[PATCH 03/12] raspberrypi: Do not include default IRQ handler and BSP specific one
Fri Mar 6 14:55:09 UTC 2015
This was tripping a linker error in the dl0[12] tests.
closes 2247.
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 1 -
 1 file changed, 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index ed134fa..c6133df 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -94,7 +94,6 @@ libbsp_a_SOURCES += ../../shared/bspreset_loop.c
 libbsp_a_SOURCES += startup/bspstart.c
 # IRQ
-libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
 libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
 libbsp_a_SOURCES += ../../shared/src/irq-generic.c
 libbsp_a_SOURCES += ../../shared/src/irq-info.c
1.9.3
