[PATCH v2] Add and use latest <sys/timespec.h> from FreeBSD
Tue Mar 10 10:51:53 UTC 2015
This addresses a potential multiple definition problem and makes it
easier to use FreeBSD header files in Newlib.
According to POSIX struct timespec and struct itimerspec are not
declared in <sys/types.h>, but instead in <time.h>.
newlib/ChangeLog
2015-03-10  Sebastian Huber  <sebastian.huber at embedded-brains.de>
	* libc/include/sys/_timespec.h: Import from FreeBSD.
	* libc/include/sys/timespec.h: Likewise.
	* libc/include/time.h: Include <sys/timespec.h>.
	* libc/include/sys/types.h (timespec): Delete.
	(itimerspec): Likewise.
	* libc/include/machine/time.h: Include <sys/_timespec.h>.
	* libc/include/sys/sched.h: Likewise.
	* libc/include/sys/signal.h: Likewise.
	* libc/include/sys/stat.h: Likewise.
 newlib/libc/include/machine/time.h  |  2 +-
 newlib/libc/include/sys/_timespec.h | 49 +++++++++++++++++++++++++++++
 newlib/libc/include/sys/sched.h     |  2 ++
 newlib/libc/include/sys/signal.h    |  1 +
 newlib/libc/include/sys/stat.h      |  1 +
 newlib/libc/include/sys/timespec.h  | 63 +++++++++++++++++++++++++++++++++++++
 newlib/libc/include/sys/types.h     | 15 ---------
 newlib/libc/include/time.h          |  1 +
 8 files changed, 118 insertions(+), 16 deletions(-)
 create mode 100644 newlib/libc/include/sys/_timespec.h
 create mode 100644 newlib/libc/include/sys/timespec.h
diff --git a/newlib/libc/include/machine/time.h b/newlib/libc/include/machine/time.h
index 9b44941..6f9a35c 100644
--- a/newlib/libc/include/machine/time.h
+++ b/newlib/libc/include/machine/time.h
@@ -8,7 +8,7 @@
 #endif
 #ifdef __SPU__
-#include <sys/types.h>
+#include <sys/_timespec.h>
 int nanosleep (const struct timespec *, struct timespec *);
 #endif
diff --git a/newlib/libc/include/sys/_timespec.h b/newlib/libc/include/sys/_timespec.h
new file mode 100644
index 0000000..bd66dfc
--- /dev/null
+++ b/newlib/libc/include/sys/_timespec.h
@@ -0,0 +1,49 @@
+ * Copyright (c) 1982, 1986, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 4. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)time.h	8.5 (Berkeley) 5/4/95
+ * from: FreeBSD: src/sys/sys/time.h,v 1.43 2000/03/20 14:09:05 phk Exp
+ *	$FreeBSD$
+#ifndef _SYS__TIMESPEC_H_
+#define	_SYS__TIMESPEC_H_
+#include <machine/types.h>
+#ifndef __time_t_defined
+typedef	_TIME_T_	time_t;
+#define	__time_t_defined
+#endif
+struct timespec {
+	time_t	tv_sec;		/* seconds */
+	long	tv_nsec;	/* and nanoseconds */
+#endif /* !_SYS__TIMESPEC_H_ */
diff --git a/newlib/libc/include/sys/sched.h b/newlib/libc/include/sys/sched.h
index 2c74294..8f43e37 100644
--- a/newlib/libc/include/sys/sched.h
+++ b/newlib/libc/include/sys/sched.h
@@ -21,6 +21,8 @@
 #ifndef _SYS_SCHED_H_
 #define _SYS_SCHED_H_
 #ifdef __cplusplus
 extern "C" {
 #endif
diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
index a29f525..7fc30a7 100644
--- a/newlib/libc/include/sys/signal.h
+++ b/newlib/libc/include/sys/signal.h
@@ -9,6 +9,7 @@ extern "C" {
 #include "_ansi.h"
 #include <sys/features.h>
 /* #ifndef __STRICT_ANSI__*/
diff --git a/newlib/libc/include/sys/stat.h b/newlib/libc/include/sys/stat.h
index 11b9d80..47caf1c 100644
--- a/newlib/libc/include/sys/stat.h
+++ b/newlib/libc/include/sys/stat.h
 #include <time.h>
 #include <sys/cdefs.h>
 /* dj's stat defines _STAT_H_ */
 #ifndef _STAT_H_
diff --git a/newlib/libc/include/sys/timespec.h b/newlib/libc/include/sys/timespec.h
index 0000000..2505cef
--- /dev/null
+++ b/newlib/libc/include/sys/timespec.h
@@ -0,0 +1,63 @@
+ * are met:
+ * SUCH DAMAGE.
+ *	$FreeBSD$
+#ifndef _SYS_TIMESPEC_H_
+#define _SYS_TIMESPEC_H_
+#include <sys/cdefs.h>
+#if __BSD_VISIBLE
+#define	TIMEVAL_TO_TIMESPEC(tv, ts)					\
+	do {								\
+		(ts)->tv_sec = (tv)->tv_sec;				\
+		(ts)->tv_nsec = (tv)->tv_usec * 1000;			\
+	} while (0)
+#define	TIMESPEC_TO_TIMEVAL(tv, ts)					\
+	do {								\
+		(tv)->tv_sec = (ts)->tv_sec;				\
+		(tv)->tv_usec = (ts)->tv_nsec / 1000;			\
+	} while (0)
+#endif /* __BSD_VISIBLE */
+ * Structure defined by POSIX.1b to be like a itimerval, but with
+ * timespecs. Used in the timer_*() system calls.
+struct itimerspec {
+	struct timespec  it_interval;
+	struct timespec  it_value;
+#endif /* _SYS_TIMESPEC_H_ */
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index ed33e0a..f20ef11 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -123,21 +123,6 @@ typedef _TIME_T_ time_t;
 #endif
-#ifndef __timespec_defined
-#define __timespec_defined
-/* Time Value Specification Structures, P1003.1b-1993, p. 261 */
-struct timespec {
-  time_t  tv_sec;   /* Seconds */
-  long    tv_nsec;  /* Nanoseconds */
-#endif
-struct itimerspec {
-  struct timespec  it_interval;  /* Timer period */
-  struct timespec  it_value;     /* Timer expiration */
 #ifndef __daddr_t_defined
 typedef	long	daddr_t;
 #define __daddr_t_defined
diff --git a/newlib/libc/include/time.h b/newlib/libc/include/time.h
index d7b6612..b9d1f20 100644
--- a/newlib/libc/include/time.h
+++ b/newlib/libc/include/time.h
@@ -25,6 +25,7 @@
 #define CLK_TCK CLOCKS_PER_SEC
+#include <sys/timespec.h>
 _BEGIN_STD_C
1.8.4.5
