[PATCH 2/3] Remove unused cpukit/libcsupport/include/zilog/z8536.h
Mon Mar 9 21:08:45 UTC 2015
 cpukit/libcsupport/Makefile.am           |   8 ---
 cpukit/libcsupport/include/zilog/z8536.h | 110 -------------------------------
 cpukit/libcsupport/preinstall.am         |   4 --
 3 files changed, 122 deletions(-)
 delete mode 100644 cpukit/libcsupport/include/zilog/z8536.h
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 77efdbb..ec9bee6 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -15,13 +15,6 @@ include_rtems_HEADERS += include/rtems/tod.h
 include_rtems_HEADERS += include/spurious.h
 include_rtems_HEADERS += include/vmeintr.h
-## motorola
-include_rtems_motoroladir = $(includedir)/rtems/motorola
-include_rtems_motorola_HEADERS = include/motorola/mc68230.h
-include_rtems_motorola_HEADERS += include/motorola/mc68681.h
 ## rtems
 include_rtems_HEADERS += include/rtems/assoc.h
 include_rtems_HEADERS += include/rtems/deviceio.h
@@ -39,7 +32,6 @@ include_rtems_zilogdir = $(includedir)/rtems/zilog
 include_rtems_zilog_HEADERS = include/zilog/z8036.h
 include_rtems_zilog_HEADERS += include/zilog/z8530.h
-include_rtems_zilog_HEADERS += include/zilog/z8536.h
 ##  General stuff
 ERROR_C_FILES = src/error.c src/__assert.c
diff --git a/cpukit/libcsupport/include/zilog/z8536.h b/cpukit/libcsupport/include/zilog/z8536.h
deleted file mode 100644
index d251735..0000000
--- a/cpukit/libcsupport/include/zilog/z8536.h
+++ /dev/null
@@ -1,110 +0,0 @@
- * @file
- * @brief Information Related to a Zilog Z8536 Counter/Timer/IO Chip
- * This include file defines information related to a Zilog Z8536
- * Counter/Timer/IO Chip.  It is a IO mapped part.
- * @note This file shares as much as possible with the include
- *       file for the Z8036 via z8x36.h.
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_ZILOG_Z8536_H
-#define _RTEMS_ZILOG_Z8536_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* macros */
-#define VOL8( ptr )   ((volatile uint8_t   *)(ptr))
-#define Z8x36_STATE0 ( z8536 ) \
-  { char *garbage; \
-    (garbage) = *(VOL8(z8536+0xC)) \
-#define Z8x36_WRITE( z8536, reg, data ) \
-   *(VOL8(z8536+0xC)) = (reg); \
-   *(VOL8(z8536+0xC)) = (data)
-#define Z8x36_READ( z8536, reg, data ) \
-   (data) = *(VOL8(z8536+0xC))
-/* structures */
-/* MAIN CONTROL REGISTERS (0x00-0x07) */
-#define MASTER_INTR           0x00   /* Master Interrupt Ctl Reg */
-#define MASTER_CFG            0x01   /* Master Configuration Ctl Reg */
-#define PORTA_VECTOR          0x02   /* Port A - Interrupt Vector */
-#define PORTB_VECTOR          0x03   /* Port B - Interrupt Vector */
-#define CNT_TMR_VECTOR        0x04   /* Counter/Timer Interrupt Vector */
-#define PORTC_DATA_POLARITY   0x05   /* Port C - Data Path Polarity */
-#define PORTC_DIRECTION       0x06   /* Port C - Data Direction */
-#define PORTC_SPECIAL_IO_CTL  0x07   /* Port C - Special IO Control */
-/* MOST OFTEN ACCESSED REGISTERS (0x08 - 0x0f) */
-#define PORTA_CMD_STATUS      0x08   /* Port A - Command Status Reg */
-#define PORTB_CMD_STATUS      0x09   /* Port B - Command Status Reg */
-#define CT1_CMD_STATUS        0x0a   /* Ctr/Timer 1 - Command Status Reg */
-#define CT2_CMD_STATUS        0x0b   /* Ctr/Timer 2 - Command Status Reg */
-#define CT3_CMD_STATUS        0x0c   /* Ctr/Timer 3 - Command Status Reg */
-#define PORTA_DATA            0x0d   /* Port A - Data */
-#define PORTB_DATA            0x0e   /* Port B - Data */
-#define PORTC_DATA            0x0f   /* Port C - Data */
-/* COUNTER/TIMER RELATED REGISTERS (0x10-0x1f) */
-#define CT1_CUR_CNT_MSB       0x10   /* Ctr/Timer 1 - Current Count (MSB) */
-#define CT1_CUR_CNT_LSB       0x11   /* Ctr/Timer 1 - Current Count (LSB) */
-#define CT2_CUR_CNT_MSB       0x12   /* Ctr/Timer 2 - Current Count (MSB) */
-#define CT2_CUR_CNT_LSB       0x13   /* Ctr/Timer 2 - Current Count (LSB) */
-#define CT3_CUR_CNT_MSB       0x14   /* Ctr/Timer 3 - Current Count (MSB) */
-#define CT3_CUR_CNT_LSB       0x15   /* Ctr/Timer 3 - Current Count (LSB) */
-#define CT1_TIME_CONST_MSB    0x16   /* Ctr/Timer 1 - Time Constant (MSB) */
-#define CT1_TIME_CONST_LSB    0x17   /* Ctr/Timer 1 - Time Constant (LSB) */
-#define CT2_TIME_CONST_MSB    0x18   /* Ctr/Timer 2 - Time Constant (MSB) */
-#define CT2_TIME_CONST_LSB    0x19   /* Ctr/Timer 2 - Time Constant (LSB) */
-#define CT3_TIME_CONST_MSB    0x1a   /* Ctr/Timer 3 - Time Constant (MSB) */
-#define CT3_TIME_CONST_LSB    0x1b   /* Ctr/Timer 3 - Time Constant (LSB) */
-#define CT1_MODE_SPEC         0x1c   /* Ctr/Timer 1 - Mode Specification  */
-#define CT2_MODE_SPEC         0x1d   /* Ctr/Timer 2 - Mode Specification  */
-#define CT3_MODE_SPEC         0x1e   /* Ctr/Timer 3 - Mode Specification  */
-#define CURRENT_VECTOR        0x1f   /* Current Vector */
-/* PORT A SPECIFICATION REGISTERS (0x20 -0x27) */
-#define PORTA_MODE            0x20   /* Port A - Mode Specification  */
-#define PORTA_HANDSHAKE       0x21   /* Port A - Handshake Specification  */
-#define PORTA_DATA_POLARITY   0x22   /* Port A - Data Path Polarity */
-#define PORTA_DIRECTION       0x23   /* Port A - Data Direction */
-#define PORTA_SPECIAL_IO_CTL  0x24   /* Port A - Special IO Control */
-#define PORTA_PATT_POLARITY   0x25   /* Port A - Pattern Polarity */
-#define PORTA_PATT_TRANS      0x26   /* Port A - Pattern Transition */
-#define PORTA_PATT_MASK       0x27   /* Port A - Pattern Mask */
-/* PORT B SPECIFICATION REGISTERS (0x28-0x2f) */
-#define PORTB_MODE            0x28   /* Port B - Mode Specification  */
-#define PORTB_HANDSHAKE       0x29   /* Port B - Handshake Specification  */
-#define PORTB_DATA_POLARITY   0x2a   /* Port B - Data Path Polarity */
-#define PORTB_DIRECTION       0x2b   /* Port B - Data Direction */
-#define PORTB_SPECIAL_IO_CTL  0x2c   /* Port B - Special IO Control */
-#define PORTB_PATT_POLARITY   0x2d   /* Port B - Pattern Polarity */
-#define PORTB_PATT_TRANS      0x2e   /* Port B - Pattern Transition */
-#define PORTB_PATT_MASK       0x2f   /* Port B - Pattern Mask */
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/libcsupport/preinstall.am b/cpukit/libcsupport/preinstall.am
index e60879d..a74203f 100644
--- a/cpukit/libcsupport/preinstall.am
+++ b/cpukit/libcsupport/preinstall.am
@@ -103,7 +103,3 @@ $(PROJECT_INCLUDE)/rtems/zilog/z8530.h: include/zilog/z8530.h $(PROJECT_INCLUDE)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
-$(PROJECT_INCLUDE)/rtems/zilog/z8536.h: include/zilog/z8536.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8536.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8536.h
1.9.3
