[PATCH 1/2] shared/include/grcan.h: Add prototypes to fix warnings
Sun Mar 8 16:19:31 UTC 2015
 c/src/lib/libbsp/sparc/shared/include/grcan.h | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan.h b/c/src/lib/libbsp/sparc/shared/include/grcan.h
index e76dee7..9f01455 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grcan.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grcan.h
@@ -193,9 +193,10 @@ struct grcan_device_info {
 /* Use hard coded addresses and IRQs to find hardware */
-int grcan_register_abs(struct grcan_device_info *devices, int dev_cnt);
+int grcan_rasta_register_abs(struct grcan_device_info *devices, int dev_cnt);
 /* Use prescanned AMBA Plug&Play information to find all GRFIFO cores */
+int grcan_rasta_register(struct ambapp_bus *abus);
 int grcan_register(struct ambapp_bus *abus);
 #if 0
 void grcan_register(unsigned int baseaddr, unsigned int ram_base);
1.9.3
