New source layout.
Sun Mar 8 21:39:50 UTC 2015
On 8/03/2015 12:51 pm, Amar Takhar wrote:
> Please ignore the previous include layout the correct is below copied from
> another email in this thread:
Thanks for starting this thread. Reorganising the source tree in RTEMS
is long over due.
I assume this is all post 4.11 and based on the up coming waf build
system. It makes sense to move RTEMS a major revision number which would
make 4.11 the last 4.x series release.
> I just noticed the layout I gave above was wrong!  Gedare sent me an
> email (he could not email the list directly from his device).  I had a typo in
> the original one and also didn't copy the new one I made.  Sigh.  I have
> reordered and fixed it below with some examples:
> The directories should be:
> include/rtems/       - Public API
> include/             - Private API
With the public API as a subtree of the private does this mean there is
only a single include path to the include tree given to the compiler ?
Does private mean the headers are not installed so are more 'internal'
than 'private' ? To me internal means they can used internally to RTEMS
but cannot be installed or referenced by public headers while private
makes me wonder what I can use and should not use.
With testing will we have in tree testing and installed testing, ie a
test to check no header leakage ?
> include/arch/        - Private architecture specific
> include/bsp/         - Common BSP files
> include/bsp/<arch>   - Architecture specific
Does this mean all <arch> references are explicit and not using compiler
include path tricks ?
> This allows for:
> #include <rtems/header.h>    - Public API
> #include <header.h>          - Private API
> #include <arch/header.h>     - Private architecture specific
> #include <bsp/header.h>      - Common BSP file
> #include <bsp/arch/header.h> - BSP architecture specific
> Where 'arch' is replaceable by any architecture.
> RTEMS has 1,500 headers we will have no issues filling these directories up.
> There are 3,258 headers in the waf build.  1,700 of these will be removed after
> we fix the references in the source -- a project for down the road.
Getting these files back under control is fantastic. Again many thanks.
