an error about RTEMS compile when make
Fri Mar 6 14:41:04 UTC 2015
Asher,
I see two problems.
First, is that the native compiler is failing for some reason in the
tools subdirectory, which is the only part of RTEMS that gets compiled
by the native compiler. From what I can tell it appears like the
native compiler is not finding the dlls needed to compile argument
processing (optargs).
The rest of RTEMS is cross-compiled, which means the compiler that
gets used when compiling RTEMS is not /bin/gcc but should instead (in
your case) be /opt/rtems-4.10/bin/arm-rtems4.10-gcc. The second
problem comes where it says:
checking for arm-rtems4.10-gcc... arm-rtems4.10-gcc
checking for arm-rtems4.10-gcc... (cached) arm-rtems4.10-gcc
checking whether the C compiler works... no
configure: error: in `/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c/csb337':
configure: error: C compiler cannot create executables
See `config.log' for more details
Makefile:712: recipe for target 'csb337' failed
make[2]: *** [csb337] Error 1
make[2]: Leaving directory '/archive/rtems-4.10.2/build-
rtems/arm-rtems4.10/c'
Look through config.log in the build subdirectory
'/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c' to try to find the
problem with arm-rtems4.10-gcc.
You might like to consider using a virtual machine with a Linux host
instead of Windows.
Gedare
On Thu, Mar 5, 2015 at 9:47 PM, zhengyazhou <zxya1014 at 163.com> wrote:
> When I first time configure and make,here comes the error in make :
> then I execute the command
>  $ ln -s /bin/gcc.exe /bin/cc.exe     ( copy from Using MS-Windows as a
> Development Host, PartA.2 Cygwin)
> then I execute configure and make again, the error changed to
> make[2]: *** No rule to make target 'all'。 停止。
> '/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c/csb337'
> Makefile:257: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> Makefile:275: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> Bellowed is the detail of the configure and make
> The first time configure and make
> first time configure infomation:
> $ ../configure --target=arm-rtems4.10 --disable-posix --disable-networking
> --dis
> able-cxx --enable-rtemsbsp=csb337 --prefix=/opt/rtems-4.10
> checking for gmake... no
> checking for make... make
> checking for RTEMS Version... 4.10.2
> checking build system type... x86_64-unknown-cygwin
> checking host system type... x86_64-unknown-cygwin
> checking target system type... arm-unknown-rtems4.10
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> configure: creating ./config.status
> configure: configuring in ./tools/build
> configure: running /bin/sh '../../../tools/build/configure'
> '--prefix=/opt/rtems
> -4.10' '--host=x86_64-unknown-cygwin' '--build=x86_64-unknown-cygwin'
> '--disabl
> e-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=csb337'
> '--ta
> rget=arm-rtems4.10'  '--cache-file=/dev/null'
> '--srcdir=../../../tools/build'
> checking for x86_64-unknown-cygwin-gcc... no
> checking for gcc... gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.exe
> checking for suffix of executables... .exe
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for style of include used by make... GNU
> checking dependency style of gcc... gcc3
> checking how to run the C preprocessor... gcc -E
> checking for grep that handles long lines and -e... /usr/bin/grep
> checking for egrep... /usr/bin/grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking getopt.h usability... yes
> checking getopt.h presence... yes
> checking for getopt.h... yes
> checking for strerror... yes
> checking for strtol... yes
> checking for bash... /usr/bin/bash
> config.status: creating Makefile
> config.status: creating install-if-change
> config.status: creating config.h
> config.status: executing depfiles commands
> configure: configuring in ./tools/cpu
> configure: running /bin/sh '../../../tools/cpu/configure'
> '--prefix=/opt/rtems-4
> '--disable-
> '--targ
> et=arm-rtems4.10'  '--cache-file=/dev/null' '--srcdir=../../../tools/cpu'
> checking rtems target cpu... arm
> === configuring in generic
> (/archive/rtems-4.10.2/build-rtems/tools/cpu/generic)
> configure: running /bin/sh ../../../../tools/cpu/generic/configure
> --disable-opt
> ion-checking '--prefix=/opt/rtems-4.10'  '--host=x86_64-unknown-cygwin'
> '--build
> =x86_64-unknown-cygwin' '--disable-posix' '--disable-networking'
> '--disable-cxx'
> '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
> 'build_alias=x86_64-unknown
> -cygwin' 'host_alias=x86_64-unknown-cygwin' 'target_alias=arm-rtems4.10'
> --cache
> -file=/dev/null --srcdir=../../../../tools/cpu/generic
> config.status: creating size_rtems
> configure: configuring in ./testsuites/tools
> configure: running /bin/sh '../../../testsuites/tools/configure'
> '--prefix=/opt/
> rtems-4.10' '--host=x86_64-unknown-cygwin' '--build=x86_64-unknown-cygwin'
> '--d
> isable-posix' '--disable-networking' '--disable-cxx'
> '--target=arm-rtems4.10'  '--cache-file=/dev/null'
> '--srcdir=../../../testsuites
> /tools'
> (/archive/rtems-4.10.2/build-rtems/testsuites/tools/g
> eneric)
> configure: running /bin/sh ../../../../testsuites/tools/generic/configure
> --disa
> ble-option-checking '--prefix=/opt/rtems-4.10'
> --build=x86_64-unknown-cygwin' '--disable-posix' '--disable-networking'
> '--disab
> le-cxx' '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
> unknown-cygwin' 'host_alias=x86_64-unknown-cygwin'
> --cache-file=/dev/null --srcdir=../../../../testsuites/tools/generic
> config.status: creating difftest
> config.status: creating sorttimes
> configure: configuring in arm-rtems4.10/c
> configure: running /bin/sh '../../../c/configure' '--prefix=/opt/rtems-4.10'
> host=arm-rtems4.10' '--build=x86_64-unknown-cygwin' '--target=arm-rtems4.10'
> -disable-posix' '--disable-networking' '--disable-cxx'
> ' '--with-target-subdir=arm-rtems4.10'
> '--exec-prefix=/opt/rtems-4.10/arm-rtems4
> .10' '--includedir=/opt/rtems-4.10/arm-rtems4.10/include'
> ll' '--srcdir=../../../c'
> checking host system type... arm-unknown-rtems4.10
> checking for arm-rtems4.10-strip... arm-rtems4.10-strip
> target architecture: arm.
> available BSPs: csb337.
> 'make all' will build the following BSPs: csb337.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> config.status: creating make/Makefile
> The first time make information:
> $ make
> Making all in make
> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/make'
> make[1]: Nothing to be done for 'all'.
> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/make'
> Making all in tools/build
> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/build'
> make  all-am
> make[2]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/build'
> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build     -g -O2 -MT cklength.o -MD
> -MP -MF .deps/cklength.Tpo -c -o cklength.o ../../../tools/build/cklength.c
> ../../../tools/build/cklength.c:87:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
> dllimport [-Wattributes]
>  extern char *optarg;                    /* getopt(3) control vars */
> ../../../tools/build/cklength.c:88:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
>  extern int optind, opterr;
> ../../../tools/build/cklength.c:88:20: 警告:‘opterr’重声明时没有 dllimport 属性:忽略先前的
> mv -f .deps/cklength.Tpo .deps/cklength.Po
> gcc  -g -O2   -o cklength.exe cklength.o
> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build     -g -O2 -MT eolstrip.o -MD
> -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o ../../../tools/build/eolstrip.c
> ../../../tools/build/eolstrip.c:80:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
> ../../../tools/build/eolstrip.c:81:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
> ../../../tools/build/eolstrip.c:81:20: 警告:‘opterr’重声明时没有 dllimport 属性:忽略先前的
> mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
> gcc  -g -O2   -o eolstrip.exe eolstrip.o
> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build     -g -O2 -MT packhex.o -MD
> -MP -MF .deps/packhex.Tpo -c -o packhex.o ../../../tools/build/packhex.c
> mv -f .deps/packhex.Tpo .deps/packhex.Po
> gcc  -g -O2   -o packhex.exe packhex.o
> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build     -g -O2 -MT unhex.o -MD
> -MP -MF .deps/unhex.Tpo -c -o unhex.o ../../../tools/build/unhex.c
> ../../../tools/build/unhex.c:98:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
> ../../../tools/build/unhex.c:99:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
>  extern int optind;
> mv -f .deps/unhex.Tpo .deps/unhex.Po
> gcc  -g -O2   -o unhex.exe unhex.o
> make[2]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/build'
> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/build'
> Making all in tools/cpu
> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
> Making all in generic
> '/archive/rtems-4.10.2/build-rtems/tools/cpu/generic'
> make[2]: Nothing to be done for 'all'.
> make[2]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
> make[2]: Nothing to be done for 'all-am'.
> make[2]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
> Making all in testsuites/tools
> '/archive/rtems-4.10.2/build-rtems/testsuites/tools'
> '/archive/rtems-4.10.2/build-rtems/testsuites/tools/generic'
> Making all in arm-rtems4.10/c
> Making all in .
> Configuring RTEMS_BSP=csb337
> checking for RTEMS_BSP... csb337
> checking whether BSP supports networking... disabled
> checking whether CPU supports libposix... disabled
> configure: setting up make/custom
> configure: creating make/csb337.cache
> make[3]: Entering directory
> make[3]: Leaving directory
> checking for RTEMS_CPU_MODEL... at91rm9200
> checking for RTEMS_BSP_FAMILY... csb337
> checking for CPU_CFLAGS... (cached) -mstructure-size-boundary=8 -mcpu=arm920
> -mfpu=vfp -mfloat-abi=soft
> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
> After execute the command  $ ln -s /bin/gcc.exe /bin/cc.exe
> The second time configure and make
> second time configure information :
> --disable-cxx --enable-rtemsbsp=csb337 --prefix=/opt/rtems-4.10
> '--build=x86_64-unknown-cygwin'  '--disable-posix' '--disable-networking'
> '--disable-cxx' '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
> '--cache-file=/dev/null' '--srcdir=../../../tools/build'
> --disable-option-checking '--prefix=/opt/rtems-4.10'
> '--disable-posix' '--disable-networking' '--disable-cxx'
> 'build_alias=x86_64-unknown-cygwin' 'host_alias=x86_64-unknown-cygwin'
> 'target_alias=arm-rtems4.10' --cache-file=/dev/null
> '--cache-file=/dev/null' '--srcdir=../../../testsuites/tools'
> (/archive/rtems-4.10.2/build-rtems/testsuites/tools/generic)
> '--host=arm-rtems4.10' '--build=x86_64-unknown-cygwin'
> '--target=arm-rtems4.10'  '--disable-posix' '--disable-networking'
> '--exec-prefix=/opt/rtems-4.10/arm-rtems4.10'
> '--cache-file=/dev/null' '--srcdir=../../../c'
> The second time make information:
> $ make
> Making all in make
> make  all-am
>  extern int optind;
> Making all in .
> Making all in csb337
> Thank you
> Best wishes
> Asher
> At 2015-03-05 22:15:29, "Gedare Bloom" <gedare at rtems.org> wrote:
>>No errors during configure?
>>Paste a little more of the make output, it seems like something else
>>is missing... The cygwin build can be a little bit hit-or-miss,
>>although I think 4.10 should work...
>>Gedare
>>On Wed, Mar 4, 2015 at 11:42 PM, zhengyazhou <zxya1014 at 163.com> wrote:
>>> Thank you for answering me,here is the details
>>>    Host     :  MS windows and  I use  Cygwin for RTEMS development
>>>    device  :  ARM based target
>>> I installed the Prebuild Toolset on Cygwin,then uncompress the RTEMS
>>> source
>>> code in the file C/Cygwin64/
>>> then execute the following command in the Cygwin command line
>>>     #export PATH=/opt/rtems-4.10/bin:$PATH
>>>     #cd ~/rtems-4.10.2
>>>     #mkdir bulid
>>>     #cd build
>>>     #../configure --target=arm-rtems4.10 --disable-posix
>>>     #make
>>> then comes the error
>>>     make[2]: Entering directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>>     make[2]: Leaving directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>> '/rtems-4.10.2/build/arm-rtems4.10/c/csb337'
>>>     make[1]: Leaving directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>> above is all the information ,can you solve this problem ?
>>> best wishes
>>> Asher
>>> At 2015-03-05 11:38:25, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>>> wrote:
>>>>You are going to have to provide more details. Host, target, configure
>>>> command, cut and paste of the error with some context around it.
>>>>On March 4, 2015 9:09:15 PM CST, zhengyazhou <zxya1014 at 163.com> wrote:
>>>>>Hi ,
>>>>>I meet error257 when I compile the RTEMS source code.I want to know the
>>>>>error type and how to handle this error
>>>>>best regards ,
>>>>>Asher
>>>>--joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
