New source layout.
Mon Mar 9 13:18:10 UTC 2015
On 09/03/15 02:42, Amar Takhar wrote:
>>> > >include/arch/        - Private architecture specific
>>> > >include/bsp/         - Common BSP files
>>> > >include/bsp/<arch>   - Architecture specific
>> >Does this mean all <arch> references are explicit and not using compiler
>> >include path tricks ?
> Yes, 100% of include paths are explicit, no compiler tricks at all the only
> include will be -Iinclude and nothing more.
This is actually a big problem and will break a lot of thinks. Currently
you use
#include <bsp.h>
and get for example RTEMS_BSP_NETWORK_DRIVER_ATTACH for the network
configuration.
You find the <bsp.h> via the -B compiler switch.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
