an error about RTEMS compile when make
zhengyazhou
zxya1014 at 163.com
Sat Mar 7 02:56:15 UTC 2015
Gedare,
The second problem can be solved by command $ ln -s /bin/gcc.exe /bin/cc.exe
but comes the error when make :
>> Making all in csb337
>> make[2]: Entering directory
>> '/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c/csb337'
>> make[2]: *** No rule to make target 'all'。 停止。
>> make[2]: Leaving directory
>> Makefile:257: recipe for target 'all-recursive' failed
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> '/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c'
>> Makefile:275: recipe for target 'all-recursive' failed
>> make: *** [all-recursive] Error 1
and I am a little confused about the first problem you say .I will check it latter.
Thank you for help,
best wishes
Asher
At 2015-03-06 22:41:04, "Gedare Bloom" <gedare at rtems.org> wrote:
>Asher,
>I see two problems.
>First, is that the native compiler is failing for some reason in the
>tools subdirectory, which is the only part of RTEMS that gets compiled
>by the native compiler. From what I can tell it appears like the
>native compiler is not finding the dlls needed to compile argument
>processing (optargs).
>The rest of RTEMS is cross-compiled, which means the compiler that
>gets used when compiling RTEMS is not /bin/gcc but should instead (in
>your case) be /opt/rtems-4.10/bin/arm-rtems4.10-gcc. The second
>problem comes where it says:
>checking for arm-rtems4.10-gcc... arm-rtems4.10-gcc
>checking for arm-rtems4.10-gcc... (cached) arm-rtems4.10-gcc
>checking whether the C compiler works... no
>configure: error: in `/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c/csb337':
>configure: error: C compiler cannot create executables
>See `config.log' for more details
>Makefile:712: recipe for target 'csb337' failed
>make[2]: *** [csb337] Error 1
>make[2]: Leaving directory '/archive/rtems-4.10.2/build-
>Look through config.log in the build subdirectory
>'/archive/rtems-4.10.2/build-rtems/arm-rtems4.10/c' to try to find the
>problem with arm-rtems4.10-gcc.
>You might like to consider using a virtual machine with a Linux host
>instead of Windows.
>Gedare
>On Thu, Mar 5, 2015 at 9:47 PM, zhengyazhou <zxya1014 at 163.com> wrote:
>> When I first time configure and make,here comes the error in make :
>> then I execute the command
>> $ ln -s /bin/gcc.exe /bin/cc.exe ( copy from Using MS-Windows as a
>> Development Host, PartA.2 Cygwin)
>> then I execute configure and make again, the error changed to
>> Bellowed is the detail of the configure and make
>> The first time configure and make
>> first time configure infomation:
>> $ ../configure --target=arm-rtems4.10 --disable-posix --disable-networking
>> --dis
>> able-cxx --enable-rtemsbsp=csb337 --prefix=/opt/rtems-4.10
>> checking for gmake... no
>> checking for make... make
>> checking for RTEMS Version... 4.10.2
>> checking build system type... x86_64-unknown-cygwin
>> checking host system type... x86_64-unknown-cygwin
>> checking target system type... arm-unknown-rtems4.10
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
>> checking for gawk... gawk
>> checking whether make sets $(MAKE)... yes
>> checking whether to enable maintainer-specific portions of Makefiles... no
>> configure: creating ./config.status
>> configure: configuring in ./tools/build
>> configure: running /bin/sh '../../../tools/build/configure'
>> '--prefix=/opt/rtems
>> -4.10' '--host=x86_64-unknown-cygwin' '--build=x86_64-unknown-cygwin'
>> '--disabl
>> e-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=csb337'
>> '--ta
>> rget=arm-rtems4.10' '--cache-file=/dev/null'
>> '--srcdir=../../../tools/build'
>> checking for x86_64-unknown-cygwin-gcc... no
>> checking for gcc... gcc
>> checking whether the C compiler works... yes
>> checking for C compiler default output file name... a.exe
>> checking for suffix of executables... .exe
>> checking whether we are cross compiling... no
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ISO C89... none needed
>> checking for style of include used by make... GNU
>> checking dependency style of gcc... gcc3
>> checking how to run the C preprocessor... gcc -E
>> checking for grep that handles long lines and -e... /usr/bin/grep
>> checking for egrep... /usr/bin/grep -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking getopt.h usability... yes
>> checking getopt.h presence... yes
>> checking for getopt.h... yes
>> checking for strerror... yes
>> checking for strtol... yes
>> checking for bash... /usr/bin/bash
>> config.status: creating Makefile
>> config.status: creating install-if-change
>> config.status: creating config.h
>> config.status: executing depfiles commands
>> configure: configuring in ./tools/cpu
>> configure: running /bin/sh '../../../tools/cpu/configure'
>> '--prefix=/opt/rtems-4
>> '--disable-
>> '--targ
>> et=arm-rtems4.10' '--cache-file=/dev/null' '--srcdir=../../../tools/cpu'
>> checking rtems target cpu... arm
>> === configuring in generic
>> (/archive/rtems-4.10.2/build-rtems/tools/cpu/generic)
>> configure: running /bin/sh ../../../../tools/cpu/generic/configure
>> --disable-opt
>> ion-checking '--prefix=/opt/rtems-4.10' '--host=x86_64-unknown-cygwin'
>> '--build
>> =x86_64-unknown-cygwin' '--disable-posix' '--disable-networking'
>> '--disable-cxx'
>> '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
>> 'build_alias=x86_64-unknown
>> -cygwin' 'host_alias=x86_64-unknown-cygwin' 'target_alias=arm-rtems4.10'
>> --cache
>> -file=/dev/null --srcdir=../../../../tools/cpu/generic
>> config.status: creating size_rtems
>> configure: configuring in ./testsuites/tools
>> configure: running /bin/sh '../../../testsuites/tools/configure'
>> '--prefix=/opt/
>> rtems-4.10' '--host=x86_64-unknown-cygwin' '--build=x86_64-unknown-cygwin'
>> '--d
>> isable-posix' '--disable-networking' '--disable-cxx'
>> '--target=arm-rtems4.10' '--cache-file=/dev/null'
>> '--srcdir=../../../testsuites
>> /tools'
>> (/archive/rtems-4.10.2/build-rtems/testsuites/tools/g
>> eneric)
>> configure: running /bin/sh ../../../../testsuites/tools/generic/configure
>> --disa
>> ble-option-checking '--prefix=/opt/rtems-4.10'
>> --build=x86_64-unknown-cygwin' '--disable-posix' '--disable-networking'
>> '--disab
>> le-cxx' '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
>> unknown-cygwin' 'host_alias=x86_64-unknown-cygwin'
>> --cache-file=/dev/null --srcdir=../../../../testsuites/tools/generic
>> config.status: creating difftest
>> config.status: creating sorttimes
>> configure: configuring in arm-rtems4.10/c
>> configure: running /bin/sh '../../../c/configure' '--prefix=/opt/rtems-4.10'
>> host=arm-rtems4.10' '--build=x86_64-unknown-cygwin' '--target=arm-rtems4.10'
>> -disable-posix' '--disable-networking' '--disable-cxx'
>> ' '--with-target-subdir=arm-rtems4.10'
>> '--exec-prefix=/opt/rtems-4.10/arm-rtems4
>> .10' '--includedir=/opt/rtems-4.10/arm-rtems4.10/include'
>> ll' '--srcdir=../../../c'
>> checking host system type... arm-unknown-rtems4.10
>> checking for arm-rtems4.10-strip... arm-rtems4.10-strip
>> target architecture: arm.
>> available BSPs: csb337.
>> 'make all' will build the following BSPs: csb337.
>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>> config.status: creating make/Makefile
>> The first time make information:
>> $ make
>> Making all in make
>> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/make'
>> make[1]: Nothing to be done for 'all'.
>> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/make'
>> Making all in tools/build
>> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/build'
>> make all-am
>> make[2]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/build'
>> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build -g -O2 -MT cklength.o -MD
>> -MP -MF .deps/cklength.Tpo -c -o cklength.o ../../../tools/build/cklength.c
>> ../../../tools/build/cklength.c:87:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
>> dllimport [-Wattributes]
>> extern char *optarg; /* getopt(3) control vars */
>> ../../../tools/build/cklength.c:88:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
>> extern int optind, opterr;
>> ../../../tools/build/cklength.c:88:20: 警告:‘opterr’重声明时没有 dllimport 属性:忽略先前的
>> mv -f .deps/cklength.Tpo .deps/cklength.Po
>> gcc -g -O2 -o cklength.exe cklength.o
>> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build -g -O2 -MT eolstrip.o -MD
>> -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o ../../../tools/build/eolstrip.c
>> ../../../tools/build/eolstrip.c:80:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
>> ../../../tools/build/eolstrip.c:81:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
>> ../../../tools/build/eolstrip.c:81:20: 警告:‘opterr’重声明时没有 dllimport 属性:忽略先前的
>> mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>> gcc -g -O2 -o eolstrip.exe eolstrip.o
>> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build -g -O2 -MT packhex.o -MD
>> -MP -MF .deps/packhex.Tpo -c -o packhex.o ../../../tools/build/packhex.c
>> mv -f .deps/packhex.Tpo .deps/packhex.Po
>> gcc -g -O2 -o packhex.exe packhex.o
>> gcc -DHAVE_CONFIG_H -I. -I../../../tools/build -g -O2 -MT unhex.o -MD
>> -MP -MF .deps/unhex.Tpo -c -o unhex.o ../../../tools/build/unhex.c
>> ../../../tools/build/unhex.c:98:14: 警告:‘optarg’重声明时没有 dllimport 属性:忽略先前的
>> ../../../tools/build/unhex.c:99:12: 警告:‘optind’重声明时没有 dllimport 属性:忽略先前的
>> extern int optind;
>> mv -f .deps/unhex.Tpo .deps/unhex.Po
>> gcc -g -O2 -o unhex.exe unhex.o
>> make[2]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/build'
>> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/build'
>> Making all in tools/cpu
>> make[1]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
>> Making all in generic
>> '/archive/rtems-4.10.2/build-rtems/tools/cpu/generic'
>> make[2]: Nothing to be done for 'all'.
>> make[2]: Entering directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
>> make[2]: Nothing to be done for 'all-am'.
>> make[2]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
>> make[1]: Leaving directory '/archive/rtems-4.10.2/build-rtems/tools/cpu'
>> Making all in testsuites/tools
>> '/archive/rtems-4.10.2/build-rtems/testsuites/tools'
>> '/archive/rtems-4.10.2/build-rtems/testsuites/tools/generic'
>> Making all in arm-rtems4.10/c
>> Making all in .
>> Configuring RTEMS_BSP=csb337
>> checking for RTEMS_BSP... csb337
>> checking whether BSP supports networking... disabled
>> checking whether CPU supports libposix... disabled
>> configure: setting up make/custom
>> configure: creating make/csb337.cache
>> make[3]: Entering directory
>> make[3]: Leaving directory
>> checking for RTEMS_CPU_MODEL... at91rm9200
>> checking for RTEMS_BSP_FAMILY... csb337
>> checking for CPU_CFLAGS... (cached) -mstructure-size-boundary=8 -mcpu=arm920
>> -mfpu=vfp -mfloat-abi=soft
>> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>> After execute the command $ ln -s /bin/gcc.exe /bin/cc.exe
>> The second time configure and make
>> second time configure information :
>> --disable-cxx --enable-rtemsbsp=csb337 --prefix=/opt/rtems-4.10
>> '--build=x86_64-unknown-cygwin' '--disable-posix' '--disable-networking'
>> '--disable-cxx' '--enable-rtemsbsp=csb337' '--target=arm-rtems4.10'
>> '--cache-file=/dev/null' '--srcdir=../../../tools/build'
>> --disable-option-checking '--prefix=/opt/rtems-4.10'
>> '--disable-posix' '--disable-networking' '--disable-cxx'
>> 'build_alias=x86_64-unknown-cygwin' 'host_alias=x86_64-unknown-cygwin'
>> 'target_alias=arm-rtems4.10' --cache-file=/dev/null
>> '--cache-file=/dev/null' '--srcdir=../../../testsuites/tools'
>> (/archive/rtems-4.10.2/build-rtems/testsuites/tools/generic)
>> '--host=arm-rtems4.10' '--build=x86_64-unknown-cygwin'
>> '--target=arm-rtems4.10' '--disable-posix' '--disable-networking'
>> '--exec-prefix=/opt/rtems-4.10/arm-rtems4.10'
>> '--cache-file=/dev/null' '--srcdir=../../../c'
>> The second time make information:
>> $ make
>> Making all in make
>> make all-am
>> extern int optind;
>> Making all in .
>> Thank you
>> Best wishes
>> Asher
>> At 2015-03-05 22:15:29, "Gedare Bloom" <gedare at rtems.org> wrote:
>>>No errors during configure?
>>>Paste a little more of the make output, it seems like something else
>>>is missing... The cygwin build can be a little bit hit-or-miss,
>>>although I think 4.10 should work...
>>>Gedare
>>>On Wed, Mar 4, 2015 at 11:42 PM, zhengyazhou <zxya1014 at 163.com> wrote:
>>>> Thank you for answering me,here is the details
>>>> Host : MS windows and I use Cygwin for RTEMS development
>>>> device : ARM based target
>>>> I installed the Prebuild Toolset on Cygwin,then uncompress the RTEMS
>>>> source
>>>> code in the file C/Cygwin64/
>>>> then execute the following command in the Cygwin command line
>>>> #export PATH=/opt/rtems-4.10/bin:$PATH
>>>> #cd ~/rtems-4.10.2
>>>> #mkdir bulid
>>>> #cd build
>>>> #../configure --target=arm-rtems4.10 --disable-posix
>>>> #make
>>>> then comes the error
>>>> make[2]: Entering directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>>> make[2]: Leaving directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>>> '/rtems-4.10.2/build/arm-rtems4.10/c/csb337'
>>>> make[1]: Leaving directory '/rtems-4.10.2/build/arm-rtems4.10/c'
>>>> above is all the information ,can you solve this problem ?
>>>> best wishes
>>>> Asher
>>>> At 2015-03-05 11:38:25, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>>>> wrote:
>>>>>You are going to have to provide more details. Host, target, configure
>>>>> command, cut and paste of the error with some context around it.
>>>>>On March 4, 2015 9:09:15 PM CST, zhengyazhou <zxya1014 at 163.com> wrote:
>>>>>>Hi ,
>>>>>>I meet error257 when I compile the RTEMS source code.I want to know the
>>>>>>error type and how to handle this error
>>>>>>best regards ,
>>>>>>Asher
>>>>>--joel
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150307/4266ba09/attachment-0001.html>
