[PATCH 2/3] Use latest <sys/time.h> from FreeBSD for RTEMS
Mon Mar 9 13:03:07 UTC 2015
Import the latest <sys/time.h> from FreeBSD for RTEMS.  This has two
reasons.
1. We want to use the FreeBSD timecounters for timekeeping in RTEMS.
See also https://devel.rtems.org/ticket/2271.
2. This makes the port of the network stack from FreeBSD easier.
newlib/ChangeLog
2015-03-09  Sebastian Huber  <sebastian.huber at embedded-brains.de>
        * libc/sys/rtems/include/sys/_timeval.h: Import from FreeBSD.
        * libc/sys/rtems/include/sys/time.h: Likewise.
        * libc/include/sys/time.h: Delete RTEMS specifics.
        * libc/include/sys/types.h (sbintime_t): Define for RTEMS.
        (suseconds_t): Likewise.
        * libc/sys/rtems/include/machine/_types.h (__suseconds_t):
        Define.
 newlib/libc/include/sys/time.h               |   6 +-
 newlib/libc/include/sys/types.h              |  12 +
 newlib/libc/sys/rtems/include/sys/_timeval.h |  52 +++
 newlib/libc/sys/rtems/include/sys/time.h     | 496 +++++++++++++++++++++++++++
 newlib/libc/sys/rtems/machine/_types.h       |   2 +
 5 files changed, 565 insertions(+), 3 deletions(-)
 create mode 100644 newlib/libc/sys/rtems/include/sys/_timeval.h
 create mode 100644 newlib/libc/sys/rtems/include/sys/time.h
diff --git a/newlib/libc/include/sys/time.h b/newlib/libc/include/sys/time.h
index 470a1a6..fc42c6c 100644
--- a/newlib/libc/include/sys/time.h
+++ b/newlib/libc/include/sys/time.h
@@ -20,8 +20,8 @@ struct timeval {
   suseconds_t tv_usec;
-/* BSD time macros used by RTEMS code */
-#if defined (__rtems__) || defined (__CYGWIN__)
+/* BSD time macros */
+#if defined (__CYGWIN__)
 /* Convenience macros for operations on timevals.
    NOTE: `timercmp' does not work for >= or <=.  */
@@ -50,7 +50,7 @@ struct timeval {
       (result)->tv_usec += 1000000;					      \
   } while (0)
-#endif /* defined (__rtems__) || defined (__CYGWIN__) */
+#endif /* defined (__CYGWIN__) */
 #endif /* !_TIMEVAL_DEFINED */
 struct timezone {
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index 280de5f..72c3ce2 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -268,7 +268,19 @@ typedef _TIMER_T_ timer_t;
 #endif
 typedef unsigned long useconds_t;
+#if defined(__rtems)
+#ifndef _SUSECONDS_T_DECLARED
+typedef	__suseconds_t	suseconds_t;
+#define	_SUSECONDS_T_DECLARED
+#endif
+#else
 typedef long suseconds_t;
+#endif
+#if defined(__rtems__)
+typedef	__int64_t	sbintime_t;
+#endif
 #include <sys/features.h>
diff --git a/newlib/libc/sys/rtems/include/sys/_timeval.h b/newlib/libc/sys/rtems/include/sys/_timeval.h
new file mode 100644
index 0000000..a0bc345
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/sys/_timeval.h
@@ -0,0 +1,52 @@
+ * Copyright (c) 2002 Mike Barcroft <mike at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS__TIMEVAL_H_
+#define _SYS__TIMEVAL_H_
+#include <machine/types.h>
+#endif
+#ifndef __time_t_defined
+typedef	_TIME_T_	time_t;
+#define	__time_t_defined
+#endif
+ * Structure returned by gettimeofday(2) system call, and used in other calls.
+struct timeval {
+	time_t		tv_sec;		/* seconds */
+	suseconds_t	tv_usec;	/* and microseconds */
+#endif /* !_SYS__TIMEVAL_H_ */
diff --git a/newlib/libc/sys/rtems/include/sys/time.h b/newlib/libc/sys/rtems/include/sys/time.h
index 0000000..f3afb23
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/sys/time.h
@@ -0,0 +1,496 @@
+ * Copyright (c) 1982, 1986, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 4. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ *	@(#)time.h	8.5 (Berkeley) 5/4/95
+ * $FreeBSD$
+#ifndef _SYS_TIME_H_
+#define	_SYS_TIME_H_
+#include <sys/_timeval.h>
+#include <sys/types.h>
+#include <sys/timespec.h>
+struct timezone {
+	int	tz_minuteswest;	/* minutes west of Greenwich */
+	int	tz_dsttime;	/* type of dst correction */
+#define	DST_NONE	0	/* not on dst */
+#define	DST_USA		1	/* USA style dst */
+#define	DST_AUST	2	/* Australian style dst */
+#define	DST_WET		3	/* Western European dst */
+#define	DST_MET		4	/* Middle European dst */
+#define	DST_EET		5	/* Eastern European dst */
+#define	DST_CAN		6	/* Canada */
+#if __BSD_VISIBLE
+struct bintime {
+	time_t	sec;
+	uint64_t frac;
+static __inline void
+bintime_addx(struct bintime *_bt, uint64_t _x)
+	uint64_t _u;
+	_u = _bt->frac;
+	_bt->frac += _x;
+	if (_u > _bt->frac)
+		_bt->sec++;
+bintime_add(struct bintime *_bt, const struct bintime *_bt2)
+	uint64_t _u;
+	_u = _bt->frac;
+	_bt->frac += _bt2->frac;
+		_bt->sec++;
+	_bt->sec += _bt2->sec;
+bintime_sub(struct bintime *_bt, const struct bintime *_bt2)
+	uint64_t _u;
+	_u = _bt->frac;
+	_bt->frac -= _bt2->frac;
+	if (_u < _bt->frac)
+		_bt->sec--;
+	_bt->sec -= _bt2->sec;
+bintime_mul(struct bintime *_bt, u_int _x)
+	uint64_t _p1, _p2;
+	_p1 = (_bt->frac & 0xffffffffull) * _x;
+	_p2 = (_bt->frac >> 32) * _x + (_p1 >> 32);
+	_bt->sec *= _x;
+	_bt->sec += (_p2 >> 32);
+	_bt->frac = (_p2 << 32) | (_p1 & 0xffffffffull);
+bintime_shift(struct bintime *_bt, int _exp)
+	if (_exp > 0) {
+		_bt->sec <<= _exp;
+		_bt->sec |= _bt->frac >> (64 - _exp);
+		_bt->frac <<= _exp;
+	} else if (_exp < 0) {
+		_bt->frac >>= -_exp;
+		_bt->frac |= (uint64_t)_bt->sec << (64 + _exp);
+		_bt->sec >>= -_exp;
+#define	bintime_clear(a)	((a)->sec = (a)->frac = 0)
+#define	bintime_isset(a)	((a)->sec || (a)->frac)
+#define	bintime_cmp(a, b, cmp)						\
+	(((a)->sec == (b)->sec) ?					\
+	    ((a)->frac cmp (b)->frac) :					\
+	    ((a)->sec cmp (b)->sec))
+#define	SBT_1S	((sbintime_t)1 << 32)
+#define	SBT_1M	(SBT_1S * 60)
+#define	SBT_1MS	(SBT_1S / 1000)
+#define	SBT_1US	(SBT_1S / 1000000)
+#define	SBT_1NS	(SBT_1S / 1000000000)
+#define	SBT_MAX	0x7fffffffffffffffLL
+static __inline int
+sbintime_getsec(sbintime_t _sbt)
+	return (_sbt >> 32);
+static __inline sbintime_t
+bttosbt(const struct bintime _bt)
+	return (((sbintime_t)_bt.sec << 32) + (_bt.frac >> 32));
+static __inline struct bintime
+sbttobt(sbintime_t _sbt)
+	struct bintime _bt;
+	_bt.sec = _sbt >> 32;
+	_bt.frac = _sbt << 32;
+	return (_bt);
+ * Background information:
+ * When converting between timestamps on parallel timescales of differing
+ * resolutions it is historical and scientific practice to round down rather
+ * than doing 4/5 rounding.
+ *   The date changes at midnight, not at noon.
+ *   Even at 15:59:59.999999999 it's not four'o'clock.
+ *   time_second ticks after N.999999999 not after N.4999999999
+bintime2timespec(const struct bintime *_bt, struct timespec *_ts)
+	_ts->tv_sec = _bt->sec;
+	_ts->tv_nsec = ((uint64_t)1000000000 *
+	    (uint32_t)(_bt->frac >> 32)) >> 32;
+timespec2bintime(const struct timespec *_ts, struct bintime *_bt)
+	_bt->sec = _ts->tv_sec;
+	/* 18446744073 = int(2^64 / 1000000000) */
+	_bt->frac = _ts->tv_nsec * (uint64_t)18446744073LL;
+bintime2timeval(const struct bintime *_bt, struct timeval *_tv)
+	_tv->tv_sec = _bt->sec;
+	_tv->tv_usec = ((uint64_t)1000000 * (uint32_t)(_bt->frac >> 32)) >> 32;
+timeval2bintime(const struct timeval *_tv, struct bintime *_bt)
+	_bt->sec = _tv->tv_sec;
+	/* 18446744073709 = int(2^64 / 1000000) */
+	_bt->frac = _tv->tv_usec * (uint64_t)18446744073709LL;
+static __inline struct timespec
+sbttots(sbintime_t _sbt)
+	struct timespec _ts;
+	_ts.tv_sec = _sbt >> 32;
+	_ts.tv_nsec = ((uint64_t)1000000000 * (uint32_t)_sbt) >> 32;
+	return (_ts);
+tstosbt(struct timespec _ts)
+	return (((sbintime_t)_ts.tv_sec << 32) +
+	    (_ts.tv_nsec * (((uint64_t)1 << 63) / 500000000) >> 32));
+static __inline struct timeval
+sbttotv(sbintime_t _sbt)
+	struct timeval _tv;
+	_tv.tv_sec = _sbt >> 32;
+	_tv.tv_usec = ((uint64_t)1000000 * (uint32_t)_sbt) >> 32;
+	return (_tv);
+tvtosbt(struct timeval _tv)
+	return (((sbintime_t)_tv.tv_sec << 32) +
+	    (_tv.tv_usec * (((uint64_t)1 << 63) / 500000) >> 32));
+#endif /* __BSD_VISIBLE */
+#ifdef _KERNEL
+/* Operations on timespecs */
+#define	timespecclear(tvp)	((tvp)->tv_sec = (tvp)->tv_nsec = 0)
+#define	timespecisset(tvp)	((tvp)->tv_sec || (tvp)->tv_nsec)
+#define	timespeccmp(tvp, uvp, cmp)					\
+	(((tvp)->tv_sec == (uvp)->tv_sec) ?				\
+	    ((tvp)->tv_nsec cmp (uvp)->tv_nsec) :			\
+	    ((tvp)->tv_sec cmp (uvp)->tv_sec))
+#define	timespecadd(vvp, uvp)						\
+	do {								\
+		(vvp)->tv_sec += (uvp)->tv_sec;				\
+		(vvp)->tv_nsec += (uvp)->tv_nsec;			\
+		if ((vvp)->tv_nsec >= 1000000000) {			\
+			(vvp)->tv_sec++;				\
+			(vvp)->tv_nsec -= 1000000000;			\
+	} while (0)
+#define	timespecsub(vvp, uvp)						\
+	do {								\
+		(vvp)->tv_sec -= (uvp)->tv_sec;				\
+		(vvp)->tv_nsec -= (uvp)->tv_nsec;			\
+		if ((vvp)->tv_nsec < 0) {				\
+			(vvp)->tv_sec--;				\
+			(vvp)->tv_nsec += 1000000000;			\
+	} while (0)
+/* Operations on timevals. */
+#define	timevalclear(tvp)		((tvp)->tv_sec = (tvp)->tv_usec = 0)
+#define	timevalisset(tvp)		((tvp)->tv_sec || (tvp)->tv_usec)
+#define	timevalcmp(tvp, uvp, cmp)					\
+	    ((tvp)->tv_usec cmp (uvp)->tv_usec) :			\
+/* timevaladd and timevalsub are not inlined */
+#endif /* _KERNEL */
+#ifndef _KERNEL			/* NetBSD/OpenBSD compatible interfaces */
+#define	timerclear(tvp)		((tvp)->tv_sec = (tvp)->tv_usec = 0)
+#define	timerisset(tvp)		((tvp)->tv_sec || (tvp)->tv_usec)
+#define	timercmp(tvp, uvp, cmp)					\
+#define	timeradd(tvp, uvp, vvp)						\
+	do {								\
+		(vvp)->tv_sec = (tvp)->tv_sec + (uvp)->tv_sec;		\
+		(vvp)->tv_usec = (tvp)->tv_usec + (uvp)->tv_usec;	\
+		if ((vvp)->tv_usec >= 1000000) {			\
+			(vvp)->tv_usec -= 1000000;			\
+	} while (0)
+#define	timersub(tvp, uvp, vvp)						\
+	do {								\
+		(vvp)->tv_sec = (tvp)->tv_sec - (uvp)->tv_sec;		\
+		(vvp)->tv_usec = (tvp)->tv_usec - (uvp)->tv_usec;	\
+		if ((vvp)->tv_usec < 0) {				\
+			(vvp)->tv_usec += 1000000;			\
+	} while (0)
+#endif
+ * Names of the interval timers, and structure
+ * defining a timer setting.
+#define	ITIMER_REAL	0
+#define	ITIMER_VIRTUAL	1
+#define	ITIMER_PROF	2
+struct itimerval {
+	struct	timeval it_interval;	/* timer interval */
+	struct	timeval it_value;	/* current value */
+ * Getkerninfo clock information structure
+struct clockinfo {
+	int	hz;		/* clock frequency */
+	int	tick;		/* micro-seconds per hz tick */
+	int	spare;
+	int	stathz;		/* statistics clock frequency */
+	int	profhz;		/* profiling clock frequency */
+/* These macros are also in time.h. */
+#ifndef CLOCK_REALTIME
+#define	CLOCK_REALTIME	0
+#define	CLOCK_VIRTUAL	1
+#define	CLOCK_PROF	2
+#define	CLOCK_MONOTONIC	4
+#define	CLOCK_UPTIME	5		/* FreeBSD-specific. */
+#define	CLOCK_UPTIME_PRECISE	7	/* FreeBSD-specific. */
+#define	CLOCK_UPTIME_FAST	8	/* FreeBSD-specific. */
+#define	CLOCK_REALTIME_PRECISE	9	/* FreeBSD-specific. */
+#define	CLOCK_REALTIME_FAST	10	/* FreeBSD-specific. */
+#define	CLOCK_MONOTONIC_PRECISE	11	/* FreeBSD-specific. */
+#define	CLOCK_MONOTONIC_FAST	12	/* FreeBSD-specific. */
+#define	CLOCK_SECOND	13		/* FreeBSD-specific. */
+#define	CLOCK_THREAD_CPUTIME_ID	14
+#define	CLOCK_PROCESS_CPUTIME_ID	15
+#endif
+#ifndef TIMER_ABSTIME
+#define	TIMER_RELTIME	0x0	/* relative timer */
+#define	TIMER_ABSTIME	0x1	/* absolute timer */
+#endif
+#if __BSD_VISIBLE
+#define	CPUCLOCK_WHICH_PID	0
+#define	CPUCLOCK_WHICH_TID	1
+#endif
+#ifdef _KERNEL
+ * Kernel to clock driver interface.
+void	inittodr(time_t base);
+void	resettodr(void);
+extern volatile time_t	time_second;
+extern volatile time_t	time_uptime;
+extern struct bintime boottimebin;
+extern struct timeval boottime;
+extern struct bintime tc_tick_bt;
+extern sbintime_t tc_tick_sbt;
+extern struct bintime tick_bt;
+extern sbintime_t tick_sbt;
+extern int tc_precexp;
+extern int tc_timepercentage;
+extern struct bintime bt_timethreshold;
+extern struct bintime bt_tickthreshold;
+extern sbintime_t sbt_timethreshold;
+extern sbintime_t sbt_tickthreshold;
+ * Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
+ * Functions without the "get" prefix returns the best timestamp
+ * we can produce in the given format.
+ * "bin"   == struct bintime  == seconds + 64 bit fraction of seconds.
+ * "nano"  == struct timespec == seconds + nanoseconds.
+ * "micro" == struct timeval  == seconds + microseconds.
+ * Functions containing "up" returns time relative to boot and
+ * should be used for calculating time intervals.
+ * Functions without "up" returns UTC time.
+ * Functions with the "get" prefix returns a less precise result
+ * much faster than the functions without "get" prefix and should
+ * be used where a precision of 1/hz seconds is acceptable or where
+ * performance is priority. (NB: "precision", _not_ "resolution" !)
+void	binuptime(struct bintime *bt);
+void	nanouptime(struct timespec *tsp);
+void	microuptime(struct timeval *tvp);
+sbinuptime(void)
+	binuptime(&_bt);
+	return (bttosbt(_bt));
+void	bintime(struct bintime *bt);
+void	nanotime(struct timespec *tsp);
+void	microtime(struct timeval *tvp);
+void	getbinuptime(struct bintime *bt);
+void	getnanouptime(struct timespec *tsp);
+void	getmicrouptime(struct timeval *tvp);
+getsbinuptime(void)
+	getbinuptime(&_bt);
+void	getbintime(struct bintime *bt);
+void	getnanotime(struct timespec *tsp);
+void	getmicrotime(struct timeval *tvp);
+/* Other functions */
+int	itimerdecr(struct itimerval *itp, int usec);
+int	itimerfix(struct timeval *tv);
+int	ppsratecheck(struct timeval *, int *, int);
+int	ratecheck(struct timeval *, const struct timeval *);
+void	timevaladd(struct timeval *t1, const struct timeval *t2);
+void	timevalsub(struct timeval *t1, const struct timeval *t2);
+int	tvtohz(struct timeval *tv);
+#define	TC_DEFAULTPERC		5
+#define	BT2FREQ(bt)                                                     \
+	(((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) /           \
+	    ((bt)->frac >> 1))
+#define	SBT2FREQ(sbt)	((SBT_1S + ((sbt) >> 1)) / (sbt))
+#define	FREQ2BT(freq, bt)                                               \
+	(bt)->sec = 0;                                                  \
+	(bt)->frac = ((uint64_t)0x8000000000000000  / (freq)) << 1;     \
+#define	TIMESEL(sbt, sbt2)						\
+	(((sbt2) >= sbt_timethreshold) ?				\
+	    ((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
+#else /* !_KERNEL */
+#include <time.h>
+#include <sys/cdefs.h>
+__BEGIN_DECLS
+int	setitimer(int, const struct itimerval *, struct itimerval *);
+int	utimes(const char *, const struct timeval *);
+#if __BSD_VISIBLE
+int	adjtime(const struct timeval *, struct timeval *);
+int	futimes(int, const struct timeval *);
+int	futimesat(int, const char *, const struct timeval [2]);
+int	lutimes(const char *, const struct timeval *);
+int	settimeofday(const struct timeval *, const struct timezone *);
+#endif
+#if __XSI_VISIBLE
+int	getitimer(int, struct itimerval *);
+int	gettimeofday(struct timeval *__restrict, void *__restrict);
+#endif
+__END_DECLS
+#endif /* !_KERNEL */
+#endif /* !_SYS_TIME_H_ */
diff --git a/newlib/libc/sys/rtems/machine/_types.h b/newlib/libc/sys/rtems/machine/_types.h
index e8b2bc7..bb2aeee 100644
--- a/newlib/libc/sys/rtems/machine/_types.h
+++ b/newlib/libc/sys/rtems/machine/_types.h
@@ -36,4 +36,6 @@ typedef __int32_t _fpos_t;
 typedef __uint32_t _mode_t;
 #define __mode_t_defined 1
+typedef	long		__suseconds_t;	/* microseconds (signed) */
 #endif
1.8.4.5
