Doxygen Warnings - Please Look at Attempt to Fix Some
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Mar 6 16:41:53 UTC 2015
Hi
There are some Doxygen issues which need to be fixed. In particular,
there are grouping errors and inconsistent group naming issues.
todimpl.h has two groups with the same name. Some files do not
have end groups.
I threw out all the "undocumented" warnings. There are ~7000 of
those. These are inconsistencies which we should attempt to narrow
down.
Thanks.
Notice: Output directory `/home/joel/rtems-4.11-work/doxygen/cpukit-tmp' does not exist. I have created it for you.
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/dev/i2c/i2c.h:432: Warning: end of file while inside a group
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/devfs.h:258: Warning: reached end of file while inside a code block!
The command that should end the block seems to be missing!
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/devfs.h:258: Warning: end of file while inside a group
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/cpuset.h:33: Warning: missing title after \defgroup ScoreCpuset
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/todimpl.h:121: group ScoreTOD: ignoring title "Time Of Day (TOD) Handler" that does not match old title "Time of Day Handler"
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredfimpl.h:29: group ScoreSchedulerEDF: ignoring title "EDF" that does not match old title "EDF Scheduler"
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:58: Warning: documentation for unknown define RTL_XGLUE found.
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:66: Warning: documentation for unknown define RTEMS_RTL_SYMS_GLOBAL_BUCKETS found.
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:71: Warning: documentation for unknown define RTEMS_RTL_UNRESOLVED_BLOCK_SIZE found.
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/error.h:106: Warning: argument 'p' of command @param is not found in the argument list of rtems_verror(rtems_error_code_t error_code, const char *printf_format, va_list arglist)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/error.h:106: Warning: The following parameters of rtems_verror(rtems_error_code_t error_code, const char *printf_format, va_list arglist) are not documented:
parameter 'arglist'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-bitmaps.h:298: Warning: The following parameters of rtems_rfs_bitmap_open(rtems_rfs_bitmap_control *control, rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *buffer, size_t size, rtems_rfs_buffer_block block) are not documented:
parameter 'block'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:262: Warning: argument '_fs' of command @param is not found in the argument list of rtems_rfs_fs_flags(_f)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:262: Warning: The following parameters of rtems_rfs_fs_flags(_f) are not documented:
parameter '_f'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:275: Warning: argument '_fs' of command @param is not found in the argument list of rtems_rfs_fs_no_local_cache(_f)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:275: Warning: The following parameters of rtems_rfs_fs_no_local_cache(_f) are not documented:
parameter '_f'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:268: Warning: argument '_fs' of command @param is not found in the argument list of rtems_rfs_fs_release_bitmaps(_f)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:268: Warning: The following parameters of rtems_rfs_fs_release_bitmaps(_f) are not documented:
parameter '_f'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file-system.h:375: Warning: End of list marker found without any preceding list items
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-file.h:298: Warning: The following parameters of rtems_rfs_file_open(rtems_rfs_file_system *fs, rtems_rfs_ino ino, int oflag, rtems_rfs_file_handle **handle) are not documented:
parameter 'oflag'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-inode.h:568: Warning: The following parameters of rtems_rfs_inode_alloc(rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino) are not documented:
parameter 'goal'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-inode.h:649: Warning: The following parameters of rtems_rfs_inode_create(rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino) are not documented:
parameter 'length'
parameter 'mode'
parameter 'links'
parameter 'uid'
parameter 'gid'
parameter 'ino'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-link.h:82: Warning: The following parameters of rtems_rfs_symlink(rtems_rfs_file_system *fs, const char *name, int length, const char *link, int link_length, uid_t uid, gid_t gid, rtems_rfs_ino parent) are not documented:
parameter 'uid'
parameter 'gid'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rap.h:47: Warning: The following parameters of rtems_rap_load(const char *name, int mode, int argc, const char *argv[]) are not documented:
parameter 'mode'
parameter 'argc'
parameter 'argv'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rap.h:55: Warning: argument 'obj' of command @param is not found in the argument list of rtems_rap_unload(const char *name)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rap.h:55: Warning: The following parameters of rtems_rap_unload(const char *name) are not documented:
parameter 'name'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-allocator.h:148: Warning: Found unknown command `\prarm'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-allocator.h:140: Warning: The following parameters of rtems_rtl_alloc_module_new(void **text_base, size_t text_size, void **const_base, size_t const_size, void **data_base, size_t data_size, void **bss_base, size_t bss_size) are not documented:
parameter 'data_size'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-obj.h:302: Warning: argument 'load_syms' of command @param is not found in the argument list of rtems_rtl_obj_file_load(rtems_rtl_obj_t *obj, int fd)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-obj.h:302: Warning: argument 'load_dep' of command @param is not found in the argument list of rtems_rtl_obj_file_load(rtems_rtl_obj_t *obj, int fd)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-obj.h:496: Warning: argument 'rec' of command @param is not found in the argument list of rtems_rtl_obj_relocate_unresolved(rtems_rtl_unresolv_reloc_t *reloc, rtems_rtl_obj_sym_t *sym)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-obj.h:496: Warning: The following parameters of rtems_rtl_obj_relocate_unresolved(rtems_rtl_unresolv_reloc_t *reloc, rtems_rtl_obj_sym_t *sym) are not documented:
parameter 'reloc'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:172: Warning: argument 'unresolved' of command @param is not found in the argument list of rtems_rtl_unresolved_add(rtems_rtl_obj_t *obj, const uint16_t flags, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:195: Warning: argument 'unresolved' of command @param is not found in the argument list of rtems_rtl_unresolved_remove(rtems_rtl_obj_t *obj, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:195: Warning: argument 'esyms' of command @param is not found in the argument list of rtems_rtl_unresolved_remove(rtems_rtl_obj_t *obj, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:195: Warning: argument 'size' of command @param is not found in the argument list of rtems_rtl_unresolved_remove(rtems_rtl_obj_t *obj, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:195: Warning: The following parameters of rtems_rtl_unresolved_remove(rtems_rtl_obj_t *obj, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel) are not documented:
parameter 'name'
parameter 'sect'
parameter 'rel'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:159: Warning: argument 'unreolved' of command @param is not found in the argument list of rtems_rtl_unresolved_table_close(rtems_rtl_unresolved_t *unresolved)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:159: Warning: The following parameters of rtems_rtl_unresolved_table_close(rtems_rtl_unresolved_t *unresolved) are not documented:
parameter 'unresolved'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:147: Warning: argument 'unresolv' of command @param is not found in the argument list of rtems_rtl_unresolved_table_open(rtems_rtl_unresolved_t *unresolved, size_t block_records)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl-unresolved.h:147: Warning: The following parameters of rtems_rtl_unresolved_table_open(rtems_rtl_unresolved_t *unresolved, size_t block_records) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:226: Warning: Found unknown command `\offset'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:159: Warning: The following parameters of rtems_rtl_obj_comp(rtems_rtl_obj_comp_t **decomp, rtems_rtl_obj_cache_t *cache, int fd, int compression, off_t offset) are not documented:
parameter 'fd'
parameter 'compression'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:275: Warning: Found unknown command `\path'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rtl.h:284: Warning: Found unknown command `\path'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/cpusetimpl.h:47: Warning: argument 'setsize' of command @param is not found in the argument list of _CPU_set_Show(const char *description, const cpu_set_t *cpuset)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/sparc.h:353: Warning: unable to resolve reference to `sparc_disable_interrupts' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/sparc.h:366: Warning: unable to resolve reference to `sparc_disable_interrupts' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/shell.h:143: Warning: The following parameters of rtems_shell_init(const char *task_name, size_t task_stacksize, rtems_task_priority task_priority, const char *devname, bool forever, bool wait, rtems_shell_login_check_t login_check) are not documented:
parameter 'devname'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/shell.h:165: Warning: The following parameters of rtems_shell_script(const char *task_name, size_t task_stacksize, rtems_task_priority task_priority, const char *input, const char *output, bool output_append, bool wait, bool echo) are not documented:
parameter 'echo'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/dev/i2c/i2c.h:349: Warning: argument 'device' of command @param is not found in the argument list of i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/dev/i2c/i2c.h:349: Warning: The following parameters of i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address) are not documented:
parameter 'dev'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/linux/i2c.h:99: Warning: unable to resolve reference to `I2C_FUNC_PROTOCOL_MANGLING' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/linux/i2c.h:109: Warning: unable to resolve reference to `I2C_FUNC_PROTOCOL_MANGLING' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/linux/i2c.h:79: Warning: unable to resolve reference to `I2C_FUNC_NOSTART' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/linux/i2c.h:89: Warning: unable to resolve reference to `I2C_FUNC_PROTOCOL_MANGLING' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/linux/i2c.h:68: Warning: unable to resolve reference to `I2C_FUNC_PROTOCOL_MANGLING' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/blkdev.h:27: Warning: unable to resolve reference to `RTEMS_BLKIO_REQUEST' for \ref command
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/capture.h:548: Warning: The following parameters of rtems_capture_release(uint32_t cpu, uint32_t count) are not documented:
parameter 'cpu'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/counter.h:118: Warning: argument 'uint32_t' of command @param is not found in the argument list of rtems_counter_initialize_converter(uint32_t frequency)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/counter.h:118: Warning: The following parameters of rtems_counter_initialize_converter(uint32_t frequency) are not documented:
parameter 'frequency'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtems/cache.h:194: Warning: The following parameters of rtems_cache_coherent_allocate(size_t size, uintptr_t alignment, uintptr_t boundary) are not documented:
parameter 'size'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtems/event.h:224: Warning: Found unknown command `\aref'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtems/ratemonimpl.h:148: Warning: The following parameters of _Rate_monotonic_Timeout(rtems_id id, void *ignored) are not documented:
parameter 'ignored'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtems/region.h:264: Warning: The following parameters of rtems_region_resize_segment(rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size) are not documented:
parameter 'old_size'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-group.h:142: Warning: argument 'block' of command @param is not found in the argument list of rtems_rfs_group_bitmap_free(rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-group.h:142: Warning: The following parameters of rtems_rfs_group_bitmap_free(rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no) are not documented:
parameter 'no'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-group.h:154: Warning: argument 'block' of command @param is not found in the argument list of rtems_rfs_group_bitmap_test(rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no, bool *state)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-group.h:154: Warning: The following parameters of rtems_rfs_group_bitmap_test(rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no, bool *state) are not documented:
parameter 'no'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rfs/rtems-rfs-group.h:96: Warning: The following parameters of rtems_rfs_group_open(rtems_rfs_file_system *fs, rtems_rfs_buffer_block base, size_t size, size_t inodes, rtems_rfs_group *group) are not documented:
parameter 'inodes'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rap.h:31: Warning: Unsupported xml/html tag <header> found
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/rtl/rap.h:32: Warning: Unsupported xml/html tag <compressed> found
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremsgimpl.h:289: Warning: The following parameters of _CORE_message_queue_Seize(CORE_message_queue_Control *the_message_queue, Thread_Control *executing, Objects_Id id, void *buffer, size_t *size_p, bool wait, Watchdog_Interval timeout) are not documented:
parameter 'executing'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremsgimpl.h:252: Warning: The following parameters of _CORE_message_queue_Submit(CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, CORE_message_queue_Submit_types submit_type, bool wait, Watchdog_Interval timeout) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:274: Warning: argument '_the_mutex' of command @param is not found in the argument list of _CORE_mutex_Seize(_executing, _mtx, _id, _wait, _timeout, _level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:274: Warning: The following parameters of _CORE_mutex_Seize(_executing, _mtx, _id, _wait, _timeout, _level) are not documented:
parameter '_executing'
parameter '_mtx'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:167: Warning: The following parameters of _CORE_mutex_Seize_interrupt_trylock(_mutex, _executing, _level) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: argument '_the_mutex' of command @param is not found in the argument list of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: argument '_id' of command @param is not found in the argument list of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: argument '_wait' of command @param is not found in the argument list of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: argument '_timeout' of command @param is not found in the argument list of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: argument '_level' of command @param is not found in the argument list of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/coremuteximpl.h:215: Warning: The following parameters of _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_Level level) are not documented:
parameter 'the_mutex'
parameter 'id'
parameter 'wait'
parameter 'timeout'
parameter 'level'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/corerwlockimpl.h:90: Warning: The following parameters of _CORE_RWLock_Obtain_for_reading(CORE_RWLock_Control *the_rwlock, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, CORE_RWLock_API_mp_support_callout api_rwlock_mp_support) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/corerwlockimpl.h:115: Warning: The following parameters of _CORE_RWLock_Obtain_for_writing(CORE_RWLock_Control *the_rwlock, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, CORE_RWLock_API_mp_support_callout api_rwlock_mp_support) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/corerwlockimpl.h:139: Warning: The following parameters of _CORE_RWLock_Release(CORE_RWLock_Control *the_rwlock, Thread_Control *executing) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/isrlock.h:178: Warning: argument 'context' of command @param is not found in the argument list of _ISR_lock_ISR_disable_and_acquire(_lock, _context)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/isrlock.h:178: Warning: The following parameters of _ISR_lock_ISR_disable_and_acquire(_lock, _context) are not documented:
parameter '_context'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/objectimpl.h:226: Warning: The following parameters of _Objects_Initialize_information(Objects_Information *information, Objects_APIs the_api, uint16_t the_class, uint32_t maximum, uint16_t size, bool is_string, uint32_t maximum_name_length, bool supports_global, Objects_Thread_queue_Extract_callout extract) are not documented:
parameter 'supports_global'
parameter 'extract'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduler.h:512: Warning: The following parameters of _Scheduler_default_Get_affinity(const Scheduler_Control *scheduler, Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset) are not documented:
parameter 'scheduler'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduler.h:529: Warning: The following parameters of _Scheduler_default_Set_affinity(const Scheduler_Control *scheduler, Thread_Control *thread, size_t cpusetsize, const cpu_set_t *cpuset) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduler.h:484: Warning: argument 'execution' of command @param is not found in the argument list of _Scheduler_default_Tick(const Scheduler_Control *scheduler, Thread_Control *executing)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduler.h:484: Warning: The following parameters of _Scheduler_default_Tick(const Scheduler_Control *scheduler, Thread_Control *executing) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerimpl.h:472: Warning: Found unknown command `\parma'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerimpl.h:471: Warning: The following parameters of _Scheduler_Start_idle(const Scheduler_Control *scheduler, Thread_Control *the_thread, Per_CPU_Control *cpu) are not documented:
parameter 'cpu'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulercbs.h:162: Warning: The following parameters of _Scheduler_CBS_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, uint32_t length) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulercbs.h:144: Warning: The following parameters of _Scheduler_CBS_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:123: Warning: The following parameters of _Scheduler_EDF_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:226: Warning: The following parameters of _Scheduler_EDF_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, uint32_t deadline) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:172: Warning: The following parameters of _Scheduler_EDF_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:158: Warning: The following parameters of _Scheduler_EDF_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority) are not documented:
parameter 'new_priority'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:193: Warning: argument 'thread' of command @param is not found in the argument list of _Scheduler_EDF_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredf.h:193: Warning: The following parameters of _Scheduler_EDF_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
parameter 'the_thread'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriority.h:108: Warning: The following parameters of _Scheduler_priority_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriority.h:144: Warning: The following parameters of _Scheduler_priority_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriority.h:165: Warning: argument 'thread' of command @param is not found in the argument list of _Scheduler_priority_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriority.h:165: Warning: The following parameters of _Scheduler_priority_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriorityaffinitysmp.h:128: Warning: argument 'thread' of command @param is not found in the argument list of _Scheduler_priority_affinity_SMP_Change_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulerpriorityaffinitysmp.h:128: Warning: The following parameters of _Scheduler_priority_affinity_SMP_Change_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulersimple.h:110: Warning: The following parameters of _Scheduler_simple_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulersimple.h:125: Warning: The following parameters of _Scheduler_simple_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulersimple.h:89: Warning: argument 'thread' of command @param is not found in the argument list of _Scheduler_simple_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/schedulersimple.h:89: Warning: The following parameters of _Scheduler_simple_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadimpl.h:317: Warning: The following parameters of _Thread_Delay_ended(Objects_Id id, void *ignored) are not documented:
parameter 'ignored'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadimpl.h:112: Warning: The following parameters of _Thread_Stack_Allocate(Thread_Control *the_thread, size_t stack_size) are not documented:
parameter 'stack_size'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:256: Warning: Found unknown command `\left'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:256: Warning: Found unknown command `\right'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:257: Warning: Found unknown command `\left'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:257: Warning: Found unknown command `\right'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:258: Warning: Found unknown command `\left'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:258: Warning: Found unknown command `\right'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:84: Warning: The following parameters of _Thread_queue_Enqueue_with_handler(Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, Watchdog_Interval timeout, Thread_queue_Timeout_callout handler) are not documented:
parameter 'handler'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/threadqimpl.h:221: Warning: The following parameters of _Thread_queue_Timeout(Objects_Id id, void *ignored) are not documented:
parameter 'ignored'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/timestamp.h:332: Warning: argument '_time' of command @param is not found in the argument list of _Timestamp_Get_As_nanoseconds(_timestamp, _nanoseconds)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/timestamp.h:332: Warning: The following parameters of _Timestamp_Get_As_nanoseconds(_timestamp, _nanoseconds) are not documented:
parameter '_timestamp'
parameter '_nanoseconds'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/timestamp64.h:378: Warning: The following parameters of _Timestamp64_Get_As_nanoseconds(_time, _nanoseconds) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/todimpl.h:325: Warning: argument 'delta' of command @param is not found in the argument list of _TOD_Adjust(const Timestamp_Control timestamp)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/score/todimpl.h:325: Warning: The following parameters of _TOD_Adjust(const Timestamp_Control timestamp) are not documented:
parameter 'timestamp'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/sparse-disk.h:62: Warning: argument 'block_count' of command @param is not found in the argument list of rtems_sparse_disk_create_and_register(const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/sparse-disk.h:62: Warning: The following parameters of rtems_sparse_disk_create_and_register(const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern) are not documented:
parameter 'media_block_count'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/sparse-disk.h:98: Warning: argument 'block_count' of command @param is not found in the argument list of rtems_sparse_disk_register(const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete)
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/sparse-disk.h:98: Warning: The following parameters of rtems_sparse_disk_register(const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete) are not documented:
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/stackchk.h:113: Warning: The following parameters of rtems_stack_checker_switch_extension(Thread_Control *running, Thread_Control *heir) are not documented:
parameter 'heir'
/home/joel/rtems-4.11-work/b-doxy/sparc-rtems4.11/leon3/lib/include/rtems/blkdev.h:91: Warning: unable to resolve reference to `RTEMS_BLKIO_REQUEST' for \ref command
