[PATCH 11/15] lpc1768_mbed.cfg: Remove -DNDEBUG flag
Mon Mar 9 19:47:14 UTC 2015
On March 9, 2015 2:38:19 PM CDT, "Marcos Díaz" <marcos.diaz at tallertechnologies.com> wrote:
>Thanks for the answer!
>I can see that we shouldn't have any asserts in the code, we are
>submitting some changes and drivers for the lpc1768 soon and will try
>to delete all the asserts in that code.
I think the rtems assert is ok since it is tied to an RTEMS configure flag and disabled by default.
A BSP fault probably should be a fatal error if it can occur in the field.
>Thanks again!
>On Mon, Mar 9, 2015 at 4:31 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>On March 9, 2015 2:25:29 PM CDT, "Marcos Díaz"
>>Hi!
>>I wanted to know which warning this raised, and how is the correct way
>>to set this flag in production code?
>First, there should be no assert's in cpukit so those there should be
>fixed. I think the same applies for BSPs.
>It tripped some warnings for set but not used variables on m68k. I
>noticed it had -DNDEBUG which it shouldn't have, so I removed them.
>Adding it to CFLAGS on the configure line is the best way but there
>shouldn't have been any.
>There is a ticket for the asserts to be removed.
>>Thanks!
>>On Mon, Mar 9, 2015 at 2:38 PM, Joel Sherrill
>> c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg | 2 +-
>> 1 file changed, 1 insertion(+), 1 deletion(-)
>>diff --git a/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>b/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>index 4cf24c8..a5ed9c6 100644
>>--- a/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>+++ b/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>@@ -8,7 +8,7 @@ RTEMS_CPU = arm
>> CPU_CFLAGS = -march=armv7-m -mthumb
>>-CFLAGS_OPTIMIZE_V = -O2 -ggdb3 -DNDEBUG
>>+CFLAGS_OPTIMIZE_V = -O2 -ggdb3
>> BINEXT?=.bin
>> # This defines the operations performed on the linked executable.
>> # is currently required.
>>1.9.3
>>_______________________________________________
>>devel mailing list
>>devel at rtems.org
>>http://lists.rtems.org/mailman/listinfo/devel
>>Marcos Díaz
>>Software Engineer
>>San Lorenzo 47, 3rd Floor, Office 5
>>Córdoba, Argentina
>>Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>Skype: markdiaz22
>--joel
>Marcos Díaz
>Software Engineer
>Córdoba, Argentina
>Skype: markdiaz22
--joel
