[PATCH 3/3] Move contents of libcsupport/include/zilog into libbsp/shared
Mon Mar 9 21:08:46 UTC 2015
Only a few BSPs use this and it should not have been in libcsupport.
 c/src/lib/libbsp/m68k/mvme136/Makefile.am     |   4 +
 c/src/lib/libbsp/m68k/mvme136/preinstall.am   |   9 +++
 c/src/lib/libbsp/m68k/mvme147/Makefile.am     |   4 +
 c/src/lib/libbsp/m68k/mvme147/preinstall.am   |   9 +++
 c/src/lib/libbsp/m68k/mvme162/Makefile.am     |   4 +
 c/src/lib/libbsp/m68k/mvme162/preinstall.am   |   9 +++
 c/src/lib/libbsp/shared/include/zilog/z8036.h | 106 ++++++++++++++++++++++++++
 c/src/lib/libbsp/shared/include/zilog/z8530.h |  97 +++++++++++++++++++++++
 cpukit/libcsupport/Makefile.am                |   7 --
 cpukit/libcsupport/include/zilog/z8036.h      | 106 --------------------------
 cpukit/libcsupport/include/zilog/z8530.h      |  97 -----------------------
 cpukit/libcsupport/preinstall.am              |  13 ----
 12 files changed, 242 insertions(+), 223 deletions(-)
 create mode 100644 c/src/lib/libbsp/shared/include/zilog/z8036.h
 create mode 100644 c/src/lib/libbsp/shared/include/zilog/z8530.h
 delete mode 100644 cpukit/libcsupport/include/zilog/z8036.h
 delete mode 100644 cpukit/libcsupport/include/zilog/z8530.h
diff --git a/c/src/lib/libbsp/m68k/mvme136/Makefile.am b/c/src/lib/libbsp/m68k/mvme136/Makefile.am
index 262e82e..2dbaef4 100644
--- a/c/src/lib/libbsp/m68k/mvme136/Makefile.am
+++ b/c/src/lib/libbsp/m68k/mvme136/Makefile.am
@@ -16,6 +16,10 @@ noinst_PROGRAMS =
 include_HEADERS += include/coverhd.h
+## Zilog component header files
+include_rtems_zilogdir = $(includedir)/rtems/zilog
+include_rtems_zilog_HEADERS = ../../shared/include/zilog/z8036.h
 noinst_LIBRARIES = libbspstart.a
 libbspstart_a_SOURCES = ../../m68k/shared/start/start.S
 project_lib_DATA = start.$(OBJEXT)
diff --git a/c/src/lib/libbsp/m68k/mvme136/preinstall.am b/c/src/lib/libbsp/m68k/mvme136/preinstall.am
index 647b809..4f605dc 100644
--- a/c/src/lib/libbsp/m68k/mvme136/preinstall.am
+++ b/c/src/lib/libbsp/m68k/mvme136/preinstall.am
@@ -57,6 +57,15 @@ $(PROJECT_INCLUDE)/coverhd.h: include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
+$(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/zilog
+	@: > $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/zilog/z8036.h: ../../shared/include/zilog/z8036.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
 $(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
 TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
diff --git a/c/src/lib/libbsp/m68k/mvme147/Makefile.am b/c/src/lib/libbsp/m68k/mvme147/Makefile.am
index 07cf646..449c683 100644
--- a/c/src/lib/libbsp/m68k/mvme147/Makefile.am
+++ b/c/src/lib/libbsp/m68k/mvme147/Makefile.am
+include_rtems_zilog_HEADERS = ../../shared/include/zilog/z8530.h
diff --git a/c/src/lib/libbsp/m68k/mvme147/preinstall.am b/c/src/lib/libbsp/m68k/mvme147/preinstall.am
index 647b809..234789e 100644
--- a/c/src/lib/libbsp/m68k/mvme147/preinstall.am
+++ b/c/src/lib/libbsp/m68k/mvme147/preinstall.am
+$(PROJECT_INCLUDE)/rtems/zilog/z8530.h: ../../shared/include/zilog/z8530.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
diff --git a/c/src/lib/libbsp/m68k/mvme162/Makefile.am b/c/src/lib/libbsp/m68k/mvme162/Makefile.am
index 8770b1d..044d361 100644
--- a/c/src/lib/libbsp/m68k/mvme162/Makefile.am
+++ b/c/src/lib/libbsp/m68k/mvme162/Makefile.am
@@ -19,6 +19,10 @@ include_HEADERS += include/page_table.h
 nodist_include_HEADERS += $(top_srcdir)/../shared/mvme/mvme16x_hw.h
diff --git a/c/src/lib/libbsp/m68k/mvme162/preinstall.am b/c/src/lib/libbsp/m68k/mvme162/preinstall.am
index 4681b20..0020d0d 100644
--- a/c/src/lib/libbsp/m68k/mvme162/preinstall.am
+++ b/c/src/lib/libbsp/m68k/mvme162/preinstall.am
@@ -65,6 +65,15 @@ $(PROJECT_INCLUDE)/mvme16x_hw.h: $(top_srcdir)/../shared/mvme/mvme16x_hw.h $(PRO
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/mvme16x_hw.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/mvme16x_hw.h
diff --git a/c/src/lib/libbsp/shared/include/zilog/z8036.h b/c/src/lib/libbsp/shared/include/zilog/z8036.h
new file mode 100644
index 0000000..fea1493
--- /dev/null
+++ b/c/src/lib/libbsp/shared/include/zilog/z8036.h
@@ -0,0 +1,106 @@
+ * @file
+ * @brief Zilog Z8036 Counter/Timer/IO Chip
+ * This include file defines information related to a Zilog Z8036
+ * Counter/Timer/IO Chip.  It is a memory mapped part.
+ * @note This file shares as much as possible with the include file
+ * for the Z8536 via z8x36.h.
+ *  COPYRIGHT (c) 1989-2011.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _RTEMS_ZILOG_Z8036_H
+#define _RTEMS_ZILOG_Z8036_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* macros */
+#define Z8036( ptr ) ((volatile struct z8036_map *)(ptr))
+#define Z8x36_STATE0 ( z8036 ) \
+  { /*char *garbage = *(Z8036(z8036))->???; */ }
+#define Z8x36_WRITE( z8036, reg, data ) \
+   (Z8036(z8036))->reg = (data)
+#define Z8x36_READ( z8036, reg, data ) \
+/* structures */
+struct z8036_map {
+/* MAIN CONTROL REGISTERS (0x00-0x07) */
+  uint8_t   MASTER_INTR;           /* Master Interrupt Ctl Reg */
+  uint8_t   MASTER_CFG;            /* Master Configuration Ctl Reg */
+  uint8_t   PORTA_VECTOR;          /* Port A - Interrupt Vector */
+  uint8_t   PORTB_VECTOR;          /* Port B - Interrupt Vector */
+  uint8_t   CNT_TMR_VECTOR;        /* Counter/Timer Interrupt Vector */
+  uint8_t   PORTC_DATA_POLARITY;   /* Port C - Data Path Polarity */
+  uint8_t   PORTC_DIRECTION;       /* Port C - Data Direction */
+  uint8_t   PORTC_SPECIAL_IO_CTL;  /* Port C - Special IO Control */
+/* MOST OFTEN ACCESSED REGISTERS (0x08 - 0x0f) */
+  uint8_t   PORTA_CMD_STATUS;      /* Port A - Command Status Reg */
+  uint8_t   PORTB_CMD_STATUS;      /* Port B - Command Status Reg */
+  uint8_t   CT1_CMD_STATUS;        /* Ctr/Timer 1 - Command Status Reg */
+  uint8_t   CT2_CMD_STATUS;        /* Ctr/Timer 2 - Command Status Reg */
+  uint8_t   CT3_CMD_STATUS;        /* Ctr/Timer 3 - Command Status Reg */
+  uint8_t   PORTA_DATA;            /* Port A - Data */
+  uint8_t   PORTB_DATA;            /* Port B - Data */
+  uint8_t   PORTC_DATA;            /* Port C - Data */
+/* COUNTER/TIMER RELATED REGISTERS (0x10-0x1f) */
+  uint8_t   CT1_CUR_CNT_MSB;       /* Ctr/Timer 1 - Current Count (MSB) */
+  uint8_t   CT1_CUR_CNT_LSB;       /* Ctr/Timer 1 - Current Count (LSB) */
+  uint8_t   CT2_CUR_CNT_MSB;       /* Ctr/Timer 2 - Current Count (MSB) */
+  uint8_t   CT2_CUR_CNT_LSB;       /* Ctr/Timer 2 - Current Count (LSB) */
+  uint8_t   CT3_CUR_CNT_MSB;       /* Ctr/Timer 3 - Current Count (MSB) */
+  uint8_t   CT3_CUR_CNT_LSB;       /* Ctr/Timer 3 - Current Count (LSB) */
+  uint8_t   CT1_TIME_CONST_MSB;    /* Ctr/Timer 1 - Time Constant (MSB) */
+  uint8_t   CT1_TIME_CONST_LSB;    /* Ctr/Timer 1 - Time Constant (LSB) */
+  uint8_t   CT2_TIME_CONST_MSB;    /* Ctr/Timer 2 - Time Constant (MSB) */
+  uint8_t   CT2_TIME_CONST_LSB;    /* Ctr/Timer 2 - Time Constant (LSB) */
+  uint8_t   CT3_TIME_CONST_MSB;    /* Ctr/Timer 3 - Time Constant (MSB) */
+  uint8_t   CT3_TIME_CONST_LSB;    /* Ctr/Timer 3 - Time Constant (LSB) */
+  uint8_t   CT1_MODE_SPEC;         /* Ctr/Timer 1 - Mode Specification  */
+  uint8_t   CT2_MODE_SPEC;         /* Ctr/Timer 2 - Mode Specification  */
+  uint8_t   CT3_MODE_SPEC;         /* Ctr/Timer 3 - Mode Specification  */
+  uint8_t   CURRENT_VECTOR;        /* Current Vector */
+/* PORT A SPECIFICATION REGISTERS (0x20 -0x27) */
+  uint8_t   PORTA_MODE;            /* Port A - Mode Specification  */
+  uint8_t   PORTA_HANDSHAKE;       /* Port A - Handshake Specification  */
+  uint8_t   PORTA_DATA_POLARITY;   /* Port A - Data Path Polarity */
+  uint8_t   PORTA_DIRECTION;       /* Port A - Data Direction */
+  uint8_t   PORTA_SPECIAL_IO_CTL;  /* Port A - Special IO Control */
+  uint8_t   PORTA_PATT_POLARITY;   /* Port A - Pattern Polarity */
+  uint8_t   PORTA_PATT_TRANS;      /* Port A - Pattern Transition */
+  uint8_t   PORTA_PATT_MASK;       /* Port A - Pattern Mask */
+/* PORT B SPECIFICATION REGISTERS (0x28-0x2f) */
+  uint8_t   PORTB_MODE;            /* Port B - Mode Specification  */
+  uint8_t   PORTB_HANDSHAKE;       /* Port B - Handshake Specification  */
+  uint8_t   PORTB_DATA_POLARITY;   /* Port B - Data Path Polarity */
+  uint8_t   PORTB_DIRECTION;       /* Port B - Data Direction */
+  uint8_t   PORTB_SPECIAL_IO_CTL;  /* Port B - Special IO Control */
+  uint8_t   PORTB_PATT_POLARITY;   /* Port B - Pattern Polarity */
+  uint8_t   PORTB_PATT_TRANS;      /* Port B - Pattern Transition */
+  uint8_t   PORTB_PATT_MASK;       /* Port B - Pattern Mask */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/shared/include/zilog/z8530.h b/c/src/lib/libbsp/shared/include/zilog/z8530.h
index 0000000..161b9a0
--- /dev/null
+++ b/c/src/lib/libbsp/shared/include/zilog/z8530.h
@@ -0,0 +1,97 @@
+ * @file
+ * @brief Information Related to a Zilog Z8530 SCC Chip
+ * This include file defines information related to a Zilog Z8530
+ * SCC Chip.  It is a IO mapped part.
+#ifndef _RTEMS_ZILOG_Z8530_H
+#define _RTEMS_ZILOG_Z8530_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* macros */
+#define VOL8( ptr )   ((volatile uint8_t   *)(ptr))
+#define Z8x30_STATE0 ( z8530 ) \
+  { char *garbage; \
+    (garbage) = *(VOL8(z8530)) \
+#define Z8x30_WRITE_CONTROL( z8530, reg, data ) \
+   *(VOL8(z8530)) = (reg); \
+   *(VOL8(z8530)) = (data)
+#define Z8x30_READ_CONTROL( z8530, reg, data ) \
+   (data) = *(VOL8(z8530))
+#define Z8x30_WRITE_DATA( z8530, data ) \
+   *(VOL8(z8530)) = (data);
+#define Z8x30_READ_DATA( z8530, data ) \
+   (data) = *(VOL8(z8530));
+/* RR_0 Bit Definitions */
+#define RR_0_TX_BUFFER_EMPTY   0x04
+#define RR_0_RX_DATA_AVAILABLE 0x01
+/* read registers */
+#define RR_0       0x00
+#define RR_1       0x01
+#define RR_2       0x02
+#define RR_3       0x03
+#define RR_4       0x04
+#define RR_5       0x05
+#define RR_6       0x06
+#define RR_7       0x07
+#define RR_8       0x08
+#define RR_9       0x09
+#define RR_10      0x0A
+#define RR_11      0x0B
+#define RR_12      0x0C
+#define RR_13      0x0D
+#define RR_14      0x0E
+#define RR_15      0x0F
+/* write registers */
+#define WR_0       0x00
+#define WR_1       0x01
+#define WR_2       0x02
+#define WR_3       0x03
+#define WR_4       0x04
+#define WR_5       0x05
+#define WR_6       0x06
+#define WR_7       0x07
+#define WR_8       0x08
+#define WR_9       0x09
+#define WR_10      0x0A
+#define WR_11      0x0B
+#define WR_12      0x0C
+#define WR_13      0x0D
+#define WR_14      0x0E
+#define WR_15      0x0F
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index ec9bee6..7474079 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -26,13 +26,6 @@ include_rtems_HEADERS += include/rtems/malloc.h
 include_rtems_HEADERS += include/rtems/termiostypes.h
 include_rtems_HEADERS += include/rtems/gxx_wrappers.h
-## zilog
-include_rtems_zilogdir = $(includedir)/rtems/zilog
-include_rtems_zilog_HEADERS = include/zilog/z8036.h
-include_rtems_zilog_HEADERS += include/zilog/z8530.h
 ##  General stuff
 ERROR_C_FILES = src/error.c src/__assert.c
diff --git a/cpukit/libcsupport/include/zilog/z8036.h b/cpukit/libcsupport/include/zilog/z8036.h
deleted file mode 100644
index fea1493..0000000
--- a/cpukit/libcsupport/include/zilog/z8036.h
+++ /dev/null
@@ -1,106 +0,0 @@
- * @file
- * @brief Zilog Z8036 Counter/Timer/IO Chip
- * This include file defines information related to a Zilog Z8036
- * Counter/Timer/IO Chip.  It is a memory mapped part.
- * @note This file shares as much as possible with the include file
- * for the Z8536 via z8x36.h.
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_ZILOG_Z8036_H
-#define _RTEMS_ZILOG_Z8036_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* macros */
-#define Z8036( ptr ) ((volatile struct z8036_map *)(ptr))
-#define Z8x36_STATE0 ( z8036 ) \
-  { /*char *garbage = *(Z8036(z8036))->???; */ }
-#define Z8x36_WRITE( z8036, reg, data ) \
-   (Z8036(z8036))->reg = (data)
-#define Z8x36_READ( z8036, reg, data ) \
-/* structures */
-struct z8036_map {
-/* MAIN CONTROL REGISTERS (0x00-0x07) */
-  uint8_t   MASTER_INTR;           /* Master Interrupt Ctl Reg */
-  uint8_t   MASTER_CFG;            /* Master Configuration Ctl Reg */
-  uint8_t   PORTA_VECTOR;          /* Port A - Interrupt Vector */
-  uint8_t   PORTB_VECTOR;          /* Port B - Interrupt Vector */
-  uint8_t   CNT_TMR_VECTOR;        /* Counter/Timer Interrupt Vector */
-  uint8_t   PORTC_DATA_POLARITY;   /* Port C - Data Path Polarity */
-  uint8_t   PORTC_DIRECTION;       /* Port C - Data Direction */
-  uint8_t   PORTC_SPECIAL_IO_CTL;  /* Port C - Special IO Control */
-/* MOST OFTEN ACCESSED REGISTERS (0x08 - 0x0f) */
-  uint8_t   PORTA_CMD_STATUS;      /* Port A - Command Status Reg */
-  uint8_t   PORTB_CMD_STATUS;      /* Port B - Command Status Reg */
-  uint8_t   CT1_CMD_STATUS;        /* Ctr/Timer 1 - Command Status Reg */
-  uint8_t   CT2_CMD_STATUS;        /* Ctr/Timer 2 - Command Status Reg */
-  uint8_t   CT3_CMD_STATUS;        /* Ctr/Timer 3 - Command Status Reg */
-  uint8_t   PORTA_DATA;            /* Port A - Data */
-  uint8_t   PORTB_DATA;            /* Port B - Data */
-  uint8_t   PORTC_DATA;            /* Port C - Data */
-/* COUNTER/TIMER RELATED REGISTERS (0x10-0x1f) */
-  uint8_t   CT1_CUR_CNT_MSB;       /* Ctr/Timer 1 - Current Count (MSB) */
-  uint8_t   CT1_CUR_CNT_LSB;       /* Ctr/Timer 1 - Current Count (LSB) */
-  uint8_t   CT2_CUR_CNT_MSB;       /* Ctr/Timer 2 - Current Count (MSB) */
-  uint8_t   CT2_CUR_CNT_LSB;       /* Ctr/Timer 2 - Current Count (LSB) */
-  uint8_t   CT3_CUR_CNT_MSB;       /* Ctr/Timer 3 - Current Count (MSB) */
-  uint8_t   CT3_CUR_CNT_LSB;       /* Ctr/Timer 3 - Current Count (LSB) */
-  uint8_t   CT1_TIME_CONST_MSB;    /* Ctr/Timer 1 - Time Constant (MSB) */
-  uint8_t   CT1_TIME_CONST_LSB;    /* Ctr/Timer 1 - Time Constant (LSB) */
-  uint8_t   CT2_TIME_CONST_MSB;    /* Ctr/Timer 2 - Time Constant (MSB) */
-  uint8_t   CT2_TIME_CONST_LSB;    /* Ctr/Timer 2 - Time Constant (LSB) */
-  uint8_t   CT3_TIME_CONST_MSB;    /* Ctr/Timer 3 - Time Constant (MSB) */
-  uint8_t   CT3_TIME_CONST_LSB;    /* Ctr/Timer 3 - Time Constant (LSB) */
-  uint8_t   CT1_MODE_SPEC;         /* Ctr/Timer 1 - Mode Specification  */
-  uint8_t   CT2_MODE_SPEC;         /* Ctr/Timer 2 - Mode Specification  */
-  uint8_t   CT3_MODE_SPEC;         /* Ctr/Timer 3 - Mode Specification  */
-  uint8_t   CURRENT_VECTOR;        /* Current Vector */
-/* PORT A SPECIFICATION REGISTERS (0x20 -0x27) */
-  uint8_t   PORTA_MODE;            /* Port A - Mode Specification  */
-  uint8_t   PORTA_HANDSHAKE;       /* Port A - Handshake Specification  */
-  uint8_t   PORTA_DATA_POLARITY;   /* Port A - Data Path Polarity */
-  uint8_t   PORTA_DIRECTION;       /* Port A - Data Direction */
-  uint8_t   PORTA_SPECIAL_IO_CTL;  /* Port A - Special IO Control */
-  uint8_t   PORTA_PATT_POLARITY;   /* Port A - Pattern Polarity */
-  uint8_t   PORTA_PATT_TRANS;      /* Port A - Pattern Transition */
-  uint8_t   PORTA_PATT_MASK;       /* Port A - Pattern Mask */
-/* PORT B SPECIFICATION REGISTERS (0x28-0x2f) */
-  uint8_t   PORTB_MODE;            /* Port B - Mode Specification  */
-  uint8_t   PORTB_HANDSHAKE;       /* Port B - Handshake Specification  */
-  uint8_t   PORTB_DATA_POLARITY;   /* Port B - Data Path Polarity */
-  uint8_t   PORTB_DIRECTION;       /* Port B - Data Direction */
-  uint8_t   PORTB_SPECIAL_IO_CTL;  /* Port B - Special IO Control */
-  uint8_t   PORTB_PATT_POLARITY;   /* Port B - Pattern Polarity */
-  uint8_t   PORTB_PATT_TRANS;      /* Port B - Pattern Transition */
-  uint8_t   PORTB_PATT_MASK;       /* Port B - Pattern Mask */
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/libcsupport/include/zilog/z8530.h b/cpukit/libcsupport/include/zilog/z8530.h
index 161b9a0..0000000
--- a/cpukit/libcsupport/include/zilog/z8530.h
+++ /dev/null
@@ -1,97 +0,0 @@
- * @file
- * @brief Information Related to a Zilog Z8530 SCC Chip
- * This include file defines information related to a Zilog Z8530
- * SCC Chip.  It is a IO mapped part.
-#ifndef _RTEMS_ZILOG_Z8530_H
-#define _RTEMS_ZILOG_Z8530_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* macros */
-#define VOL8( ptr )   ((volatile uint8_t   *)(ptr))
-#define Z8x30_STATE0 ( z8530 ) \
-  { char *garbage; \
-    (garbage) = *(VOL8(z8530)) \
-#define Z8x30_WRITE_CONTROL( z8530, reg, data ) \
-   *(VOL8(z8530)) = (reg); \
-   *(VOL8(z8530)) = (data)
-#define Z8x30_READ_CONTROL( z8530, reg, data ) \
-   (data) = *(VOL8(z8530))
-#define Z8x30_WRITE_DATA( z8530, data ) \
-   *(VOL8(z8530)) = (data);
-#define Z8x30_READ_DATA( z8530, data ) \
-   (data) = *(VOL8(z8530));
-/* RR_0 Bit Definitions */
-#define RR_0_TX_BUFFER_EMPTY   0x04
-#define RR_0_RX_DATA_AVAILABLE 0x01
-/* read registers */
-#define RR_0       0x00
-#define RR_1       0x01
-#define RR_2       0x02
-#define RR_3       0x03
-#define RR_4       0x04
-#define RR_5       0x05
-#define RR_6       0x06
-#define RR_7       0x07
-#define RR_8       0x08
-#define RR_9       0x09
-#define RR_10      0x0A
-#define RR_11      0x0B
-#define RR_12      0x0C
-#define RR_13      0x0D
-#define RR_14      0x0E
-#define RR_15      0x0F
-/* write registers */
-#define WR_0       0x00
-#define WR_1       0x01
-#define WR_2       0x02
-#define WR_3       0x03
-#define WR_4       0x04
-#define WR_5       0x05
-#define WR_6       0x06
-#define WR_7       0x07
-#define WR_8       0x08
-#define WR_9       0x09
-#define WR_10      0x0A
-#define WR_11      0x0B
-#define WR_12      0x0C
-#define WR_13      0x0D
-#define WR_14      0x0E
-#define WR_15      0x0F
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/libcsupport/preinstall.am b/cpukit/libcsupport/preinstall.am
index a74203f..211a246 100644
--- a/cpukit/libcsupport/preinstall.am
+++ b/cpukit/libcsupport/preinstall.am
@@ -90,16 +90,3 @@ $(PROJECT_INCLUDE)/rtems/gxx_wrappers.h: include/rtems/gxx_wrappers.h $(PROJECT_
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/gxx_wrappers.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/gxx_wrappers.h
-$(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/zilog
-	@: > $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/zilog/z8036.h: include/zilog/z8036.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
-$(PROJECT_INCLUDE)/rtems/zilog/z8530.h: include/zilog/z8530.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8530.h
1.9.3
