[PATCH 2/5] posix: Change sem_t to the 32-bit object type
Mon Mar 9 12:18:33 UTC 2015
 cpukit/posix/include/semaphore.h | 2 +-
 cpukit/posix/src/semopen.c       | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/posix/include/semaphore.h b/cpukit/posix/include/semaphore.h
index b22453d..58b77e7 100644
--- a/cpukit/posix/include/semaphore.h
+++ b/cpukit/posix/include/semaphore.h
@@ -40,7 +40,7 @@ extern "C" {
  *  11.1 Semaphore Characteristics, P1003.1b-1993, p.219
-typedef int sem_t;
+typedef uint32_t sem_t;
  *  Bad semaphore Id
diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
index 0b98ca6..8841a6f 100644
--- a/cpukit/posix/src/semopen.c
+++ b/cpukit/posix/src/semopen.c
@@ -139,6 +139,6 @@ return_id:
     the_semaphore->Semaphore_id = the_semaphore->Object.id;
     return &the_semaphore->Semaphore_id;
   #else
-    return (sem_t *)&the_semaphore->Object.id;
+    return &the_semaphore->Object.id;
   #endif
1.8.4.5
