[PATCH] testsupport: Add cascade option to parallel test
Fri Mar 6 15:14:45 UTC 2015
Thanks looks better now.
On Fri, Mar 6, 2015 at 10:13 AM, Alexander Krutwig
<alexander.krutwig at embedded-brains.de> wrote:
>  cpukit/libmisc/testsupport/test.h         | 25 ++++++++-
>  cpukit/libmisc/testsupport/testparallel.c | 30 +++++++----
>  testsuites/smptests/smpatomic01/init.c    | 90 ++++++++++++++++++++-----------
>  3 files changed, 104 insertions(+), 41 deletions(-)
> diff --git a/cpukit/libmisc/testsupport/test.h b/cpukit/libmisc/testsupport/test.h
> index afed462..ae6c17e 100644
> --- a/cpukit/libmisc/testsupport/test.h
> +++ b/cpukit/libmisc/testsupport/test.h
> @@ -141,13 +141,16 @@ typedef struct {
>     * @param[in] ctx The parallel context.
>     * @param[in] arg The user specified argument.
> +   * @param[in] active_workers Count of active workers.  Depends on the cascade
> +   *   option.
>     * @return The desired job body execution time in clock ticks.  See
>     *   rtems_test_parallel_stop_job().
>    rtems_interval (*init)(
>      rtems_test_parallel_context *ctx,
> -    void *arg
> +    void *arg,
> +    size_t active_workers
> @@ -155,12 +158,15 @@ typedef struct {
> +   *   option.
>     * @param[in] worker_index The worker index.  It ranges from 0 to the
>     *   processor count minus one.
>    void (*body)(
>      void *arg,
> +    size_t active_workers,
>      size_t worker_index
> @@ -172,13 +178,28 @@ typedef struct {
> +   *   option.
>    void (*fini)(
> -    void *arg
> +    void *arg,
> +   * @brief Job specific argument.
>    void *arg;
> +   * @brief Job cascading flag.
> +   * This flag indicates whether the job should be executed in a cascaded
> +   * manner (the job is executed on one processor first, two processors
> +   * afterwards and incremented step by step until all processors are used).
> +  bool cascade;
>  } rtems_test_parallel_job;
> diff --git a/cpukit/libmisc/testsupport/testparallel.c b/cpukit/libmisc/testsupport/testparallel.c
> index 681f769..c1bdeda 100644
> --- a/cpukit/libmisc/testsupport/testparallel.c
> +++ b/cpukit/libmisc/testsupport/testparallel.c
> @@ -44,6 +44,7 @@ static void start_worker_stop_timer(
>      ctx
>    _Assert(sc == RTEMS_SUCCESSFUL);
> +  (void) sc;
>  static void run_tests(
> @@ -58,21 +59,31 @@ static void run_tests(
>    for (i = 0; i < job_count; ++i) {
>      const rtems_test_parallel_job *job = &jobs[i];
> +    size_t n = rtems_get_processor_count();
> +    size_t j = job->cascade ? 0 : rtems_get_processor_count() - 1;
> -    if (rtems_test_parallel_is_master_worker(worker_index)) {
> -      rtems_interval duration = (*job->init)(ctx, job->arg);
> +    while (j < n) {
> +      size_t active_worker = j + 1;
> -      start_worker_stop_timer(ctx, duration);
> +      if (rtems_test_parallel_is_master_worker(worker_index)) {
> +        rtems_interval duration = (*job->init)(ctx, job->arg, active_worker);
> +        start_worker_stop_timer(ctx, duration);
> +      _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
> -    _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
> +      if (worker_index <= j) {
> +        (*job->body)(ctx, job->arg, active_worker, worker_index);
> -    (*job->body)(ctx, job->arg, worker_index);
> +        (*job->fini)(ctx, job->arg, active_worker);
> -      (*job->fini)(ctx, job->arg);
> +      ++j;
> @@ -91,6 +102,7 @@ static void worker_task(rtems_task_argument arg)
>    sc = rtems_event_transient_send(warg.ctx->master_id);
> +  (void) sc;
>    run_tests(warg.ctx, warg.jobs, warg.job_count, warg.worker_index);
> diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
> index fbd20fa..0241a01 100644
> --- a/testsuites/smptests/smpatomic01/init.c
> +++ b/testsuites/smptests/smpatomic01/init.c
> @@ -98,7 +98,8 @@ static void test_fini(
>  static rtems_interval test_atomic_add_init(
>    rtems_test_parallel_context *base,
> -  void *arg
> +  void *arg,
>    smpatomic01_context *ctx = (smpatomic01_context *) base;
> @@ -111,6 +112,7 @@ static rtems_interval test_atomic_add_init(
>  static void test_atomic_add_body(
>    void *arg,
>    size_t worker_index
> @@ -125,7 +127,11 @@ static void test_atomic_add_body(
>    ctx->per_worker_value[worker_index] = counter;
> -static void test_atomic_add_fini(rtems_test_parallel_context *base, void *arg)
> +static void test_atomic_add_fini(
> +  rtems_test_parallel_context *base,
> +  void *arg,
> @@ -134,7 +140,8 @@ static void test_atomic_add_fini(rtems_test_parallel_context *base, void *arg)
>  static rtems_interval test_atomic_flag_init(
> -  void *arg
> +  void *arg,
> @@ -148,6 +155,7 @@ static rtems_interval test_atomic_flag_init(
>  static void test_atomic_flag_body(
>    void *arg,
>    size_t worker_index
> @@ -168,7 +176,11 @@ static void test_atomic_flag_body(
> -static void test_atomic_flag_fini(rtems_test_parallel_context *base, void *arg)
> +static void test_atomic_flag_fini(
> +  void *arg,
> @@ -177,7 +189,8 @@ static void test_atomic_flag_fini(rtems_test_parallel_context *base, void *arg)
>  static rtems_interval test_atomic_sub_init(
> -  void *arg
> +  void *arg,
> @@ -190,6 +203,7 @@ static rtems_interval test_atomic_sub_init(
>  static void test_atomic_sub_body(
>    void *arg,
>    size_t worker_index
> @@ -204,7 +218,11 @@ static void test_atomic_sub_body(
> -static void test_atomic_sub_fini(rtems_test_parallel_context *base, void *arg)
> +static void test_atomic_sub_fini(
> +  void *arg,
> @@ -213,7 +231,8 @@ static void test_atomic_sub_fini(rtems_test_parallel_context *base, void *arg)
>  static rtems_interval test_atomic_compare_exchange_init(
> -  void *arg
> +  void *arg,
> @@ -227,6 +246,7 @@ static rtems_interval test_atomic_compare_exchange_init(
>  static void test_atomic_compare_exchange_body(
>    void *arg,
>    size_t worker_index
> @@ -259,7 +279,8 @@ static void test_atomic_compare_exchange_body(
>  static void test_atomic_compare_exchange_fini(
> -  void *arg
> +  void *arg,
> @@ -269,7 +290,8 @@ static void test_atomic_compare_exchange_fini(
>  static rtems_interval test_atomic_or_and_init(
> -  void *arg
> +  void *arg,
> @@ -282,6 +304,7 @@ static rtems_interval test_atomic_or_and_init(
>  static void test_atomic_or_and_body(
>    void *arg,
>    size_t worker_index
> @@ -316,7 +339,8 @@ static void test_atomic_or_and_body(
>  static void test_atomic_or_and_fini(
> -  void *arg
> +  void *arg,
> @@ -326,7 +350,8 @@ static void test_atomic_or_and_fini(
>  static rtems_interval test_atomic_fence_init(
> -  void *arg
> +  void *arg,
> @@ -341,6 +366,7 @@ static rtems_interval test_atomic_fence_init(
>  static void test_atomic_fence_body(
>    void *arg,
>    size_t worker_index
> @@ -369,7 +395,11 @@ static void test_atomic_fence_body(
> -static void test_atomic_fence_fini(rtems_test_parallel_context *base, void *arg)
> +static void test_atomic_fence_fini(
> +  void *arg,
> @@ -383,29 +413,29 @@ static void test_atomic_fence_fini(rtems_test_parallel_context *base, void *arg)
>  static const rtems_test_parallel_job test_jobs[] = {
> -    test_atomic_add_init,
> -    test_atomic_add_body,
> -    test_atomic_add_fini
> +    .init = test_atomic_add_init,
> +    .body = test_atomic_add_body,
> +    .fini = test_atomic_add_fini
> -    test_atomic_flag_init,
> -    test_atomic_flag_body,
> -    test_atomic_flag_fini
> +    .init = test_atomic_flag_init,
> +    .body =test_atomic_flag_body,
> +    .fini =test_atomic_flag_fini
> -    test_atomic_sub_init,
> -    test_atomic_sub_body,
> -    test_atomic_sub_fini
> +    .init = test_atomic_sub_init,
> +    .body =test_atomic_sub_body,
> +    .fini =test_atomic_sub_fini
> -    test_atomic_compare_exchange_init,
> -    test_atomic_compare_exchange_body,
> -    test_atomic_compare_exchange_fini
> +    .init = test_atomic_compare_exchange_init,
> +    .body =test_atomic_compare_exchange_body,
> +    .fini =test_atomic_compare_exchange_fini
> -    test_atomic_or_and_init,
> -    test_atomic_or_and_body,
> -    test_atomic_or_and_fini
> +    .init = test_atomic_or_and_init,
> +    .body =test_atomic_or_and_body,
> +    .fini =test_atomic_or_and_fini
> -    test_atomic_fence_init,
> -    test_atomic_fence_body,
> -    test_atomic_fence_fini
> +    .init = test_atomic_fence_init,
> +    .body =test_atomic_fence_body,
> +    .fini =test_atomic_fence_fini
> 1.8.4.5
> devel mailing list
> devel at rtems.org
