the protocol name.
> List of target subcommands:
> target core -- Use a core file as a target
> target exec -- Use an executable file as a target
> target extended-remote -- Use a remote computer via a serial line
> target record -- Log program while executing and replay execution from log
> target record-btrace -- Collect control-flow trace and provide the execution
> history
> target record-core -- Log program while executing and replay execution from
> log
> target record-full -- Log program while executing and replay execution from
> log
> target remote -- Use a remote computer via a serial line
> target tfile -- Use a trace file as a target
> Type "help target" followed by target subcommand name for full
> documentation.
> Command name abbreviations are allowed if unambiguous.
> Regards,
> Cyrille Artho - http://artho.com/
> War is like love, it always finds a way.
>                 -- Bertolt Brecht, "Mother Courage"
> devel mailing list
> devel at rtems.org
