[PATCH 05/12] Temporarily disable libdl for v850
Fri Mar 6 15:12:36 UTC 2015
On Fri, Mar 6, 2015 at 9:55 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> There is an issue linking dl0* which has not been resolved.
> This issue is being tracked but is not considered a release
> blocker. This patch is a workaround which disables libdl
> for the v850 until the ticket is resolved.
> updates 2260.
>  cpukit/configure.ac              | 5 ++++-
>  testsuites/libtests/configure.ac | 5 ++++-
>  2 files changed, 8 insertions(+), 2 deletions(-)
> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> index f4d4e7b..39104ec 100644
> --- a/cpukit/configure.ac
> +++ b/cpukit/configure.ac
> @@ -377,11 +377,14 @@ AM_CONDITIONAL([RPCTOOLS],[test "$RPCGEN" = rpcgen \
>  AC_MSG_CHECKING([whether CPU supports libdl])
>  case $RTEMS_CPU in
>    arm | h8300 | i386 | lm32 | m32r | m68k | mips | \
> -  moxie | powerpc | sparc | v850)
> +  moxie | powerpc | sparc)
>     HAVE_LIBDL=yes ;;
>    # bfin has an issue to resolve with libdl. See ticket #2252
>    bfin)
>     HAVE_LIBDL=no ;;
> +  # v850 has an issue to resolve with libdl. See ticket #2260
> +  v850)
> +   HAVE_LIBDL=no ;;
Can you conjoin these cases like
bfin | v850 | *)
>     HAVE_LIBDL=no ;;
>  esac
> diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
> index 7c82394..5308384 100644
> --- a/testsuites/libtests/configure.ac
> +++ b/testsuites/libtests/configure.ac
> @@ -45,11 +45,14 @@ AM_CONDITIONAL(HAS_POSIX,test x"${rtems_cv_RTEMS_POSIX_API}" = x"yes")
>  case $RTEMS_CPU in
>     TEST_LIBDL=yes ;;
>    bfin)
>     HAVE_LIBDL=no ;;
> +  v850)
> +   HAVE_LIBDL=no ;;
>     TEST_LIBDL=no ;;
>  esac
> 1.9.3
> devel mailing list
> devel at rtems.org
