[PATCH 00/12] Ticket Closing/Moving Milestone Patches
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Mar 6 14:55:06 UTC 2015
Hi,
This series of patches is an odd mix. It addresses a lot of
build issues which may or may not have tickets. There are a
handful of libdl tickets which either impact an entire
architecture or a subset of BSPs. All have tickets. If it
was an architecture issue, libdl is now disabled. It is
was a subset of BSPs, then a I added a special testdata
file and included it.
I fixed some odd issues along the way like the Pi not working
with libdl.
Some BSPs had tests which did not fit into memory and the
builds had not gotten far enough in long enough to spot that.
One of the patch adds fsscandir01 as needed to about 20 BSPs
which wouldn't build that far when I added the test.
I have started a build of all BSPs with networking and all tests
enabled. There may still be a nit but I wanted a basic review
in case I messed up something obvious like the Trac annotation.
I really don't expect much since this should mostly be build
related to work around outstanding issues or disable tests.
Once committed, the libdl tickets which are updated can have
their milestone moved past 4.11. This should eliminate 6-8
tickets between us and 4.11
--joel
Joel Sherrill (12):
lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file
lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01
raspberrypi: Do not include default IRQ handler and BSP specific one
Temporarily disable libdl for bfin
Temporarily disable libdl for v850
Temporarily disable libdl for lm32
dltests-broken-on-this-bsp.tcfg: New file used for dl* tests work
around
Temporarily disable libdl tests on some MIPS BSPSs
Always disable networking for h8300
Temporarily ignore dl* tests on some PowerPC BSPs
Add jffs2_fsscandir01 to more BSPs testsuite configuration
Temporarily disable libdl for h8300
c/src/aclocal/check-networking.m4 | 3 ++-
.../arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg | 2 ++
.../arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg | 1 +
.../arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg | 1 +
.../arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg | 1 +
.../make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg | 2 ++
.../arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.tcfg | 7 -------
.../make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg | 1 +
.../arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg | 1 +
.../lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg | 2 ++
.../make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg | 1 +
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 1 -
.../arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg | 1 +
.../arm/stm32f4/make/custom/stm32f4-testsuite.tcfg | 1 +
.../make/custom/tms570ls3137_hdk_intram-testsuite.tcfg | 1 +
.../m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg | 2 ++
.../m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg | 1 +
.../m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg | 1 +
.../mips/hurricane/make/custom/hurricane-testsuite.tcfg | 5 +++++
.../mips/rbtx4925/make/custom/rbtx4925-testsuite.tcfg | 5 +++++
.../mips/rbtx4938/make/custom/rbtx4938-testsuite.tcfg | 5 +++++
.../powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg | 2 ++
.../mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg | 2 ++
.../mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg | 2 ++
.../mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg | 2 ++
.../mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg | 2 ++
.../mpc55xxevb/make/custom/mpc5668g-testsuite.tcfg | 5 +++++
.../make/custom/mpc5674f_ecu508_app-testsuite.tcfg | 5 +++++
.../make/custom/mpc5674f_ecu508_boot-testsuite.tcfg | 1 +
.../mpc55xxevb/make/custom/mpc5674f_rsm6-testsuite.tcfg | 1 +
.../mpc55xxevb/make/custom/mpc5674fevb-testsuite.tcfg | 5 +++++
.../make/custom/mpc5674fevb_spe-testsuite.tcfg | 5 +++++
.../make/custom/phycore_mpc5554-testsuite.tcfg | 2 ++
.../qoriq/make/custom/qoriq_core_0-testsuite.tcfg | 5 +++++
.../qoriq/make/custom/qoriq_core_1-testsuite.tcfg | 5 +++++
.../qoriq/make/custom/qoriq_p1020rdb-testsuite.tcfg | 5 +++++
.../qoriq/make/custom/qoriq_t2080rdb-testsuite.tcfg | 5 +++++
.../qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg | 5 +++++
cpukit/aclocal/check-networking.m4 | 4 ++++
cpukit/configure.ac | 16 ++++++++++++++--
testsuites/libtests/configure.ac | 16 ++++++++++++++--
testsuites/testdata/dltests-broken-on-this-bsp.tcfg | 8 ++++++++
42 files changed, 135 insertions(+), 13 deletions(-)
delete mode 100644 c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.tcfg
create mode 100644 c/src/lib/libbsp/mips/hurricane/make/custom/hurricane-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5668g-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb_spe-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_0-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_1-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb-testsuite.tcfg
create mode 100644 c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg
create mode 100644 testsuites/testdata/dltests-broken-on-this-bsp.tcfg
1.9.3
